Staro 01.03.2007., 15:52   #31
sick_boy
sick_boy's Avatar
Postovi: 680
Mihael, ajd provrti 3DČmark05 i 06. Nešto mi smrde moji rezultati:
3DČmark06, 1280x800 (sve default): 638
3DČmark05, 1024x768 (sve default): 1211
Edit: Uh, našao sam neke opcije u Powerplay izborniku, pa sam postavio kad je na struji da bude "optimized for perfomance". Sad to izgleda malo bolje (ali još uvijek lošije od review-a x1600 mobility grafike na netu):
3DČmark06, 1280x800 (sve default): 1379
3DČmark05, 1024x768 (sve default): 2516
Nisam još probao ATI overdrive
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
Zadnje izmijenjeno od: sick_boy. 01.03.2007. u 16:22.
sick_boy je offline   Reply With Quote
Staro 01.03.2007., 15:55   #32
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor sick_boy Pregled postova
Mihael, ajd provrti 3DČmark05 i 06. Nešto mi srde moji rezultati:
05 mi je oko 3500 markova, a 06 nemam, puno mi ga je za skidat...
7.2 catalyst driver za moble x1600
Da nisi slučajno vrtio na bateriji? da ti nije proc se spustio ili grafa?
Staro 01.03.2007., 16:24   #33
sick_boy
sick_boy's Avatar
Postovi: 680
Evo, editirao sam gore post. Još uvijek je to dost' loše kod mene, ali treba napomenuti da je to na Visti x64 sa beta driver-ima (sa Catalyst 7.1 i 7.2 mi ne radi WoW )
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 01.03.2007., 16:32   #34
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Pretpostavljam da je problem u visti, no imaš dosta rama i meni je na visti davao 3500 mark 05, a imam gigu rama i semprona
Staro 01.03.2007., 17:21   #35
sick_boy
sick_boy's Avatar
Postovi: 680
Hehe, isključio sam u potpunosti Powerplay:
3DČmark06, 1280x800 (sve default): 1699
3DČmark05, 1024x768 (sve default): 3243
Sad je već zanemariva razlika između tvog i mog rezultata (posebno ako uzmem u obzir da se radi o Visti x64 i beta driverima)
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Zadnje izmijenjeno od: sick_boy. 01.03.2007. u 17:48.
Staro 01.03.2007., 18:28   #36
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
meni je tako sa uključenim powerplayom na optim-pref.
Na visti sam dobio iste rezultate kao na xp, možda manje za 20-30 bodova.
S time da imam lošiji proc i manje rama...
Možda je vista x64 toliko loša...hm
Staro 01.03.2007., 22:22   #37
sick_boy
sick_boy's Avatar
Postovi: 680
Ma, mislim da nije do x64 Viste, nego do činjenice da se ipak radi o 32-bitnoj aplikaciji (3DMark). U svakom slučaju, ovo je OK, ostavio sam ga ovako, a čini mi se da je battery life otprilike isti (dok ne pokrenem neku igru, što ionako ne namjeravam na bateriji).
Inače, sve više mi se čini da odustajem od prodaje - lap mi se sad čini skroz OK (privikao sam se), još moram koji put isprobati vanjski monitor pod opterećenjem, pa ako se ponovi nestajanje slike, onda ću ga reklamirati, a ako ne, tim bolje. Uskoro, vjerojatno, desktop ide na prodaju.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 01.03.2007., 22:24   #38
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Ma i meni je ok, jedino su monitor i optika dosta loši, ali eto koliko para toliko muzke .
Glavno da igre rade kako spada.
Staro 01.03.2007., 22:30   #39
sick_boy
sick_boy's Avatar
Postovi: 680
Optika? Kod mene je Philips-ov DVDRW i ne čini mi se nešto posebno loš (doduše nisam ga nešto previše testirao).
Eh da, daljinski radi po defaultu u Vistinom mediacenteru
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 01.03.2007., 22:38   #40
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Meni nekada ne želi čitat dvde, a kad ga stisnem unutra onda čita... otvorim ga zatvorim i onda radi, philipsov je unutra.
Daljinski radi i pod xp-om, ali samo gore dolje, mute, backspace i OK ..
Staro 05.03.2007., 21:17   #41
Pink_Floyd
Postovi: 325
Evo bas veceras isa snimit 7.2 mobility drivere i nemogu ih snimit.Odaberem normalno drivere za xp,mobility,x1600,i kad skinem prvo onaj file od 600kb sta valjda triba pokrenit instalaciju ispise mi thank u for interesting in catalyst,unfortunately this software cannot be installed on your system.Please contact your notebook manufcaturer for driver updates.U everestu mi nista ne ocitaje pod gpu,sad san stavia omegine drivere na temelju 7.1 ,daje 3223 u marku05? Aj nek neko proba na xpu snimit te nove 7.2 mobility drivere!
Pink_Floyd je offline   Reply With Quote
Staro 05.03.2007., 21:41   #42
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
http://ati.amd.com/online/mobilecatalyst/
Link si možeš slobodno bookmarkirat, na njemu će biti i sve nove verzije kako budu izlazile.
Meni taj 7.2 mobile radi bez problema.
Oni ti ne sadrže, kao oni dobiveni s laptopom, SB driver i još one druge.
Dakle samo 7.2 mobile driver i 7.2 ccc
Poz
Staro 07.03.2007., 11:56   #43
sick_boy
sick_boy's Avatar
Postovi: 680
I dalje me prati glupi problem sa povremenim nestankom slike. No, sinoć sam spojio vanjski monitor preko VGA sučelja i nije se ni jednom desilo.
Damn, čini mi se da mi šteka DVI port na laptopu (monitor, naravno, radi bez greške preko DVI konektora na desktop stroju).
Interesantno je da slika nestaje samo u u određeim uvjetima. Recimo, WoW, kad sam u Stormwind City-ju ili na nekim određenim lokacijama, ali neki dan sam igrao dva sata bez problema na jednoj drugoj mapi, te se počelo dešavati zbilja tek kad sam se vratio u Stormwind! Također, 3DMark06 sam pustio nekoliko puta uzastopce - nikakvih problema (još nešto je interesantno - kad je spojen na vanjski monitor 3DMark score je niži - oko 1500, ali moram još provjeriti jesam li koristio iste rezolucije za test).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 07.03.2007., 12:56   #44
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
3D mark 06 postavlja nativnu rezoluciju monitora.
Tako da je najvjerojatnije stavio na 1400x1050, dok je na lapu 1280x800, zato i je manji
Staro 07.03.2007., 16:44   #45
Pink_Floyd
Postovi: 325
Mihael hvala na linku sad su se uspili snimit,nego me zanima zasto mi se nisu tili snimit driveri kad se idu skinit preko onog Installation Verification Software di ti prvo provjeri kompaktibilnost pa tek valjda onda pocme ih skidat?i ako slucajno imas everest home edition daj vidi je li ti sta pod gpu ocitava?
Staro 07.03.2007., 16:53   #46
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Imam everest ultimate i sve mi normalno pokazuje.
Što se tiče onoga sa atija, uopće se ne čudim i s time ne vrijedi razbijat glavu, glavno da driveri rade i da se mogu skinut direktno sa linka, za ono me nije briga.
No kako se vama kreću temperature, kako vam se zagrijava/hladi, kako vam je dok je na bateriji, a kako dok igrate igrice, je li vam jako vruč?
tnx
Staro 07.03.2007., 18:10   #47
sick_boy
sick_boy's Avatar
Postovi: 680
Onaj ATIjev tool provjere OEM id-eve, te ako proizvođač laptopa nema ugovor s ATIjem, neće ga prepoznati. Za Vistu, npr., nije potrebna nikakva provjera, driveri se mogu direktno skinuti i rade bez pogovora.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 07.03.2007., 18:14   #48
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
A kakvo je zagrijavanje kod tebe? Kako se grije?
Staro 08.03.2007., 15:07   #49
sick_boy
sick_boy's Avatar
Postovi: 680
Ma, nisam mjerio. Šta ja znam, kad se igram bude topao (da ne kažem skoro vruć) i onaj ventilator sa strane se vrti dosta brzo (ali nije previše bučan).
Kad izmjerim neke točne vrijednosti, postaću ovdje.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 08.03.2007., 21:26   #50
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Ajde zamolio bih te za to jer moj se fakat JAKO grije...
Pogotovo kod igranja igrica.
Temp procesora i hdd-a se može vidjeti pomoću NHC-a ili Everesta, a GPU u CCC-u.
tnx
Staro 10.03.2007., 10:13   #51
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor Mihael Pregled postova
tnx
Uz ovo, jel se vama čuje disk dok ništa ne radi, onako hhhhhhhhhhhhhhh, kao da neki vent puše, a nije već se disk čuje u leru.
Jel to normalno... Kada se disk ugasi onda se ne čuje.
tnx
Staro 12.03.2007., 23:44   #52
sick_boy
sick_boy's Avatar
Postovi: 680
Uh, sorry još nisam stigao istestirati temperature (ovih dana ću, obećajem).
Nisam primjetio da se disk tako čuje. Reklamacija?
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 13.03.2007., 09:50   #53
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Hajde pa javi, baš me zanima događa li se isto tebi kao i meni.
A dik je fujitsu, imao doma hp-a od frenda, isto fujitsuov disk samo od 120gb, potpuno isto radi, identičan zvuk izlazi iz njega kao kod mene.
poz
Staro 14.03.2007., 11:07   #54
sick_boy
sick_boy's Avatar
Postovi: 680
Evo ovako, što se CPU-a tiče, mjerio sam sa Speedfan-om (nova verzija je kompatibilna sa Vistom x64 koju koristim):
Idle: 60-62 stupnja
Opterećenje: 72-73 stupnja
Zvuči zabrinjavajuće, ali nisam još osjetio nikakve nestabilnosti u radu. Opterećenje je postignuto pokretanjem Prime95 (64-bit), torture test (ne znam kako se zove, ali onaj za maksimum heat and power consumption) i to dvije instance - affinity na jednu jezgru po instanci. Vrtio se cca 15-tak minuta (nisam više imao vremena, ali se temperatura već nakon 5 minuta ustalila na 72-73 stupnja i slijedećih 10 minuta nije se mjenjala).
Grafička (mjereno sa Catalyst-om):
Idle: 55-58 stupnjeva
Opterećenje: cca 70 stupnjeva
Opterećenje je izmjereno nakon pol sata-sat igranja.
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 16.03.2007., 11:56   #55
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Puno hvala na trudu, i moj se tako negdje grije , sve zbog lude grafičke i loše izvedenog hlađenja...
Staro 21.03.2007., 19:54   #56
Rebellion
Killer of your Dreams
Rebellion's Avatar
Lokacija: Final Digit of the Rainbow
Postovi: 107
Cool
Autor NoN Miller Pregled postova
Evo stari danas sam prijatelju uzeo taj laptop i totalno smo nezadovoljni. Prva stvar koju sam ti i spomenio na vidilabu je nekvaliteta plastike. Tipkovnica skripi na nekim tipkama, space "sece", ladica od dvd je vrlo krhka, vrijeme autonomije za procesor je oko 1:20 sto je lose. pogotovo zato sto je nova i ima 512 rama na konfi- sto ce biti sa vise rama? Jos jedna stvar koja je ne tako vazna a to je da je touchpad totalno ukurcu i prati svaki vas pomak tako da ce vam se prilikom tipkanja dogadja da setate po tekstu.
Ja imam Benq P52EG i nikakvog škriputanja nema sa tipkovnicom, niti space šeče,a ako ne znaš tipkat sa 2 ruke što već svaka budala zna, lako ti se može dogoditi da mičeš cursor po ekranu, što se opet meni meni nikada ne događa, a za desktop replacement laptop ti defintivno nije važna baterija, međutim, ako hoćeš imaš Vistaportove i duplo većeg kapaciteta za Benq (tj. reci frendu). RAM ne može značajno skratiti vrijeme autonomije jer nema mehaničkih dijelova niti se javlja velika disipacija topline što ti govori da nema velikih gubitaka energije. Prouči na netu potrošnju u Watt-ima za Random Access Memory pa ćeš vidjeti!
Autor Lesa Pregled postova
IMHO pogrešno razmišljaš. Makar i za 5500kn, što nisu ni u kom slučaju mali novci, koja su ti pobogu ovo rješenja? Touchpad katastrofa -isključi ga. Baterija sat i pol -smanjuj sve da se dočepaš dva sata. Dobro da nisi rekao da koristi eksternu tipkovnicu pošto ova ne valja. No ajde, kad smo kod narodnih:"Poklonjenom konju se ne gleda u zube"
NoN, zašto ga nisi pregledao u HGu? Laptop sa takvim komponentama i cijenom gotovo sigurno je izložen. Naročito pošto ga i reklamiraju na webu? Ovo oko tipkovnice i kućišta se vidi na prvi pogled.
Ako ga možeš vratiti vrati. Mislim da je ovo dosad najbolji primjer da za lowend brandove nečije osobno iskustvo ne vrijedi k***a. Kratak je put od fantazije i vulkanskog stakla do škripavca sa sat vremena runtime-a
Rješenja koja si naveo nisu potrebna i jesu idiotska ako ti trebaju. Laptop jest izložen i može se probati. Benq nije lowend brand. Ne uzimajući IBM u usporedbu Benq je relativno blizu Asusa, ***eno jači od Acera (probajte staviti nešto težine kazetofona na Acera pa će vam ostati trajne posljedice, na Benq sam stavio i 2 druga laptopa i ništa!),a i Dell ima laptope koji se mogu bacati sa 1.5m i one koje ne smijete sa 15cm - ljudi postoje kategorije laptopa po namjenama!!!
Eh da, volio bih naći Mini PCI TV tuner za njega. Ovaj model to ima kao opciju i dok sam mijenjao memoriju, vidio sam da je čak i izvod za antenu spreman. Kome da se obratim glede toga - ovaj BenQ technical support mi ne ulijeva neko povjerenje?
Mislim da tvoj laptop ima TV tuner, samo ne radi pod Vistom (provjereno), pogledaj jel imaš u Device Manageru nepoznatog hardware-a bez instaliranih drivera? Moj P52EG sa Vividom ima ***enu sliku, ali možeš i sa nekim programima kontrolom topline boja ispraviti dojam ispranosti boja! Meni eksterni VGA radi OK, još nisam imao prilike isprobati DVI. Ako ga budeš prodavao imaš zainteresiranog kupca - za koliko bi ga prodavao?
Poz
Odgooglaj chipset drivere za ATI mobile i dobit ćeš kompletne drivere
...i moj se tako negdje grije , sve zbog lude grafičke i loše izvedenog hlađenja...
Hlađenje je isto na P52EG (moj) i P52 i tu je za*** jer se dvojezgreni Mobile Turion ipak grije jače od Mobile Semprona
Meni su ti temperature:
CPU idle:54-56°C
CPU opterećen:65-67°C
VGA idle 54-56°C
VGA opterećena:69-70°C
Rebellion je offline   Reply With Quote
Staro 21.03.2007., 21:43   #57
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Ne kužim kakav je to vivid ekran?
Imam neki dojam da na mome slika i nije baš nešto...
Jesi podešavao boju s nekim programom ili što?
tnx
Staro 23.03.2007., 00:56   #58
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,918
Moze li netko napisati što je plus a što je minus kod tog laptopa ukratko?(u biti,znam što je plus...)jel ima 5.1 zvucnu?Meni se cini da ne...jel 5.1 zvucna rijetkost u laptopima ili?Neznam ako bi ga uzeo,kako bi se culi logitechovi THX Z5500 zvucnici?Mislim na filmove,surround itd...
& ima li tko volje poslikati ga digitalcem,jaaaaako zahvalno bi to bilo
Staro 23.03.2007., 01:12   #59
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor Thoroughbred B Pregled postova
ak uzmeš laptop uzmi si i ovo http://ve-mil.hr/opis.aspx?sifra=635...02054804225314 pa si onda miran što se zvuka tiče
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 23.03.2007., 01:21   #60
Thoroughbred B
Lokacija: RI
Postovi: 4,918
Autor Lihto Pregled postova
To sam imao Zanimljiva je to kutijica bila Dakle nadoplata od 400kn...
EDIT: Ovo je ipak malo bolja stvar http://www.hgspot.hr/opis.aspx?ID=24026
Zadnje izmijenjeno od: Thoroughbred B. 23.03.2007. u 01:41.
