Staro 29.04.2006., 01:42   #31
Mailman
Mailman's Avatar
Postovi: 1,606
Autor OveRkiLL
ne znam, tad je bila zadnja pošiljka koja se da otključat valjda, kažu samo da se ove prije tog datuma otključavaju ako su Connect3D, ali i neke HIS.
to su većinom bile XL samo flashane u GTO, neke su čak imale naljepljeno GTO preko XL oznake.
tko kaže? imaš li neki link? na techpowerup forumu nisam puno toga našao a baš me zanima...
Mailman je offline   Reply With Quote
Staro 29.04.2006., 01:48   #32
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
Autor OCW Forum
so far, as far as i can tell, the device id usually doesn't change. however, one user reported that his HIS card actually had a XL label on it with a GTO sticker. It seems that HIS may have just flashed XLs at least initially..
http://www.ocworkbench.com/ocwb/ulti...24/1934/9.html
pročitao sam negdje da su te dolazile prije 15.3., al ne znam di više, potražit ću još.
EDIT: našo sam, na 1. stranici onog threada gore
Autor OCW Forum
In the previous news item, there is a report that the X1800 GTO can be flashed into a X1800XL.
According to our sources, the early batches as early as March 15 were using X1800XL chips. This may not be limited to review samples sent out during that period of time.
If you happen to have an early batch of the X1800GTO, you might be having a X1800XL with the pipelines "locked" to 12pipelines. Flashing in a X1800XL will unlock it to a full fledge X1800XL.
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
