Staro 19.12.2013., 13:38   #31
yoke
yoke's Avatar
Postovi: 440
Autor Mileni Pregled postova
Da, bijele boje su slusalice i punjac. Tako sam i ja uz svoj (sad vec prodani) Note 3 dobio. Ne znam sta te to toliko cudi, vecina daje bijelu boju. I proslogodisnji Note2 je cini mi se dolazio uz bijele slusalice.
ne znam, meni je nekako logicno da uz crne uredjaje ide i ostatak crne opreme...
ali o.k.
yoke je offline   Reply With Quote
Staro 19.12.2013., 14:51   #32
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Da. Sva prateća oprema je bijela. Jebiga. Samsung je cijepljen protiv bilo kakvog promišljanja industrijskog designa koje bi išlo bilo gdje drugdje osim u ekonomsku računicu, kad su u pitanju stvari koje nemaju izravnu funkcionalnu ulogu.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 19.12.2013., 16:24   #33
Mileni
Mileni's Avatar
Postovi: 1,554
Autor yoke Pregled postova
ali o.k.
Ista stvar je i kod Applea. Bijele slusalice uz crni iPhone. A ja tu bijelu ne mogu smisliti ocima. No Apple slusalice je problem promijeniti jer su jako kvalitetne. No ja bi najradije crne
Staro 19.12.2013., 20:45   #34
yoke
yoke's Avatar
Postovi: 440
ne znam tko ovima iz samsunga bira slusalice
kao da su iz china shopa za 8kn
dobro, lako ih je promjeniti
ali kad vec prodajes kao nekakav highend uredjaj pa bar daj kvalitetne slusalice u boji uredjaja...
inace ne zvuce lose,onako, kao nekakve sluhe od 100-150kn, ali zato lose leze u usima
bar mojim
oblik im je totalno kriv
Staro 19.12.2013., 20:57   #35
yoke
yoke's Avatar
Postovi: 440
sad sam vidio koji sam idiot
G2 je 9kuna
jucer je bio 600...ne mogu vjerovati ali dobro
(nije mi palo na pamet da provjerim dali su se cijene promjenile u jednom danu)
Zadnje izmijenjeno od: yoke. 19.12.2013. u 21:04.
Staro 20.12.2013., 10:37   #36
fishkal
fishkal's Avatar
Datum registracije: Dec 2009
Postovi: 1,116
Znači po cijeni Notea imaš g2 i 2 odojka? Čak i gajba pive se ubaci u proračun.
Kad se tako pogleda, mislim da si pogriješio :-)
Šalim se malo, sretno s Noteom.
Gledam, čitam, kad ne znam pitam!
fishkal je offline   Reply With Quote
Staro 20.12.2013., 11:40   #37
Lak
Lak's Avatar
Datum registracije: Feb 2010
Postovi: 397
Da li je to možda u Vip-u kupljeno? Sa 50% popusta na prvih 12 mjeseci na 400 kn tarifu.
Ako nije, gdje to ima LG G2 za 9 kn i mjesečno 250 kn pretplate bez nekih caka da tih 250 kn nakon 12 mjeseci postane 450 kn?
Lak je offline   Reply With Quote
Staro 20.12.2013., 13:14   #38
antebr
antebr's Avatar
Postovi: 421
Autor Lak Pregled postova
Vip, ako prebaciš broj u njihovu mrežu.
antebr je offline   Reply With Quote
Staro 20.12.2013., 13:20   #39
Lak
Lak's Avatar
Postovi: 397
I onda 250 kn mjesečno prvih godinu dana, nakon toga 450 kn?
Staro 20.12.2013., 18:19   #40
antebr
antebr's Avatar
Postovi: 421
Ne, 250kn 2 god.
Pa pise ti na njihovim stranicama.
http://m.vipnet.hr/pretplatnici/nove-tarife
Staro 20.12.2013., 18:46   #41
yoke
yoke's Avatar
Postovi: 440
Da u vipa...
ja sam prbacio broj
2godine 250kn/mjesecno + 5kn radijske
zafrk je jedino sto u ovoj tarifi nisu poruke...osim onih prema vipu...
tamo da cu morati pronaci neko rjesenje...imam viber...ali je pitanje dali ga imaju i ostali kontakti...
jos jedan mali ispravak
sluhe su ipak malo bolje kvalitete
pri tome mislim na zvuk...
sviraju bolje od nekih sony koje sam platio oko 200kn
ali je dizajn i dalje ocajan ...meni malo lose leze u usima
Staro 20.12.2013., 19:38   #42
Lak
Lak's Avatar
Postovi: 397
Nisam vidio da za prebacivanje broja pogodnost traje 2 godine.
Malo điberski da u 250 kuna nema poruka prema svima.
Nisam zainteresiran ipak, previše je to novaca
Staro 21.12.2013., 08:36   #43
yoke
yoke's Avatar
Postovi: 440
Autor fishkal Pregled postova
Ma znam
Samo eto...
bar imam sredstvo za samoobranu...sto s G2 nebi imao
Staro 21.12.2013., 11:11   #44
fishkal
fishkal's Avatar
Postovi: 1,116
Ma bit ćeš oduševljen, svi ti današnjimtop uređaji su strava.
