Staro 26.03.2025., 13:57   #61
prileee
laser
prileee's Avatar
Postovi: 2,356
Samo da ostavim info, ako nekome u buducnosti bude trebalo, na kraju sam kupio key sa https://www.allkeyshop.com/blog/buy-...ompare-prices/ odabrao sa Wincdkey i onaj koji ima GLOBAL pod regions a ne phone activation i radi.
Staro 03.04.2025., 08:17   #62
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Microsoft Urges Businesses To Abandon Office Perpetual Licenses
Microsoft is pushing businesses to shift away from perpetual Office licenses to Microsoft 365 subscriptions, citing collaboration limitations and rising IT costs associated with standalone software. "You may have started noticing limitations," Microsoft says in a post. "Your apps are stuck on your desktop, limiting productivity anytime you're away from your office. You can't easily access your files or collaborate when working remotely."
In its pitch, the Windows-maker says Microsoft 365 includes Office applications as well as security features, AI tools, and cloud storage. The post cites a Microsoft-commissioned Forrester study that claims the subscription model delivers "223% ROI over three years, with a payback period of less than six months" and "over $500,000 in benefits over three years."
Aha
Staro 10.04.2025., 09:26   #63
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Čisto informativno...danas sam nanovo instalirao Win11 na lapu i naravno htio instalirat Office 2019 Pro Plus Retail koji sam kupio pred nekih 3 godine sa jednog od respektabilnih "sivih" sajtova po cca 50 Eura (reko aj necu za 1 Euro sigurno je scam). Čini se da je ključ blacklistan:
https://support.microsoft.com/en-us/...7-554a6076c910
Meni osobno ne pere samo mi diže tlak usljed hrpe istih sajtova po netu i kad ekipa takve ključeve koristi i za službene uređaje i svi tvrde da je to OK. Nije legalno i nebi se trebalo promovirat. Ne samo da je piratluk nego je još gore - piratluk koji se plaća. Hvala al ne hvala al onda ću radije ili koristiti alternativu koja ne košta ništ ili ću iskeširat kolko treba za legalnu verziju direktno kod MS i bok (uostalom M365 je 10 Eura mjesečno, ak imam za kavu imam i za to).
/rant off
Zadnje izmijenjeno od: tomek@vz. 10.04.2025. u 11:46.
Staro 10.04.2025., 09:56   #64
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,799
Koliko je meni objasnjeno, kljuc nije "blacklistan", nego ga mozes aktivirati samo jednom. Ocito ga nije moguce "deaktivirati", jebiga...
Programer
Staro 10.04.2025., 10:08   #65
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Autor Bubba Pregled postova
Ma prošao sam u zadnjih nekoliko godina više reinstalacija Win10/11 na 3 računala (uvijek aktiviran samo na jednom) i nikad u 3 godine problema. Jebaj ga.
Staro 10.04.2025., 10:35   #66
nino
nino's Avatar
Postovi: 12,613
Si pokusao preko ms acc aktivirat?
Staro 10.04.2025., 10:39   #67
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Autor nino Pregled postova
Yep.
Staro 10.04.2025., 11:04   #68
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,837
Možda je do broja aktivacija na raznim računalima?
Staro 10.04.2025., 11:44   #69
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Autor Libertus Pregled postova
RETAIL
Staro 10.04.2025., 14:13   #70
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,111
Broj aktivacija na različite kompove, mislim da je 5...
Nazovi onaj 0800 broj pa aktiviraj telefonom, to kad sam davno delal je pomoglo
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 17.04.2025., 05:41   #71
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Microsoft has acknowledged that Classic Outlook can mysteriously transform into a system resource hog, causing CPU usage spikes between 30-50% and significantly increasing power consumption on both Windows 10 and 11 systems.
Users first reported the issue in November 2024, but Microsoft only confirmed the problem this week, offering little resolution beyond stating that "the Outlook Team is investigating this issue." The company's sole workaround involves forcing a switch to the Semi-Annual Channel update through registry edits -- an approach many enterprise environments will likely avoid. Microsoft hasn't announced a definitive end date for Classic Outlook, but the company continues pushing users toward its New Outlook client despite its incomplete feature set.
Staro 17.04.2025., 05:46   #72
njOob
njOob's Avatar
Lokacija: Jug
Postovi: 502
Ja sam prije par godina uzeo bio za 15 eura kljuc koji je bindan za account i evo nisam ni znao tocno kako ide ali na kraju ispalo na kojem god kompu da imam svoj account logiran imam i office 2021 aktiviran.
Edit: sad isti taj bindan je 59$
https://wholsalekeys.com/shop/micros...essional-plus/
Sent from my SM-S926U1 using Tapatalk
njOob je offline   Reply With Quote
Staro 02.05.2025., 07:42   #73
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
We are introducing a new Startup Boost task from the Microsoft Office installer to optimize performance and load-time of experiences within Office applications. After the system performs the task, the app remains in a paused state until the app launches and the sequence resumes, or the system removes the app from memory to reclaim resources. The system can perform this task for an app after a device reboot and periodically as system conditions allow.
MC1041470 – New Startup Boost task from Microsoft Office installer for Office applications
Staro 25.07.2025., 09:12   #74
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,147
Hah ovo ide i MS i Libreoffice i vjerojatno sve ostale Office alate koji su alternative MS Officea...
An artificially complex XML schema as a lock-in tool
Staro 25.07.2025., 14:06   #75
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,837
To je tako godinama. MS želi zadržati svoj monopol i komplicira gdje god stigne svoj xml. Kada je ods proglašen standardom, ms je podmazao da se i jedna njegova verzija proglasi standardom.
Koliko je sjećam ni ms office ne otvara ms standard format kako treba.
Za EU bi vjerojatno izlaz iz toga bilo da proglasi ods obavezan standard za sve države i agencije. MS isto podržava ods ali namjerno loše.
S vremenom kada bi većina datoteka bila ods, i to službena verzija ne neka izmišljena od strane ms, bilo bi svima svejedno koji office alat koriste.
Staro 22.08.2025., 22:04   #76
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Organizations still using default Microsoft 365 email domains face severe throttling starting this October. The restrictions target the onmicrosoft.com domain that Microsoft 365 automatically assigns to new tenants, limiting external messages to 100 recipients per day starting October 15. Microsoft blames spammers who exploit new tenants for quick spam bursts before detection. Affected organizations must acquire custom domains and update primary SMTP addresses across all mailboxes -- a process that requires credential updates across devices and applications.
Staro 22.08.2025., 23:18   #77
domy_os
domy_os's Avatar
Postovi: 18,946
Ne vidim problem. Koliki postotak ljudi (ne botova) koristi defaultnu domenu? Ima li takav podatak?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 28.08.2025., 07:14   #78
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Starting with Word for Windows version 2509, Microsoft is making cloud saving the default behavior. New documents will automatically save to OneDrive (or another cloud destination), with dated filenames, unless users manually revert to local saving in the settings. From the report: "Anything new you create will be saved automatically to OneDrive or your preferred cloud destination", writes Raul Munoz, product manager at Microsoft on the Office Shared Services and Experiences team. Munoz backs up the decision with half a dozen advantages for saving documents to the cloud. From never losing progress and access anywhere to easy collaboration and increased security and compliance. While cloud saving is without doubt beneficial in some cases, Munoz fails to address the elephant in the room. Some users may not want that their documents are stored in the cloud. There are good reasons for that, including privacy.
Summed up:
- If you do not mind that Word documents are stored in the cloud, you do not need to become active.
- If you mind that Word documents are stored in the cloud by default, you need to modify the default setting.
Staro 08.10.2025., 09:34   #79
lovranac
lovranac's Avatar
Datum registracije: Feb 2011
Lokacija: lovran
Postovi: 79
Koja je razlika između Office 2021 Professional Plus i Office 2021 Home & Business. Pro Plus je uvijek jeftiniji.
Može li se i Professional Plus kupiti za korištenje u firmi ili ima neki nedostatak.
lovranac je offline   Reply With Quote
Staro 08.10.2025., 16:19   #80
Ivan357
Datum registracije: Jun 2020
Postovi: 176
pro plus sadrži sve kao i h&b + access
gdje je pro+ jeftiniji, na onim "sumnjivim" stranicama?
zašto se ne bi mogao kupiti za korištenje u firmi?
Ivan357 je offline   Reply With Quote
Staro 08.10.2025., 19:32   #81
lovranac
lovranac's Avatar
Lokacija: lovran
Postovi: 79
Autor Ivan357 Pregled postova
office Professional Plus 2021 sam gledao na uzishop.hr - 174 €link -
office Home & Business 2021 sam gledan preko nabave - link - 217 € u svijet medija
- zanemario sam dućan Masquerade jer mi nije uopće poznat
Radi se o razlici od 40 €, odnosno 20%
Staro 08.10.2025., 20:10   #82
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Ukratko - Pro je inace skuplji, ukljucuje jos i Access i Publisher. Vjerojatno nist od toga ne trebas al uzmi jednostavno kaj je jeftnije i bok. Oba smijes za poslovne svrhe koristiti.
https://brytesoft.com/blog/office-20...right-one.html
Staro 08.10.2025., 20:19   #83
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,147
Osim ako nije s onih sumLJivih stranica za nekoliko desetaka eura/dolara
Staro 08.10.2025., 20:21   #84
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,333
Autor spiderhr Pregled postova
OP je postao linkove, post iznad mog, sve je legit.
Autor lovranac Pregled postova
Staro 08.10.2025., 20:45   #85
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,147
Znam da je postao, samo sam se nadovezao da ne naleti eventualno na te linkove jer kao povoljnije je.
Staro 08.10.2025., 23:21   #86
Ivan357
Postovi: 176
ne možeš uspoređivat cijene različitih dućana, ako te stvarno zanima cjenovna usporedba, onda ih usporedi u istom dućanu, ili još bolje na ms web-u
isto tako si mogao postati cijenu sa stranice koja preprodaje licence i reći da je tamo proplus 20€, odnosno 10 puta jeftiniji od h&b u bilo kojem hr dućanu
da post ne bude skroz beskoristan, razlike u verzijama: https://en.wikipedia.org/wiki/Microsoft_Office_2021
