Staro 21.01.2011., 23:56   #61
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
Autor bluefluid Pregled postova
I
Inace, evo i prvih modela sa 1GB vrama:
HIS Intros Radeon HD 6950 1 GB Fan Edition Graphics Card
Izvor: techpowerup
el zna ko kad bi se ove od 1 gb mogle pojaviti?
hobitxxx je offline   Reply With Quote
Staro 25.01.2011., 08:52   #62
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
6970 je ludnica, al topla, moš jaja peč na njoj. Malo je i dugačka pa će zahtijevat preinake na kućištu, tipa disk van plus rezanje stranice i ubacivanje dodatnog venta.
Staro 25.01.2011., 15:38   #63
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Nije to baš GTX480
Duža je od GTX580, GTX480 te GTX295. Kakva će tek onda bit HD6990, bojim se i mislit
fran123456 je offline   Reply With Quote
Staro 25.01.2011., 16:31   #64
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Autor hobitxxx Pregled postova
Ma nista to, gle ovo:
AMD Slashes Prices of Radeon HD 6800 and HD 6900 Series Products
AMD finalized its recalibrated product pricing of Radeon HD 6800 and Radeon HD 6900 series products in the wake of NVIDIA's launch of the GeForce GTX 560 Ti later today. NVIDIA's new GPU is expected to revive the green giant's competitiveness at a key sub-$300 price-point, which could destabilize AMD's SKUs in the price-proximity. Without many options left, AMD is setting the following new prices (EUR and USD):
Radeon HD 6870 1 GB: 189.99€, $219
Radeon HD 6950 1 GB: 225.00€, $259
Radeon HD 6950 2 GB: 239.99€, $269~289
The prices should be in effect very soon. Prices apart, AMD will also release a new driver that will bring about considerable performance improvements to all Radeon HD 6000 series GPUs.
Spek ju veri mač nevidija!
Staro 25.01.2011., 16:52   #65
hobitxxx
hobitxxx's Avatar
Postovi: 412
zvuči predobro samo je pitanje dal ce naši trgovci snizit cijene dovoljno da grafe nebudu i dalje preskupe.
Staro 26.01.2011., 18:03   #66
Rush xxx
Postovi: 41
Evo jednog scora u 3d Mark-u 2011.Bios je origigi xfx-ov moddan otključani shaderi.Čudno u Vantageu memorija prolazi na 1500, u 3d marku 2011 1450 najviše.
ORB
6679
Rush xxx je offline   Reply With Quote
Staro 27.01.2011., 00:39   #67
Minox
Minox's Avatar
Postovi: 565
pozdrav ekipa jucer sam postao ponosni vlasnik
6970 sapphire,pa kad je malo izbenchham ,javim reze
Minox je offline   Reply With Quote
Staro 29.01.2011., 17:45   #68
brunex
brunex's Avatar
Lokacija: Osijek City
Postovi: 97
Autor Minox Pregled postova
aj probaj večeras, u ponedjeljak trebam kupiti Gigabyte 6970 a pošto imamo jako sličan ostatak konfe, baš bi me zanimalo.
Zadnje izmijenjeno od: brunex. 30.01.2011. u 12:41.
brunex je offline   Reply With Quote
Staro 30.01.2011., 17:17   #69
Minox
Minox's Avatar
Postovi: 565
imas 1 bench za sada pod 3dmark11 sekciji , ostalo cu tokom tj
p.s jel mi moze neko objasniti zasto kada upalim youtube , bespotrebno dignu klokovi grafe, i onda se bzvz grije ? :/
tj sa 250/150 na 500/1375
Staro 30.01.2011., 17:30   #70
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Desni klik na klip, settings, i makni kvacicu sa Enable hardware acceleration.
Staro 30.01.2011., 17:38   #71
Minox
Minox's Avatar
Postovi: 565
tnx !
Staro 02.02.2011., 09:22   #72
gumeni
gumeni's Avatar
Datum registracije: Dec 2009
Postovi: 97
uzeo sam 6950 pa me zanima dal ovaj GPU OBSERVER gadget prepoznaje 6xxx seriju, jer meni ne prepozna moju...
gumeni je offline   Reply With Quote
Staro 02.02.2011., 09:31   #73
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Pa lijepo piše:
Supported GPU's:
- NVIDIA Desktop Cards (Generation: 7,8,9,200,300,400)
- ATI Desktop Card (Generation HD 2,3,4,5 [Catalyst 9.3 or above])
- Several NVIDIA Mobile Cards
Last updated: 5/12/2010
Staro 02.02.2011., 10:42   #74
gumeni
gumeni's Avatar
Postovi: 97
Autor Jelc Pregled postova
Pa lijepo piše:
čitao sam da kao ima i verzija 3.7 koja podržava 6 seriju al ne nađem ja to za skinut....a ta što sam dao link je 3.6 verzija...
Staro 02.02.2011., 17:41   #75
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
http://download.orbmu2k.de/download.php?id=49
Evo ti 3.7 verzija Podržava i seriju 6900 isprobano jedino neznam kako namjestiti da očitava temp. u C, a ne u fahrenhaitima.
Zadnje izmijenjeno od: ECHO. 02.02.2011. u 17:48.
Staro 02.02.2011., 20:23   #76
Minox
Minox's Avatar
Postovi: 565
ne radi ni ova verzija,imam 64bit win 7 ,jel mozda do toga ?
Staro 02.02.2011., 23:41   #77
gumeni
gumeni's Avatar
Postovi: 97
Autor ECHO Pregled postova
E majstore puno ti hvala...meni šljaka...i očitava temperaturu u °C....neznam šta bi te moglo zezat...
Staro 03.02.2011., 00:08   #78
ECHO
Postovi: 2,354
I ja imam Windows 7 i sve radi OK, bila uključena opcija za pokazivanje u F. ali po defaultu je uključeno C, ja pokačio sve opcije i nisam ni gledao za čega su pa tako uključio i tu za F.Sad je sve OK
Staro 03.02.2011., 09:19   #79
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,074
ajde da vas pitam kakve su po pitanju buke,jel iritantna!
Staro 03.02.2011., 09:24   #80
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
Kad se zagrije (imam turbinu referentnu), čuje se, ali ne strašno. Otvoreno mi je kućište pa je čujem. Kad imam sluške na ušima ili kad ne moram stišat zvučnike zbog ukućana, onda se ne čuje uopće.
Staro 03.02.2011., 10:03   #81
Schtefek
Schtefek's Avatar
Datum registracije: Jun 2010
Lokacija: Križevci
Postovi: 172
Jel bi bilo dobro staviti neki kvalitetniji hladnjak umjesto one stock turbine?
Jel se gubi garancija ako se skine stock hladnjak?
Schtefek je offline   Reply With Quote
Staro 03.02.2011., 10:33   #82
ECHO
Postovi: 2,354
Normalno da gubiš garanciju ali da se to sve pažljivo razmontirati i smontirati da se i nevidi remont i ukoliko nešto pođe po zlu samo vratiš origigi cooler i sve OK.
Neznam ja jućer igrao Stalker-a 2h i uopće nije glasan cooler, kad pojačaš zvuk, a ja igram bez sluški nečujem ništa imam još par ventilatora i čujem samo 140mm na vrhu kučišta. Barem glede 6950 1GB modela cooler radi na 24% i u idlu 37c nisam mjerio u load-u, a i nisam neki freek glede tišine pa me nesmeta
Staro 03.02.2011., 10:35   #83
D1viry
D1viry's Avatar
Lokacija: Slavonija
Postovi: 2,066
99% sam siguran da se gubi garancija. Svi zahvati poništavaju garanciju, osim ako to uspiješ napravit na način da možeš vratit oriđiđi hladnjak prije nošenja u servis u slučaju kvara. (koja zavisno složena, bez zareza )
edit: ECHO je bio brži .
Staro 03.02.2011., 13:43   #84
groc
groc's Avatar
Datum registracije: Aug 2009
Lokacija: kašina,zagreb
Postovi: 37
Tiha je grafa......turbina se cuje na oko 40 posto okretaja(u full loadu ide do 37 posto i temp je oko 88)....a sve ispod je fakat tiho.....vise cujem 200mm ventove
groc je offline   Reply With Quote
Staro 03.02.2011., 22:57   #85
Minox
Minox's Avatar
Postovi: 565
jel to normalno da mi grafa ide na 80 stupnjeva u loudu pri 950/1450 i vent @ 40 % na stock voltazi , igro sam DS2 i nakon pola sata na MSI Afteru mi je pokazalo 99 posto zazece gpua hmmm ? jel to uredu ili da vratim grafu na stock postavke ,hvala unaprijed
Zadnje izmijenjeno od: Minox. 03.02.2011. u 23:12.
Staro 03.02.2011., 23:06   #86
HCS
Premijum
HCS's Avatar
Postovi: 1,360
jel to normalno da mi grafa ide na 90 stupnjeva u loudu pri 950/1450 i vent od 40,50 % na stock voltazi , igro sam DS2 i nakon pola sata na MSI Afteru mi je pokazalo 99 posto zazece gpua hmmm ? jel to uredu ili da vratim grafu na stock postavke ,hvala unaprijed
Sve je to unutar "safety limitsa", ali nije bas lijepo vidjet tolku temp ne, probaj jace vent pucat, ako ti buka ne smeta, s druge strane, cemu OCat 6970 za 24/7? Fali ti snage negdje? A ovih 99% je super, znaci da iskoristavas puni potencijal grafe.
Staro 03.02.2011., 23:35   #87
Minox
Minox's Avatar
Postovi: 565
fala ti ;O) ,vec sam brio da je nes sa grafom , eo kad sam stavio na 40 % ide do 80 max al vidim da si me preduhitrio dok sam editiro post , ovo za 99% nisam znao znači i5 na 3.8 mu je čist dosta heh
eo primjera DS2 @ maxed all out , na stocku je oko 60,70 fpsa a kod OC-a penje se do 100/110 dobra reza zar ne ?
Staro 04.02.2011., 00:04   #88
Schtefek
Schtefek's Avatar
Lokacija: Križevci
Postovi: 172
Mislim da bi mogao upiknuti jednu 6950, samo me zanima jel ima velike razlike između 1 i 2 gb verzije, osim otključavanja :-D
Po nekim testovima obje su brže od gtx560 ali u nekima je brža jedna a u drugima druga.
Staro 04.02.2011., 00:11   #89
Minox
Minox's Avatar
Postovi: 565
odi rađe na 2gb ver ...
Staro 04.02.2011., 08:19   #90
Schtefek
Schtefek's Avatar
Lokacija: Križevci
Postovi: 172
Super, ali argument zašto ?
Zadnje izmijenjeno od: Schtefek. 04.02.2011. u 08:20. Razlog: glup smajl stavljen
