Staro 15.06.2017., 15:36   #31
Postovi: 23,634
Igraj se jer ništa od tih "naprednih" funkcija nije dokumentirano i potvrđeno da stvarno rade.
Ne treba zaboraviti da (ovisno od routera do routera), brzina transfera zna biti problematična.
Po meni usb na routeru (ove igračke od operatera) jedino valja za print share ako se može složiti,
kod normalnih aftermarket routera je druga priča.
Staro 15.06.2017., 16:02   #32
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Primjetih da ništa nije dokumentirano. Zato i tu tupim.
Brzina je nikakva. Koriranje je max 3 MB/s (u rijetkim slučajevima do 5), ali ipak je dovoljno za stream 1080p materijala.
Koji bi router bio dobar za Wi-Fi share network diskova?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 15.06.2017. u 16:09.
estugarda je offline   Reply With Quote
Staro 07.01.2021., 18:56   #33
cdhr
cdhr's Avatar
Datum registracije: Jul 2016
Postovi: 161
Isto pitanje ali 2021 godina
Piknuo unutra 1TB FAT externi hdd
Pod storage device očita ga bez problema:
disk1_1 fat 953635 24414
Kreirao user account
Kako da mu pristupim preko file expolerer ili ?
Jer trebam imati neki storage lokalni u mreži gdje kad nešto trebam mogu prebaciti na storage neovisno koji uređaj je spojen na njega.
thx
Isto na iskon ali je InnboxV51 AnnexB što je realno isti šrot kao i v45 smeće što je realno sve smeće jer dolazi od Iskon-a
cdhr je offline   Reply With Quote
Staro 07.01.2021., 20:43   #34
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,560
mislim, nisam 100% siguran, da je to samo ftp.
probam za 15tak minuta pa ti javim
edit meni to ne šljaka, idem na create user, apply, i samo stane prazna stranica. niti greške, niti odradi posao.
moguće da imam verziju fw-a koja to ne dozvoljava.
Zadnje izmijenjeno od: jp_rv. 07.01.2021. u 21:33.
Staro 07.01.2021., 22:48   #35
cdhr
cdhr's Avatar
Postovi: 161
Pa čini se i meni da mi ovo neda glupi ruter...joj zvati iskon .....joj
javim kad se čujem sa profesorima...
EDIT:
To je po iskon default isključeno
Odmah kontra a zašto je to isključeno i zašto ja to sad nemogu koristiti?!
Javiti će mi povratno nakon upita dali mi mogu riješit FW gdje je to otključano..
iskon
Zadnje izmijenjeno od: cdhr. 07.01.2021. u 22:53.
Staro 07.01.2021., 23:02   #36
Postovi: 23,634
Dobit ćeš košaricu ... napredne funkcije ... nedaju podršku ...
Ako nabodeš superuser / admin usera možda aktiviraš funkciju.
Staro 07.01.2021., 23:37   #37
jp_rv
Lokacija: istra
Postovi: 3,560
Neće ići. Baš je fw takav.
Staro 08.01.2021., 12:46   #38
Night
Lokacija: Dbk
Postovi: 1,327
Operateri često zaključaju opcije koje nisu nužne za njihovu uslugu. Ima smisla, jer se korisnička i tehnička služba ne želi baviti upitima tipa "zašto mi ne učitava titlove sa filma koji sam skinuo s torenta i stavio na USB stick uštekan u vaš router."
