Staro 30.11.2008., 17:20   #721
vercetti
vercetti's Avatar
Datum registracije: May 2003
Postovi: 1,226
12) COMMAND LINE PARAMETERS
Graphics:
-renderquality: Set the render quality of the game. (0-4)
-shadowdensity: Set the shadow density of the game. (0-16)
-texturequality: Set the texture quality of the game. (0-2)
-viewdistance: Set the view distance of the game (0-99)
-detailquality: Set the detail quality of the game. (0-99)
-novblank: Disable wait for vblank (No Vsync)
-norestrictions: Do not limit graphics settings
-width: Set width of main render window (default is 800)
-height: Set height of main render window (default is 600)
-safemode: Run the graphics in the lowest setting possible
-frameLimit: Limit frame to interval of refresh rate
(ex If refreshrate is 60HZ –frameLimit 1 = Locks down to 60HZ)
-refreshrate: Set the refresh rate of main render window
– Warning - Monitor must support (ex. –refreshrate 60)
-fullscreen: Force fullscreen mode
-windowed: Force windowed mode
-availablevidmem: Set amount of physical Video Memory(ex. –availablevidmem 0.9)
-percentvidmem: Percentage of video memory to make available to GTA
Postoje naredbe za dodatno smanjivanje detalja i kojekakvih efekata, tako da jos ima nade za nas koje posjedujemo kalkulatore od racunala
Nece biti neka grafika, al bitno da igramo lol
vercetti je offline   Reply With Quote
Staro 30.11.2008., 17:28   #722
Bang
Datum registracije: Mar 2008
Postovi: 167
Autor Željac Pregled postova
o prelasku na konzolu (tocnije ps3) sam i ja razmisljao.
dovoljno je sredeno da se igraju pucacine iz prvog lica u mp-u i to je dovoljno.
jedino bi sredio komp da moze pokrenut diabla III ( sto ce vrlo vjerojatno i moci), i imat ga radi muzike, surfanja itd.
za igranje bi bila plejka tu.
a, o gta IV ne mogu niti pomisliti na ovoj masini !
(nazalost )
kužim te ali uz plejku treba i dobra telka dakle još minimum 3000 kuna. a što se tiče gta.nije mi jano da tim debilima daju da prave takvu igru.to je navodno drugi dio rockstara ili tak nešto.neulazim baš u to puno.dio koji je napravio bully. ako bude ko bully neće se dobro provesti.
frend će kupit odma original.predbilježio se.pa kad vidim kod njega kako to ide možda ju i ja kupim. bumo vidli
Bang je offline   Reply With Quote
Staro 30.11.2008., 21:08   #723
xEnomania
xEnomania's Avatar
Lokacija: Purger city
Postovi: 109
neam komentara
You called down the thunder.
xEnomania je offline   Reply With Quote
Staro 30.11.2008., 22:24   #724
chingyos
chingyos's Avatar
Postovi: 375
Autor xEnomania Pregled postova
neam komentara
Valjda ce biti za medium igranje
chingyos je offline   Reply With Quote
Staro 30.11.2008., 23:32   #725
Mad_Duke
LOL
Kakve su to fore
Pa to je "program" koji ima kod sebe najvjerojatnije onaj isti popis koji smo ovdje vidjeli vec sto puta i samo ti kaze koliko "score" imas!
Da skratim pricu. Klonite se tih gluposti!
Staro 01.12.2008., 00:08   #726
vercetti
vercetti's Avatar
Postovi: 1,226
Staro 01.12.2008., 01:27   #727
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Dobar strip
Staro 01.12.2008., 02:35   #728
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Prema onome sta mi kazu na canyourunit.com, morat cu mijenjat grafu... :P
Staro 01.12.2008., 02:42   #729
Mad_Duke
Stripovi su svjetski
Staro 01.12.2008., 03:00   #730
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Valjda će bit do srijede u prodaji
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 01.12.2008., 10:37   #731
vercetti
vercetti's Avatar
Postovi: 1,226
Eurogamer review
Novi review, ocjena 9/10
Staro 01.12.2008., 10:43   #732
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,778
Autor vercetti Pregled postova
Eurogamer review
i opet sam baš to htio postat, i opet ti prije
xGAME je offline   Reply With Quote
Staro 01.12.2008., 11:27   #733
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Odmah upozorenje - bez priča o tome gdje je izašao, kako se skida, koja verzija je ok itd. Mislim da se razumijemo i da nitko ne želi nepotrebne banove i slično.
Staro 01.12.2008., 12:21   #734
R2D2x2
Postovi: 152
mene samo zanima kad to dolazi kod nas u ducane i po kojoj cijeni
gledam sad po algoritmu i debili prodaju san andreas za 430kn (pc verzija) pa mogu mislit koliku ce konzolasku cijenu nabiti na GTAIV...
R2D2x2 je offline   Reply With Quote
Staro 01.12.2008., 12:24   #735
chingyos
chingyos's Avatar
Postovi: 375
Autor R2D2x2 Pregled postova
Strasno da ta stara igra moze kostati 430 kn nek se ubiju
Inace trebala bi doci oko 300-350 kn toliko dođu PC igre
Zadnje izmijenjeno od: chingyos. 01.12.2008. u 12:24. Razlog: .
Staro 01.12.2008., 12:38   #736
Beo
Lokacija: United Kingdom
Postovi: 512
A jel ima da se jos vise povecaju detalji?
Šalu na stranu
Inace GTA SA nisam mogo smislit, bio mi je katastrofa. Tako da ovaj nastavak s iscekivanjem ocekujem
EDIT:
Nisam bas u toku, pa jel mozda zna netko jel ce ga bit moguce uzet preko steam-a?
Zadnje izmijenjeno od: Beo. 01.12.2008. u 13:05.
Beo je offline   Reply With Quote
Staro 01.12.2008., 13:12   #737
chingyos
chingyos's Avatar
Postovi: 375
Autor Beo Pregled postova
Šalu na stranu
EDIT:
Tebi ce extra radit super konfa
Staro 01.12.2008., 13:14   #738
Bang
Postovi: 167
Šalu na stranu
EDIT:
mislim da se može preko steama.
Staro 01.12.2008., 13:24   #739
vercetti
vercetti's Avatar
Postovi: 1,226
GTA 4 PC gameplay na najmanjim mogucim detaljima
http://uk.youtube.com/watch?v=kMYsaFDckY4
Staro 01.12.2008., 13:50   #740
Bang
Postovi: 167
previše zblurana...definitivno
Staro 01.12.2008., 15:13   #741
junkieee
junkieee's Avatar
Postovi: 994
meni igra dolazi sutra ujutro, nadam se da cu je moc vrtit na svom kompu...Ako ne izlgeda da mi placa ode na novi komp
Staro 01.12.2008., 15:15   #742
chingyos
chingyos's Avatar
Postovi: 375
Autor junkieee Pregled postova
Ode placa
Staro 01.12.2008., 15:24   #743
Beo
Postovi: 512
@chingyos:
Thx
Utuko dusu i krv u taj komp i drag mi je ko da mi je dijete
@vercetti:
Legendo! Jesam se nabrio i onda vidim filmic i pras u smijeh.
@Bang:
Thx.
Jos cu provjerit pa ako ima uzimam tako a ako nema zna se
EDIT: Eto ima na steamu! Release date: 37 sati od kad sam ovo stavio :P
Zadnje izmijenjeno od: Beo. 01.12.2008. u 15:55.
Staro 01.12.2008., 16:24   #744
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
izasao je... ima ga vec i u internet ... trgovinama ...
i na streamu
~Kaiser_Chief~ je offline   Reply With Quote
Staro 01.12.2008., 16:28   #745
chingyos
chingyos's Avatar
Postovi: 375
Autor pcgameanalyser Pregled postova
i na streamu
Mozda u svijetu ali kod nas sigurno nema u trgovinamatko zna kada ce doci...iako i ovi sto imaju tek ce moci za jedno 8 h pokreniti igru
Staro 01.12.2008., 16:32   #746
vercetti
vercetti's Avatar
Postovi: 1,226
Staro 01.12.2008., 17:18   #747
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
oš reč da si naručio iz amerike , hehe
trebo sam i ja tak, evo meni ovo poslalo...
Dear Mr Klen,
Order number(s):xxxxxxxxx
I am delighted to let you know that your Preorder for Grand Theft Auto IV is now being processed subject to successful payment being taken from your credit card when it is dispatched. The order will be despatched by your chosen delivery method in time to reach you for the day of release.
By using the GAME 1st To Play Preorder Service you have ensured that you will be among the first people to receive Grand Theft Auto IV, and we are confident that you will be happy with the order, our service and our speedy delivery!
znači trebalo bi stič 3.12.
ja sam se nekak više nadao da če stiči drito za svetog nikolu...
Pizz je offline   Reply With Quote
Staro 01.12.2008., 17:22   #748
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
pa bolje da stigne prije... evo meni dolazi za oko 8 sati.. bilo je receno da ce prije, ali ne prije 3.
Staro 01.12.2008., 18:16   #749
EvilM@ster
Ev1LMa5ter
EvilM@ster's Avatar
Lokacija: Koprivnica
Postovi: 675
taman stegno remen a ono banana izgleda da cemo za Bozic u kupnju nove pile .....
EvilM@ster je offline   Reply With Quote
Staro 01.12.2008., 18:21   #750
Lihto
Lihto's Avatar
Postovi: 3,945
nešt si pobrkao..da nepališ ekipu evo šta piše na steamu...
GTA4
Available: December 2nd, 2008
This game will unlock in approximately 1 day and 8 hours
iPhone XR 128gb
