Staro 01.10.2015., 10:17   #61
grinccaffe
Datum registracije: Jun 2010
Postovi: 14
Autor coconut Pregled postova
Nije to virus nego malware. Probaj SuperAntiSpyware.
Odrađeno ali SuperAntiSpyware nije riješio problem;(
grinccaffe je offline   Reply With Quote
Staro 01.10.2015., 10:31   #62
alen.s
alen.s's Avatar
Postovi: 1,441
vjerovatno si vec proba al evo svejedno;
http://malwaretips.com/blogs/activit...s-com-removal/
Staro 01.10.2015., 10:38   #63
grinccaffe
Postovi: 14
Autor alen.s Pregled postova
Sve sa tog linka odrađeno i ništa ne pomaže.
Staro 01.10.2015., 12:26   #64
alen.s
alen.s's Avatar
Postovi: 1,441
nijedan od alata ne nalazi ništa ili nađe ali ne ukloni ? jesi proba napravit novi firefox profil ?
Staro 01.10.2015., 12:48   #65
grinccaffe
Postovi: 14
Evo sad mi je frend preko TeamViewera sredio problem na način da je Firefox vratio na neke stare postavke (bar mislim tako).
Evo šta je napravio:
Clean Reinstall
We use this name, but it's not about removing your settings, it's about making sure the program files are clean -- and do not contain alien code files. As described below, this process does not disturb your existing settings. Do NOT uninstall Firefox, that's not needed.
(1) Download a fresh installer for Firefox 37.0.1 from https://www.mozilla.org/firefox/all/ to a convenient location if you have an older one. (Scroll down to your preferred language.)
(2) Exit out of Firefox (if applicable).
(3) Rename the program folder
(64-bit Windows folder names)
C:\Program Files (x86)\Mozilla Firefox
to
C:\Program Files (x86)\OldFirefox
(32-bit Windows folder names)
C:\Program Files\Mozilla Firefox
to
C:\Program Files\OldFirefox
(4) Run the installer you downloaded in #1. It should automatically connect to your existing settings.
Any difference?
Note: Some plugins may exist only in that OldFirefox folder. If something essential is missing, look in these folders:
\OldFirefox\Plugins
\OldFirefox\browser\plugins
Staro 28.12.2019., 13:07   #66
zlatko
zlatko's Avatar
Lokacija: slavonac
Postovi: 498
Da li neko ima problema sa novim Malwarebytes anti-malware? Zakuca mi računalo na 100 %. Pomaže jedino uninstal...i onda sve radi normalno. Probao instalirat više puta sa različitih izvora... uvijek isto. Zakuca 100% i nemrda . Restart i uninstal, i sve 5. Starija verzija radi normalno.
Windows home original.
Dopuna. Kad instaliram mwb i pokrenem ga kao free, sve stane kako je napisano gore. Kad ga pokrenem na 14 dana u ful modu sve radi bez greške. Kad mu isključim live nadzor, opet sve stane. Evo, pa koga zanima. Pričekat ću novu verziju, možda riješe problem.
he,he
Zadnje izmijenjeno od: zlatko. 29.12.2019. u 09:38.
zlatko je offline   Reply With Quote
Staro 28.12.2021., 13:14   #67
atjeroid
dežurno smetalo
atjeroid's Avatar
Lokacija: Krapinske Toplice
Postovi: 309
Jel može netko pomoć u vezi sljedeće situacije:
Stari je uspio u obrtu pokupit neki malware (a možda i virus, nemam pojma) koji USB kada se otvori, samo pokazuje shortcut (od USB-a), te tek onda otvara filove (i zarazi komp)
Jel netko imao iskustva s time, kako locirati i maknuti. Malware Bytes nađe nešt, ali nakon restarta isto.
atjeroid je offline   Reply With Quote
Staro 28.12.2021., 13:40   #68
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,833
Autor atjeroid Pregled postova
Koji OS?
Staro 28.12.2021., 13:44   #69
atjeroid
dežurno smetalo
atjeroid's Avatar
Postovi: 309
Autor Sinac Pregled postova
Koji OS?
Win10 Pro
Staro 03.03.2022., 08:28   #70
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
Dobio sam jučer navečer poruku na mob da je nekakva sumnjiva radnja na mom gmailu i odmah sam promijenio password. Danas se idem logirati preko windowsa (Vivaldi) i dobivam poruku da je otkriven zlonamjerni software na ovom računalu i neka ga uklonim i da onda pristupim gmailu. Malwarebytes (free) ne nalazi ništa kao ni Win Defender. Na kompu je sve legalno da legalnije ne može biti. Savjeti?
Hvala
EDIT: Chrome ne radi paniku...
Staro 03.03.2022., 08:39   #71
tiki66
tiki
tiki66's Avatar
Postovi: 2,751
Od koga/čega dobivaš tu poruku, kako izgleda?
Ako u Chrome radi, vjerojatno ti je neki vrag u browseru, neka ekstenzija i slično...
tiki66 je online   Reply With Quote
Staro 03.03.2022., 09:06   #72
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
Ali me malo muči jer sam jučer navečer dobio tu poruku i na mob kad je laptop bio ugašen...
EDIT: obrisao kukije i sada je ok :O
EDIT 2: Obavijest i dalje stoji
Ovako to izgleda. Ne vidim nigdje da provjerim koja je to aplikacija i koji je to komp.
Zadnje izmijenjeno od: Problem. 03.03.2022. u 11:54.
Staro 08.03.2022., 03:40   #73
TomaN
Postovi: 27
Probaj vidjeti pod ekstenzijama dali si slucajno nesto instalirao
TomaN je offline   Reply With Quote
Staro 08.03.2022., 15:28   #74
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
nemam doslovno ni jedne instalirane u vivaldiju
