Staro 26.10.2011., 00:38   #31
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Od svih navedenih mislim da je UD5 još najbolji izbor. UD7 i G1 će najvjerovatnije biti way too much preskupe.
ASUS... ASUS?
Staro 31.10.2011., 16:46   #32
Postovi: 7,568
ASRock X79 Extreme9, X79 Extreme4 i X79 Extreme4-M
ASRock X79 Extreme9 looks to become one of the killer motherboards this Winter. he deep black circuit board have some extra layers of copper and gold-plated connectors and graphical details, but it is the components that makes us want it. Five PCI Express 3.0 x16 ports for 3-way SLi and CrossFireX, 12 SATA ports, a bunch of USB 3.0 ports (6 or maybe even 8), 8 DDR3 memory slots and dedicated buttons for Start, Reboot and Clear CMOS. Diode for troubleshooting and a big piece of cooling for the voltage regulators include functions worth mentioning. The cream of the crop is an expansion card that houses Creative's latest quad-core sound processor Sound Core3D and most likely a network circuit from Bigfoot Networks.
ASRock showed off pictures of the first socket LGA2011 motherboard in the compact micro-ATX form-factor, the ASRock X79 Extreme4-M Within its small board footprint of 240 x 240 mm, the X79 Extreme4-M offers almost every feature the platform has to offer. To begin with, the LGA-2011 socket is powered by an 8-phase VRM that makes use of high-grade solid-state chokes, and driver-MOSFETs. It is wired to four DDR3 DIMM slots, two on either sides of the socket. All four expansion slot bays available to the mATX form-factor are made use of, with three PCI-Express 3.0 x16 and one legacy PCI. The CMOS can be reset from the rear panel. The board will be driven by UEFI firmware.
Izvor: NordicHardware i techPowerUp
Staro 31.10.2011., 18:02   #33
Garro
Postovi: 2,394
Mislim da sam našao svoju novu ploču, ovaj Extreme9 ima sve sto mi treba. Još samo da potvrde da će biti kompatibilna sa IB-E kada izađe i razbijam kasicu-prasicu.
Garro je online   Reply With Quote
Staro 31.10.2011., 23:16   #34
Dottore
Dottore's Avatar
Postovi: 7,701
Bit će potvrđena kompatibilnost i konačno si riješio nedoumicu glede SATA priključaka ( ima ih 12 )
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 01.11.2011., 12:09   #35
Garro
Postovi: 2,394
Od viška glava ne boli.
Da mi je netko prije par godina rekao da ću razmišljati o kupnji ASRocka, pogotovo high-end ploče, preporučio bi mu posjet Vrapču. A vidi sada...
Staro 01.11.2011., 15:08   #36
Ordem
Datum registracije: Sep 2010
Lokacija: Vk
Postovi: 572
"Creative's latest quad-core sound processor Sound Core3D"
taj creative je toliki fail sa svojim zvucnim karticama - uci ce u anale sto se tice svojih drivera i podrske za zvucne kartice
katastrofa, ne znam zasto bi to itko htio imati (osim ako se nesto radikalno nije promjenilo u zadnjih par godina sto se tice creativea?)
btw sta je IB-E? ivy bridge?
Ordem je offline   Reply With Quote
Staro 01.11.2011., 15:12   #37
Postovi: 7,568
Da, Ivy Bridge-E je nasljednik Sandy Bridge-E platforme. Desktop derivati serverskih Xeon modela baziranih na poboljšanoj aktualnoj Sandy Bridge, tj. nadolazećoj Ivy Bridge arhitekturi.
Staro 01.11.2011., 22:46   #38
Ordem
Lokacija: Vk
Postovi: 572
Autor McG Pregled postova
tnx
i koja ce biti njihova nomenklatura? pretpostavljam da ce intel nastaviti koristiti i3,i5 i i7 nazive samo dodati tisuce na kraj kao sa trenutnim procesorima?
i btw da li je ivy bridge samo evolucija trenutnih sandy bridge procesora ili potpuno nova generacija intelovih procesora? koji je proizvodni proces (25nm)?
Staro 01.11.2011., 23:00   #39
Postovi: 7,568
Ivy Bridge je 22nm die-shrink Sandy Bridge arhitekture, ali procesori budu donijeli i nove tehnologije, poput 3D tranzistora i DX11 grafičke jezgre uz manju potrošnju i bolji overclock potencijal.
Nazivi pojedinih modela se još ne znaju, ali pretpostavlja se da bude Intel koristil sličnu filozofiju ko i sa sadašnjim Sandy Bridge procesorima.
Staro 01.11.2011., 23:35   #40
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Foxconn Quantum Force X79 Final Version Pictured
Foxconn's latest premium gamer-overclocker segment motherboard, the Quantum Force X79, has finally taken shape. Foxconn's Quantum Force motherboards are designed to offer good overclocking features at a great value. The Quantum Force X79 uses a 14-phase VRM to power the LGA2011 "Sandy Bridge-E" processor, plus a 2-phase VRM for the memory. There are four DDR3 DIMM slots, one per memory channel. Expansion slots include three PCI-Express 3.0 x16 (PCI-E1_x16, PCI-E3_x16, and PCI-E4_x16. The second black slot (PCI-E2_x16) is electrical PCI-Express 2.0 x8.
The board is packed with features that help overclockers, starting with triple redundant BIOS, voltage measurement points for manual voltage measurements (with a wide range of voltage domains), manual overclocking buttons on board, power, reset, clear-CMOS buttons, POST speaker, and plenty of fan headers.
In terms of connectivity, there are four each of SATA 6 Gb/s (red) and SATA 3 Gb/s (black) internally, two of the 6 Gb/s ports are driven by an ASMedia-made controller. There are two eSATA 3 Gb/s ports on the rear panel, driven by a JMicron controller. There four USB 3.0 ports (two on the rear-panel, two via header), both sets driven by Renesas-made controllers. Also available are two gigabit Ethernet connections, one of these two are controlled by an Intel-made GbE chipset, the other by a Realtek-made one. To top it off, there's 8+2 channel HD audio with optical and coaxial SPDIF outputs.
http://www.techpowerup.com/154464/Fo...-Pictured.html
C L O W N I N G A R O U N D
Staro 04.11.2011., 17:28   #41
Dottore
Dottore's Avatar
Postovi: 7,701
Potpuna specifikacija za ASRock matična ploča sa Intel X79
ASRock X79 Extreme 7
ASRock X79 Extreme 4
ASRock X79 Extreme 4-M
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 04.11.2011., 17:48   #42
Momir
Momir's Avatar
Postovi: 1,011
I7-3930K kod nas u cjeniku, ja narucio 10 komada
EDIT:Eto, otkazali mi narudjbu i koliko vidim maknuli su iz cjenika, bilo je 1kn.
Zadnje izmijenjeno od: Momir. 04.11.2011. u 21:30.
Momir je offline   Reply With Quote
Staro 04.11.2011., 19:18   #43
Ordem
Lokacija: Vk
Postovi: 572
novi gigabyte 3D with Dual UEFI BIOS
http://www.youtube.com/watch?feature...&v=Q62I2uHLkKc
x79-ud5 maticna
Staro 04.11.2011., 21:44   #44
Dottore
Dottore's Avatar
Postovi: 7,701
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 04.11.2011., 22:55   #45
Ordem
Lokacija: Vk
Postovi: 572
zasto su USB 3.0 portovi i dalje u manjini? tj zasto se uopce vise i koriste USB 2.0 portovi?
Staro 04.11.2011., 22:59   #46
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Vrlo vjerojatno zato što X79 chipset ne podržava nativno USB 3.0, a pitanje je koliko im se da/isplati/nešto_treće stavljati USB 3.0 kontrolere gore.
Matth€w je offline   Reply With Quote
Staro 04.11.2011., 23:24   #47
Dottore
Dottore's Avatar
Postovi: 7,701
Kako nema? Vanjska dva i unutarnja za kejs.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 08.11.2011., 09:00   #48
Doink the Clown
Postovi: 6,214
Staro 10.11.2011., 13:17   #49
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Autor youngpro
MSI X79A-GD65, garbage, i dont care if MSI is reading this, in fact I hope they are, maybe they will actually TRY to write a bios
Valjda neće biti isto i sa ovim BigBangom.
Staro 12.11.2011., 01:41   #50
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor Milentije Pregled postova
Pusti to...
Kad več briju na "military class", oćemo dobit kakvu "pljucu" uz ploču ?
Kolko sam skužio, gore je 6 metaka... strojnica na vrhu i mina jedna, ebo me pas ak su oni normalni...
Staro 12.11.2011., 02:56   #51
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,755
Autor Halos Pregled postova
Pusti to...
Nelose izgleda (osim ovih pasivnih usera al ajd). Ali ovi slotovi za ram mi se cine preblizu cpu socketu, pogotovo prva dva s live i desne strane...
Pa sto ovi proizvodjaci maticnih misle da se cpu cooleri smanjuju zajedno sa proizvodnim procesom
Staro 14.11.2011., 10:46   #52
Postovi: 8,231
Izgleda da je krenulo pomalo sa testovima
Nije loše al izgleda da voli i poteć iz utičnice kao i FX, al naravno uz adekvatne performanse.
Staro 14.11.2011., 14:43   #53
Chiron
Chiron's Avatar
Postovi: 371
Destiny isn't already Forged!!!
Chiron je offline   Reply With Quote
Staro 14.11.2011., 15:11   #54
Chiron
Chiron's Avatar
Postovi: 371
Staro 14.11.2011., 16:23   #55
denied
denied's Avatar
Postovi: 1,193
Došli i u naše dućane
denied je offline   Reply With Quote
Staro 15.11.2011., 09:17   #56
Doink the Clown
Postovi: 6,214
Introducing the EVGA X79 Motherboards
True next generation motherboards have arrived with the EVGA X79 lineup. The new EVGA X79 motherboard series packs in the latest technologies to give you an uncompromising experience! Unparalleled memory bandwidth with true quad channel DDR3 memory support, and Intel Turbo Boost Technology 2.0 gives you intelligent computing by optimizing performance on the fly! Up to 4-Way SLI** gives you the expansion you need to maximize your graphics performance.
Highperformance 12+2 PWM, 100% POSCAP Capacitors and ESR/ESL Film Capacitors* deliver clean, optimal power to your system for maximum overclocking. Dual 8pin CPU connectors* can provide up to 600w of steady power to the CPU through a high quality CPU socket with three times* the normal amount of gold content for the lowest impedance, and highest current transfer. Also, with built in EVGA EVBot support, you can overclock on the fly from the palm of your hand.
This board is loaded: 10 USB 3.0 Ports*, SATA III/6G support, 5 PCI-E 3.0 ready ports, integrated Bluetooth*, PCI-E/DIMM Disable jumpers, and a Right Angled 24pin power connector* to assist with cable management.
http://www.techpowerup.com/155157/In...herboards.html
Staro 17.11.2011., 23:10   #57
Postovi: 7,568
Staro 12.12.2011., 20:51   #58
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Recnzija gdje je medu ostalima i i7 3820.
Link
Dobra stvar je za potencijalne korisnike to da procesor ima puno vise OC potencijala od zakljucanog 1155 ekvivalenta, i7 2600 i bez problema prelazi 4.6ghz. Performanse su nesto malo bolje od 2600k ali nedovoljno da bi bio isplativ.
Staro 12.12.2011., 21:14   #59
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Zanimljiv chipset.. procesori su brutalni i tko zna šta će još doc.. poboljšani igpu i možda najveći plus hydra lucid, spajanje različitih grafika (ati/nvidia) u sli.. na ovom će chipsetu apsolutno sve moći radit skupa..
dean225 je offline   Reply With Quote
Staro 16.12.2011., 08:15   #60
Momir
Momir's Avatar
Postovi: 1,011
Autor dean225 Pregled postova
Cipset je zapravo jedini promasaj nove platforme po mom.
Nedonosi nista novoga u odnosu na p67/Z68.
A za veliki broj PCI-E staza zaduzen je sam procesor.
