Staro 06.10.2006., 13:58   #31
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
ja nebi stavio prava brzina nego orginalna brzina
Smartguy je offline   Reply With Quote
Staro 06.10.2006., 13:59   #32
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Autor Thoroughbred B Pregled postova
Promjenio sam u Tren.Brzina i Orig.Brzina,sta kažete?
Pa, bumo vidjeli. Nije ni to loše. Nego, gore si promjeni da piše 30min, a ne 30mn.
Inače, lijepo od tebe i domy-ja što pomažete čovjeku, a i svima nama
Lijepo je vidjeti nešto na Rvackome
Staro 06.10.2006., 13:59   #33
Tetedeiench
Lokacija: Lille, France
Postovi: 44
Thoroughbred & domy : since you guys worked in parrallel, maybe you can fusion your work to get one result ? Both of you will get credit anyway At first, in the README, but for the next version, when the about screen will be redone, in the app's about screen
Tetedeiench je offline   Reply With Quote
Staro 06.10.2006., 14:04   #34
domy_os
domy_os's Avatar
Postovi: 18,847
I'm glad, nice to see that. Domybred B company? LOL
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 06.10.2006., 14:09   #35
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
@Tetedeiench
Thanks for starting this initiative...it's great idea, and we'll help you as much as we can.
Regards.
Ph03n1x je offline   Reply With Quote
Staro 06.10.2006., 14:23   #36
Thoroughbred B
Thoroughbred B's Avatar
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,910
Ok,Domy sta cemo?Uploadaj svoj file kao ja,pa neka kolege s foruma procjene šta bi trebalo promjeniti.Pa da to bude konacno : cheers2
Zadnje izmijenjeno od: Thoroughbred B. 19.08.2021. u 11:38.
Staro 06.10.2006., 14:29   #37
domy_os
domy_os's Avatar
Postovi: 18,847
Evo ga...
Zadnje izmijenjeno od: domy_os. 02.05.2010. u 22:15.
Staro 06.10.2006., 17:46   #38
Thoroughbred B
Lokacija: RI
Postovi: 4,910
Autor domy_os Pregled postova
Sorry,i'm not gay
Staro 06.10.2006., 18:53   #39
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
@Tetedeiench
try "core temp"
It is quite simple to take temps from it
Staro 06.10.2006., 19:32   #40
Tetedeiench
Postovi: 44
I'll
One last question : how do you say croatian in croatian ?
how do you call your own language ?
That's the last thing i need to complete the translation
Staro 06.10.2006., 19:34   #41
Thoroughbred B
Lokacija: RI
Postovi: 4,910
Autor Tetedeiench Pregled postova
I'll
In Croatian its "Hrvatski"
Staro 06.10.2006., 19:36   #42
Tetedeiench
Postovi: 44
Perfect
"Hrvatski" will thus be supported in OCCT's next version, due very soon
Staro 06.10.2006., 19:47   #43
Vuco
Vuco's Avatar
Postovi: 9,505
Many thanks
EDIT:
Može se i ovako
Staro 06.10.2006., 19:51   #44
domy_os
domy_os's Avatar
Postovi: 18,847
Thank you very much se kaže!
Staro 06.10.2006., 22:23   #45
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
ne nego thx very much
Staro 10.10.2006., 16:11   #46
Tetedeiench
Postovi: 44
OCCT Perestroika V1.0.0 OUT !
With "hrvatski" support
Website will be up tonight
Thanks Toroughbred and domy !
http://www.ocbase.com/download/OCCTPT1.0.0.zip
http://www.ocbase.com/download/OCCTPT1.0.0.exe
Staro 10.10.2006., 20:22   #47
Simba-OS
Simba-OS's Avatar
Postovi: 359
A da pojam "brzina" zamijenite sa pojmom "takt"? Skratiti će se string, a i pravilnije je. Jer se fizikalna veličina BRZINA izražava mjernom jedinicom m/s ili km/h, a (mega)hercima se izražava frekvencija ili - takt.
Također, "deklarirano" bi bilo pravilnije od "originalno" ili "pravo". Ukoliko bi stalo u string.
Simba-OS je offline   Reply With Quote
Staro 10.10.2006., 22:40   #48
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
I see you didn't put any other program for temp monitoring. Can we expect something in newer versions?
Staro 10.10.2006., 22:43   #49
Vuco
Vuco's Avatar
Postovi: 9,505
@Smartguy
Daj pogledaj, čini mi se kao da sam vidio nešto o tome na FAQ-u na službenom site-u od OCCT-a da piše nešto o tome. Da nije moguće nekaj napravit, ili nešto takvo...
Staro 10.10.2006., 22:46   #50
domy_os
domy_os's Avatar
Postovi: 18,847
Da, rekao je da će stavit...
Staro 11.10.2006., 00:40   #51
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
Autor Vucko Pregled postova
@Smartguy
ako dobro vidim spominje se nešto intel core 2 duo ali francuski mi nije baš
pa ako bi moga neko reć koji se program namjerava stavit ili možda prevest sva pitanja.
Staro 11.10.2006., 21:07   #52
hash
Postovi: 1,431
Autor Simba-OS Pregled postova
slazem se s ovim i promjenite 'kučište' u "kućište"
english:
Simba-OS suggested that 'originalna brzina' should be replaced with 'deklarirani takt' , and 'trenutna brzina' should be replaced with 'trenutni takt'
I would also like to add that 'kučište' should be replaced with 'kućište' which is the proper way to spell it
Staro 11.10.2006., 22:01   #53
domy_os
domy_os's Avatar
Postovi: 18,847
Nema šta mjenjat "kučište" u "kućište" kad već stoji "kućište", moj prijevod je u finalnoj verziji.
Je li se još nekome pojavljuje ova poruka kod pokretanja:
Tetedeiench, I've a problem - OCCT bring me this message after I started the program...
Can you fix that?
EDIT: Found out the problem solution. Open Properties of OCCT's shotcut on the desktop and Start Menu too, fill the field "Start in" with this data:
"C:\Program Files\OCCT" (with quotes)
Click OK and that's it.
Staro 11.10.2006., 22:08   #54
Vuco
Vuco's Avatar
Postovi: 9,505
If you have problems of starting, remove the file “occt.ini” in the repertory of OCCT and start again to it… the installor theoretically will do it automatically, but one never knows.
Probaj ovo, tako piše na forumu tamo kod njih
EDIT:
@domy_os
Toga nije bilo kada sam ja gledao
Zadnje izmijenjeno od: Vuco. 11.10.2006. u 22:18.
Staro 11.10.2006., 22:11   #55
hash
Postovi: 1,431
nisam vidio finalnu, : goood :
Staro 11.10.2006., 22:12   #56
domy_os
domy_os's Avatar
Postovi: 18,847
Pogledaj gore EDIT...
Staro 11.10.2006., 22:40   #57
masni
masni's Avatar
Lokacija: Zagreb,Travno
Postovi: 2,110
svaka čast dečki...nema šta...imamo i hrvacki jezik na nekom stress test softveru...totalni zakon...: goood :: goood :: goood :
Tetedeiench - WELCOME TO PCE FORUM CROATIA...
@smartguy (i ostali sa ASUS pločama)...
nemojte se nadati da ce bilo koji softver dobro očitavati temp sa vaše ploče, jer za to nema nade (osim možda neki ultra ***eni update biosa) jer sve ploče krivo očitavaju temp... (barem što se tiče temp procesora)...
Staro 12.10.2006., 14:00   #58
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
Autor masni Pregled postova
znam ja da svi oni čitaju krivo i da neće to bios sredit ali nije mi toliko ni važno.. zapravo najvažnije mi je da imam neku usporedbu da vidim koliko stupnjeva se digne temp ako dignem voltažu za toliko i toliko. Kužiš??
I ja sam imao onaj problem od gore. I sredio go onako :clap:
Staro 12.10.2006., 21:24   #59
Tetedeiench
Postovi: 44
Can you fix that?
Somebody else warned me about that and it's already fixed It was a problem with the install version. Download it again if you want it fixed once and for all
Staro 13.10.2006., 22:33   #60
Jurko
Lokacija: Zg, Kvatrić
Postovi: 148
Proud to be croat.
Jurko je offline   Reply With Quote
