Zaključane teme
Staro 28.09.2013., 20:28   #661
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Mogu li dobit change log od tog novog updatea ?
Snowrider je offline
Staro 29.09.2013., 16:00   #662
Autor Daky007 Pregled postova
naravno da možeš (2.67 vs .244):
Framework
- Volume Up / Down keys will turn the screen on while a call is in progress (very useful if you like terminating calls with the power button)
- Default wallpaper is now a black screen
- One additional short code recognized as a free number (72340, in "de")
- Key charmap now used in the handler for AT+CKPD commands
Google apps
- Books updated from 2.7.39 to 2.8.69
- Chrome updated from 26.0.1410.58 to 28.0.1500.94
- new system app com.google.android.configupdater, version 4.2.2-721232
- Gmail updated from 4.3.1 to 4.5.2-714156
- Maps updated from 6.14.3 to 7.0.2
- GMS updated from 3.1.36 (669520-36) to 3.1.59 (736673-30)
- Hangouts updated from 1.0.1.678536 to 1.1.1.753199
- Magazines updated from 1.2.1 to 2.0.0
- Music updated from 4.5.914I.590354 to 5.1.1106K.749200
- Play updated from 4.0.25 to 4.1.10
- new system app Play Games, version 1.0.06 (750395-30)
- Plus updated from 3.6.0.44338848 to 4.0.2.48854689
- Talkback updated from 3.3.0 to 3.4.0
- Quick Search Box updated from 2.4.10.626027 to 2.6.7.721924.arm
- Videos updated from 2.4.14 to 2.6.9
- Youtube updated from 4.4.11 to 4.5.17
Other apps
- Bluetooth: 2 small fixes on Headset and Phone Book functions
- SMS app: now discards drafts when exiting the app in certain circumstances
- Album: fix for reload completed detection
- Calendar: minor layout change on the month view
- Contacts Provider: security vulnerability patched (related with exported files)
- Email: fixed parsing of styles when created hyperlinks on phone numbers
- Phone: only update the navigation bar if Phone is the foreground window; fixed handling focus on USSD dialogs
- Sony Share: change in landscape layout
- SmallAppsLauncher: better filtering when searching Play store for small apps
- Screen Mirroring: handle empty PIN when using WPS to connect to WiFi
Binaries and libs
- Includes (disabled?) support for CLAT: make IPv4 apps work on IPv6-only networks (http://dan.drown.org/android/clat/)
- Modem updated from ACEFWMAZQ-30110057 to ...-30110068
- several new libs related with image effects (blur, retrolux, ...)
- new font: Padauk
Kernel
- Changes in the calculation adjusted battery charge state (perhaps fixing the battery bug??? The code now matches line 1792 of this source)
- Some corrections in the MSM video driver
- No relevant changes on the ramdisk
Brko je offline
Staro 30.09.2013., 14:30   #663
warlock25
warlock25's Avatar
Postovi: 2,327
Ljudi.imam problem kada stisnem poziv samo blicne i nie se ne dogadja.moram po 2 do 3 puta stisnut da reagira.nekad iz prve ide.to se dogadja samo kad ocu nekog zvat.inace mob radi savrseno.xperia z je mob
warlock25 je offline
Staro 30.09.2013., 15:13   #664
Autor warlock25 Pregled postova
Prodaj ga i kupi nekaj drugo ti zbilja imaš pehove sa tim aparatom.
Probaj ga reflešati ili ga opet nosi na reklamaciju.
Brko je offline
Staro 30.09.2013., 19:35   #665
Postovi: 34,075
Ma kakvo flashanje. Direktno na reklamaciju s njime.
EDIT: procurile specke za Z1 Mini aka Z1 f
http://www.xperiablog.net/2013/09/30...ni-specs-leak/
coconut je offline
Staro 30.09.2013., 23:17   #666
warlock25
warlock25's Avatar
Postovi: 2,327
Ma ne vjerujem da je to za reklamaciju.bum ga fleshao ponovo i factory reset pa bum vidio
Staro 01.10.2013., 22:28   #667
Da, ali i kod fleša lijepo postaviš da sve u mobu ubije, tako da će ti već to tada biti tvornički reset.
Brko je offline
Staro 02.10.2013., 02:45   #668
boy005
boy005's Avatar
Postovi: 598
boy005 je offline
Staro 02.10.2013., 07:32   #669
Postovi: 34,075
Ima je i na oglasniku za 4.5k kn. Naravno, otključana na sve mreže.
coconut je offline
Staro 02.10.2013., 08:40   #670
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Sinoć došao i za brandirani software update (t-mobile) .... 10.3.1.A.2.67 dosta brzo u usporedbi s unbranded.
Staro 02.10.2013., 21:51   #671
Da se ne bojiš flešati službene sony firmwareove, već bi ga imao i ne bloatanog
Brko je offline
Staro 02.10.2013., 22:01   #672
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Zbog gare se "bojim" al čisto sam iznenađen kako je brandirani t-mobile software stabilan i bez FC....
Staro 02.10.2013., 22:03   #673
Nitko nije rekao da je nestabilan, ali mene ubija ono rozo T na početku
Brko je offline
Staro 02.10.2013., 23:08   #674
mislav_os
freak
Postovi: 2,688
I samo zato stavljas sluzbeni Sony?
Inace, ja jos nisam updejtao iako mi gore stoji i bode oci, updejtat cu kad budem za kompom da ga mogu odmah rootat
mislav_os je offline
Staro 03.10.2013., 00:08   #675
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Istina kad vidim T-mobile logo...ufff :banghead: al srećom je to jako rijetko pošto mob puštam da se ugasi jednom mjesečno
Staro 03.10.2013., 01:49   #676
spajder
spajder's Avatar
Datum registracije: May 2011
Lokacija: Solin
Postovi: 184
PRAGMATIZAM „Bolji je gram iskustva, nego tovar teorija.“ – DEWEY
spajder je offline
Staro 03.10.2013., 19:04   #677
Autor mislav_os Pregled postova
I zbog toga i zbog updatea jer ne dobije svaka kostumizacija u isto vrijeme, pa onda mu uteram novi fw čim je neki ftf dostupan na xda. Rootanje i onda brisanje gluposti i to je to. I nema tcum loga
Brko je offline
Staro 05.10.2013., 13:57   #678
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Z1 drop test
Staklo vise ne puca ali zato ekran od kvragu.
viper je offline
Staro 07.10.2013., 00:45   #679
mislav_os
freak
Postovi: 2,688
Ovaj Kingo za root je odlicna stvar.
Updejtao sam mob i rootao ga za 5 sek, jednim klikom!
spajder, hvala na linku.
Staro 07.10.2013., 15:44   #680
Postovi: 34,075
Slike i specke Z1 Mini aka Z1 f. U principu, sve je isto kao kod većeg brata osim što je ekran manji - 4,3" 720p. Dakle, nije kao kod Samsunga da su Mini verzije obično klasu ispod flagshipa.
http://www.xperiablog.net/2013/10/05...brochure-leak/
http://rbmen.blogspot.co.uk/2013/10/...2013-2014.html
coconut je offline
Staro 07.10.2013., 21:56   #681
rodriguez
rodriguez's Avatar
Postovi: 2,067
I ako je Triluminos display, to je to!!
Može promjena naziva teme u Sony android mobiteli?
Thinkpad T430 running
rodriguez je offline
Staro 08.10.2013., 22:02   #682
viper
super user
viper's Avatar
Postovi: 1,805
Sony Xperia Z1 + Sony prijenosni punjač @ T-Mobile
Cijena uređaja bez ugovora: 5.698,00 kn
Zadnje izmijenjeno od: viper. 09.10.2013. u 12:57.
viper je offline
Staro 11.10.2013., 18:52   #683
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Ja sam ju naručio prošli tjedan preko webshopa, ali idući dan sam dobio obavijest da je rasprodana (navodno da su dobili samo 7 komada - informacija od agentice u SZK) i da će me kontaktirati kad stigne (rekli su da će stići ovaj tjedan). Naravno, još ništa.
BTW. cijene u VIP-u su fenomenalne.
sinisa1989 je offline
Staro 13.10.2013., 14:18   #684
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Autor coconut Pregled postova
Ovo je vrhunski i najbolji mini na tržištu. Iako nema potrebe za ovim chiposetom za 720p ekran, dobro je što su ga koristili jer je snap800 puno štedljiviji od snap600. Odlican mob!!
dean225 je offline
Staro 13.10.2013., 22:21   #685
rodriguez
rodriguez's Avatar
Postovi: 2,067
Zasad je izašao samo za Japan
Ako bude dostupan u Europi uzimam ga sigurno.
Ako ga Sony ne pusti van Japana, napravit će si užasnu antireklamu, žele biti 3. na svijetu po zastupljenosti smartphonea, a jako puno ekipe se pali na ovaj Z1f, i morali bi ga pustit na internacionalno tržište.
Zadnje izmijenjeno od: rodriguez. 13.10.2013. u 22:51.
Staro 18.10.2013., 22:06   #686
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Taj Z1 mini je ono sto ja cekam vec duuuuugo vremena idealna velicina ekrana a da neokrljaste specifikacije...
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline
Staro 21.10.2013., 03:17   #687
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Navodno da mali Z1 ipak dolazi u Njemačku...
dean225 je offline
Staro 21.10.2013., 13:02   #688
rodriguez
rodriguez's Avatar
Postovi: 2,067
Link?
Staro 23.10.2013., 16:00   #689
Postovi: 34,075
Xperia linija proizvoda dobila podršku za DualShock3 gamepad
http://developer.sonymobile.com/2013...id-game-video/
coconut je offline
Staro 24.10.2013., 11:48   #690
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Sony Xperia Z1 s: Vorstellung des Mini-Z1 am 12. November [Gerücht]
http://feedproxy.google.com/~r/andro...3/Lw5Fqetm7NE/
Evo ga.
Sorry, moji linkovi su na njemačkom, neka ekipa posta eng linkove. Dolazi EU verzija sony mini z1s.
Zadnje izmijenjeno od: dean225. 24.10.2013. u 12:02.
dean225 je offline
Zaključane teme
