21.07.2007., 20:57 | #661 |
mrzi zimu
Lokacija: behind blue eyes
Postovi: 318
...provjeri AH kako se prodaje to sto bi zeli prodati...nekad se jednostavno ne ispalti, a nekad mozes lijepo zaraditi na ah...
Destruction leads to a very rough road But it also breeds creation RHCP |
06.08.2007., 09:42 | #662 |
Postovi: 113
06.08.2007., 10:56 | #663 |
Ekspert iz sjene ...
Lokacija: New Eden
Postovi: 3,801
Pitam se dali svaka klasa može postati Death Knight i koliko brutalno gnjusno puno grinda treba za to .... Daj da vidim - pokoriti sve instance, 5 man - 40 man u roku od 10 sati za vrijeme noći bez mjesečine dok Rob Pardo leti preko Pacifika .... |
06.08.2007., 11:39 | #664 | |
woot!!!
Postovi: 2,473
- Hybrid Tank and DPS - Tanks using 2H or DW - Can only use 'bladed' weapons (known: Swords, Axes) - Referred to as "Rune Weapons" - Wears plate armor - Blend of melee and some spellcasting - Known spell: "Army of the Dead" - raises several temporary minions "Unholy Embrace" - Instant Cast. 5 min cooldown Target is embraced by a silhouette of darkness for 12 seconds, corrupting any healing spells and effects cast upon or currently affecting the target to cause damage for 50% of their healing potential instead of restoring health. Any damage shields cast upon or currently affecting the target will also be instantly consumed, dealing 50% of their absorption potential in damage. Once afflicted with Unholy Embrace, the target cannot be afflicted with Unholy Embrace again for 1 minute." - Is a Hero Class - Unlocked by an epic questline (no raids involved) at level 80 - Will allow you to start a new character as a Death Knight at a higher level (told to expect between 55 - 70). Will not overwrite previous character. - More Hero classes may be to come - will continue to be based on Warcraft III Heroes - Death Knight does not use rage or mana - will use a new mechanic, 'Runes' - Rune schools (similar to Death Knight talents) split up into Blood, Frost, Unholy - Runes are carved into the Death Knight's weapon - 6 slots total, any combination of runes (e.g. 2 of each, 4 Blood/2 Frost, 6 Unholy, etc.) - Rune cooldowns will be modified by talents taken, etc. - Certain spells will reactive runes; spells can consume more than one rune |
07.08.2007., 02:22 | #665 |
Postovi: 999
Samo se nadam da neće izaći tako skoro |
07.08.2007., 14:52 | #666 |
woot!!!
Postovi: 2,473
a racunaj za oko 6-8mj jer je receno prije bc da ekspanzije budu izlazile svaku 1 god anyway na http://worldofraids.com/ imate puno zanimljivosti/novosti o ekspanziji |
07.08.2007., 16:37 | #667 |
Postovi: 999
Dobro, sa tom brojkom se već mogu pomiriti Za 6 tjedana bi trebao imati cijeli A2 set, eventualno još 6 tjedana extra za staff. Nakon toga - čuvanje arena i honor poena za lvl80 |
08.08.2007., 13:09 | #668 |
mrzi zimu
Postovi: 318
vi iskusni igrači ...što vi mislite o tome? mislim, o ekspanzijama svake godine? ...moje mišljenje je podijeljeno...s jedne strane mi je super kad dou novi kvestovi, nova područja i sve to, s druge strane prekida se napredak guilde sto je koma.... ne znam ni sama da li da se veselim ili ne
08.08.2007., 17:22 | #669 |
Postovi: 999
Q: Will there be other hero classes? A: ...Some other hero classes could definitely be things like Demon Hunter, Blademaster, etc. Razlog zašto ću nastaviti igrati |
08.08.2007., 19:57 | #670 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,023
Mislim da se ja ponovo vracam igri i to uskoro. Samo jedno pitanjce, koji je dobar pvp server, a da je relativno novi i ima dosta hrvata? |
09.08.2007., 09:13 | #671 |
mrzi zimu
Postovi: 318
beren, ja i još par ljudi iz zagreba smo na mazrigosu...server je ful mali i meni to nekad beskrajno ide na zivce jer je nac grupu za instacu pravo umijeće
09.08.2007., 11:32 | #672 |
Postovi: 5
prodajem account Priest na serveru Skullcrusher,uskoro na Dunemaul serveru,ima cijeli PvE healing gear (90%epic sa bonus healingom 1750+) i PvP gearom 4/5 gladiator set 12k HP-a (full epic osim trinketa i wanda :P). imam sve heroic kljuceve + Karazhan key,3 epic mounta i jednog flying non-epic mounta 60% speed.exalted sa 4 frakcije,od profesija imam tailoring (primal mooncloth set crafted) i herbalizam,dakle obje profesije na max skillu mozete pogledati gear na: http://armory.wow-europe.com/charact...er&n=Zalandron javite se na PP ukoliko ste zainteresirani.hvala |
09.08.2007., 13:50 | #673 |
Postovi: 113
pvp server
@ Vga Killer dragonmaw je pvp server i ima nešto hrvata (ne baš previše), čak i dvije gilde mislim koje su većinom hrvatske. Na serveru ima još i dosta nizozemaca (tzv dutch ppl), belgijanaca, skandinavaca, ponešto i engleza. Samo što Dmaw nije najnoviji server koliko znam. Mislim da ima i dosta veliki broj igrača na njemu (nije pust), samo je teško sada procijeniti zbog ljeta. lp p.s. govorim za horde stranu :P Zadnje izmijenjeno od: b.b.. 10.08.2007. u 09:04. |
09.08.2007., 14:10 | #674 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,023
Tnx. Ma mislil sam s ekipom krenut ispocetka na nekom novom serveru, a da nije neki najnoviji i da nije bilo preseljenja da mogu pratit korak s ekipom, a ne da su mi sad svi 70lv |
09.08.2007., 23:29 | #675 |
Lokacija: Novi Zagreb
Postovi: 979
Auchiondoune ... tak nešto, možda čak i tako Server na kojem ja igram...ima fakat dosta hrvata...imaš guild Balkan forces...ima ih pun k...to je što se tiče alijance... E sad bedara... 39% je alijance ostatak je horda na serveru... Tak da ako tu kreneš...alijancu preporučam... Horda se žali na duga čekanja za BG...i tako to... Zadnje izmijenjeno od: GoGzS. 09.08.2007. u 23:41. |
10.08.2007., 17:30 | #676 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,023
Nema sanse da igram alliance, a i volim kad je njih vise, imam vise za klat |
11.08.2007., 13:39 | #677 |
Postovi: 999
11.08.2007., 14:36 | #678 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,023
@GogzS - kolko je taj tvoj server star i jel ima puno ekipe na 70lv |
12.08.2007., 17:32 | #680 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,023
E dajte pomagajte, frend bi htjel pocet igrat samo ni on ni njegovi nemaju ni jednu od ovih kartica koj se moraju upisat kad se radi acc, pa jel ima neka druga shema da se to izbjegne?? |
12.08.2007., 17:42 | #681 |
Sruk
Datum registracije: Sep 2004
Postovi: 1,163
12.08.2007., 17:59 | #682 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,023
Al tek kupuje igru i kaj netreba za kreiranje samog acc broj kartice? A i nema sad para da kupuje odmah i bon |
12.08.2007., 18:12 | #683 | |
Sruk
Postovi: 1,163
a to, sjecam se da se to neak moze...uglavnom, nazvo sam sad prijatelja, reko mi je da se moze kreirat acc sa onim brojem kaj ti da 2 tjedna besplatno....onaj brojcek na kartici da prijatelja pozoves da se i on igra....pa nek upise to....i onda posle nastavi placat ak ce htjet....ja mislim da se to moze tako.... al pricekaj da dode paske il ova partyjana kaj znaju sve o tome, oni ce ti najbolje znat rec. eo sad sam pitao jos to jel se moze nastavit placat pa mi je prijatelj reko da se moze, al ...kreces ispocetka... |
12.08.2007., 23:06 | #684 |
Lokacija: New Eden
Postovi: 3,801
Za kreiranje acc-a je trebao broj kartice, ali koliko znam ne treba više. Dobro ti veli JVC - neka drpi besplatni trial od 14 dana, koji se kasnije može upgrade na full account. Inaće te trialove su nekada davali uz original igre, ali sada se lako dobije od Blizza na WOW stranicama. |
19.08.2007., 23:20 | #685 |
Postovi: 979
@Fan...server je krenuo kad i TBC... Ekipe na 70 lvl ima...malo pročešljaj wow-forum pod realm forums...pa ćeš vidit... Kao što rekoh...problem je previše horde na serveru a i u samom battle-groupu...uđem u BG...igramo 7 alijance protiv 15 horde... Zato preporučam alijancu...a ti kak hoćeš |
21.08.2007., 17:48 | #686 |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,023
gogzs - ja danas krecem na tom tvom serveru, naravno na strani "zla" tkao da se vidimo |
25.08.2007., 23:18 | #687 |
Postovi: 979
Koji drek... Hoću se logirat...surprise...wrong log in information... Ispunim sve, na wow stranici...dobim novi pass...logiram se... Još jedno iznenađenje...likovi goli do kože...sve što se moglo prodat...prodano...golda fali dosta...sve u svemu...banana za sada... Friend lista...ošla, sve pobrisano, samo Magicd ostao...a neznam ni tko je ni šta je to... Nije mi bio uopće na frend listi... Sad sam GM ticket otvorio...fakat banana teža...jel imao tko sličnih iskustava i kako je prošlo? EDIT: account bannan...e-mail je ohrabrujuć...nemožemo account vratit na neki prijašnji back up, pružite što više mogućih informacija...we will investigate the problem... Stvarno...igro sam toliko besplatnih igara, i ono, stalno čito po forumuma, hakiran sam, bla bla...meni se nikad ništa desilo... I sad plaćam da bi igrao...i logiram se...imam pee i poop u inventoriju a likovi ko da rade u striptiz baru... Zadnje izmijenjeno od: GoGzS. 25.08.2007. u 23:38. |
26.08.2007., 09:59 | #688 |
Postovi: 1,099
heh, dobit ces acc natrag, imat ces sve iteme sto si do tada imao ali bez enchanta i takih stvari, morat ces platit u goldu onoliko koliko je taj lik sto ti je maznuo zaradio. ako je disenchantao epixe onda ces platit broj shardova*cijena na ah a ako je samo prodao vendoru onda ti je to lakse, samo platis koliko je on zaradio. uglavnom reci frendovima da ti skupe sta golda pa ces ti vratit kada nafarmas. 2 tjedna RL ti negine sada p.s. ja bi to vrijeme iskoristio da dignem novog lika na neki lvl jer je sa tim hi lvl likovima bezveze igrat kad su goli. p.p.s. nemoj igrat alijansu i instaliraj si firefox sa noscript addonom koji ce ti bit ukljucen na stranicama kao sto je allakhazam, warcraft movies itd... ja sam vjerovao samo wowheadu gdje su scripte bile dozvoljene. p.p.p.s. ako je server toliko nov kao sto kazes onda ti i nije toliki problem za opremu, uglavno bi trebala bit plavkasta. |
08.09.2007., 17:27 | #689 |
Postovi: 979
Ah...da bumpam temu i kažem šta se desilo na kraju krajeva Dobio sam sve iteme nazad (samo bez enchanteva i gemova...) gold sam nazad dobio... E sad, golda sam dobio više nego sam imao...znam da sam zadnje pare dao za 150 riding skill i epic mount...a ono poštom došlo 690 g od GMa... I da...dosta itema sam dobio duplo i tako... Sve u svemu, ja zadovoljan |
08.09.2007., 18:20 | #690 | |
woot!!!
Postovi: 2,473
