Staro 22.02.2018., 12:14   #31
Kolega robimarko-bug je stavio link:
https://support.amd.com/en-us/kb-art...em-Bootup.aspx
Vi koji ste uzeli 2200G ili 2400G, zatrazite ovaj A6 Bristol Ridge i šerajte ga tu po forumu za pivu
Sent from Mobara
Staro 22.02.2018., 12:26   #32
ti.le
[CTN]Mr.Ti
ti.le's Avatar
Lokacija: Zg, Novi Zg
Postovi: 567
To je LOAN KIT koji se vraća u roku 10 dana od primitka (ima plaćeni return shipping), a i prije treba kontaktirati proizvođača ploče koji bi trebao:
The Original Design Manufacturer (ODM) of the motherboard will support affected end users with an RMA exchange for a compatible motherboard, upon request. Affected end users are recommended to contact their local representative for the motherboard manufacturer to exchange their motherboard.
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO
ti.le je offline   Reply With Quote
Staro 22.02.2018., 12:47   #33
robimarko-bug
Datum registracije: Jul 2013
Lokacija: Tenja(Osijek)
Postovi: 1,138
Ne moraš uopće kontaktirati vendora.
Otvoriš RMA case gdje te traže serial s CPU-a i ploče ako se ne varam i onda ti shippaju taj CPU s return labelom i kada si završio samo ga pošalješ nazad.
Free je shipping i return je isto plaćen.
Staro 22.02.2018., 13:21   #34
ti.le
[CTN]Mr.Ti
ti.le's Avatar
Postovi: 567
This service is free of charge with the following condition:
Once you have submitted your claim for a processor loan boot kit, AMD will require a picture of your Ryzen with Radeon Vega graphics processor, that clearly shows the model number and unique serial number as well as a copy of the purchase invoice to authorize the request. Additionally, a summary or copy of communication with the motherboard manufacturer is requested to indicate why support from the Original Design Manufacturer (ODM) is not suitable
Staro 23.02.2018., 21:58   #35
rebuss
Datum registracije: Dec 2016
Lokacija: Sinj
Postovi: 9
Autor rebuss Pregled postova
Kupio sam MSI Mortar 350m matx. Ona mi je jedina bila kod njih za kupit a najvise mi je odgovarala.
Vidit ce mo u petak kad dodjem doma, nadam se da ce bootat :fingerscrosed:
Poslano sa mog SM-G935F koristeći Tapatalk
Nema slike, nema ton samo vrte vent? A ii jadaaa
Edit: jel ja iman pravo vratit plocu i cpu nazad?
Zadnje izmijenjeno od: rebuss. 24.02.2018. u 01:07.
rebuss je offline   Reply With Quote
Staro 24.02.2018., 15:09   #36
Ako si kupio preko neta, da, u 14 dana. Vrati i kupi tamo gdje to ne naplaćuju vidi u Uzi Shop temi, zadnja 4 posta se piše o tome
Sent from Mobara
Staro 25.02.2018., 03:32   #37
KrpaZG
Detect, Respond, Complain
KrpaZG's Avatar
Datum registracije: Dec 2011
Lokacija: Remote
Postovi: 253
Jos uvijek se ne naplacuje slaganje konfiguracije i instalaciju windowsa ako se kupi u ducanu
I Read Logs So You Don’t Have To
Zadnje izmijenjeno od: KrpaZG. 25.02.2018. u 07:14.
KrpaZG je offline   Reply With Quote
Staro 25.02.2018., 17:03   #38
croshad
Postovi: 80
Autor RimtuTiTuki Pregled postova
Je... nekad nisu ni slaganje konfiguracije i instalaciju windowsa naplačivali...
Ček, hoćeš reći da ako uzmem cijelu konfu kod nekog, da će mi naplatiti slaganje ?
croshad je offline   Reply With Quote
Staro 25.02.2018., 18:31   #39
Neki dućani hoće.
Sent from Mobara
Staro 26.02.2018., 19:02   #40
rebuss
Lokacija: Sinj
Postovi: 9
Evo zvao adm. Oni u ducana naplacuju 125kn(ka sta sam spominja), dok ovi u njihovom servisu to naplacuje 60kn :S
I sta cu, poslao u zagreb u njihov servis
Staro 26.02.2018., 19:31   #41
Ti ne čitaš kaj sam ti napisao?
14 dana imaš fore DA VRATIŠ ROBU i DOBIJEŠ POVRAT NOVACA. I onda kupiš sve ponovno u dućanu koji ti NEĆE NAPLATITI FLEŠANJE, npr. UZI SHOP.
Ali dobro, kad se tebi bacaju pare "šalji tamo, šalji natrag i daj flešaj" u vrijednosti SSD-a 128GB, samo ti daj
Staro 26.02.2018., 19:44   #42
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
.. još uvjek stigne reći da ne fleshaju nego neka mu samo vrate lovu ..vjerujem da će mu biti nekim čudom besplatno
MojSkuter
Staro 26.02.2018., 19:55   #43
Kaj ne treba obrazac ispuniti za to prije...?
Sent from Mobara
Staro 28.02.2018., 21:54   #44
Frung
Frung's Avatar
Lokacija: zg westside
Postovi: 625
Okej, danas stigla pošiljka u Uzi, Gigabyte GA-AB350M-DS3H i R3 2200G
Memorija prije kupljena, Kingston Predator 2x4GB kit 3200
Nabrzinu sam sklepao mašinu, opažanja:
1. Ploča je došla s inicijalnim F1 BIOSom (18.01.2018), eksplicitno sam tražio da ga ne flešaju, i 2200g kurbla iz prve, BIOS sam updateao bez problema na najnoviji 22b (13.02.2018) preko QFlasha iz BIOSa
2. Ne radi mi XMP1 na 3200, radi XMP2 na 3000, s tim ću se još probati igrati
3. Bootao bez greške u W10 64 originalno instaliran na b85 haswellu
4. Ova b350m ploča ima zapravo X370 ČIPSET!!! Originalno mislio da je samo dokumentacija na webu kriva, ali ista stvar piše i na kutiji, i u speccyu, i u aidi itd. Na redditu još spominjali da je gigabyte potvrdio to https://www.reddit.com/r/Amd/comment...coming_450470/
Isto tako kažu da i nema neke razlike u fičrima
Ali zanimljivo, obzirom da je najjeftinija X370 ploča oko 1000 kn, ovo praktički duplo manje
5. RADI HDMI 2.0 4K@60 Hz ! Ovo na integriranim grafikama kod intela ima JEDINO Z370N gigabyte s posebnim chipom koji jedan displayport converta u hdmi 2.0. Ispravite me ako griješim, ali dosta sam to istraživao
Performanse isprobao u Wowu i AC:Origins do sad, igrivo Nisam clockao jos cpu ni gpu, nemam bas kuciste provjetreno za to trenutno
Zadnje izmijenjeno od: Frung. 01.03.2018. u 10:07.
Frung je online   Reply With Quote
Staro 28.02.2018., 23:16   #45
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Ne može biti x370 čipset kad "nema extra funkcionalnosti nad b350" jer je to čitava poanta čipseta (x370 ima recimo CF/SLI, više konekcija i sl.)
Vjerojatno se radi o tome da mbo koristi isti pcb kao jeftinije gigine x370 mbo ili nešto tako pa neki programi registriraju tako (recimo za moju mbo u aidi piše B350-F/X370 prime pro i još jedna mislim)
Staro 28.02.2018., 23:31   #46
Frung
Frung's Avatar
Postovi: 625
A vidi ovo:
https://www.gigabyte.com/Motherboard...DS3H-rev-1x#kf
Znači blizanke, svaki port isti. Samo štampa oznake modela na ploči, BIOSi svi imaju identične verzije na isti dan izašle.
Staro 28.02.2018., 23:46   #47
Manuel Calavera
Postovi: 14,589
Gdje je SLI support recimo? (mus za x370 čipset)
Gigabyte očito čipsete tumači na svoju ruku
EDIT
Vidim nisu jedini, gledam sad x370-a - samo crossfire, no one ne supportaju ni to prema siteu
Zadnje izmijenjeno od: Manuel Calavera. 28.02.2018. u 23:52.
Staro 28.02.2018., 23:56   #48
Frung
Frung's Avatar
Postovi: 625
A na kupcu je očito da provjeri koliko je proizvođač fičra čipseta zapravo odlučio implementirati na ploči. Ovo je samo primjer kako iz jednog proizvoda na papiru napraviti 2 za različite segmente tržišta. A možda im je fakat usfalilo b350 čipova za matične. Ploča ima 2xpcie 16 slota, nazivno može i SLI i Xfire, nažalost nemam dovoljno odgovarajućih kartica za isprobati.
https://en.wikipedia.org/wiki/Socket_AM4
Staro 28.02.2018., 23:58   #49
Manuel Calavera
Postovi: 14,589
Da ima 2 slota, ali CF i SLI support moraju izričito navesti ako podržava.
Ako se to sve tumači labavo koja je uopće poanta čipseta, onda svaku ploču možeš nazvati svakako
Staro 01.03.2018., 12:22   #50
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Nema labavo
Ma ocito fusaju, ili igraju na gratis opcije kao kod procova gdje si dobio extra jezgre.
MojSkuter
Staro 01.03.2018., 12:25   #51
Gigi1
Postovi: 2,138
Autor Frung Pregled postova
za cpu spusti voltaze, a ostavi stock settingse na clockovima, ocaj samo gpu i vozi bez dobro provjetrenog kucista
Staro 01.03.2018., 14:51   #52
Necronomicon
सच्चाई यह है कि वहाँ से ब
Necronomicon's Avatar
Lokacija: Dubrovnik
Postovi: 570
A vidi ovo:
Zanimljivo...
Vidim i na kutiji od ove AB350M DS3H piše da ima X370 chipset.
Specifikacije na webu iste.
Što je po pitanju VRMa?
Da probaš flashnut bios od ove AX370...
Necronomicon je offline   Reply With Quote
Staro 01.03.2018., 14:53   #53
Frung
Frung's Avatar
Postovi: 625
Eh, bi da ima dual BIOS Ovak mi je malo frka. Al ozbiljno, mislim da je jedina razlika labela modela koji ti piše u BIOSu.
Eh da, nove generacije GIGE ne podrazumijevaju dual BIOS više, sad je to high end mobo fičr. Tak da se ljubitelji GIGE ne zalete bez da provjere jel tog ima na toj ploči.
Staro 01.03.2018., 17:31   #54
nino
nino's Avatar
Postovi: 12,613
Danas preuzeta.
Staro 01.03.2018., 17:39   #55
Kad stižu procOvi ? Naravno, da nisu ovi 2200 i 2400
Sent from Mobara
Staro 01.03.2018., 17:44   #56
robimarko-bug
Postovi: 1,138
Kažu travanj.
Staro 02.03.2018., 15:14   #57
nathan.fake
Lokacija: n/a
Postovi: 1,258
Nista novo za Gigabyte, nedavno sam kupio AM3 plocu GA-970A-DS3P FX po imenu bi pomislio da ploca koristi AMD 970 chipset, al je zapravo "jaci" AMD 990FX (naravno nikake koristi nema, jer sama ploca ne koristi dodatne PCIe linije 990FX chipseta te je funkcionalnost identicna 970 chipu).
Ista stvar sa B350 i X370, vjerovatno ciste lagere, spremaju se za X470
U principu chipset vise nije ni tolko bitan, jer je Ryzen SoC, vise manje je sve u samom procesoru.
Ovo je potvrdio AMD PR-ovac... HDMI 1.4 na nekim plocama sa novim APU se "pretvara" u HDMI 2.0.
1. slot je PCIe 3.0 x16 (vuce linije direkt iz CPU-a)... stvar se komplicira dalje: ako koristis APU, onda taj slot radi kao PCIe 3.0 x8
2. slot je PCIe 2.0 x4 (vuce linije iz chipseta)
Ovakva konfiguracija podrzava samo AMD Crossfire.
Teoretski bi vjerojatno radio i SLI, ali Nvidia trazi minimalno dva x8 slota te naravno naplacuje SLI certifikat... zato samo high end ploce podrzavaju SLI.
Zadnje izmijenjeno od: nathan.fake. 02.03.2018. u 15:32.
nathan.fake je offline   Reply With Quote
Staro 12.03.2018., 10:36   #58
Schtefek
Schtefek's Avatar
Datum registracije: Jun 2010
Lokacija: Križevci
Postovi: 172
Pomoć
Kupio sam matičnu GIGABYTE GA-AB350N-Gaming WIFI i AMD Ryzen 5 2400G ali matična nema ažuriran BIOS, vele mi da bi mogao donijeti matičnu pa mi oni napravili update, ali da to košta isto oko 125 kn, i treba čekati nekoliko dana da mi vrate, ali znam da bi to trajalo oko 7-10 dana, a neda mi se vračati sve. Jel ima netko za posuditi APU ili neki drugi proc za AM4 samo da ažuriram bios?
Plaćam pivu.
Schtefek je offline   Reply With Quote
Staro 12.03.2018., 11:03   #59
Javi se AMDu da ti posudi CPU.
Brže i jeftinije će ti oni to poslati.
Ili...
Ako si kupio preko neta, vrati sve tamo gdje je kupljeno i neka ti vrate lovu.
I onda kupi tamo gdje će ti mukte flešati. Pogledaj malo ovu temu, vidjeti ćeš da postoje dućani koji će ti to odraditi za Đ.
Ili napravi kako misliš da treba i okini 150+ kn za flešanje i poštarinu.
Eto
Sent from Mobara
Staro 12.03.2018., 11:24   #60
Schtefek
Schtefek's Avatar
Lokacija: Križevci
Postovi: 172
Ili...
Eto
Sent from Mobara
Nisam, kupio direkt u dućanu, a ne da mi se čekati tjedan dana da mi pošalju. Ma riješiti ću to nekako.
