Staro 14.11.2007., 15:26   #781
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
vidim i da su sredili AH konačno su dali 48h da nešt može stajat na tržnici a ima još stvari tipa što se strijelica mjenja zavisno do koga dođeš itd. treba stavit šta se sve mjenja ako ima neko link nek stavi
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 15.11.2007., 00:34   #782
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,029
Hmmm, za sad mi se svida, puno je lakse levelat. Sad samo moram pricekat da mi sve addonove naprave za novu verziju jer mi je igrat bez njih ravno samoubojstvu
Staro 15.11.2007., 01:10   #783
brentaal
Postovi: 298
Može netko reć' kakve su hunter promjene? Čuo sam nekaj u vezi smanjenja aimed shot cast timea, a i vidio sam da ostale klase nerf-callaju, neki tvrde da se aimed shot može spamat, rofl
http://www.youtube.com/watch?v=WrM8fXwS2XM
brentaal je offline   Reply With Quote
Staro 15.11.2007., 12:16   #784
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
Aimed Shot now reduces healing done to that target by 50% for 10 seconds, shot time reduced by 0.5 seconds.
Arcane Shot (Ranks 6 and above) now dispel 1 Magic effect in addition to their normal damage.
Explosive Trap: The initial damage dealt by this trap is now also increased by 10% of your ranged attack power.
Serpent Sting: The total damage dealt by this sting is now also increased by 10% of your ranged attack power.
a ovdje kompletne promijene Patch 2.3
EDIT: zaboravio sam napisat da nema više deadzonea, range je sad od 5-35, a na 4 je već melee
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 15.11.2007., 19:59   #785
destroyer
Lokacija: okolica Varaždina
Postovi: 166
Po mnogocemu bolje nego prije, ali svejedno nije to to...
nije da sam ocekivao nesto od tog patcha, ali svejedno bi mogli malo buffati i shadow priestove... cak mi je i shield slabiji nego prije, a jos je k tome jako ranjiv zbog novog arcane shot.... hunteri su sad overpowered.... jako.. paladini su bili jaki i prije a sad cak mogu i dmg raditi...
bezveze... jedva cekam wrath of the lich king nadam se jakim buffovima pa da budem overpowered bar do 3.1 patcha
a do onda mozda reroll shaman ili nes takvo kao alt... samo cekam da ubijemo kaela pa da vidim i MH i BT...
dobar je shadow priest za pvp ali nije mi to neka zabava... PvE ftw!
destroyer je offline   Reply With Quote
Staro 16.11.2007., 09:14   #786
Demon Hunter
Postovi: 999
1. Nije istina da je shield sada slabiji. Base absorb mu je smanjen, ali sada +healing/dmg utječu na dmg absorb.
2. Hunteri nisu nikad OP, još uvijek su easy-kill
3. Što se tiče stavke sa paladinima - tu se slažem
Demon Hunter je offline   Reply With Quote
Staro 16.11.2007., 14:34   #787
destroyer
Postovi: 166
A gle, za mene je hunter overpowered ak zna sa trapovima...
stavi mi one zmije koje mi nedaju da castam, probam staviti shield ali ima glupi arcane shot koji radi dmg i jos k tome unisti shield, ak nemam shield onda unisti stamina buff....
ne mogu fearat ako ima bestial wrath, a zmije su imune na fear cini mi se...
jedina sansa protiv njega je da stavim dot i sakrijem se iza stupa ako je nagrand arena i polako se healati i redot ako moze... al ako ima hilera iza sebe, mogu samo gledati kako nas ownaju.... makar... imam dobrog pallu u 2v2 pa mogu ubiti hilera kad mi ovaj stavi BoP a ja full nuke najdrazi su mi druje jer vecinom imaju malo hp
a ja bi neki aoe... nes poput arcane explosion, moze bit i slabije, tek tolko da se mogu boriti protiv hrpe mobova s malo hp (hunterove zmije)....
Staro 16.11.2007., 16:03   #788
brentaal
Postovi: 298
Hunteri mozda jesu overpowered u 1v1 (nisam imao prilike isprobat), ali Blizz nije ciljao na 1v1, i kao sto su vec izjavili PvP u WoWu nije orijentiran oko 1v1 duela. Oni ciljaju na poboljsanje hunterovih mogucnosti u areni, gdje u svim segmentima hunteri totalno suckaju i najmanje prisutna klasa su u top 200 timova (primjer, u 2v2 hunteri zauzimaju oko 0.5% mjesta u top 100 ili 200 timova, a za ostale segmente je situacija gotovo jednaka)...
Staro 16.11.2007., 18:24   #789
Demon Hunter
Postovi: 999
@destroyer - Snake trap nije immune na Fear, tako da slobodno iskoristiš aoe fear i miran si (ionako ga nećeš koristit protiv BM huntera). 1v1 hunter nema šanse protiv spriesta
A u areni možeš lako spamat Burn Mana, te si tako olakšat život (cca 4 su dovoljna da hunter bude oom).
Staro 20.11.2007., 04:02   #790
Last7emplier
Last7emplier's Avatar
Lokacija: Usa
Postovi: 38
server Kor'gall
gilda Croatians ... nas 30ak
ljudi koji niste pridruzite se
ima likova kick ass 70
a ima i lvl16
ekipa je uslužna i poželjna
vidimo se
btw nek vas moj sign ne zavara =)
alije smo....
Beautiful Girls in your town
Last7emplier je offline   Reply With Quote
Staro 20.11.2007., 08:32   #791
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Stay away from da Kor'gall mon.
DevNull je offline   Reply With Quote
Staro 20.11.2007., 15:18   #792
tskarda
tskarda's Avatar
Postovi: 1,125
Autor DevNull Pregled postova
O fino te vidjet da si ziv. jos da navratis na Dragonmaw ili ICQ slucajno
Staro 20.11.2007., 15:52   #793
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Autor Last7emplier Pregled postova
server Kor'gall
a ima i lvl16
vidimo se
alije smo....
To nije server - to je štala u najbolju ruku
Tupavi Španjolci i njihovo odbijanje komunikacije na Eng. jeziku. Pobjego sam od tamo na Emeriss prvom prilikom, potegnuo guild sa sobom - nikad zažalio ...
Staro 20.11.2007., 16:49   #794
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Autor tskarda Pregled postova
Eh ne igram previse bas onak nekad igram par dana nekad par dana ne, na icq sam slabo
Staro 21.11.2007., 15:52   #795
tskarda
tskarda's Avatar
Postovi: 1,125
Paske, u kojoj si guildi bio kada si emigrirao na emeriss?
Staro 21.11.2007., 17:43   #796
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Sličan problem imam i ja sa ludim turcima..koju god instancu da igram,oni trabunjaju nešto na alahovskom..i tako gulcum,yesrem,aldi..itd. itd. itd.....a ja se derem brate,heaaaaal!!!...nitko ne hebe 1%...mislim da ću i ja pomalo emigrirat..
Staro 21.11.2007., 17:48   #797
DevNull
Spam Witch
DevNull's Avatar
Lokacija: Belišće
Postovi: 94
Ako me pamcenje ne vara paske ti je igrao Bullrocka
Staro 21.11.2007., 20:44   #798
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Yep - Bullrock - GM Dark Side
kasnije sam zarolao Warriora koji je postao main
Staro 22.11.2007., 14:58   #799
tskarda
tskarda's Avatar
Postovi: 1,125
aa sjecam te se
Staro 22.11.2007., 18:33   #800
Paske
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Pajdaš moj i dalje igra Paskea, ali nekak mi se čini da je lik pao u kvaliteti od kad me nema
Možda se vratim za ekspanziju - ovisi o AoC i WAR.
Staro 29.11.2007., 02:11   #801
tskarda
tskarda's Avatar
Postovi: 1,125
Guzva danas u igri, Arena season 1 gear za honor pointe, svatko si je nabavio nesto.
cijene enchanta i gemova skocile
moja mula zaradila 600g samo s arcane dustom preprodavajuci. kupio jucer, prodao danas.
Staro 29.11.2007., 13:24   #802
Demon Hunter
Postovi: 999
Zato sam ja još prije 2 tjedna napunio AH sa matsima vrijednosti 1.5k golda
Što za moj novi gear, što za prodaju.
Staro 30.11.2007., 11:31   #803
flare
mrzi zimu
flare's Avatar
Lokacija: behind blue eyes
Postovi: 318
kako ja mlatim pare s arcanit barovim, to nije normalno ...mislila sam da to vise nikome ne treba, no izgelda da sam se prevarila
But it also breeds creation
RHCP
Staro 30.11.2007., 12:43   #804
thedream
thedream's Avatar
Postovi: 5,458
Autor flare Pregled postova
istina..svakom paladinu ti za epic mount q,onaj dvodijelni,na lv60..treba 6 arcanite barova..ako se ne varam,40 runeclotha..5 strat. holy watera itd...za drugi dio 150g za početak..
Staro 05.12.2007., 01:08   #805
Lihto
Lihto's Avatar
Postovi: 3,945
Jel netko može preporučit neke instance za grupu gdje ima nekih 5x40-45lvl?
iPhone XR 128gb
Staro 05.12.2007., 09:19   #806
veve
woot!!!
veve's Avatar
Postovi: 2,498
Autor Lihto Pregled postova
Uldaman, Zul'Farrak, Maraudon
veve je offline   Reply With Quote
Staro 05.12.2007., 09:59   #807
thedream
thedream's Avatar
Postovi: 5,458
Sunken Temple..ako ste polako preko 45..
Staro 09.12.2007., 14:58   #808
Stormbreaker
Stormbreaker's Avatar
Postovi: 527
Tek sam počeo igrati WoW i trebao bih odgovor na par po malo glupih pitanja (meni nisu glupa ali većini vas jesu)...Dakle, kada izvršim quest, što trebam napraviti da bih dobio nagradu?
I mogu li promjeniti kameru, da na lika gledam iz malo daljeg?
I gdje mogu vidjeti koji sam level, kada stisnem C, prikaže mi attack, defend etc., ali ne vidim nigdje da piše LVL..
Stormbreaker je offline   Reply With Quote
Staro 09.12.2007., 16:38   #809
brentaal
Postovi: 298
Nagradu u većini slučajeva dobiješ kod istog NPCa koji ti je i dao quest, no često to ne bude tak'. Ako moraš nekome drugome predati quest, onda će ti biti naznačeno u quest logu (kratica za quest log je L ak' se ne varam). Ima i pregršt sajtova sa bazama svih questova, itema te svega i svačega iz igre, pa možeš i na njima provjeriti gdje je quest NPC (wowhead.com). Samo upiši naziv questa u search box i brzo ćeš pronaći svoj quest, a uz informacije o njemu će tamo biti i komentari ostalih playera... Pa tak' možeš npr. saznati dal' se isplati raditi quest, dal' ima neki bug, neka caka, itd...
Kameru možeš približiti i udaljiti putem mousewheela, a može se i podesiti koja je najveća udaljenost putem Interface Options izbornika. Level ti piše pokraj avatara tvog lika (lijevi gornji kut) ako si izvan borbe.
Staro 09.12.2007., 17:55   #810
Stormbreaker
Postovi: 527
Hvala na odgovoru!
