Staro 18.08.2016., 17:49   #9151
ODO
Datum registracije: Feb 2015
Postovi: 594
1 x Intel CPU Desktop Core i5-4460 (3.2GHz, 6MB,LGA1150) box
1 x ASRock H81M-HDS R2.0 (s1150,DDR3,USB 3.0,SATA III,DVI/VGA/HDMI) mATX,Usb 3.0 header
1 x Sapphire Radeon RX460 2GB, 128bit GDDR5
1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail
1 x HDD Western Digital Caviar Blue 1TB, 7200rpm
1 x Fortron Hexa+ 400W, 80+
1 x Kućište MS Mercury 2
Ukupno: 4031,54 kn (besplatno slaganje i dostava)
1 x Intel Core i3-6100 (3,7 GHz, Skylake, Socket 1151, 51W), Intel HD 530, box
1 x Asrock H110M-DGS (s1151,DDR4,USB 3.0,SATA III,LAN,DVI) mATX
1 x Crucial DRAM 8GB DDR4 2133 MT/s (PC4-17000) CL15 SR
Ukupno: 3693,77 kn (besplatno slaganje i dostava)
GIGABYTE GeForce GTX 950 GDDR5 2GB, HDMI/2xDVI/DP
Ukupno: 3843,77 kn (besplatno slaganje i dostava)
Zadnje izmijenjeno od: ODO. 18.08.2016. u 17:56.
ODO je offline   Reply With Quote
Staro 18.08.2016., 18:01   #9152
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Kingmax 1x8GB DDR4 2133 GLJG, KIN-8GB DDR4 2133
SEAGATE HDD Desktop Barracuda 7200 ST1000DM003 (3.5",1TB,64MB,SATA III-600)
Procesor Intel Core i5 6402P
Gigabyte RX 460WF2 OC, 2GB DDR5, HDMI, DVI
Fortron napajanje Hexa Plus 400W, 80+
MSI H110M PRO-D, LGA 1151, DDR4-2133, Military Class 4
MS VOYAGER 2 kućište bez napajanja
3.994,11kn
Staro 18.08.2016., 19:36   #9153
seric1990
Datum registracije: Apr 2016
Lokacija: Solin
Postovi: 8
Konf
Ispričavam se ako sam bio nejasan ali potreban mi je i monitor.
seric1990 je offline   Reply With Quote
Staro 18.08.2016., 20:32   #9154
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,359
Zadnje izmijenjeno od: coconut. 19.08.2016. u 08:14.
nick praskaton je online   Reply With Quote
Staro 19.08.2016., 00:11   #9155
ODO
Postovi: 594
Intel Core i3-6100
Asrock H110M-DGS
Crucial DDR4 8GB (1x8GB) 2133MHz CL15
SAPPHIRE NITRO Radeon ™ R7 360 2G D5
WESTERN DIGITAL Blue 1TB, WD10EZRZ
be quiet! SYSTEM POWER 8 400W
Kućište Mercury 2
Monitor Acer V6 V226HQL 21.5" Crno Full HD
4 054,60 kn (besplatno slaganje i dostava, te forumski popust uključeni)
Staro 19.08.2016., 00:46   #9156
nick praskaton
Asshole
Lokacija: RH
Postovi: 2,359
tesko da moze bolje od ovoga, eventualno bi ja mozda graficku i monitor isao na polovno mozda s njuskala, jer ovako su graficka i monitor teski minimum zbog ogracnicenog budgeta
Staro 21.08.2016., 01:16   #9157
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
trebam složit konficu za pajdaša, ali sam ja po difoltu prelijen, pa proslijeđujem ovamo
Znači za do 3k (bolna granica 3.5k) krznenih treba nekaj da za surf / film i malo gaymanja (GTA, AC i slično)
ima grafku (nisam ziher kaj točno, ali ak treba pitam i nadopišem) / kučište / monitor
Treba mu ostalo - proc, matična, napajanje itd.
Ako je moguće možda i kakav SSD za ubacit u sve kombinaciju
Preferira Links, makar ja bi radije u FUTURI ili UZIju (znam da imaju popust za forumaše, pa to ja morem k'o proviziju zakaparit ).
Hvala kome god da se da složit
54' / 74' / 90' / 2014
Staro 21.08.2016., 01:44   #9158
Smartic
Smartic's Avatar
Postovi: 2,707
AMD Radeon R3 SATA III 240GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 530 MB/s / 470 MB/s
Zalman 500W GVM Series Retail, ZAL-ZM500-GVM
MS MONSTER gaming kućište bez napajanja s plavim LED ventilatorom
3.211,19kn
Kakva grafa
Staro 21.08.2016., 09:38   #9159
ODO
Postovi: 594
Bilo bi lijepo znati grafičku, jer on bi kao malo gejmao, ali AAA naslove.
Intel Core i5-6500
ASRock H110M HDS
Sandisk 240GB 2,5" SATA3 SSD Plus
be quiet! SYSTEM POWER 8 500W
3 286,36 kn (besplatna dostava i forumski popust uključeni)
Staro 21.08.2016., 18:03   #9160
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
da ne bi bilo - provjerih
trenutno je na 7770
i hvala!
Staro 22.08.2016., 17:42   #9161
MatijaV
MatijaV's Avatar
Datum registracije: May 2011
Lokacija: Koprivnica
Postovi: 131
Ekipa trebam konfiguraciju(CPU, SSD, GPU, MBO, RAM, NAPAJANJE) nije bitno AMD ili INTEL, konfiguracija bi služila za igranje, internet, programiranje. Cijena 3500-4200kn
MatijaV je offline   Reply With Quote
Staro 22.08.2016., 17:48   #9162
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
CPU INT Core i3 6098P
Sapphire RX 460 OC, 2GB GDDR5,HDMI, DP, DVI
AMD Radeon R3 SATA III 240GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 530 MB/s / 470 MB/s, Random R
3640kn
Pojačavanja - i5 6402P (430kn gore) ili jaču grafičku ako ti je gaming izraženiji (gtx 960, R9 380, RX 470)
Staro 22.08.2016., 21:52   #9163
sime_b
Lokacija: split
Postovi: 34
Pozdrav svima!
Trebam konfu do 4000kn, da sadrzi:
- procesor (po mogucnosti intel i5),
- maticnu sa integriranom grafikom i hdmi izlazom (ali takvu da mogu poslije bez problema uzeti neku graficku ako mi dodje igrati igre)
- hard disk (1000gb)
- ssd disk (120gb)
- ram 8gb
- napajanje
- kuciste
E sad, ono sto je najveci problem, da to bude sve u jednom ducanu i u Rijeci, znaci ne kupovina preko interneta nego recimo Links, hgspot, instar...
Ja sam složio ovako nesto, u Links-u, molio bi misljenje i savjete i prijedloge:
- Matična ploča ASROCK B85M Pro3, Intel B85, DDR3, zvuk, G-LAN, S-ATA, PCI-E 3.0, USB 3.0, D-SUB, DVI, HDMI, mATX, s. 1150
- Procesor INTEL Core i5 4460 BOX, s. 1150, 3.2GHz, 6MB cache, GPU, Quad Core
- Memorija PC-14900, 8 GB, KINGSTON HyperX Fury Black HX318C10FB/8 DDR3 1866MHz
- Tvrdi disk 1000.0 GB SEAGATE ST1000DM003, SATA3, 64MB cache, 7200 okr/min, 3.5"
- SSD 120.0 GB CORSAIR Force LS series CSSD-F120GBLSB, SATA3, 2.5", maks. do 540/450 MB/s
- Napajanje 550W, LC POWER Silent Series, ATX V2.2, 120mm vent.
- Kućište LC POWER PRO-923B Red Captor, MIDI, crno, bez napajanja-a
Ukupno: 3.840,85 kn
Zadnje izmijenjeno od: sime_b. 22.08.2016. u 22:42.
sime_b je offline   Reply With Quote
Staro 22.08.2016., 23:05   #9164
Smartic
Smartic's Avatar
Postovi: 2,707
Radije HGSpot onda, malo je jeftiniji.
Procesor INTEL Core i5 6400, 2700/3300 MHz, Socket 1151
Memorija KINGSTON 8 GB DDR4, 2133 MHz, DIMM, CL15
Tvrdi disk 1 TB, TOSHIBA DT01ACA100, 3.5", SATA III
Kućište ZALMAN Z1, bez napajanja
Napajanje THERMALTAKE TR2 Gold, 500W
SSD disk 240 GB, A-DATA SP550, 2.5", SATA III
Matična ploča ASROCK H110M-HDS, socket 1151, DDR4
3.964,28kn
240GB SSD, puno bolje napajanje(ali možda ga nemaju), bolje kućište i Skylake/DDR4.
Staro 22.08.2016., 23:40   #9165
sime_b
Lokacija: split
Postovi: 34
ok, a jel moze drugo kuciste i da li je bolje uzeti 2 x 4gb ili jedan od 8gb:
2 x Memorija KINGSTON 4 GB DDR4, 2133 MHz, DIMM, CL15
Kućište ZALMAN Z1 NEO, bez napajanja
4.010,78 kn
Zadnje izmijenjeno od: sime_b. 23.08.2016. u 10:05.
Staro 23.08.2016., 10:40   #9166
Getriba94
Getriba94's Avatar
Datum registracije: Jun 2016
Postovi: 1,052
ram radije jedan od 8gb pa je kasnije lako dodat jos 8 u prazan slot
Sent from my NOA_VIVOse using Tapatalk
Staro 24.08.2016., 08:00   #9167
golfw12
golfw12's Avatar
Postovi: 424
Treba bi konfa za bratica do max 4000kn jer mi je toliko dao ni lipe vise. Treba samo kuciste, namjena gaming, mislim da mu netreba ssd zbog buđeta, trgovine? E sad tu je najveci problem sto bi on komp sto prije znaci dolaze u obzir one za koje znate da imaju najveci dio komponenti dostupnih odmah jer bi trebao narucit danas popodne pa da mu stigne do recimo ponedjeljka ili tamo recimo srijede. Znaci da bude 7 dana rok dostave i njihove naruđbe tih stvari ako budu falile. Tnx
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 24.08.2016., 13:27   #9168
Manuel Calavera
Postovi: 14,584
U većini shopova ti dođe za dan ili dva (i do osijeka). Provjereno
1 x Procesor Intel Core i3 6098P, 3.6GHz, 1151
1 x MSI H110M PRO-D (S1151, DDR4, USB3.1, SATA III, DVI, Audio, LAN) mATX Retail
1 x Kingston 8GB 2133MHz DDR4 Non-ECC CL15 DIMM 1Rx8
1 x Fortron Hyper 500W, 80+ - 60mj.
1 x Zalman Z3, USB3.0 black, 3x120mm
3950kn
Staro 24.08.2016., 17:05   #9169
golfw12
golfw12's Avatar
Postovi: 424
naručio:
Zalman Z3 mid tower case
MSI B150M Pro-VD,
Intel Core i3-6100
ASUS DRW-24F1MT/BLK/B/AS SATA
1TB Seagate Barracuda, 3.5"
Grafička kartica SAPPHIRE RX 460 2G D5, 2 GB DDR5
Napajanje 400W FSP Fortron/Source Hexa+
DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial
Ukupno : 4,469.99 Kn
Vrsta plaćanja : (-10 %) -447 Kn
Ukupno : 4,022.99 Kn
počastio sam ga s 23kn
HDD: 256 GB M.2 SSD
PSU: HP 90W
Staro 24.08.2016., 23:34   #9170
lucija85
Datum registracije: Sep 2010
Postovi: 90
Pozdrav ekipa!
Ovako, zamolila bih vas za preporuku gejmerske konfe za malog brata, budget je 4000 kuna i monitor ne treba jer to već imamo! Po mogućnosti sve u istom shopu. Dakle, treba mu ful gejmerska konfa (najbolja moguća grafička, druge komponente su manje bitne) bez monitora koja bi mogla bez problema igrati najnovije AAA igre ako je to uopće moguće sa ovim budgetom. Nadam se da jest
lucija85 je offline   Reply With Quote
Staro 25.08.2016., 01:32   #9171
Smartic
Smartic's Avatar
Postovi: 2,707
Procesor AMD X4 FX-4320
Patriot Sig.,D3, 1600Mhz, 8GB (1x 8GB) PSD38G16002
Toshiba P300 1TB, 64MB, 7200rpm HDWD110UZSVA
CORSAIR Power Supply, Builder Series CX 80+ Bronze, 430 Watt, ATX, EPS12V, PS/2, EU Version
2x MS PC COOL 12cm hladnjak za kućište
LC Power CPU Hladnjak LC-CC-95 - 90mm Intel/AMD
ASRock 980DE3/U3S3, AM3
XFX RADEON RX 470 Single Fan 4GB GDDR5 True OC, XFX-RX-470P4SFD5
Sveukupno: 4.007,91kn
Evo naglaska na grafičku ...samo je još nedostupna.
Dosta bi pomoglo ako se možeš protegnuti za još 300kn. Ubacila bi se bolja matična i grafička s boljim hlađenjem
Staro 25.08.2016., 01:44   #9172
lucija85
Postovi: 90
Hvala Smartic, što više opcija to bolje
Kako bi izgledala bolja matična i grafička? A Intel varijanta?
Staro 25.08.2016., 03:45   #9173
Manuel Calavera
Postovi: 14,584
Imaš onaj moj gore prijedlog. Nije u tolikoj mjeri naglasak na grafičku, ali kod intela nebih išao ispod i3-ice
Staro 25.08.2016., 09:34   #9174
CheCola
Postovi: 371
može preporuka gaming konfe za kolegu, bez periferije monitora i ostaloga, iznos cca 4500, eventualno do 5000, plaćanje amex 12 rata. i bilo bi dobro da se može ubacit neka rx470/480
Zadnje izmijenjeno od: CheCola. 25.08.2016. u 14:04.
CheCola je offline   Reply With Quote
Staro 25.08.2016., 17:38   #9175
lucija85
Postovi: 90
Molim za mišljenje o ove dvije konfiguracije složene u Uzi shopu.
http://i.imgur.com/EntDUNb.png
http://i.imgur.com/ZwR4G9k.png
Staro 25.08.2016., 19:03   #9176
Smartic
Smartic's Avatar
Postovi: 2,707
@lucija85
http://imgur.com/a/2I8jp
Dobiješ 3% popusta kao član ovog foruma kod UziShopa pa je to ispod 4100kn Grafička je i prejaka za ovaj procesor(dosta jača od R9 380), ali će moći to nadograditi.
@ODO
Ti sad ispadaš lud nakon mojeg edita
Zadnje izmijenjeno od: Smartic. 25.08.2016. u 19:41.
Staro 25.08.2016., 19:33   #9177
ODO
Postovi: 594
Wink
Smartic, hebi se
Autor CheCola Pregled postova
Procesor AMD FX X8 8300 BOX, s. AM3+, 3.3GHz, 16MB cache, Eight Core
Matična ploča GIGABYTE GA-970A-DS3P
Cooler LC POWER LC-CC-95
Grafička kartica PCI-E GIGABYTE AMD RADEON RX 470 G1 Gaming, 4GB DDR5, HDMI, DP, DVI
Memorija PC-14900, 8 GB, MUSHKIN Essentials, 992132, DDR3 1866Mhz
Kućište RAIJINTEK Arcadia, MIDI, bijelo, bez PS
Napajanje 560W, LC POWER Silent Giant GREEN POWER LC6560GP3 V2.3, 140mm vent.
5.131,90 kn (cijena je za web narudžbu)
Ako baš mora biti 5, onda nek ide na FX 6300
Za i5 mu treba 300-tinjak kn više
Zadnje izmijenjeno od: ODO. 25.08.2016. u 19:43.
Staro 25.08.2016., 23:45   #9178
lucija85
Postovi: 90
@Smartic
Ako malo dignem budget i u kombinaciji sa RX 470 ubacim i i3-6100 procesor jel onda treba još i dodatni cooler? Sa drugom matičnom naravno. To mi izgleda super.
Staro 26.08.2016., 04:06   #9179
Smartic
Smartic's Avatar
Postovi: 2,707
Za i3 ne trebaš dodatni cooler, onda bi to bilo negdje +250kn(Asrock H110M-DGS, i3 6100, Crucial 1x8GB DDR4)
Staro 26.08.2016., 14:05   #9180
lucija85
Postovi: 90
Super, hvala!
