#31 | |
Lokacija: n/a
Postovi: 6,128
#32 |
In the ghetto
Postovi: 1,943
Fala na odgovoru, ja se bum isto vratilna stariju verziju. V206 mi zbog toga vise odgovara.
#33 |
Postovi: 3,780
Riva Tuner 2.08
izašla je nova verzija popularnog programa http://downloads.guru3d.com/RivaTune...nload-163.html bacite pogled na datum izdavanja, 11.3 back to the future...Version 2.08: Minor bugfixes: RivaTuner no longer crashes when RivaTuner module activation launcher item is scheduled to run at Windows startup. Fixed association between low-level refresh overrider rules and target display adapter, broken due to low-level profiles association related changes in the previous version. Minor UI and localization fixes. What's new: Updated databases for Detonator and ForceWare drivers. Added database for ForceWare 169.44. Added Catalyst 8.3 drivers detection. Updated Catalyst 8.3 certified SoftR9x00 patch script (for Windows 2000/XP drivers only). Updated PCI DeviceID database for ATI graphics processors. Added PCI DeviceID for RADEON HD 3850 AGP. Improved G94 graphics processors support. Thanks to Jurgen in 't Zandt @ Point of View for providing NVIDIA GeForce 9600GT sample for testing. The list of G94 related improvements includes: Added low-level fan control support for integrated PWM controllers of G94 graphics processors. Improved driver-level fan control support for integrated PWM controllers of G94 graphics processors. Now RivaTuner can be used for switching between driver-level automatic and driver-level direct fan control modes on GeForce 9600GT series. Improved RV6xx graphics processors family support. With this version RivaTuner continues tradition of providing workarounds for bugs existing in fan controller calibration routines of many reference AMD HD 38x0 BIOS images. The list of new workarounds and enhancements includes: Extended list of tweakable automatic fan speed control rule parameters for RV6xx fan controllers. Now besides editing previously available thermal lookup and temperature transfer formula parameters RivaTuner also allows editing parameters of RV6xx fan controller's acoustic management system. Acoustic management related parameters include PWM hysteresis and PWM ramp settings, which are also improperly calibrated in certain AMD HD 38x0 BIOS images. Now RivaTuner forcibly resets fan controller's PWM hysteresis settings when adjusting fan speed in fixed mode. This enhancement provides fine fan speed adjustment in fixed fan speed mode instead of stepwise fan speed adjustment mode on the systems affected by erroneously programmed PWM hysteresis. Changed representation format for temperature transfer function's T slope parameter. Now the parameter is displayed and edited in percents instead of PWM ticks to simplify transfer formula readability. Minor UI changes and improvements. EDIT: koliko sam zasad vidio onaj guide za fan profile vise ne radi ili je promijenjen nacim aktiviranja pojedinih fan profila. ako netko skuzi nek javi kako je uspio... ![]() Zadnje izmijenjeno od: alengrosevic. 10.03.2008. u 19:34. Razlog: dodatak... |
#35 |
In the ghetto
Postovi: 1,943
Evo pocela me nesto zezati riva verzija 206 pa sam zato potrazil vec ovu davno otvorenu temu. Kao sto vidite u slikicam rivi se brkaju brzine vrtnje venta: I to mi se prvi put pocelo događat neki dan bez ikakve veze, niti sam mjenjal drivere niti ista drugo. Mozda je neka opce poznata glupost koju sam previdio ali vas svejedno molim da mi pomognete rijesiti zagonetku. Ja sam sve to lijepo po uputama sa guru3d stranice poslozio da mi se brzina venta postepeno dize za razlicite temperature. Samo sada kad odem na Launcher i kad stisnem vent na 29% on mi se vrti puno vise nego kaj bi trebal i isti je problem i u obrutoj situaciji. EDIT: Problem rijesen! Malo sam oglupavel pa nemojte se dat smetati. U ovome je bila stvar: Naravno ja sam mislil da znam to naparviti i bez previse gledanja u salabahter sa guru 3d stranice. Ugl. ovako kako je prikazano na slici normalno, a meni je bilo poslozeno u suprotnom smjeru tj. od vecih okretaja prema nizim - samo sam preslozil i gotovo. Ovo je cito da da ne ponavljate moje greske.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor Zadnje izmijenjeno od: elvis again. 11.03.2008. u 10:32. |
#37 |
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
kao što tekla kaže, jučer sam skino v2.07 ali još bolje samo neka izlaze nove verzije jer vidim sve više i više bugova popravljaju i sad prepoznaje catalyste 8.3
#39 |
Lokacija: livno
Postovi: 1,065
#40 |
Avocado
Postovi: 7,856
jos uvijek nema test... i to je jedino sto mi fali.
Spoiler alert! |
#42 |
Postovi: 11,642
Što će ti taj ''Test''? Ja sam to isključivao i kad je bilo... |
#43 |
Slažem se sa Razerom,poprilično neprecizan&iritirajući dio RT-a(a kao takav posljedično gotovo beskoristan).Ionako je radio po principu toplo-hladno,i koja korist onda od toga? Više nedostaje ovo što SRV spominje... |
#44 |
Postovi: 288
Meni se 2.08 verzija glupira. Išao sam je instalirati na svježe stavljene Windowse, pa mi kaže da RivaTuner is already running in background i ne želi ga instalirati... verzija 2.06 sa onim cfg fajlom koji mi detektria grafičku je radila savršeno. I overclock i regulacija venta, sve... |
#45 |
In the ghetto
Postovi: 1,943
Pa jesi prvo maknul staru verziju 2.06?
#46 |
Postovi: 288
#47 |
In the ghetto
Postovi: 1,943
A nis vrati se na 206 kao sto ce i vecina uciniti, bar ja jesam :-)
#49 |
Postovi: 202
Evo ja sam preko njega iso clockat grafu (7600gt) sa core 560 i memory 700 na 600/800. No kad restartam komp i pokrenem onaj load monitor on meni kaze da je grafa OC sa 800 memory a umjesto clock 600 na 576...sta da radim da je dignem na 600? je stavljen mozda neki limit ili? plz ko zna nek odg |
#50 |
Postovi: 11,642
Druga tema na kojoj upadaš sa pričom o svojoj 7600GT ![]() Pročitaj si stare teme o dotičnoj kartici, barem njih ima gro... |
#52 |
Postovi: 11,642
Upadaš ![]() Zašto neće clockati više? Nije ti palo napamet da kartica jednostavno ne ide više (bilo to zbog premalo ''soka'' bilo zbog lošeg hlađenja)? |
#53 |
Avocado
Postovi: 7,856
Spoiler alert! |
#54 |
Postovi: 11,642
Okvirno više manje znam i sam koliko ide. A tu je i Artifact Test u AT-u... |
#55 |
Postovi: 288
Vezano uz RivaTuner 2.08 i neke njegove nedostatke, vezano uz podešavanje vrtnje ventilatora. što se tiče verzije 2.06 sa 174.74 Beta drajverima, znao mi se tu i tamo zblesirati. Ili ne podigne vrtnju venta ili ju podigne i ostavi na 100%. Pa sam išao probati sa 2.08. Ovdje sam našao lijepi guide: Code:
http://www.vaguesoft.com/index.php?pageid=rt207#advcontrol Za vlasnike novih 8800 GTS-ica Meni je Duty cycle min 36, Duty cycle max 100, T min 46 (zbog nekakvog offseta od 8, znači to je 52-8=46), T range 10, T operating 110, kao i T high limit, T low limit 0. Zašto tako, pročitajte članak. Nakon mijenjanja postavi pod Power User za enablanje automatic fan control, ne mojte zaboraviti restartati RivaTuner, jer nećete moći mijenjati postavke automatic fan controla. |
#56 | |
Lokacija: Dubrovnik
Postovi: 2,583
Riva Tuner 2.09
Izasla je nova verzija svima poznatog - Riva Tuner-a. Najvise srece stize za one koji imaju CF/SLI a nikako nisu mogli kontrolirat oba venta tj od jedne i od druge kartice istovremeno. I svi koji su kukali da nemaju TEST opciju, u ovoj verziji je vracena. No to je samo najmanji detalj naspram onome sto sve donosi drugo. Download Citiraj:
Download Zadnje izmijenjeno od: Bullet1. 01.05.2008. u 13:57. |
#58 |
Postovi: 11,642
To nije moguće udesiti. Moguće je samo ovisno o temperaturi. A to zapravo dođe na isto s loadom ![]() |
#59 |
Postovi: 330
#60 |
Lokacija: Ivanić_Grad
Postovi: 2,013
