Staro 03.12.2004., 17:42   #31
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
meni se baš to sve nesviđa
SetH je offline   Reply With Quote
Staro 08.06.2005., 12:03   #32
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ak ti se to ne svida sta kazes na:
kucište coolermaster centurion 5, silver, cac t05, midi, bez ps links 333kn
mbo dfi lan party ut nf4 sli-d, ddr, zvuk, s-ata, fw, 2xg-lan, pci-e, s. 939 links 1436kn
cpu amd athlon64 3200+ box, socket 939, venice, 2000mhz, 512kb c., fsb 800mhz links 1436kn
ram pc-4000, 1024mb, ddr, ocz, kit, gold vx, ddr 500 mhz, 2 x 512mb links 2217kn
2xhdd 160.0 gb hitachi, serial ata ii 8 mb cache, 7200, deskstar gst t7k250 links 1370kn
vga pci-e leadtek px6800gt tdh, geforce pcx 6800gt, 256mb ddr3, dvi, tv links 3105kn
dvd±rw nec nd-3540, 16x, black, dual layer ± recording, bulk links 389kn
dvd rom toshiba 16x 48x, black, sd-m191t, bulk links 157kn
napajanje ocz powerstream 520w, atx2 ver 2.0 links 1407kn
11850
kuciste neko drugo,i jos pokovi vent,mozda vodeno...da se svasta izmjenit
blup
mc_fish je offline   Reply With Quote
Staro 03.07.2005., 12:06   #33
maxtor
maxtor's Avatar
Postovi: 382
Što kažete na ovu konfu
MB GIGABYTE K8N Ultra-9, Socket 939, NVIDIA nForce4 Ultra, 4 x Serial ATA II, 4 x Serial ATA, SATA RAID, UDMA133, 3PCI, 2PCI-E x1, PCI-E x16, 4DDR (Dual Channel, 400/333/266MHz), 8-channel Sound (with Universal Audio Jack, UAJ), SPDIF in/out (coax), 966 kn Ve-Mil
CPU AMD Athlon64 3500+ (64-bit, integ. mem. kontr., 512K L2 on-chip cache), Winchester jezgra (90nm), Socket 939 2109 kn Ve-Mil
Zalman 7000B-CU Cooler, cijeli od bakra, AMD Athlon64 (Socket754, Socket939, Socket940), 109 (L) x 109 (W) x 62 (H) mm, hladnjak s 92mm ventilatorom, 1350-2600rpm, 2-ball bearing, 298kn Ve-Mil
DDR 512 MB 184 pin, 400MHz, SuperRAM, KINGMAX (2 komada) 706 kn Ve-Mil
Cooler for case PAPST, 80 mm, 9 dB, N/2GLLE (2 komada) 216 kn Hgspot
HDD Seagate ST3200822AS, 200 GB 8MB, S-ATA150, 7200 815 kn Ve-Mil
VGA PCI-E SAPPHIRE ATI Radeon X850 XT 256 bit, 256 MB, tv-out, DVI 3500 kn Hgspot
DVD+RW/-RW/RAM LG GSA-4163BB, DVD+R DL 4x, Multi-Format Writing, DVD+RW (8x), DVD+R (16x), DVD-RW (6x), DVD-R (16x), DVD-RAM (5x), CD-RW (24x), CD-R (40x), ATAPI, 2MB buffer, Superlink Buffer Underrun Error Protection, bulk 384 kn Ve-Mil
SAMSUNG 913N Matisse, 19" TFT, 1280x1024, 300cd/m2, 700:1, 160°/160°, 8ms World fastest response time, Silver/Black, Analog, Narrow, MagicTune, MagicBright, TCO03, MJ19ESKSB Ideal for gaming and multimedia (Prince of Persia DVD Game included) 2974 kn Procesor Računala
Ukupno; 11 968 kn
maxtor je offline   Reply With Quote
Staro 03.07.2005., 12:35   #34
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
nema kuciste i napajanjekao prvo kao drugo dobra konfa se MORA bazirat na dobroj maticnoj a gigabyte nije bas neka tak predobra tvrtka
taj winchester je sporiji od 3200+ venice a uz to se venice moze bar 3x vise klokat nego wini
zalman ok..tu se slazem makajr ima boljih rjesenja a i jeftinijih(frizer)
extra jaka konfa mora imati (ne mora al je pozeljno) 1024 mb rama...a uz to je kingmax lutrija i nije predobar ram(dobar za midi end i low end konfe)
papstove se ne ispalti uzimati ako nisi prevelki noise freak...
ako ti vec maticna podrzava sata2 uzmi si onda sata 2 al ni ovaj disk nije promasaj barakuda je jako dobar tih i hladan hdd (pun pogodak)
dvd rw nema druge nego pionir 109 ili nec 5-ica
i zakaj dat 3 soma kuna ako mos za 2 dobit bolji monitor? samunf nf959
o konfama se treba znat jer bacanje novaca nije pozeljno a uz to mora i doc neko iskustvo koje sma ja gradio dobre 3 god...nista osobno al konfa bi radila..mozda cak i dobro al za manje para(ili isto ova moja gore) je uredno za 20% brza a kad se pocne klokat nema joj boga
blup
Staro 03.07.2005., 22:52   #35
maxtor
maxtor's Avatar
Postovi: 382
Zašto ploča nije dobra?????Prijatelj mi je ima i prezadovoljan je s njom.....
Koji bi ti hladnjak stavio na ovu konfu???
što se tiče dvd-rw pcexpert preporučuje ovu navedenu LG pržilicu
što se monitora tiče to nije LCD,možda je bolji ali nikad nećeš pogriješit ako uložiš u monitor
Staro 05.07.2005., 22:39   #36
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ajmo redom nisam te kritizirao mada kad sad citam tako izgleda nego jednostavno iz razloga da za jeftinije pare dobis bolje...dfi dagf...a posto je ovo ipak konfa "teske klase" treba imat i dobru maticnu ne? s toga nista ispod fitalitija ili ultra/sli d
ja osobno unutra imam hyper 48 i tisi je od zalmana a hladi isto ako ne i mrvicu bolje...sad si misli kak bi hladio na malo vecem broju okretaja
znam da pce preporucava lg-a i ne kazem da je losa...al ima kao sto rekoh boljih i ovo je ipak konfa teske klase pa u nju treba ic sve najbolje ili?
za monitor: osobno nisam vidio boljeg monitora od 959 nf ili iiyame
mozda je bolji ovaj tvoj al nebi rekao te za 959nf je sigurno
konfa kaj si slozio i nije tako losa..uz par sitnih izmjena i sve 5 inace kako ce uopce radit taj stroj bez napajanja?
blup
Staro 05.07.2005., 23:30   #37
maxtor
maxtor's Avatar
Postovi: 382
Gdje ima kupit tog hyper 48 hladnjak
Staro 06.07.2005., 00:42   #38
Overvide
Postovi: 540
www.links.hr
Overvide je offline   Reply With Quote
Staro 06.07.2005., 12:22   #39
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
Originally posted by Overvide
www.links.hr
preduhitrio si me
ps za detaljnu pretragu svih shopova(ne 100% al ajde) doi na www.nabava.net
blup
Staro 06.07.2005., 22:17   #40
maxtor
maxtor's Avatar
Postovi: 382
Ja sam razmišljao o ovom;
Hladnjak Glacialtech Turbine 4500
Šta misliš
Staro 06.07.2005., 23:17   #41
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ako ne kanis klokat dobro
blup
Staro 07.07.2005., 00:24   #42
maxtor
maxtor's Avatar
Postovi: 382
Baš zato bih uzeo taj hladnjak,za overclock
Specifications
Socket Type 478 / 603 / 604
Intel CPU Clock Speed
(max.)
P4 Prescott 3.4 GHz
(478-pin socket)
Xeon 3.2 GHz
(603-pin & 604-pin socket)
Cooler Dimension (mm) 100 x 98 x 108
Cooler Weight (gram) 800
Fan
Type
12 Volts / Ball Bearing
Dimension (mm)
80 x 80 x 18
Speed (RPM)
1,900 (± 10 %)
Airflow (CFM)
29.20 (± 10 %)
Noise (dBA)
20.0
Interface Material
High Efficiency Thermal
Staro 07.07.2005., 11:21   #43
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
na stok frekvama i slabom ocu je jako dobar al kad poche extremno ko ja...gubi dah(recimo da mu vent nema konde )
ako kanis ono klokat za 200-300 mhz...uz min dizanje napona i da nije preskot...moze...ak ne...zalim
blup
Staro 07.07.2005., 17:06   #44
maxtor
maxtor's Avatar
Postovi: 382
Išao bih za 600MHz a onaj tvoj mi je skup,Htio bih neki jeftiniji a da je dobar za overclock
Staro 07.07.2005., 20:30   #45
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
ok i to se da sredit...(napisao sam ti vec kako)
blup
Staro 11.07.2005., 14:25   #46
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
uzmi rađe socket 939
terminator je offline   Reply With Quote
Staro 27.09.2005., 22:53   #47
Unregistered
Postovi: 8
Evo ova konfa nije bas do 12k kn,al nema veze....:
MBO DFI, s. 939, Lan Party UT, nForce 4 Ultra-D, BUS 2000 MHz, serial ATA, RAID, 7.1 zvuk, DDR 400, 2x 1Gbps, FireWire, ATX 2------- 1.229,00 kn
AMD Athlon 64 3700+, 2200 MHz, 1 Mb c., socket 939, BUS 2000 MHz, BOX (San Diego)-------- 2.207,00 kn
RAM, 1 GB, DDR 2, PC-4300, 533 MHz, KINGMAX----------- 821,00 kn
Cooler ZALMAN, CNPS 7700 AlCu, (socket 478, socket 775, socket 754, socket 939, socket 940)---------232,00 kn
Napajanje 580 W ATX 2, HIPER HPU-4K580-MU------- 748,00 kn
kućište raidmax bzerk 868s, midi, srebrno, bez napajanja----------314,02 KN
vga pci-e sapphire ati radeon x800gt, 256mb ddr3, dvi, tv-------------1.450,60 KN
hdd 160.0 gb maxtor, diamondmax plus 10, serial ata, 8mb cache, 7200--------681,01 KN
DVD pisač, DVD±RW & DVD±R, NEC ND-3540, 16x, 8x dual layer 8.5 GB, bulk, crni-----------373,00 kn
DVD ROM Drive, 16x 48x, LITE ON, bulk, crni----------- 137,00 kn
Tipkovnica HR, LOGITECH HR Internet, PS/2, crna-------- 89,00 kn
Miš CREATIVE LABS, Creative Mouse 5500----------- 137,00 kn
Podloška za miša THERMALTAKE Damier, plava (A2192)-------- 17,00 kn
Ukupno:8441 kn + monitor Mon. LCD 17" Acer AL1751A, crystal bright panel-------- 2.554,00 kn
Ukupno:10995 kn
Periferije sam stavio zato kaj mi je bilo dosadno...:clap:
Unregistered je offline   Reply With Quote
Staro 27.09.2005., 22:57   #48
Unregistered
Postovi: 8
Uups, stavio sam DDR2 memoriju.....umjesto toga x2 ram pc-3500, 512mb, ddr, kingmax, ddr 433 mhz---810 kn
Staro 31.10.2005., 04:17   #49
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
1.213,04kn
northbridge hladnjak zalman zm-47j, pasivni --------------->24,62kn
hladnjak za procesor:
thermaltake sonictower, pasivni, alum-bakreni ----------->236,96kn
ventilator papst 80mm, 9db, n/2glle ------------------------>104,54kn
memorija:
corsair c25, kit, twinx, ddr 550 mhz, 2x512mb ---------->1.870,26kn
graficke kartice:
xfx, geforce pcx 6800, 128mb ddr ------------------------->1.580,66kn
hard diskovi:
hdd 160.0 gb seagate, ncq, 8mb cache -------------------->728,31kn
optika:
dvd±rw pioneer dvr-110, 16x, black ------------------------>409,04kn
dvd rom toshiba 16x 52x, black ------------------------------>147,32kn
kuciste:
chieftec lcx-01bbsl-w, midi, produljeno --------------------->556,43kn
napajanje:
tagan 480w, super silent, tg480-u01 ----------------------->736,20kn
monitor:
19" hyundai q995,96khz, 0.25mm,dynaflatx ------------>1.389,93kn
------------------------------------------------ukupno -------->12037,82kn
tips'n tricks:
hardove spojiti u raid
graficke normalno u sli
plocu moddate da radi sli
ugodno clockanje....
procesor:
amd athlon64 3500+ tray, socket 939, venice --------- >1.615,06kn
maticna ploca:
dfi lan party ut nf4 ultra-d ,socket 939 ------------------->1.213,04kn
memorija:
graficke kartice:
hard diskovi:
optika:
kuciste:
napajanje:
monitor:
tips'n tricks:
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 17.11.2005., 17:25   #50
Bota
Bota's Avatar
Lokacija: KC
Postovi: 4
MBO DFI LAN PARTY UT nF4 SLI-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 -------- 1.553,44
CPU AMD Athlon64 3700+ BOX, socket 939, San Diego, 2200MHz, 1MB c., HTT 1000MHz ----- 2.103,12
Cooler ZALMAN CNPS7700-Cu, socket 478/775/754/939/940 --------------------------------- 323,02
2x512MB, RAM PC-3200, DDR, Corsair, Value Select C2.5, DDR 400 MHz -------------------- 861,62
HDD 36.0 GB WESTERN DIGITAL Raptor, Serial ATA, 8MB cache, 10000 okr/min (system) ----- 910,31
HDD 200.0 GB SEAGATE, 8MB cache, 7200.8 Plus (storage) -------------------------------- 766,30
VGA PCI-E SAPPHIRE ATI RADEON X800GTO Ultimate Edition, 256MB DDR3, DVI, TV --------- 1.804,08
DVD±RW PIONEER DVR-110D, 16x, black, Dual layer ± recording, bulk --------------------- 393,21
DVD ROM LITE ON 16x 48x, SOHD-16P9S, bulk --------------------------------------------- 144,68
Kućište CHIEFTEC DG-01BD-UW, MIDI Dragon, bez PS, Office series ----------------------- 382,14
Napajanje CHIEFTEC 400W, GPS-400AA-101A, 12cm fan, ATX2 ver 2.0 ----------------------- 374,33
Mon. LCD 17" HYUNDAI B70A, 8ms ------------------------------------------------------ 2.048,00
Miš LOGITECH, Ultrax B85, Optical PS/2 + USB ------------------------------------------ 127,00
Tipkovnica HR, LOGITECH Media Keyboard Special Edition, PS/2 -------------------------- 168,00
____________________________________________________________________
Ukupno ------------------------------------------------------------------------------ 11959,25
DFI LAN PARTY UT nF4-D
AMD Athlon64 3700+ San Diego@2200MHz (200x11)
PCI-E SAPPHIRE ATI RADEON X550
Kingmax 2x256 DDR433@400 2.0-4-4-8
Zadnje izmijenjeno od: Bota. 17.11.2005. u 17:48.
Bota je offline   Reply With Quote
