#31 |
M.U.P.
Datum registracije: Sep 2004
Postovi: 2,277
Pogledaj u everestu i u ati toolu. |
#32 |
Avocado
Postovi: 7,856
Field Value Graphics Processor Properties Video Adapter GeCube Radeon 9600 XT Game Buster GPU Code Name RV360 PCI Device 1002 / 4152 Transistors 76 million Process Technology 0.13u Bus Type AGP 4x Memory Size 128 MB GPU Clock 459 MHz (original: 459 MHz) RAMDAC Clock 400 MHz Pixel Pipelines 4 TMU Per Pipeline 1 Vertex Shaders 2 (v2.0) Pixel Shaders 1 (v2.0) DirectX Hardware Support DirectX v9.0 Pixel Fillrate 1836 MPixel/s Texel Fillrate 1836 MTexel/s Memory Bus Properties Bus Type DDR Bus Width 128-bit Real Clock 290 MHz (DDR) (original: 290 MHz) Effective Clock 580 MHz Bandwidth 9280 MB/s Memory Timings CAS Latency (CL) 4T RAS To CAS Delay (tRCD) 5T RAS Precharge (tRP) 4T RAS Active Time (tRAS) 9T Row Refresh Cycle Time (tRFC) 15T RAS To RAS Delay (tRRD) 3T Write Recovery Time (tWR) 4T Graphics Processor Manufacturer Company Name ATI Technologies Inc. Product Information http://www.ati.com/products/gamer.html Driver Download http://www.ati.com/support/driver.html ovo ti je iz everesta pod display-GPU
Spoiler alert! |
#33 |
Avocado
Postovi: 7,856
______________________________ General Display adapter Radeon 9600XT (4152) Core Name RV360 SubVendor GeCube\GeXCube\GIGACUBE (18BC) SubDevice 0243 BUS 1 Device 0 Function 0 Base Address 0 C0000008 Base Address 1 0000C001 Base Address 2 E9000000 Base Address 3 00000000 Catalyst Registry Path System\CurrentControlSet\Control\Video\{02C89848-969F-40C7-B723-9E24CE2858F5}\0000 ______________________________ Clock Information BIOS VPU 459,00 Current VPU 459,00 BIOS MEM 290,25 Current MEM 290,25 ______________________________ Radeon PCI configuration space 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 02 10 52 41 07 00 B0 02 00 00 00 03 08 FF 80 00 10 08 00 00 C0 01 C0 00 00 00 00 00 E9 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 BC 18 43 02 30 00 00 00 00 58 00 00 00 00 00 00 00 0B 01 08 00 40 00 00 00 00 00 00 00 00 00 00 00 00 BC 18 43 02 50 01 00 02 06 00 00 00 00 02 50 20 00 17 02 00 4F 60 12 03 00 1F 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ______________________________ Hardware Information Installed memory 128 Mb Memory Type DDR SDRAM Memory Width 128 bit Active Rendering Pipelines 4 ______________________________ ASIC details Family 45 Emulated Revision 3 Gfx Engine ID 0 ______________________________ Radeon Registers RADEON_BIOS_0_SCRATCH 00040004 RADEON_BIOS_1_SCRATCH 0100C000 RADEON_X_MPLL_REF_FB_DIV 03222B04 RADEON_XCLK_CNTL 00A07FF9 RADEON_MCLK_CNTL 00031212 RADEON_XDLL_CNTL 0400BC30 RADEON_XPLL_CNTL 48001A00 GB_TILE_CONFIG 00010011 MC_TIMING_CNTL 1B391922 MC_SDRAM_MODE_REG 31420042 MC_REFRESH_CNTL 00002023 ______________________________ Video BIOS Information Version 008.017D.016.00 Part Number BK-ATI VER008.017D.016.000 Date 2004/10/22 10:05 ______________________________ Controller Configurations Controller 0 Active Connections: -Primary Display (0) 1024x768x85 Controller 1 Active Connections: No Active Connections ______________________________ Displays supported by adapter 0 Monitor (CRT1) 1 Second Monitor (CRT2) 2 Component Video Output 3 TV 4 Digital Flat Panel a ovo iz ati tray.
Spoiler alert! |
#34 |
Hejter
Postovi: 6,521
Ne znam , ovo moje se valjda malo zblesiralo , ili je mozda do toga kaj imam drivere malo stariju omegu , mislim na catsima 4.11 . |
#35 |
Lokacija: Zagreb-Dubrava
Postovi: 505
Meni u everetu i ati tool pokazuje rv360. Za xt extreme sam procitao u jednom ducanu (mislim Feniks) imala je hladnjak od x800. Valjda su krivo napisali. Znaci ovo je tvoja. Imam jedno pitanjce vidio sam da se u ati tool-u moze podesavat latencije memorije jel neko to podesavao i na koliko. |
#36 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
koja je max dopuštena temp GPU? nabavio sam gecube infinity, stock frekve su joj 470/700.. probao sam atitoolom clockati, gpu mi se sruši na 515, a memorija odmah na 705, što mi je čudno... ,alo sam nešto kemijao oko hlađenja... |
#37 |
Hejter
Postovi: 6,521
Everest pokazuje ovo: Informacije o grafičkom procesoru: Grafička kartica ATI Radeon 9600 XT (RV360) Kodno ime grafičkog procesora RV360 PCI uređaj 1002 / 4152 Broj tranzistora 76 milijuna Tehnologija izrade 0.13u Tip sabirnice AGP Kapacitet memorije 128 MB Radni takt grafičkog procesora 520 MHz RAMDAC radni takt 400 MHz Pixel cjevovoda 4 TMU po cjevovodu 1 Vertex shader-a 2 (v2.0) Pixel shader-a 1 (v2.0) Hardverski podržani DirectX DirectX v9.0 Pixel Fillrate 2080 MPixel/s Texel Fillrate 2080 MTexel dakle Tray tool vrti neki svoj film. |
#39 | |
Avocado
Postovi: 7,856
Spoiler alert! |
#40 |
Hejter
Postovi: 6,521
vec sam stavljao sliku ovdje , ali mislim da je ista takva ko sto si rekao. |
#41 | |
Postovi: 505
btw na memi su mali pasivci a na gpu nekakav mali vent i kockasti hladnjak. Jer netko stavio silencera na gpu i koliko se da klokat onda da znam jer se isplati ili ne?? |
#42 |
Hejter
Postovi: 6,521
Ja sam ga mislio stavljati kad sam vidio da si povukao temu o tome , i malo mi je falilo da ga odem kupiti , ali proradio mi je razum - jednostavno se ne isplati davati 150kn za hladjenje grafe koja vrijedi 500kn da bi MOZDA izvukao par mhz vise. ovo hladjenje na njoj je ok , ide na takt iznad obicnog XT-a i to je ok . |
#43 |
Postovi: 505
U toj sam i ja dilemi i sada mi ide daleko pa neznam koliko bi još mogao izvuci. Ne znam za tvoju al moja nije baš tiha pa ak nista uzel bum silencera samo zbog toga. |
