Staro 12.06.2012., 14:02   #31
mighty
mighty's Avatar
Postovi: 519
Autor mdrla Pregled postova
znači i ti imaš iskon/carnet il? a koji ti je drugi router?
zajeb, previdio sam taj dio s iskoncarnetom... ja sam na bnet carnetu...
mighty je offline   Reply With Quote
Staro 23.06.2012., 20:35   #32
maryo1313
Datum registracije: Jun 2012
Lokacija: rijeka
Postovi: 1
nisam pročitao postove ali ja sam si podesio vezu na smartphone pomoću programa connectify koji vaš laptop pretvara u router...ograđujem se,možda tu nije vaš problem,ali evo,ja nisam imao pojma za to..
maryo1313 je offline   Reply With Quote
Staro 10.07.2012., 19:15   #33
mdrla
mdrla's Avatar
Lokacija: ZG Dubrava
Postovi: 471
Postavke Routera
Evo molio bih malo pomoći oko spajanja Linksys WRT54gc na Siemens gigaset sx 763, gnjavim se već danima pa nikako da ih spojim
ovo su postavke Linksys-a:
Postavke:
PPPoE
User: xxxx Pasword: xxxxx
Host name: gigaset.lan Domain name: gigaset.lan
MTU: Auto size 1492
Lokal IP address 192.168.5.2
Subnet mask: 255.255.255.0
DHCP Server: Enable
Starting IP Address: 192.168.5.100
Advanced Routing
Dynamic Routing (RIP) Enable
Static Routing Router Entries: 1 (gigaset.lan)
Enter Route name gigaset.lan
Destination LAN IP 192.168.5.1
Default Getaway: 192.168.5.1
Interface: Internet (WAN)
Routing Table:
Destination Mask Getaway Metric
192.168.5.0 255.255.255.0 192.168.5.2 1
192.168.5.1 255.255.255.0 192.168.5.1 2
192.168.5.2 255.255.255.255 192.168.5.2 1
a ovo su postavke Siemensa
Internet connection
Protocol: PPPoE, User: xxx, Pasword: xxx
MTU 1942, Line mode: Automatic, EncaPsulation: LLC, QoS: UBR, VPI/VCI: 0/86
24h reconnection: Off, Connection mode: Always on, UPnP: ON
Routing Of
Local network
IP address 192.168.5.1
Subnet mask 255.255.255.0
DHCP server ON
Lease time 1 day
First issued IP 192.168.5.2
Last issued IP 192.168.5.100
Default getaway 192.168.5.1
Domain name gigaset.lan
Pa ako ima neko kakvu ideju, dobro bi došla pomoć, unaprijed se zahvaljujem!
mdrla je offline   Reply With Quote
Staro 14.07.2012., 14:17   #34
mdrla
mdrla's Avatar
Postovi: 471
zar nitko nema ideje sta bi trebalo promjenit?
Staro 14.07.2012., 20:42   #35
borisko
Lokacija: .com
Postovi: 519
dobiješ li kakvu grešku? imaš li gdje za podesiti auth. protocol na linksysu u pap?
jesi li probao resetirati Siemensa na tvorničke postavke?
mislim da u njemu postoji jedna skrivena opcija pppoe-pass-trough pa bi mozda i to valjalo uključiti...
borisko je offline   Reply With Quote
Staro 21.08.2012., 21:11   #36
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,493
Malo čitam ovo pa mi nije jasno. Planiram uzeti Iskonov duo (int+tel). Zar router nema mogućnost wifi spajanja drugih mobitela/prijenosnih računala ili se ovdje govori o nečem drugom?
Staro 21.08.2012., 22:38   #37
srale7
srale7's Avatar
Postovi: 5,796
Ako ces uzet carnet, onda ne mozes spojit mob, laptop normalno mozes.
Staro 21.08.2012., 23:08   #38
Ag008
Ag008's Avatar
Postovi: 7,493
Da. Samo koliko sam vidio ne mogu biti dva računala odjednom.
Ima neke cake s još jednim ruterom i ostao bi mi t-comov sx763.
Carnet opcija je 117kn a 157kn ista opcija s uključenih 60min poziva.
Sad, ako je 20lipa min, to je kao 129kn obične tarife i 30kn mjesečno skuplje bez zezancije.
Btw, kako je telefon na drugom kraju stana od rutera koji je do računala, sada je išlo to preko onog djelitelja a prema shemi od iskona, iz telefonske utičnice ide direkt u router i iz njega phone ide u telefon. Je tako u svim opcijama ili ide prema T-Comovoj staroj shemi?
Staro 21.08.2012., 23:53   #39
srale7
srale7's Avatar
Postovi: 5,796
Autor Ag008 Pregled postova
Krivo si vidio, mogu dva racunala odjednom
Staro 22.08.2012., 08:22   #40
Ag008
Ag008's Avatar
Postovi: 7,493
Hmmm. mogu samo ako se doda još jedan router?
"za uslugu DUO.CARNet modem je podešen za rad u bridge modu; CARNet-ov sustav
ne dozvoljava istovremeni pristup internetu više računala pomoću istih korisničkih podataka"
Btw. iako mi je iz Carneta rečeno da ne ograničavaju pristup nekim web. str. već da to rade samo u ustanovama iz Iskona mi je rečeno da carnet ima svoja pravila oko toga te da se može dogoditi da nešto blokiraju. Neće im biti sumnjiv promet od 70GB mjesečno?
Staro 22.08.2012., 14:40   #41
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Uvijek mozes uzeti jos jedan router, spojiti na taj sto dobijes i tako imati WLAN po kuci za vise uredjaja.
70-tak GB prometa nije problem. Samo pripazi sa torrentima, jer Carnet cesto salje opomene ako skidas ilegala stvari.
Staro 22.08.2012., 16:27   #42
Ag008
Ag008's Avatar
Postovi: 7,493
Hmmm. to je problem.
Iako mi je ljubezan gospodin s Carnet podrške rekao da mi mogu privremeno isključiti moj račun ako vlasnik autorskih prava da pritužbu na mene (skidam ilegalno njegovo vlasništvo), moju ip adresu u nekom određenom trenutku te da se to dogodilo samo nekoliko puta.
Sad od tebe čujem malo drugačije. Skidam svaki tjedan 3-4 serije od 300mb, zar bi mi stvarno radi toga slali opomenu?
Btw. radi li ovako nešto
http://forum.pcekspert.com/showthread.php?t=198720
Jer praktički time bi se spajao na net kao do sada, na mobitelu, laptopu u stolnom računalu.
Staro 22.08.2012., 16:57   #43
rodriguez
rodriguez's Avatar
Postovi: 2,066
Meni dosad nikad ništa nije poslano.
A nije da ne skidam
Staro 22.08.2012., 17:54   #44
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
da, znaju poslati opomene.
Munjara je offline   Reply With Quote
Staro 22.08.2012., 18:24   #45
srale7
srale7's Avatar
Postovi: 5,796
Boldano je neistina, imam taj paket doma i cimer i ja se normalno spajamo sa istim korisničkim podacima i najnormalnije smo u isto vrijeme na netu
Staro 22.08.2012., 20:05   #46
Ag008
Ag008's Avatar
Postovi: 7,493
Neljubazna gospođa iz podrške kaže da nema nikakvog spajanja više korisnika odjednom te da ne mogu birati koji uređaj ću dobiti.
Puno različitih informacija dobivam svugdje.
Staro 23.08.2012., 18:41   #47
-Ivan-
Lokacija: Tu
Postovi: 27
Sluzbeno carnet ne podrzava spajanje s istim podacima, ali u praksi 99% slucaja radi bez problema(osobno vidio 5 kompa spojena s istim podacima), samo ako je neki problem prvo pitanje je jer se spajas s 1 ili vise podataka. Ako mislis spajati i mob ili tablet onda najbolje spojit drugi router i nemas brige.
-Ivan- je offline   Reply With Quote
Staro 23.08.2012., 20:27   #48
Ag008
Ag008's Avatar
Postovi: 7,493
Mislim spajati mobitel, Android uređaj.
Laptop, stolni i mobitel-(samo).
Ovaj malo prije spomenuti vodič za sx763 navodno omogućava ppoe konekciju direkt s routera pa se router sam spaja sa carnet podacima.
Koliko je to istina i bi li dobio takav router, teško je reći.
Staro 23.08.2012., 20:59   #49
-Ivan-
Lokacija: Tu
Postovi: 27
Da, na siemensu je lako podesiti, ali sansa da ces ga dobit je skoro nikakva.
Staro 24.08.2012., 00:56   #50
Hackerivs
Datum registracije: Aug 2009
Lokacija: Middle of nowhere
Postovi: 451
fino si prebaci sx u router mode da nemaš problema s carnetovim pppoe-om.
sx763 ti jako dobro podnosi iskonov carnet u router modu.
btw ako imaš neki ruter viška zašto nebi iskoristio prednosti VoIP tehnologije?
recimo nonoh?
platiš 10€, dobiješ 120 dana besplatnog telefoniranja u skoro sve fiksne mreže svijeta (a u neke zemlje tipa USA su i mobiteli besplatni).
jedino ograničenje je 200 minuta tjedno, a nakon 120 dana trošiš novce od onih uplaćenih 10€ po smiješnim cijenama od 0,02€/min. kod mene tih 10€ potraje pola godine i bolje je nego bilo kakva tarifa sa fiksnim operaterom. doplata od 40 kn za pišljivih 60 minuta mjesečno?? pa za 40 kuna ja trećinu godine pričam badava sa mjesečnim limitom od 1000 minuta.
Hackerivs je offline   Reply With Quote
Staro 01.09.2012., 09:55   #51
Ag008
Ag008's Avatar
Postovi: 7,493
Navodno noviji sx763 nemaju tu mogućnost. No, rekli su mi da će mi dati sx763 prilikom potpisivanja. Još samo da dođe neka promocija ili akcija (npr. da čekam Božić) jer su i ovo proljeće imali akciju za carnetovce koju sam propustio.
Staro 20.10.2012., 19:25   #52
xxx360034
Datum registracije: Feb 2010
Postovi: 10
Lightbulb Tako blizu a tako daleko..
Pozdrav svima.
Da malo obnovim ovu temu. Imam ISKON CARNet i ALBIS SLI-5460-I i već dva vikenda sam izgubio pokušavajući ga natjerati da radi u route modeu.
Uglavnom; prije godinu dana nakon mnogo muke uspio sam ga staviti u route mode i radio mi je internet preko mobitela i laptopa bez dodatne konekcije na laptopu za carnet. Nedavno mi je pukla veza i ISKON ljudi su mi ga resetirali i čini mi se flashali bez mog dopuštenja. Nakon toga više nigdje nisam mogao naći mjesto da upise user i password od CARNet-a.
Uspio sam ga otključati preko uputa sa stranice:
http://forum.pcekspert.com/archive/i.../t-217854.html
Sada sam u Advanced>Internet>DNS Server meniu unio user i password i on se automatski spoji na internet i zasvijetli mu zelena lampica od interneta i više mi nije potrebna carnet konekcija da bi surfao internetom.
Sve 5.
Ali..
Za otprilike 4 minute veza sa modemom pukne i nemoguće je više se spojiti na njega. Na njemu internet ledica iz zelene pređe u crvenu i moram ga ugasiti i upaliti da bi mu mogao opet pristupiti.
Pomoć nisam dobio ni od CARNeta ni od ISKONa, oboje su rekli da to nije njihova dužnost.
Nisam preveliki expert u Inernet, DNS, DHCP, Upnp, QoS postavkama ali mi se čini kao da sam blizu rješenja.
Jako puno sam experimentirao i uvijek isto, router se zablokira i mora ga se gasiti/paliti.
Nakon otključavanja postoje jako puno opcija za promijeniti pa molim nekog experta da pomogne upornima.
Prilažem slike iz otključanog ALBIS-a:
Slika 1. Početno stanje
Slika 2. DNS Server meni
Slika 3. Novi status meni nakon Apply-a na DNS server meniu
Dakle nakon oko 4 minute pukne ova PPPoE veza i ALBIS se nemože više pingat.
Slika 4. i 5. Neznam da li mora WAN interface bit ADSL ili EWAN. Isto tako koji ADSL tip mogu koristiti.
HILFEN!
xxx360034 je offline   Reply With Quote
Staro 20.10.2012., 19:29   #53
xxx360034
Postovi: 10
Ne želi mi priljepit slike iako imaju sve skupa 439 KB. :-/
Probao sam ih i zipat i neće. GRrrrrr!!!
Staro 20.10.2012., 20:45   #54
Ag008
Ag008's Avatar
Postovi: 7,493
Dobivam vjerojatno isti uređaj- za tjedan dana jer prelazim na Iskon Carnet.
Sa susjedom sam već dogovorio da bi samo mijenjali koji god dobijem za SX 763.
Stavi na tynipic slike pa ovdje kopiraj link.
Staro 20.10.2012., 21:35   #55
Postovi: 23,607
@xxx360034
Postanje slika radi tako da ih prvo upload - aš na neki image host servis pa onda na forum ide odgovarajući link.
Ako imaju remote managment na tom ALBIS - u sve šta promijeniš u postavkama oni će vratiti nazad.
Ako je sada Iskon - Carnet konekcija PPPoE tipa onda posudi / nabavi WAN Router sa ili bez wireless - a po želji.
To je router kojem je ulaz mrežni port a ne adsl modem, ulaz spojiš na ALBIS - a, podesiš Carnet konekciju u njemu i pjevaj.
Staro 20.10.2012., 21:39   #56
xxx360034
Postovi: 10
Staro 20.10.2012., 22:16   #57
Ag008
Ag008's Avatar
Postovi: 7,493
Samo jednostavnije je da nemaš dva routera.
Ja recimo ništa ne vidim na ovim slikama.
Je li prije njihove nadogradnje sve radilo bez problema? Možda postoji mogućnost downgradeada.
Staro 20.10.2012., 23:47   #58
xxx360034
Postovi: 10
Je. Najnormalnije.
Isključio sam da mi nemogu uskakat remotly na modem ali ista stvar.
Nije mi jasno zašto radi prvih par minuta a onda umre.
Užasno frustrirajuće!!
Staro 21.10.2012., 00:04   #59
xxx360034
Postovi: 10
Neznam, možda moram namjestiti port EWAN a ne ADSL. Koja je razlika?
Staro 21.10.2012., 00:24   #60
Ag008
Ag008's Avatar
Postovi: 7,493
A što se dogodilo da su ti stavili novu verziju?
Da nije možda negdje uključena opcija da ti se diskonekta nakon neaktivnosti ili nešto slično...
Na slici 5 što još možeš odabrati pod connect mode
