Staro 27.05.2006., 20:36   #31
jjd37
jjd37's Avatar
Postovi: 245
Možda malo OT ali nisam dobro shvatio dali se to dešava samo na 7900 EXTREME verzijama ili na svim 7900? Namjera mi je kupiti 7900GTX ali nakon čitanja ovog nisam baš siguran.
jjd37 je offline   Reply With Quote
Staro 27.05.2006., 20:38   #32
Wolverine
Wolverine's Avatar
Postovi: 12,429
7900GT -> verzije koje imaju više taktove dakle Extreme, XXX i tako dalje...ne obične 7900GT
7900GTX neke i većina Extreme verzija
vidi link na nVidia forum pa ćeš sve znat
http://forums.nvidia.com/index.php?showforum=25
no vele da će sad novije pošiljke dolazit bolje testirane i sa nekim izmjenama (rano su se sjetili)
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 27.05.2006., 20:43   #33
Wooo13
Datum registracije: Feb 2003
Lokacija: RI
Postovi: 67
Bios poslan.Uzeo sam je u Hgspotu.Gainward Bliss 7900GT.
Londo Mollari:
"There comes a time when you look into the mirror, and you realize that what you see is all that you will ever be. Then you accept it, or you kill yourself. Or you stop looking into mirrors."
Wooo13 je offline   Reply With Quote
Staro 27.05.2006., 20:45   #34
Wolverine
Wolverine's Avatar
Postovi: 12,429
khm.....ko je sad tu LUUUUDDD ti ili ja....piše da imaš Leadtek 7900GT a daš mi bios od Gainward-ice i veliš da imaš Gainward
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 27.05.2006., 21:06   #35
Wooo13
Lokacija: RI
Postovi: 67
Ma ja sam lud, maknut cu taj sig da vise ne buni ljude i mene samog .Kako sam prije imao 7800GT od Leadteka samo sam promijenio u 7900GT bez da sam mjenjao proizvodjaca, ono...taj sig me ne dira bas puno pa je upravo zato cesto i kriv.Evo izmijeniti cu, ali ne garantiram da ce opet biti kako treba .Dakle Final conclusion: Da , ja trenutno imam Gainward Bliss 7900GT...
Londo Mollari:
Staro 27.05.2006., 21:08   #36
jjd37
jjd37's Avatar
Postovi: 245
Autor Wolverine
Hvala izgleda da ću ipak pričekati s kupnjom: nono : ili ostati na ATIju pa makar se i grijao ko visoka peč željezare.
Staro 27.05.2006., 21:34   #37
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Autor Wolverine
samo malo Ozy ... odeš u dučan ... vidiš 7900GT 2600kn i pored nje 7900GT Extreme 2630kn.... taktovi 450/660 vs 520/715 koju ćeš uzet?
Istina
Samo bed je sad to što kenja,malo se igraj,pa ako ne napraviš ništa,reklamiraj im to...
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
Staro 31.05.2006., 22:52   #38
Wooo13
Lokacija: RI
Postovi: 67
Evo ja sam montirao VF-900 i nemogu reci da sam pretjerano odusevljen...naime sa Vmodom GPU-a na 1.4V temp je u idle-u oko 45C a u COD2 koji definitivno rastura bar sto se tice zagrijavanja temp je 75C.Vent na full speed.Kada je vent na minimumu temp se penje za nekih 5C.Nakon toga sam vidio da to i nije bas zdravo previse pa sam Vmodao na 1.3V GPU i sada su temp puno bolje.Frekvencije sljedece: 620/1800(da, da memorija odjednom radi na 1800...prije je max bio 1750), a sada su temp Idle: 42C , Full load: 64C...puno bolje a prakticki sam izgubio samo 30tak Mhz na GPU-u.
Sto se tiče VF-900 unatoc tome sto nije bas clockerski vent, odlican je, lagan, montaza je smijesno jednostavna, ultratih na minimumu a relativno tih na maksimumu.Sve u svemu vrlo dobar hladnjak, ali za 230 kn to se i ocekuje...
Londo Mollari:
Staro 01.06.2006., 12:22   #39
Wolverine
Wolverine's Avatar
Postovi: 12,429
ček samo malo sa VF900 ti je temp 75°C
pa meni je (napravi sam vmod) 1,55v 700MHz temp 62 u full load-u
na 1,4v 660MHz je 55
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 01.06.2006., 13:58   #40
Orthodox
Orthodox's Avatar
Lokacija: Ostrovo
Postovi: 351
Wolverine, kako radiš 1,4 i 1,55 vmod?
Pogledao sam na netu malo oko toga, ali mi nije baš sve u potpunosti jasno.
Ja sam izgleda ubo dobar primerak 7900GT (thx to Goran aka vranoga1) i volio bih da znam kako da iz nje izvučem maximum (sada prvo samo testa radi, a kasnije kada to zaista zatreba). Inače grafu držim na default frekvi, jer stvarno za sada nema potrebe za nekim 24/7 overclockom.
Orthodox je offline   Reply With Quote
Staro 01.06.2006., 14:59   #41
Wolverine
Wolverine's Avatar
Postovi: 12,429
vmod GPU-a je jako lagano naopraviti...IMHO 1,55v nije baš dobro jer neke jezgre se onda jako griju a ovisi i o komponentama na grafi! 1,4-1,45v ti je sasvim dovoljno za cca 600-650MHz (moja sa 1,4v ide na 650MHz)
vmem nemoj raditi ne zbog čipova već zbog mosfeta i kondenzatora koji se znaju napuhnuti (a mosfeti izgoriti) probaj prstima dal se griju...na XS-u vele da se JAKO griju no moji su hladni ali lto je vjerojatno zato što moja ima već tvornički napravljen vMem mod (baš sam jjučer gledao)
u glavnom mod radiš tekućim srebrom.... slike ti postam kasnije...sad sam na faksu
mod može biti
1,25 ; 1,3v ; 1,35v ; 1,4v ; 1,45v ; 1,5v ; 1,55v
a hard modovima sa lemljenjem otpornika ide na 1,75v ali to je već jako ekstremno!
Dobre jezgre idu sa 1,5-1,55v na 700+ moja ide na 720MHz na 1,55v
P.S. sa stock hlađenjem ne preporučam nikakav mod viši od 1,3v
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 01.06.2006., 15:11   #42
Wooo13
Lokacija: RI
Postovi: 67
Da, temp su takve kakve sam napisao , barem tako keze rivatuner.Moguce da senzor laze kod mene ili kod tebe.Iako kada uzmem u obzir da se 7900GTX sa onom zvijerkom od stock coolera grije pod full loadom na 68-70C nekako mi je cak temp. kod mene realnija kada se uzme u obzir sljedeca tvrdnja covjeka koji je probao VF-900 na GTX: I have the Evga 7900GTX and thought that the Zalman VF900 would work better since the review on the 900 were so good. So I tried it. My temps went up 3c at idle and 6c at load. You really cant beat the stock GTX cooler.
Sad tesko je ista reci, kao i kod procesora GPU takodjer moze biti iz boljeili losije serije, na par siteova po reviewovima ljudi pisu da GTX u full loadu neide preko 55C dok sam vidio kako se spominju temp od 70C, pa cak i 100C.
Za Orthodox-a:
http://forums.extremeoverclocking.co...d.php?t=216265
Ne znam sto ti tu nije jasno...
Londo Mollari:
Staro 01.06.2006., 15:26   #43
Wolverine
Wolverine's Avatar
Postovi: 12,429
Autor Wooo13
Za Orthodox-a:
Gle meni su temp ako gledam u Rivi, Everestu, driverima
stock napon 12v VF900
idle 40 load 47
1,4v
idle 41 load 50
1,55v
idle 42 load 62
grafa je i na dodir mlaka, kao i mosfeti koji su na dodir topli...
ono kod tebe su za 1,4v prevelike temp...mislim gledao sma gro review-a i svugdje su temp na stock naponu ko kod mene.
ono o serijama stoji jer Daddy ima 7800GTX koja je nevjerojatno hladna dok se moja 7800GT grijala i do 10°C više sa istim coolerom!
Jel ti VF900 vruć na dodir...IMHO da je 75°C nebi ga mogo primit u ruke...
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 01.06.2006., 18:05   #44
Wooo13
Lokacija: RI
Postovi: 67
Ovako, povadio sam van DVB-S i DVB-t kartice koje su dodatno podgrijavale stvar... i sada je na 1.3V @ 620/1800 temp u idle-u 38 C, a u load-u oko 56C sto je nekih 10C nize nego prije...sto i dalje opet nije sjajan rezultat s u odnosu na tvoje load temp koje su nize cak i pri 1.4V.Pogotovo mi nije jasno to sto je meni idle temp niza nego tebi, a load temp je visa.Mozda je jednostavno GPU kod tebe bolji ili senzor neciji laze.Kada je GPU bio na 75C vf900 je bio topao, ali mogao sam ga drzati bez problema, rekao bih otprilike oko 45C iz cega bi se dalo zakljuciti da senzor kod mene laze...
U svakom slucaju 620/1800 je vise nego dovoljno pa cu vjerojatno ostati pri tome, mozda jos eventualno probam 1.55V cisto da vidim koliko GPU moze...
Superzadovoljan sam ovim modom sa srebrnom tintom jer evo jucer sam prepravljao mod 1.4V na 1.3V i uz malo alkohola i stapica za usi tinta se skine bez problema i u slucaju nekog kvara, kartica se moze dati na servis bez vidljivih tragova moda.
Londo Mollari:
Staro 01.06.2006., 21:05   #45
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,826
evo da se ubacim nevezano uz temu al samo ukratko ak mi ko može reč coolbits mi izbaci optimal detect frequencies 607/798.driveri84.21..pa me zanima dali bi te postavke mogo koristit bez problema?il bi trebal neke testove provrtit?sad to je kakti neki lagani clock..konfa iz siga...hvala
Staro 01.06.2006., 22:44   #46
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor zvonac_1
Najpametnije ti je pomalo clockat i vrtiti testove.
Staro 01.06.2006., 22:50   #47
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Autor zvonac_1
Ja sam uvijek vrtio bezbeda, što god i s kojom god grafom sam probao.
Znači, ono što mi je coolbits rekao, to mi je uvijek radilo, a kad sam isprobavao malo po malo još više od toga, bilo je oko 10MHz više sam uspio naterat bez grešaka i nuspojava.
MC
Staro 02.06.2006., 05:33   #48
zvonac
zvonac's Avatar
Postovi: 5,826
ok.znači mogu se držat onog kaj coolbits izbaci taj optimal?ne vjerujem da bi sad baš tak pogrešil s frekvama....pošto je ovo najbrži način..
Staro 02.06.2006., 10:51   #49
Zvijerko
Pečurka
Zvijerko's Avatar
Lokacija: U blizini Osijeka
Postovi: 1,294
Pa ja baš i ne bih vjerovao coolbitsu, jer meni kao optimalnu stavi 360 i nešt mhz, a vidiš na kojoj frekvenciji radi bez problema
ECS Z77H2-A2X Deluxe
I5 3350P
G-Skill 16 GB DDR3 2133MHz
Gainward Phantom GTX760
250 GB Samsung Evo Basic SSD
XFX XTR 650W
Silencio 650
Zvijerko je offline   Reply With Quote
Staro 03.06.2006., 21:17   #50
kameni
kameni's Avatar
Postovi: 78
Samo par rjeći kaj se teperatura tiće mali igra po 5-6 sati u komadu
(kad ode pišat brzo pogledam temp ) i mogu reći da nisam vidio da je bila veća od 58
grafa radi na 700-1700
intel i7 920 , asus p67deluxe , corsisr750w
ddr3 2x4gb,hdd wd640gb vga asus gtx 295
kameni je offline   Reply With Quote
