Staro 21.12.2011., 08:33   #541
Mad_Duke
Autor KorisNick Pregled postova
Kod nas neće bit takve ni kad uđemo u EU, jer lopovi ostaju lopovi, bez obzira na "otvorene granice" tj. bez carinjenja robe.
Pa naravno da neće biti takve ni kad uđemo u EU jer sigurno nećemo imati manje cijene nego u EU
Staro 21.12.2011., 10:20   #542
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
EVGA's GeForce GTX 580 Classified Ultra 3 GB graphics card goes on sale
U prodaji
Outed last week, the highly-customized GeForce GTX 580 Classified Ultra from EVGA has become available for purchase, 'coincidentally' just before AMD launches the Radeon HD 7970.
This new, GF110-powered model features 512 CUDA Cores, GPU/shader clocks of 900/1800 MHz (772/1544 MHz stock), a 384-bit memory interface, 3 GB of GDDR5 memory set to 4212 MHz (4008 MHz), a 14+3 phase power design, a dual-slot cooler, 4-way SLI and EVBot support, one NEC Proadlizer, Super Low ESR SP-Cap capacitors, and high frequency 3 MHz shielded inductors.
The GeForce GTX 580 Classified Ultra costs $619.99 and can be found @ Newegg.
C L O W N I N G A R O U N D
Staro 30.12.2011., 12:18   #543
Postovi: 8,226
Izgleda da neke EVGAe sa P/N: 015-P3-1580 i 015-P3-1582 dolaze bez IHS-a na čipu. Samo je problem što to nigdje nije naznačeno na pakiranju i nemože se znati dok se neskine hladnjak dole
Staro 17.01.2012., 20:38   #544
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Bas gledam malo cijene na Newegg i EVGA ULTRA 3GB kosta 550$. Pojeftinila je podosta u odnosu na 620$ koliko je kostala.
http://www.newegg.com/Product/Produc...82E16814130751
Ostali modeli kostaju isto, osim par ref. modela koji su malo pojeftinili. Brijem da ce 1.5gb modeli uskoro u EOL a da ce 3GB nesto malo pojeftinit i ostat do novih modela.
Zadnje izmijenjeno od: MAGARAC. 17.01.2012. u 20:51.
Staro 21.01.2012., 00:59   #545
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Malo sam osvjezio friendovu gxt 580. AC Extreme + i novi bios 880/1050 1.075v. Hladnjak radi na 12v i dosta je tih. Manje nebi stavljao zbog VRMa jer nema mjesta za kemijanje. Temp. su odlicne 56c i koji stupanj manje u igrama.
Malo przenja,
Prema njoj moja 580 izgleda malo..
Staro 21.01.2012., 04:39   #546
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Autor MAGARAC Pregled postova
Pa zar nije obvezno kupiti i VR004 set?
http://www.links.hr/?naziv=hladnjak-...kl=050.909.172
Ili je problem izražen i s tim setom?
Staro 14.04.2012., 13:07   #547
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
@ bluzer, ide vr004 gore i grafa se ne grije uopce s tim ( ako se ne grije 480 ne grije se ni 580 )
btw . kraj jedne lijepe sage NVIDIA Stops Production of GeForce GTX 580
Staro 03.12.2013., 18:20   #548
bixsy the king
bixsy the king's Avatar
Lokacija: Hercegovac
Postovi: 974
Pitanjce za iskusnu gardu...
Koliko vata guta GTX580...s obzirom na moj komp kolika bi bila ukupna potrošnja u loadu ?
bixsy the king je offline   Reply With Quote
Staro 03.12.2013., 21:27   #549
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Prozuji po ovom postu
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 19.06.2015., 21:24   #550
skela
Datum registracije: Mar 2011
Lokacija: Nova Gradiška
Postovi: 7
koliko bih mogao dobiti za gtx 580 koja je poluispravna? pod poluispravna mislim da se svaka 2-3 mjeseca mora peci u pecnici ,ali uredno radi. verzija je gigabyte windforce
skela je offline   Reply With Quote
Staro 19.06.2015., 23:18   #551
bilicvitak
bilicvitak's Avatar
Datum registracije: Nov 2014
Lokacija: ¯\_(ツ)_/¯
Postovi: 542
Dvoguzu pivu
bilicvitak je offline   Reply With Quote
Staro 10.09.2017., 09:47   #552
dustox
dustox's Avatar
Datum registracije: Dec 2011
Lokacija: Bukovlje
Postovi: 25
Legacy GPU
...pozzz
Evo jedno tehnicko pitanje
... dakle crkla je gtx 580 a ni jednu noviju gpu koju ubacim mbo ne prepoznaje (gtx 750/gtx1050) dok recimo staru gtx 9600 i hd 4650 uredno ucita... znaci izbaci mi b4 na post code-u kaze cmos wrong settings... i kaze press f2/del... ja fino stisnem del anakon toga crna slika i baci kod b2...
...citam po netu da moze biti stvar do biosa...
...maticna koju koristim je ecs a990fxm-a... navodno ima legacy bios i mogu samo legacy gpu u nju???
dustox je offline   Reply With Quote
Staro 10.09.2017., 10:03   #553
Postovi: 23,595
Dobro čitaš, probaj resetirati bios po proceduri.
Računaj da ćeš kasnije trebati pregledati i promijeniti šta treba.
Staro 10.09.2017., 10:14   #554
dustox
dustox's Avatar
Lokacija: Bukovlje
Postovi: 25
...napravio sam update biosa na zadnju dostupnu verziju ali sam bios je škrt sa opcijama...
...ako se nekome da neka skicne YT pregled opcija u BIOSu pa ako misli da se nesto moze napraviti ne bi bilo lose... https://www.youtube.com/watch?v=h0EH7W6_lAk
...normalno da sam pokusavao sa clear cmos itd itd... bez pomaka...
...dovoljno bi mi bilo da me netko uputi na neku GPU sa legacy biosom kako bi bila komaktibilna s mojom MBO znaci i polovnjaca kakva bi dosla u obzir...
Staro 10.09.2017., 11:30   #555
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
Neka GPU iste ili starije generacije kao i ta gtx580?
jedino ako ti taj rang nije preslab?
X
Staro 10.09.2017., 13:20   #556
dustox
dustox's Avatar
Lokacija: Bukovlje
Postovi: 25
..okej zanima me samo da li mi ovo moze biti orijentir...
na stranici techpowerup moguce je pogledati koja grafa ima kakav bios pa tako recimo za gtx 770 kazu VBIOS Version:
80.04.B4.00.05
UEFI Supported:
Yes
BIOS Build date:
2013-05-16 00:00:00
sto bi znacilo da ju moja legacy MBO ne podrzava dok recimo za gtx 680 kazu
VBIOS Version:
80.04.09.00.A3
UEFI Supported:
No
BIOS Build date:
2012-03-29 00:00:00
u prijevodu nju bi moja maticna mogla podrzati?
