Staro 07.05.2007., 22:53   #61
dedal
Toshiba ko' ludo
dedal's Avatar
Lokacija: zagreb-west side
Postovi: 250
Autor Paske Pregled postova
Evo jedan mali, ali odličan filmić - wellcome to the universe.Da - sav footage je ingame i rađen većinoma za vrijeme masovne koljaže http://eve-files.com/dl/103371
Odlican video, i ja bi tak velike brodove ...
dedal je offline   Reply With Quote
Staro 07.05.2007., 22:57   #62
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
EvE mon ne radi - moraš skinuti novu verziju. CCP nekaj mudruje oko toga ....
@ Dedal - Treba ti više struje da upogoniš.
CAP je "baterija" koja se troši u borbi / minanju ... itd. Onaj naramđasti krug
Tu počni:
http://www.kylania.com/eve/skills.php?p=core
Staro 07.05.2007., 23:01   #63
dedal
Toshiba ko' ludo
dedal's Avatar
Postovi: 250
Znam da mi treba struje a kaj onda da kupim. ... Od market-a me boli glava..Vise citam forume nego kaj se igram
Kad zavrsim sa igranjem napisat cu Memoare..
Staro 08.05.2007., 09:22   #64
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Digneš skillove - click na link !
Za tebe - Engineering....
These are skills you'll want at level IV
Skill Name - [Bonus per level of skill] (Ex: Level 4 Electronics gives 20% more CPU.)
* Electronics 1 [+5% CPU]
o Targeting 2 [Extra target]
* Engineering 3 [+5% Power Grid]
o Energy Management 4 [+5% Capacitor Power]
o Energy Systems Operation [+5% Capacitor Recharge]
o Shield Management [+5% Sheild Points]
o Shield Operations [+5% Shield Recharge]
* Mechanic 5 [+5% Structure Points]
o Hull Upgrades 6 [+5% Armor Points]
* Navigation 7 [+5% Velocity]
o Afterburner 8 [+10% longer AB useage]
o Warp Drive Operations [+5% less cap needed to warp]
* Spaceship Command 9 [+2% Agility]
o Frigate 10 [See Ship Description]
o Destroyer 11 [See Ship Description]
o Industrial 12 [See Ship Description]
o Cruiser 13 [See Ship Description]
Staro 08.05.2007., 10:40   #65
Dawar
OMG, thats the funky shit
Dawar's Avatar
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Dedal kaj si po specijalizaciji?
Dawar je offline   Reply With Quote
Staro 08.05.2007., 11:08   #66
dedal
Toshiba ko' ludo
dedal's Avatar
Postovi: 250
Autor Dawar Pregled postova
Military,special forces ....To mi je bilo ok
@Paske Tnx.. U biti nisam ni poceo igrat., jer kad sam zavrsio trial uzeo novi lik i onda nisam mogao igrati,nego sam dizao skillove ..
Staro 09.05.2007., 15:47   #67
dedal
Toshiba ko' ludo
dedal's Avatar
Postovi: 250
Evo završio prvu misiju (do 03:00h) pa zaspao na posao ,a bilo je dobro,trebalo je ccc 15 dronova roknut i zadatak obavljen.Moram izgleda pojacat shiled to mi je izgleda slaba strana Riftera...
Staro 10.05.2007., 00:38   #68
Dawar
Dawar's Avatar
Postovi: 1,221
Kupio za 8$ 100milja ISKa i s time si kupim novi brod i par skillbookova za research. I taman sad gledam i vidim treba mi jos 200milja da mogu pocet sa inventionom
Staro 10.05.2007., 09:33   #69
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Autor dedal Pregled postova
Svaki brod ili shield ili armour tanka.
Ako imaš više med slotova - bolje je shield tankat, ako imaš više low slotova onda armour tank !
Isto tako ovisi koja si rasa - Amarr recimo obićno shield tankaju, tko je zamišljeno.
Toplo preporučam da prošvrljaš po eve-online.com forumima - newbie section. Gro korisnih informacija. EvE na početku iziskuje poprilično puno učenja
@ Dawar - i ja sam svojevremeno kupio od Kineza. Onda sam saznao da se može LEGALNO prodavati Game Time Card ( GTC ) za ISK. Princip je u detalje objašnjen u eve noline offical forumima - sell / buy sekcija. Legalno i jeftino !
Toplo preporučam ovaj servis za kupnju GTC-a:
http://www.shatteredcrystal.com/
Službeno podržani od CCP-a, nakon što te jednom nazovu šalju GTC code u roku od 5 min po narudžbi. 5+ usluga !
Staro 10.05.2007., 09:56   #70
dedal
Toshiba ko' ludo
dedal's Avatar
Postovi: 250
Ma kupio sam shield + armor plate i sad je ok,a tankanje bi bilo kao npr.svaki brod ili rasa ima odredene fitinge i onda se slaze prema onome za sta si se opredijelio...( ili grijesim) .
@Paske.,Level 2 Electronics : 1 dan cca10sati, a kaj do Levela 4 .Ipak tnx za skillove,ma to sve piše na EVE forumu a ko još vremena ima za to..
Staro 10.05.2007., 12:12   #71
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Pa koliko si dignuo learning skills ?
Mislim - to ti je osnova za sve ostalo, bez toga si mrzli ....
copy / paste iz: http://myeve.eve-online.com/ingamebo...hreadID=242786
- Instant Recall 1
- Analytical Mind 1
- Learning 1
- Instant Recall 2
- Analytical Mind 2
- Learning 2
- Instant Recall 3
- Analytical Mind 3
- Learning 3
- Instant Recall 4
- Eidetic Memory 1
- Eidetic Memory 2
- Eidetic Memory 3
- Analytical Mind 4
- Logic 1
- Logic 2
- Logic 3
- Learning 4
- Eidetic Memory 4
- Logic 4
- Spatial Awareness, Iron Will, and Empathy 1-4 (Order does not matter. Train level 5 of these before training their advanced counterparts if you want to stick to the optimal order.)
- Determining the best order in which to train Clarity, Focus, and Presence is a little tricky. For each skill, take your current attributes and plug them into this simple formula: Primary + ( Secondary / 2 ) Whichever skill gives the highest result, train it to level 1 first. Repeat this until all three skills are at level 1, then repeat this same process for levels 2-4.
For the average player without implants, this process would take about a month and you’d be training 2.19 times as fast as you were to begin with. Though it would eventually be worthwhile to train the learning skills to level 5, it can literally take years to make up the time spent training them. That said, many people do actually max them all out, myself included.
Staro 10.05.2007., 13:32   #72
dedal
Toshiba ko' ludo
dedal's Avatar
Postovi: 250
Sad sam na poslu,ali dizao sam bas learning skillove,ajd javim kad dodjem doma... Evo:
Iron Will / Rank 1 / SP: 45255 of 256000
Learning / Rank 1 / SP: 45267 of 256000
Spatial Awareness / Rank 1 / SP: 8000 of 45255
P.S Zaboravi na gornji post,krivo sam napisao za skill.Treniram
Energy Grid Upgrades na Level3.Sry valjda sam spavao kad sam gledao...
Zadnje izmijenjeno od: dedal. 10.05.2007. u 13:53.
Staro 10.05.2007., 15:00   #73
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Gore ti piše kaj trebaš dignuti, bez toga češ kasnije krv piš*ti kad ti zatreba advanced training
Staro 10.05.2007., 17:12   #74
dedal
Toshiba ko' ludo
dedal's Avatar
Postovi: 250
Hvala,znas kak sve bi ja skuzio u jednom danu ali nejde ....
Staro 16.05.2007., 08:40   #75
Dawar
Dawar's Avatar
Postovi: 1,221
Oprez!
Due to the potential end result of the creation of a courier mission with 0 days to complete, this action is not permitted and has been classified as an exploit. Players found exploiting this issue will be punished accordingly, up to and including permanent bans. It is highly recommended that players with outstanding zero-day contracts cancel them immediately.
The Dev team is aware of the issues this exploit has caused and will resolve it in the near future. We apologize for the inconvenience this issue has caused.!
Objavili tu vijest nakon što sam im ja poslo Petition , jer se meni to dogodilo i izgubio 70milja . Sad čekam da mi vrate lovu nazad
Staro 16.05.2007., 10:22   #76
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Ček, ček - daj malko pojasni.
Ja naime radim samo ubij / uništi misije, pa mi je ovo strano ...
Daklem misija bi trebala "nestati" jerbo je vrijeme iscurilo, međutim i dalje se može završiti ?!?
Staro 16.05.2007., 16:59   #77
Dawar
Dawar's Avatar
Postovi: 1,221
To nije misija u klasičnom smislu. Odi vidi u contracte i odaberi Courier. To su misije koje radiš za prave playere npr neko ima viška para i neda mu se odnjet neki paket ili nekaj stvar u neki sistem. Ti prihvatiš contract i platiš colateral koji ti se vrati zajedno sa nagradom nakon što obaviš misiju. Dosada to radio i uvijek ok. Al ovaj put nisam skužio da je lik stavio vrijeme za koje to trebaš obaviti 0 days tak da nikako nisam mogao stići na vrijeme. Uglavnom platio sam 70 milja i trebao sam to dobit nazad i 5.5 milijuna zarade
Staro 16.05.2007., 21:08   #78
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
AAHHHAAA - vidiš nisam nikad tako nešto radio .... Courier contracts mislim.
Pa - slobodno se javi GM-u za scam.
Njemu ban tebi pare natrag
Staro 16.05.2007., 23:17   #79
Dawar
Dawar's Avatar
Postovi: 1,221
Jesam javio se jesam i to 2 petitiona i prošlo više od 24h i ništa još, ako mi ne vrate nazad zbogom EVE, jer jednostavno to nije fer...
BTW vidi gore desni kut
Staro 17.05.2007., 09:52   #80
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
LOL - Google ads su zakon
Inaće kad mi ponestane ISK-a ( a popušim barem 1 BC dnevno ) - samo prodam GTC od 30 dana. 160 mil ISK u pađe, a 100% legalno i podržano od CCP-a.
Mrak ^^
Inaće - koliko znam za takv e stvari im treba cca 7 ili više dana, a obzirom da ima sigurno GRO ljudi koji pizde - možda i malko duže :/
Anyway - BOLESTAN battle report iz fronte BoB-a. Za sve BoB hatere tamo, sucks to be you ^^ Meni je osobno svejedn, znam kaj je bilo i mene se ne tiće, barem za sada ....
Report je uzet sa PCPlay foruma, a postao ga je Hey You - ćlan BoB-a.
Red Alliance, GoonSwarm, Agains All Authoritis vs Band of Brothers
Uzivajte:
9-98 Battle Report, Tuesday May 15th
Primer: This battle was long as hell, one of the longest I've ever been in.. but there was very little change throughout the battle, so the BR won't take you 2 hours to read Razz
It started like every other epic event starts, with me logging onto IRC and asking the terrible question "Need another dread?". It was already 18:00 GMT or so when I got on, and by then, a reported 35 capitals from RA/AAA were staged in 46DP (Next to 9-9Cool heavy on dreads and with one Titan and one Mothership. In JV1V, a GoonSwarm capital gang of around 20 was prepping itself. BoB had around 27 Dreadnaughts, 4 Motherships, 3 Titans and a half dozen Carriers.
The target, as it turned out, was an RA POS belonging to UAI that was completely irrelevant to the sovereignty war we were fighting with GoonSwarm. I could tell that most people were expecting the op to be called off, or if not, that we would attempt some form of trickery to gank a few of their capitals then escape.
Eventually Molle didn't want to wait any further even though we had a half dozen capitals coming down from AZN to JO-, and asked the following on teamspeak:
"Evening ladies."
"We have a small problem.."
"We have about 30 dreads, and the hostiles have about 50 dreads."
"So, who wants to lose a dread?"
And in typical BoB fashion, a chorus of "Me!" erupted on voice coms with Dianabolic following with:
"Right, all of you flying corp dreads can just shut the fuck up"
And that was it, the fleet was committed to this battle, win or lose. Those on command channels stopped debating the risks and strategies and began organizing cynos and warp in points. The whole capital fleet aligned itself to planet 10 and warped to a loading spot 350km from the RA tower. Minutes later, we warped to the tower and entered siege. The tower went down extremely fast, and by the time the hostiles began cynoing in, it was already dead. The hostile capital fleet began emergency warping all over, and bouncing off the POS shield. Our dreads came out of siege and we had the option of cynoing them out, or warping them out. We refused, and aligned ourselves for their POS as they aligned themselves for ours. In total, the BoB capitals were out of siege for approximately five minutes. Eventually 75 enemy capitals with around 50 of those being Dreadnaughts (give or take a few) warped to us, and we entered siege.
The hostile capital fleet came right on top of us, or into the middle of us and bounced a few (myself included). Molle called the first two targets that loaded, then TWD took over for the next 15-20 minutes. Initially as the fight began, Carriers were given the order to launch tech 1 drones only. Taking the bait, ET tried to use his Aurora Ominae early in the fight but missed and activated it at the Goon POS (as we later found out). Then, enemy Carriers launched a sea of fighters. Our cyno went up and after several minutes of lag, the Judgement went off, annihilating them. Fleet was called in, our own Carriers began launching actual fighters. Hostile fleets began pouring in, and we had two fleet battles happening simultaneously.. one between the battleship and support groups, the other between capitals. Because of everyone being mashed together in one spot, we called by name, teamspeak for capitals and IRC for battleships (yes, fucking IRC).
TWD eventually crashed and emergency warped out, I took over for the next 20-30 min or so. In the middle of this, a dozen capitals from the late comers and stragglers organized in 5P, trying to get themselves into the fight to reinforce us. Due to having spent our pre-positioned cyno pilots, and the lag involved, pilots couldn't warp to the motherships to grab a new ship. We never got them into the main fight at all as a result. Lag made the battle extremely slow, sometimes taking 5 minutes just to get enough guns on an enemy dread to break its tank, but overall the game was still playable and target after target died.
Towards the end of my target calling, a solid hour had gone by since we first entered siege and the majority of both fleets were starting to run out of gas. Hostile capitals trickled out via cyno one by one. Knowing that if ours jumped as well to 5P for refuel they'd never get back in. Dreadnaughts that came out of siege were ordered to warp to 5-1 friendly tower and refuel from backup strontium aboard the Motherships. I was one of them, and made it out fine but never loaded the friendly POS to refuel, Blockoindi took over from me and called for the remainder of the battle. Capital numbers on both sides were dropping fast, mostly cynoing and warping out. Towards the end the hostiles had 15 dreadnaughts on the field, we had 5. They primaried DimensionZ, who was promptly neutralized out of cap by their Carriers. Because of their pitiful damage out of siege and lack of fighters, our Carriers were able to keep him alive with remote reps and they were unable to score any more capital kills after this.
A second hostile Cyno went up for ET's Doomsday which had reset itself in the course of this fight. Lag hit him once again, and Carriers were able to retract most of their fighters. In short, he doomsdayed more Goons than anything as we only lost 7 bs and 6 support out of over 150. On command channels we knew he would do this as a saving move to remove our tacklers and egress their capitals. Our fleet was able to come back right away, and pin most of them down, with one hostile carrier being held at planet 1 for some 15 minutes by Isabele Sweet.
At this point the lag began clearing up, the refueled dreads from friendly POS made it back and some in 5P were able to load 10-1 towards the end. Another 8 hostile capitals were downed after the second Doomsday. Their bs and support gang regrouped and came back, but ended up being taken out by our battleships, which then focused back to dealing damage on the dreadnaughts.
The next hour was spent on cleanup, clearing hundreds and hundreds of wrecks from the 10-1 moon, killing anyone that came back online, taking the dreads back to refuel. At one point Molle threatened to Doomsday anyone found killing Goons at the station, because we were fighting against the clock and needed everyone to help loot. By the time ET's DD cycled a third time, we were all but done. A friendly tower was placed in 10-1 to catch hostiles that logged off.
Final tally for the day was:
737 kills of which there were..
79 Battleships
24 Dreadnaughts
5 Carriers
89 losses of which there were..
13 Battleships
14 Dreadnaughts
Local peaked at 450.
We had several opportunities to disengage, before and after the enemy POS was killed and didn't. Our capitals were outnumbered by a solid 50%, and we came out with a 29:14 or 2:1 ratio. We held the field, and made away with billions in loot. Numbers might shift a bit over the next few days, but for the most part that is the final score.
Those that died are simply a statistic, as you would expect to lose a few battleships in any normal fleet battle. Personally speaking, which I shouldn't do in these reports, the only thing I can find to nitpick about our achievement was that we should of planned more cynos to bring our reinforcements in sooner. Thats about it.
Good game to all involved, definitely one of the best and longest battles ever seen this year.
PS: More dreads!
Staro 17.05.2007., 14:08   #81
Dawar
Dawar's Avatar
Postovi: 1,221
Ma znam za te GTCove al mi je to skuplje i kompliciranije, ovo samo uplatim i dobim u 10 minuta. Što se tiče legalnosti ak me pitaju kažem kompa mi poklonio a ak me banaju ko im je kriv izgubili su mojih 15$ mjesečno....
Staro 17.05.2007., 14:30   #82
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Pa i nije komplicirano ....
Tu kupiš time code. Na EVE forumima odeš na WTS dio foruma i staviš oglas - obično ide za 160 Mil ISK.
Kad se lik javi preko svojej account managera pošalješ ponudu, on primi ingame i svi sretni
14$ = 160 M ISK - nije loš tečaj
Staro 17.05.2007., 22:08   #83
Dawar
Dawar's Avatar
Postovi: 1,221
Vratili mi pare Sad napokon idem po BCa i po salvaged materials za proizvodnju rigova
Staro 18.05.2007., 11:37   #84
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Hehe - zakon ^^
Tko je reko da CCP ne brine o svojim mušterijama
Staro 28.05.2007., 11:58   #85
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Kaj je bilo ekipa - nekak ste mi utihnuli
Pa nije vrag da ste odustali o.O
Staro 28.05.2007., 20:22   #86
Dawar
Dawar's Avatar
Postovi: 1,221
Nismo naravno da nismo
Ja fitiao svog battlecruisera jedino jos moram drone jace nabavit. Nakon toga krecem skilat za mining barge
Staro 28.05.2007., 20:48   #87
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Ja samo PVP pikam i moram priznati da i dalje sucksam
Staro 29.05.2007., 09:51   #88
dedal
Toshiba ko' ludo
dedal's Avatar
Postovi: 250
Ja sam na "godisnjem",nekak mi se neda,a i sad su rostiljade pocele pa se vikendima tulumari ...
Staro 29.05.2007., 12:52   #89
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Samo nemoj zaboraviti dizati skillove
Staro 08.06.2007., 00:42   #90
Dawar
Dawar's Avatar
Postovi: 1,221
Danas imao loš dan. Prvo na corp eventu gdje smo išli u low space ratsi mi uništili jednog cruisera. Kasnije ja kreno u low space sa mining bargeom minati led kad odjedanput doleti tip sa intercepterom i skoro mi uništi brod. Tražio me 5 milja koje sam mu dao jer mi brod i oprema vrijedi više
