#7021 |
trpi, trpi...
Datum registracije: Oct 2019
Lokacija: CRO
Postovi: 110
A to zen3 ide isto na am3? |
#7022 |
Lokacija: Zd
Postovi: 4,754
#7023 |
trpi, trpi...
Lokacija: CRO
Postovi: 110
Dražesno od AMDa ako bude tako. |
#7025 |
Samo ne treba gledat Škotove monologe ili ih ne uzimati ni najmanje za ozbiljno ![]() A mislim da je i sam naučio tu lekciju da bude sa taktovima jako oprezan ubuduće, Očekujem iste taktove sa porastom IPC-a. |
#7026 | |
Datum registracije: Apr 2017
Postovi: 343
Ne bi baš rekao, to je izjavio AMD VP, Forest Norod, a on sigurno ne lupa bezveze kao Škot, dakle; 8 jezgreni CCX na chipletu sa duplo večim cacheom, manje latencije, itd...citiram: The Zen 3 microarchitecture is around the corner, and AMD is setting expectations high. Last month, a rumour started on ChipHell forums claimed that an early Zen 3 engineering sample could deliver about 8% IPC gains over comparable Zen 2 chips, but the reality may be even greater. In a far-reaching interview with The Street, Forrest Norrod, GM of AMD's Datacenter and Embedded Solutions Business Group, explained the changes that AMD has made with Zen 3. Norrod started by clarifying that Zen 2 represented an evolution of the original Zen microarchitecture, but that it had delivered higher than expected IPC gains because AMD had brought ideas that it had not been able to implement in Zen to Zen 2. By contrast, he claimed that AMD has started anew with Zen 3. According to The Street, Norrod reported that AMD expects around 15% IPC gains from evolutionary upgrades like Zen 2, but was coyer with the gains that Zen 3 could offer over Zen 2. He is quoted as remarking that IPC improvements will be: "Right in line with what you would expect from an entirely new architecture." As Wccftech has inferred, Norrod is implying that Zen 3 will exceed the IPC gains that Zen 2 made over the original Zen microarchitecture. The move to a more advanced 7 nm manufacturing process will help Zen 3 processors achieve "moderately higher" clock speeds too, which will help improve performance over their Zen 2 predecessors. Linkovi: https://www.notebookcheck.net/AMD-cl....444010.0.html https://www.wepc.com/news/ipc-amd-zen-3/ |
#7027 |
Lokacija: Zd
Postovi: 4,754
#7028 | |
Master Of Disaster
Datum registracije: Nov 2002
Postovi: 1,271
#7029 |
Postovi: 14,589
#7030 | |
Master Of Disaster
Postovi: 1,271
#7031 |
Postovi: 14,589
#7032 |
Postovi: 8,508
Meanwhile in other news... ![]()
#7035 |
Postovi: 14,589
#7037 | |
Postovi: 8,508
Dell may turn to AMD CPUs, expects Intel shortage to extend into H2 2020 ![]() Citiraj:
#7039 |
Postovi: 8,508
Da, ovo je grdo, ali neovisno o Intelovim R&D milijardama, nitko (čak ni Dell) ih neće čekati godinama da to možda i urodi plodom, dok se istovremeno svi okreću AMD-u i popratnoj zaradi prodajom njihovog hardvera. |
#7040 | |
Postovi: 14,589
Pa nije li njihov CEO prošle godine rekao da AMD ne dolazi u ozbiljno razmatranje? Citiraj:
A u ono doba kad je Intel mitio, oni su bili jedni od najznačajnijih na platnoj listi... I sad im malo pala primanja zbog situacije u Intelu pa bi se odmah prebacili... Koliko AMD-u uopće znači to što bi oni kupili? Ionako prodaju sve što naprave... Zamisli da im AMD sad utjera kajlu i kao Vojko Fau kaže - ne može... Naravno to se neće dogoditi, u biznisu samo para caruje. AKO dođe do toga... |
#7042 |
Postovi: 14,589
Da, ali ne vjerujem da mogu zadovoljiti sve njihove potrebe. AMD-u je (trenutno) svejedno kom će prodati ovo što prodaju... Vani baš nešto nema puno Ryzen R9 i threadrippera, ovo malo što dođe se sve rasproda. Eventualno imaju ovih entry stvari što se ne prave na 7nm (apu) za uredske konfe... |
#7045 |
Postovi: 14,589
Iako se ne radi o AMD-u gdje drugdje staviti kad je forum podjeljen po brandovima, pa eto tu: Huawei Preps Desktop PC Motherboards Featuring Up To 8 Core Kunpeng 920 ARM v8 CPUs |
#7046 |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,513
Evo ni ja neznam di bi stavio ali je jako zanimljivo povjesno "stivo" za pogledat. https://youtu.be/LTXhZnjS238 Sent from my Redmi Note 5 using Tapatalk |
#7047 |
Postovi: 14,589
Evo jedan zen3 summary video. https://youtu.be/OtlvNqH2pgA Kom je predugačko negdje poslije 2 min. prođe uvod, a summary lista je negdje mislim oko 15-16 minute... Uglavnom što se tiče clocka, kao što sam rekao ne treba očekivati ništa, jer su neki njegovi dodatni izvori rekli da se +100-200mhz odnosi na inženjerske primjerke Milana (serverski) u odnosu na inženjerski primjerak Romea u toj fazi. Budući da i njihove gotove verzije nemaju previsoke clockove očito se radi o jako niskim clockovima trenutno, pa prema tim njegovim izvorima tog porasta vrlo vjerojatno neće biti na desktop ryzenima odnosno na visokim clockovima No što je još važnije izgleda da nas čeka još jedan značajan IPC porast + spominje se kompatibilnost s postojećim pločama, no to nam ne znači previše dok se ne spominju konkretni čipseti I kaže Q4 2020, kao što sam i sam govorio da će to biti relativno kasno u godini, možda neki modeli i u 2021 |
#7048 | |
Postovi: 8,508
Early listings reveal first 8C/16T AMD Ryzen 4000 mobile APUs ![]() Citiraj:
#7049 |
Postovi: 343
AMD Zen 3 CPUs Allegedly Features 17% IPC Gain Over Zen 2 Architecture https://wccftech.com/amd-zen-3-ryzen...pc-gain-rumor/ |
#7050 |
Postovi: 8,508
CES 2020 (07.01. - 10.01.) ![]()
