#31 |
aka Edo, aka Syncros
Postovi: 1,780
Sad cekam da mi se enlajta sata driver u xp instalaciju pa cemo vidjet kaj to je. |
#32 |
dedicide
Lokacija: Slav.Brod
Postovi: 686
Evo što sam pročitao na xtremesystem forumu u vezi ove meme, planiram ju kupiti ali ako nema d9gkx možda da neku drugu uzmem. Tko ima memu dali mu ide na 1066mhz 4-4-4-12 sa 2.4V? You're right and I don't think anyone is going to be able to deny the fact that T1000UX2G4 has been quite impossible to come by. About 2 weeks ago, in response to my email, I was told pretty much what I have expected. From what I was informed a while ago, this kit is built with Micron's DDR2-800 parts (D9GKX) and these have been in extremely low supply for the past 2 months. Therefore shortage of T1000UX2G4. On the other hand, Super Talent's T800UX2GC4 (which used to be D9GKX) is quite available and that leads me to believe they switched to D9GMH (I believe it has been confirmed somewhere), which supply situation is a bit better, although not as great as many vendors would like it to be. I was told, that as soon as they are able to buillt more of T1000UX2G4, it will be available at Newegg right away. As you noticed, other memory manufacturers are also having same problems with their fastest rated DDR2 lines (8000 or 8500 ), so this is an industry-wide shortage. Some manufacturers seem to switch to D9GMH for their high bins and maybe this is some sort of workaround at this moment... __________________
#34 | |
teta Mraz
Lokacija: hr
Postovi: 1,596
![]() edit: mislio sam da je cl4, nisam dobro gledao, u tom slućaju razlika nije tolika no ja bi prednost ipak dao super talentu
#35 |
Postovi: 1,780
Trenutno je: proc 271.5x10 = 2715mhz memorija: 1090mhz 5-5-5-15 2.3v to je sve nabrzinu, nisam jos detaljno istestirao |
