#7411 |
MiningMod
Postovi: 8,715
Mozes ovako "malo" poboljšati 1 x Procesor AMD FX X6 6300 3.5Ghz (4.1GHz) box 1 x LC POWER LC-CC-95, socket 775/1155/1156/AMD 1 x GIGABYTE GA-970A-DS3P, AM3+ 1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11 1 x Seagate HDD, 1TB, 7200rpm, SATA 6, 64M 1 x MSI Video Card Radeon R9 280 GAMING GDDR5 3GB/384bit 1 x Zalman Z3+, USB3.0 black 1 x Fortron Hyper 500W, 80+ Ukupno: 4908,00 kn |
#7412 |
Datum registracije: Dec 2014
Postovi: 4
Super, hvala. |
#7413 |
Datum registracije: Mar 2011
Postovi: 2,707
Stane FX 8320 ![]() Thermaltake Hladnjak za procesor, Thermaltake Contac 21 AMD FD8320FRHKBOX, FX Series X8 8320 CPU XFX R9-280A-TDFD, DD Radeon R9 280 933M 3GB DDR5 2xmDispayPort, HDMI, 2x DVI Sharkoon VS3-V Chrome Tower ATX kućište, bez napajanja, crno XFX-P1-550S-GREN 550W Power Supply Black Edition, Bronze Certified, Full wired Gigabyte GA-970A-DS3P Seagate ST1000DM003, 1TB, 7200 rpm, 64MB, SATA 6Gb s, Barracuda The Power of One Patriot Sig.,D3, 1600Mhz, 8GB (1x 8GB) Iznos: 4.937,35kn |
#7414 |
Datum registracije: Jun 2014
Postovi: 23
Moze gaming konfa za 3500 kn.Bez periferije. |
#7415 |
MiningMod
Postovi: 8,715
1 x AMD Athlon X4 860K, Black Edition Kaveri (3.7GHz,4MB,95W,FM2+) box 1 x LC POWER LC-CC-95, socket 775/1155/1156/AMD 1 x Asrock FM2 FM2A88M EXTREME4, mATX 1 x Crucial 4GB DDR3 1600 Mhz (PC3-12800) CL11 1 x Seagate HDD, 1TB, 7200rpm, SATA 6, 64M 1 x Gigabyte GV-R726XWF2-2GD, AMD Radeon™ R7 260x, PCI-E 3.0,2048MB GDDR5 1 x SILVERSTONE Strider ST40F-ES 400W, 1x120, 80+ 1 x Raijintek Arcadia, USB3.0, black 3500kn |
#7416 | |
Postovi: 4
#7417 | |
Postovi: 14,578
![]() jesi vidio 3 posta iznad? Nema neke razlike trenutno u gamingu (pogotovo mainstream grafom), osjetio bi eventualno u MP BF4 i sl... |
#7418 |
Postovi: 4
Vidio sam, zato i pitam jer vidim da je Smartic spomenuo taj procesor, ali je promijenio neke komponente. Mene zanimalo jel ide u onu konfiguraciju koju je stavio FRipper taj procesor. Ali ako nema neke razlike onda ostaje ova koju je FRipper složio, hvala. |
#7420 |
Postovi: 14,578
amd - jer dobiješ bolji cpu za nove i buduće igre, od intela bi te mrvicu jeftinije izišao i3 za takav buđet. Procesor AMD X6 FX-6300 Matična ploča Gigabyte GA-970A-DS3P,AM3,A970,D3,S3,U3,A Spire Kepler Rev.2 hladnjak 115X/775/AM2-3/FM1-2 Crucial Module 8GB, 240-pin DIMM, DDR3 PC3-12800, CL=11, Unbuffered, NON-ECC Grafička kartica XFX AMD Radeon R9 270A 2GB DDR5, XFX-R9-270A-CDFC Toshiba DT01ACA100 1TB 3.5'' CORSAIR Power Supply, Builder Series CX 80+ Bronze, 430 Watt, ATX, EPS12V, PS/2, EU Version MS PHOENIX kućište bez napajanja 4056kn izbačena pržilica (os možeš i sa usb-a snimit) edit - na kartice ide 8% gore u ovim primjeru, onda samo zamjeni grafičku za gtx 750 ili 260x, hard od 500gb, eventualno 4gb rama... |
#7422 |
Postovi: 2,707
Napajanje FORTRON Hexa Plus, 400W, 80+, active, 12cm Kućište SHARKOON VG4-S, bez napajanja, crno Tvrdi disk 500 GB, SEAGATE Barracuda ST500DM002, 3.5", 7200 rpm, SATA III Memorija A-DATA 4 GB DDR3, 1600 MHZ DIMM, bulk Grafička kartica XFX AMD Radeon R7 260X,1GB DDR5 Procesor Intel Pentium G3258, 3.2 GHz, Socket 1150 Matična ploča MSI H81M-P33, socket 1150 Ukupna cijena: 2.995,65 kn |
#7423 |
Lokacija: u mraku
Postovi: 846
Hvala. Biti ce slicno. Sad sam bio u trgovini. napajanje ce biti xilence eco 450w i 1tb toshiba. Tako je ispalo .ono sto su imalo na stanju smo stavili, a da bude u budjetu.komp treba hitno veceras, riknio stari lap, a treba zavrsiti nesto danas i sutra u cadu... Zadnje izmijenjeno od: snorky_vk. 19.12.2014. u 23:42. |
#7424 |
Lokacija: Poreč
Postovi: 29
Pozdrav ekipa, evo prijavio sam se na forum po preporuci prijatelja koji mi je rekao da mogu vas pitati za savjet u vezi slaganja konfiguracije. Pa da krenem. Grafička(HD4870 1GB) mi je vrisnula ko gica pred kolinje i sad sam na mukama jer ne mogu zaigrati apsolutno nikakvu igru osim briškule ![]() 1-KUČIŠTE -Thermaltake soprano DX 2-HARD -Toshiba DT01ACA100 750 GB 3-PROCESOR -Intel core 2 Duo E8500 3,16 Ghz 4-MATIČNA -Gigabyte X48-DS4(Chipset beachwood)775 5-MEMORIJA -OCZ 2Raper 2x2 gb ocz2rpr10662g 6-GRAFIČKA -Radeon HD4870 (1gb) RU770XT 7-NAPAJANJE -Chiftec CFT-750-14 8-MONITOR -Dell P2414H 9-HLADNJAK VGA-Setsugen 2 (star 1 mjesec ![]() Znači, treba mi pomoć oko slaganja a budžet je cca 4000-5000 kn, bez monitora i kučišta. Molim vas da mi napišete nekoliko verzija ako nije problem. Jako se dvoumim između Nvidije i Ati-a. Do sad sam imao Ati navedenu karticu koja nikad nije imala problema i sad nakon 6 godina, otišla je u zasluženu mirovinu. Također se dvoumim da li da mijenjam i napajanje ili da ga ostavim pošto radi.Ako može, napišite mi verzije s INTELOM i AMD-ovom matičnom i procom i navedite mi prednosti i mane. Ispričavam se na ovako dugačkom postu ali gori mi pod nogama. HVALA unaprijed na pomoći. LP ![]() P.S. Ako može, navedite mi koliko bi se moglo dobiti novaca kad bi isao prodati ove postojece komponente preko njuškala. Naravno osim ove grafičke koja ne radi za sve osim za internet :P Zadnje izmijenjeno od: eXactMat. 17.12.2014. u 20:41. Razlog: dopuna |
#7425 |
Postovi: 2,707
Ja bih zadržao i disk, a gore staviš SSD. Ako ti je WoT primarna igra, svakako Intel. Patriot Sig.,D3, 1600Mhz, 8GB (1x 8GB) PSD38G16002 Patriot SSD Blaze R545/W430, 120GB, 7mm, 2.5" Procesor Intel Core i5 4460 Matična ploča ASRock H87-PRO4, 1150 Grafička kartica Gigabyte Radeon R9 280 WF3 OC, 3GB GDDR5, HDMI, DVI XFX 550W Easy rail Bronze, XFX-P1-550S-GREN =4.999kn Bez napajanja je to ~4550kn, iako je tvoje dosta staro, na papiru ovo odrađuje s pola snage. Trebalo bi biti u redu... Stare komponente: CPU: 200-250kn Matična: 250kn RAM: 250kn |
#7427 | |
Lokacija: Zagreb/Križevci
Postovi: 346
#7428 |
MiningMod
Postovi: 8,715
#7430 |
Datum registracije: Aug 2014
Lokacija: Slavonija
Postovi: 84
GTX ti trosi manje struje i koliko sam cuo, pretjerano se ne grije dok radeonka trosi vise struje i ponovno, kako sam cuo, dosta se zagrije. Gledao sam sad na googlu malo i vidio da gtx-ica daje i vise fps-ova ^koliko ti je ovo pomoglo ne znam ;D :P ali ja bih osobno isao na gtx-icu ali mozda neki jeftiniji model. ![]() ![]() ![]()
3.2.2015.-"Reći ću vam samo jednu stvar - zapamtite VukoWar" |
#7431 |
Postovi: 14,578
970 je malo jača, troši drastično manje struje (možeš koju kn uštedjeti na napajanju, za 290 bi bilo najpametnije 650w kvalitetno ili jače), ima više featurea i sl... Minus joj je izvjesniji coil whine... r9 290 je osjetno jeftinija, asusova je OK, cooler je dobar (tj. ne pregrijava se), pa sam odluči što ti se isplati |
#7432 | |
Lokacija: Poreč
Postovi: 29
#7433 |
Postovi: 14,578
a ovisi od igre do igre. Tako da je relativno to dal bi osjetio (također imaš i posebne nvidia grafičke feature). Najbolje da si pogledaš neke testove, al ovako u globalu, što se tiče samih perfomansi - nije velika razlika |
#7434 | |
Lokacija: Poreč
Postovi: 29
Proc: i5 4690k Matična: GA-Z97-D3H Grafička: ASUS R9 290 DIRECT CU II OC 4 GB Memorija: Kingston hyper x fury black 1866 mhz 2x4 gb Napajanje ostaje moje chiftec 750 koji sam naveo prije u postu Kučište ostaje moje thermaltake soprano dx S tim da kroz mjesec, dva mislim uzeti drugo kučište i napajanje, ali prvo da prodam ove moje komponente i da legne nova plaća. Evo trebam brzo mišljenje o ovome navedenom. Hvala i LP |
#7435 | ||||
Postovi: 14,578
Napajanje nije cvijeće, al trebalo bi raditi. Na papiru ima i više nego dovoljno snage... Samo provjeri dal ti stane u case grafa, ta asusica je 28.7cm EDIT - stane s micanjem hdd cagea
#7437 |
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 590
moj prijedlog ti je da uzmes zalman z3+ ili recimo zalman r1 koji su oko 300kn. uzmi jeftiniju graficku (usparaj 600kn) i imas za novo kuciste. nek ti ekipa u ducanu sastavi kupljene komponente, a iduci mjesec sam ubacis novo napajanje. |
#7439 |
Lokacija: somewhere
Postovi: 565
Pozdrav, treba mi preporuka za konfiguraciju. Neki budžet mi je do 4 - 4,5 tisuća kuna. Glavna zadaća kompa je obrada video materijala HD ali i 4K HEVC. Ovo drugo me u biti najviše muči koliko bi komp za te pare mogao obavljati takvu zadaću pa ako može preporuka od nekoga tko ima iskustva sa istim. Pretpostavljam da bi tu trebala neka jača mašina? Ono što bi još bilo dobro je da grafička ima video izlaze da se danas-sutra može priključiti i na TV (neki hdmi izlaz bi valjda tu trebao?) te da je komp što tiši jer osoba koja će raditi na njemu će ga držati u spavaćoj sobi i vjerojatno će nekad ostati i upaljen preko noći pa da se ne čuje. Što se igrica tiče - nula bodova, sigurno se neće nikada nikakva igrica instalirati na to. Monitor, tipkovnica, miš - ne ulaze u gornju cijenu. Ako netko može pomoći i zna 100% da će konfiguracija koju složi biti adekvatna za takvo što (osobito naglavašavam za 4k hevc obradu) molio bi da napravi neku konfiguraciju do 4 - 4,5 tisuće kuna. Hvala ![]() |
#7440 |
MiningMod
Postovi: 8,715
1 x Intel Core i7-4790 Soc 1150 CPU 1 x ASRock B85-PRO4, 1150 1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11 1 x MSI Video Card GeForce GT 740 GDDR5 2GB/128bit 1 x SEAGATE HDD DESKTOP SSHD 3.5" / 1TB / 64m/ SATA/ 7200rpm 1 x Optički uređaj Samsung SH-224DB SATA Bulk Crni 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x Fortron Hexa+ 400W, 80+, active, 12 cm 5600 kn + kasnije ako bu potrebe dodati još 8gb rama... |
