#7351 |
Datum registracije: Feb 2011
Lokacija: Dubrovnik
Postovi: 55
Nego ima li tko prijedlog za Intel ekvivalent? Predpostavljam neke midrange i5-ce? S odgovarajucom MBO. |
#7352 |
Datum registracije: Mar 2011
Postovi: 2,707
1 x Procesor Intel Core i5-4460 (3.20GHz,1MB,6MB,84 W,1150) Box 1 x Asrock H81M-HDS, s1150, Intel H81, M-ATX, Dual Channel 2xDDR3 1 x DDR3 8GB (1x8GB) Crucial, 1600MHz CL11 1 x Zalman Z1 mid tower case. 199(W)x432(H)x457(D)mm. MB standard 1 x HDD Seagate 1TB, Serial ATA III, 7200 rpm, ST1000DM003 1 x Napajanje XFX TS Series 550W PSU -P1550S-XXB9 1 x Intel 120GB SSD 520, 2.5", SATA III-600, R/W:550/520MB/s 1 x XFX R9-280A-TDFD, Double Dissipation Edition Radeon R9 280 933M 5.544,20Kn |
#7353 |
Datum registracije: Nov 2014
Postovi: 3
Imam budžet od 4500kn, treba mi konfiguracija iz future. Hvala unaprijed! |
#7355 |
Postovi: 3
#7356 |
MiningMod
Postovi: 8,715
1 x Procesor AMD FX X6 6300 3.5Ghz (4.1GHz) box 1 x LC POWER LC-CC-97, socket 775/1155/1156/AMD 1 x GIGABYTE GA-970A-DS3P, AM3+ 1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11 1 x MSI R9 270X GAMING, 2GB GDDR5 1 x TOSHIBA DT01ACA050 (3.5", 500GB, 32MB, SATA III-600) 1 x Optički uređaj LG GH24NS SATA Bulk Crni 24x 1 x Fortron Hexa+ 500W, 80+ 1 x MS PHOENIX kućište bez napajanja 1 x Xilence hladnjak za kućište 80×80×25mm, crni (3-pin Molex + 4-pin) Ukupno: 4525,99 kn |
#7357 | |
Postovi: 10
Dakle dobio sam ponudu od ovog poznanika koja je sasvim prihvatljiva, covjek ce mi sve fino slozit, pomoc i uvijek bit pri ruci Evo ponude: CPU AMD A10 X4 7850K AMD A10 X4 7850K, Socket FM2+, Radni takt 3700 MHz, L2 cache 2x 2 MB, Jezgra Kaveri, Hladnjak da, Integrirani ... MBO FM2+ ASR FM2A88M EXTREME4+ FM2A88M EXTREME4+, FM2,FM2+, AMD A88X (Bolton-D4), DDR3, Broj utora 4, 1600,1866 MHz, PCI 1, PCIe x16 1, PCIe MEM DDR3 4GB x2 1600MHz XMP HyperX Savage KIN DDR3 4GBx2 1600MHz XMP HyperX Savage, Latencija CL9, Napajanje 1,5 V, XMP HyperX Savage HDD INT WD 10PURX WD Purple 10PURX, 1000 GB, SATA3, 64 MB, 3,5", Intellipower rpm CAS TT Versa II Versa II, Midi tower, ATX,mATX, 5,25" vanjski utor 3, 3,5" vanjski utor 1, 3,5" unutarnji utor 5, USB 2.0 1 PSU MSI LOGIC 600W ATX 2.2 + kabel Napajanje LOGIC 600W ATX 2.2, 600 W, pasivni PFC, Hlađenje 12cm ventilator, 24-pinski konektor 1, ATX12V 1, SA ... MON 23 AS VX239H IPS, Slim, HDMI x2 sa zvučnicima VX239H, 23", 16:9, 1920x1080, 250 cd/m2, 80.000.000:1, 178 °, 178 °, 5 ms, D-Sub,HDMI, Po ... Cijena: cca 4900kn Jos jednom, kompjuter nije za gaming nego za internet i upotrebu raznih programa za audio i video obradu (FL Studio, neki video editori za mene i racunovodstvo za majku), mozda tu i tamo nesto pokrenem od igrica i ak ce ikad trebat mozda stavim VGA, ali zasad je dovoljna ova integrirana za dostojno editanje Btw, napajanje u ponudi je ocajno po mom misljenju, to ce se valjda ispravit (preporuke?) I da, u budgetu jos uvijek imam nesto para, razmisljam o ssdu, neke preporuke za 600-700kn ssd? Sto mislite o svemu ovome? Svi savjeti su dobrodosli. |
#7358 | |
Postovi: 3
#7359 | |
MiningMod
Postovi: 8,715
kupi šta hoćeš ![]() p.s. reci tim poznanicima da se upucaju ![]() |
#7360 | |
Postovi: 10
![]() Gledao sam i cijene i sve valja, sve je tu negdje, oni su mozda malo skuplji Amd a10 sam detaljno proucio i ne znam sto mu fali ako je u tome stvar... |
#7361 |
Postovi: 14,589
fx 6300 je bolji proc, u isto lovu ti još stane puno bolja zasebna grafa pa ne vidim kako je to bolje, dobiješ loše napajanje, neisplativ case, neadekvatan hdd i sl... Nedaj da te valjaju kojekakvi likovi, ne kupuješ pc svaki dan. Mislim ne vidim problem da povedeš staru u neki normalan shop koji se time bavi - pogotovo kad si iz zagreba, čist račun duga ljubav, nego se držat kojekakvih likova. Imaš besplatno sastavljanje u takvim shopovima, u pravilu besplatnu dijagnostiku 1 god. i garanciju na svaku komponentu (2,3 ili 5 god.) |
#7362 | |
Postovi: 10
Covjek kaze da si trgovina zaradi 200kn, majka mi odma kaze da ne davim za tu lovu, a i svaku cijenu sam pogledao ispadne tolka cijena recimo na admu ili bilo kojem drugom web shopu Mozete li mi preporuciti koju grafu bih stavio uz fx 6300 (ne treba mi mrcina neka), napajanje ce se svakako promijeniti, za hdd pretpostavljam da bi trebao biti black a ne purple, a case bi recimo bio zalman z1, a neka preporuka za ssd? Covjek je fleksibilan, dogovorit cemo se, ne treba ga odma osudivat P.S okolica sam Zagreba, tak da nije bas samo tak doc do trgovine u zgu |
#7363 |
MiningMod
Postovi: 8,715
@lovrom23 Zadnji put... Složim ti, ti to isprintaj i odi kod tog lika, lupi papirom o kasu i reci OČU TO!!! NIŠTA DRUGO, TOOOO! p.s. slažem ti tako da nemre reči da on to nema i ne može nabaviti PROCESOR: AMD FX 6300, AM3+ HLADNJAK: Spire kepler, TT Contact, Zalman Performa...bilo koji od 100-150kn MATIČNA: Asrock Extreme 3, Gigabyte 970 DS3P pa čak ako i nema tih imaš Pro3 MEMORIJA: najeftinija 2x4 ili 1x8gb ddr3 1600mhz DISK: Wd blue 1tb ili Seagate 1Tb GRAFIČKA: ATI radeon R7 250x ili 260 ili 260x ili GTX 750 NAPAJANJE: Corsari CX 430, Fortron Hexa/Hyper 400/500, Xilence RedWing 480W, Enermax 500W, TT Smart SE 530W KUĆIŠTE: Svejedno...neko jeftinije koje ti se sviđa izgledom Z1 je pravi izbor ako imaju... A ako ostane love, onda tek uzmeš SSD 120gb obavezno... *Ako kojim slučajem nema FX6300 Onda opcija najeftiniji Intel I3 na 1150 socketu + bilo koja H81/B85 ploča i onda izbaciš hladnjak jer za intela ti ne treba dodatni i orginal je okp.s. ne osuđujem nikoga, ali malo mi je smiješno da netko tko prodaje računala ne zna napraviti poštenu preporuku... Zadnje izmijenjeno od: FRipper. 27.11.2014. u 22:31. |
#7364 | |
Postovi: 10
![]() Kolko je cca cijena tog builda i sto mislite o mom monitoru? I da, neki odredeni ssd? Nisu svi bas iste kvalitete, neki od 600-700kn? |
#7366 |
Postovi: 10
#7367 |
Datum registracije: Apr 2013
Postovi: 1,336
ne bi smjelo bit više..evo i moj glas za konfu od Frippera, ono gore što ti je lik preporučio je smiješno..nit za igre nit za net..ništa..konfa koju su ti dečki složili je puno bolja za apsolutno svaku primjenu...a ako je ono gore konfiguracija za video obradu onda je moja konfa za simulacije svemirskih letova ![]() |
#7368 |
Postovi: 73
Pozdrav, treba mi neka konfa koja bi prvenstveno bila za: * Programiranje - više otvorenih alata, Visual Studio, instalirano više SQL servera, baza ... * Igranje NBA2K15, FIFA15 - ništa osim toga Dakle mislim bar 8GB rama, neku matičnu za eventualno kasnije nadograđivanje komponenti.. Naravno, što jeftinije moguće... Hvala |
#7369 |
Postovi: 430
1 x Intel Core i5-4460 Soc 1150 1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11 1 x Asrock H81M-HDS, Sck 1150 1 x HDD SEAGATE Barracuda (3.5",1TB,64MB,SATA III) 1 x Optički uređaj LG GH24NS SATA Bulk Crni 24x 1 x Zalman Z1, USB3.0 black, 2x120mm 1 x Fortron Hyper 500W, 80+ 1 x MSI R7 260 OC, 1GB GDDR5, VGA, DVI, HDMI Ukupno: 4316,00 kn |
#7371 | |
Postovi: 73
Da li može i MSI 260X R7 2GD5 OCV1 čisto da i 2k16 bude radio? i još neki SSD 120 GB |
#7372 | ||
Postovi: 1,336
te sportske igre su relativno nezahtjevne i ne trebaju neke jake kartice..ali ako ti stane u budžet samo daj za SSD su Intel i Samsung uglavnom top preporuke |
#7377 |
Postovi: 430
A koje je kućište? |
#7379 |
Postovi: 430
1 x Intel Core i5-4460 Soc 1150 1 x Asrock H81M-HDS, Sck 1150 1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11 1 x HDD Desktop TOSHIBA DT01ACA050 (3.5", 500GB, 32MB, SATA III-600) 1 x Fortron Hyper 500W, 80+ 1 x MSI Video Card Radeon R9 280 GAMING GDDR5 3GB/384bit, 827MHz/5000MHz, PCI-E 3.0 x16, 2x miniDP, HDMI, DVI-I, Double Slot), Retail Ukupno: 4813,00 kn Pržilicu nisam stavio, windowse snimi s USB. |
#7380 |
Datum registracije: Mar 2008
Postovi: 94
Ili ako može i kučište se ugurati do 5000kn stom kombinacijom? |
