Staro 30.10.2018., 21:18   #4831
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Odličan video. Pogotovo ove info o steppinzima, te "high availability" sredinom 2019. Taj 7nm je stvarno "next big thing" od trpanja abnormalnog broja jezgri u serverima, do brutalne efikasnosti u low power segmentu
Staro 06.11.2018., 18:06   #4832
Postovi: 8,353
AMD Next Horizon Live Stream + AnandTech Live Blog
  • Zen 2: World's first 7nm High Perf x86 CPU (7nm CPU chiplets + 14nm IO die)
  • It was briefly mentioned that a boost of performance by 25 percent IPC is expected, compared to Zen+
  • Radeon MI60 optimized for datacenter: World's first 7nm GPU
Zadnje izmijenjeno od: The Exiled. 06.11.2018. u 19:16.
Staro 06.11.2018., 20:21   #4833
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
oDkud ti ovo o IPC-u?
ne mogu nigdje naći neki trag o tome...?
X
Staro 06.11.2018., 20:23   #4834
Postovi: 8,353
Evo jedan od linkova, a obzirom da sad skoro svi prate jedno-te-istu stvar, bude se na kraju sve skupa iskristaliziralo.
Process migration has allowed AMD to double chip density by 2X, halve power consumption, and deliver claimed boost in overall performance by 25 percent compared to its previous gen Zen+ architecture.
U međuvremenu:
  • 02:20PM EST - Rome is PCIe 4.0
  • 02:20PM EST - Socket compatible with Naples
  • 02:20PM EST - Up to 64 Zen 2 cores, 128 threads
  • 02:19PM EST - Preview of Rome
Staro 06.11.2018., 20:33   #4835
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
25% performance, ne IPC. Tih 25% je IPC + takt, a brojke vezane samo za IPC su dosad bile 13-15%.
Staro 06.11.2018., 20:44   #4836
Postovi: 8,353
Zato i velim da treba pričekati da se sve privede kraju, jer su zasad završili s prezentacijom, slijedi još demo tih novih čudesa.
Uglavnom, 7nm Zen 2 64C/128T Rome EPYC CPU (8-core CCX) izgleda obećavajuće i za ostatak (desktop) ponude.
Zen 2 is a departure from the monolithic CPUs that, while bringing the aforementioned density, power, and core configuration gains, also introduces a design concept which both AMD and Intel have been gushing about for a few years now: a modular CPU built on an interconnect (Infinity Fabric) linking multiple CPU chiplets (in this case, the CCX). In Zen 2, each 7nm chiplet contains 8 physical cores and sits on a second gen Infinity Fabric interconnect (built on a 14nm process), connecting the CCX clusters. This enables AMD to add increased flexibility to the CPU designs and, eventually, roll out lower-ranking SKUs such as a next-gen Threadripper and Ryzen 3xxx series CPUs. It also means that AMD found the semiconductor manufacturing Holy Grail, as it can keep costs way down by producing small area (high yield) 7nm dies, and connect them via the 14nm-built infinity fabric. It will essentially punch out multiple CPU SKUs from a single package setup (altough, this is arguably overkill for desktop Zen 2).
Izvor: TechSpot
Zadnje izmijenjeno od: The Exiled. 06.11.2018. u 21:08.
Staro 06.11.2018., 21:13   #4837
messiah
aka Mithrandir
messiah's Avatar
Postovi: 449
Ako ne pregaze Intel u server marketu iduće godine, ne znam kad će.
Sklopili deal s Amazonom.
https://www.barrons.com/articles/amd...ces-1541528041
Koliko znam, Azure ih je već otprije koristio.
Bit će zanimljivo
messiah je offline   Reply With Quote
Staro 06.11.2018., 21:20   #4838
Postovi: 8,353
HP, Dell (VMware), Cray, Oracle, IBM, Baidu, Microsoft (Azure), Amazon (AWS), Tencent, Google, Facebook - mislim da su pokrili sve veće igrače.
Intel muči to kaj single i dual-socket EPYC mašine nude jako lijepi omjer uloženog i dobivenog.
Zadnje izmijenjeno od: The Exiled. 06.11.2018. u 22:00.
Staro 06.11.2018., 22:16   #4839
Manuel Calavera
Postovi: 14,584
Isus AdoredTV je i najavio ovakav dizajn od 9 čipova tj. 8 sa jezgrama na 7nm + IO/ostalo na jednom velikom od 14/12nm. Ludnica.
Taj veći čip će im vjerojatno praviti GloFo, tako da rješe 2 muhe jednim udarcem
Nemoš vjerovat kako im se poklopilo, jer je zen2 vjerojatno tako zamišljen od starta sa Jim Kellerom.
Combining this breakthrough design methodology with the benefits of TSMC’s leading-edge 7nm process technology, “Zen 2” delivers significant performance, power consumption and density generational improvements that can help reduce datacenter operating costs, carbon footprint and cooling requirements. Other key generational advances over the award-winning “Zen” core include:
- An improved execution pipeline, feeding its compute engines more efficiently.
- Front-end advances – improved branch predictor, better instruction pre-fetching, re-optimized instruction cache and larger op cache.
- Floating point enhancements – doubled floating point width to 256-bit and load/store bandwidth, increased dispatch/retire bandwidth and maintained high throughput for all modes.
- Advanced security features – Hardware-enhanced Spectre mitigations, taking software migration and hardening it into the design, and increased flexibility of memory encryption.
Multiple 7nm-based AMD products are now in development, including next-generation AMD EPYC CPUs and AMD Radeon Instinct GPUs, both of which AMD detailed and demonstrated at the event. Additionally, the company shared that its follow-on 7nm+-based “Zen 3” and “Zen 4” x86 core architectures are on-track.
Zadnje izmijenjeno od: Manuel Calavera. 06.11.2018. u 22:32.
Staro 06.11.2018., 22:32   #4840
Meću i ne vade... baš fino
Iako me najviše zanima Ryzen desktop CPU, malo manje Epyc ali dobro je. 1 CCX sa 8/16 da bude u destopu je majka.
Samo pred 2 godine se ovdje pisalo o bankrotu AMDa i o tome kako je Agrokor veća firma od AMDa 2 godine kasnije, lntel se oznojava...
Imam osećaj da će mnogim zagovarateljima singl-tred performansi one odjednom postati nebitne, na isti način kako je i zagrijavanje/potrošnja nestalo sa usana istih.
What a time to be alive
Sent from Usreo Mobara
Staro 06.11.2018., 22:33   #4841
Postovi: 8,353
Pazi(te) razliku između Rome i Naples EPYC modela. Dva ova mala 7nm 8C/16T Zen 2 čipa komotno (uz IO kontroler) stanu (primjera radi) na AM4 pakiranje. Zapravo, AMD sad može kombinirati kaj god ih volja, neovisno o socketu.
Staro 06.11.2018., 22:37   #4842
Manuel Calavera
Postovi: 14,584
Definitvno mogu sa iznimnom lakoćom izbaciti 16 core na AM4, tu odavno nema više dileme. Samo je pitanje dali žele tj. dali im to treba. Iskreno mislim da to neće navući 95% mainstream publike, ali bi moglo nekakvu semi-pro ekipu kojoj ne treba gro pci-e lejnsa, a ovih 95% će isključivo zanimati IPC i clock napredak, te i efikasnost.
Što se tiče ryzena 3xxx i Navija očito se onda čeka taj 09.01.2019 i CES za predstavljanje/najavu
Staro 06.11.2018., 22:39   #4843
Postovi: 8,353
Većini sigurno ne treba, ali hej - ko zna kaj bude Intel spremil za kraj godine. Zlu ne trebalo nek je i dual-7nm 8C/16T@AM4 opcija spremna.
Staro 06.11.2018., 22:40   #4844
Forbes kaže da je Intel naručio pošiljku od 90.000 plavih A5 kuverti.
Staro 06.11.2018., 22:42   #4845
Postovi: 8,353
Mislim da je u tom slučaju ova prigodna...
Staro 07.11.2018., 08:31   #4846
Manuel Calavera
Postovi: 14,584
Ovo je zanimljiv graf vezano uz node situaciju kako stoje AMD-ovi 14nm i 12nm naspram intelovih 14nm (inferiornije), te 7nm vs intelovih 10nm klik. Praktično je i 12nm mrvicu slabiji i od intelove ranije verzije 14nm
Što se tiče nadolazećih arhitektura samo je potvrđeno ono što je ranije rečeno:
AMD also confirmed in their long-term roadmap that while Zen 2 7nm chips have started sampling now and Zen 3 7nm+ chips are on track for launch around 2020, they also have the new Zen 4 CPU architecture nearing design completion which will be featured in their post-2020 CPU products. It is a really interesting time for AMD with multiple strong products coming out and them finally getting back in action.
Zadnje izmijenjeno od: Manuel Calavera. 07.11.2018. u 08:48.
Staro 07.11.2018., 09:21   #4847
Postovi: 8,353
AMD EPYC 2 Rome v. Intel Xeon Scalable Cascade Lake-SP
AMD EPYC 2 Rome stacks up closer to a four socket Intel Xeon Scalable server. Even in many of those cases, AMD EPYC 2 Rome still has several points where it comes ahead. Intel will have Optane Persistent Memory and features like VNNI for inferencing. As we wrote in our Hot Chips 30 piece’s closing comments Intel needs more. These are technologies that are first generation parts that may become important in the future, but it will be some time before there is broad enough support to say that virtually every server will use both features every day.
Intel wanted to get ahead of the news and offer its own solution, the Intel Cascade Lake-AP. Intel has entered the multi-chip package arena with this announcement. First, Intel Cascade Lake-AP will almost certainly require a new socket. As it stands, Intel’s announcement of Cascade Lake-AP is a one-off product until Cooper/ Ice Lake arrive. In many ways, the Cascade Lake-AP dual socket architecture looks like a quad socket Intel Xeon Scalable system, just in two packages. As a result, the numbers should be close to the above 4P numbers, except with an asterisk that Intel may be able to get up to 256 PCIe lanes from their platform. That would give more lanes to Cascade Lake-AP and bring bandwidth parity with Rome.
Izvor: ServeTheHome
Staro 07.11.2018., 09:33   #4848
Manuel Calavera
Postovi: 14,584
AMD je za epyc napulj navodio 80% TAM (Total addressable market) na serverskom tržištu, što znači da se na 20% serverskog tržišta ne može natjecati s intelom, e sad ne znam dali se sa zen 2 odnosno epyc rimom TAM proširio? Nisam nigdje vidio da navode da jest.
Staro 07.11.2018., 09:38   #4849
Postovi: 8,353
Nisam ni ja skužil da bi se o tome pričalo, ali sudeći po cloud-HPC-AI-machine-learning-itd. "ekipi" koja se okupila oko AMD-a, mogel bi sav serverski dio - polako, ali sigurno ići u njihovu korist.
Nek zgrabe taman toliko koliko im treba da više ne moraju spajati kraj s krajem, jer Intel bude na ovaj ili onaj način spremil adekvatan odgovor na svu Zen arhitekturu.
Pa onda, ako ništ drugo, da bar nakon više od desetljeća imamo Intel i AMD koji se ravnopravno nadmudruju.
Staro 07.11.2018., 13:51   #4850
Manuel Calavera
Postovi: 14,584
Sad im je prilika da grabe do 2021 možda 2022 god. a nakon toga kreće nova etapa. Intel će vjerojatno krenuti opako i opet zadominirati kad izbace truly nove arhitekture, pretpostavljam na ddr5 platformi i njihovom 7nm nodeu (osim ako se i to ne krene odgađati). Nadam se da se ozbiljno radi na Zen 4 i nasljednicima tj. da neće opet zaostati. Imam neki feeling da ako tada krenu zaostajati na cpu polju da će opet povući gpu divizija - taman se tada izbave iz čemera mainstreama u tom nekom post Navi razdoblju tj. arhitekturama razvijenim na zen novcu. Mislim da će Navi ubijati kao mrtvu mačku par godina, kao sada polaris
Ako ništa bude barem aktualnija od polarisa sada tj. dijeliti će nove tehnologije sa next-gen konzolama
Zadnje izmijenjeno od: Manuel Calavera. 07.11.2018. u 13:59.
Staro 07.11.2018., 19:29   #4851
Postovi: 8,353
Iskreno, nadam se da Intel i AMD u godinama koje dolaze ne budu u pozicijama u kojima su bili do prije dvije godine. S jedne strane, AMD-u je ovo sjajna prilika da se makne iz vječne sjene i napokon zgrabi malo veći dio tržišta (Intel trenutno još uvijek drži 90%+ u svim segmentima), a s druge strane, Intelu je ovo itekakav poziv na buđenje i poruka da krajnji korisnici više ne padaju na jedno-te-iste (sad već desetogodišnje) fore. AMD trenutno ima IMHO možda čak i bolje rješenje od orginalnog Athlona64, a Intel ima mogućnost da ponovi Core 2 Duo ili Sandy Bridge dane slave iz čega su svojevremeno proizašli modeli koji su (onda) sasvim opravdano pokopali AMD (mada je Phenom II ispal i više nego solidan) uzduž i poprijeko. Početkom 2017. je lansiran Core i7-7700K (4C/8T + iGPU), a danas imamo Threadripper 2990WX (32C/64T) za po doma, dok Intel 6C/6T + 8C/8T i AMD 6C/12T + 8C/16T modeli postaju mainstream.
Staro 07.11.2018., 21:41   #4852
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,764
Samo info za Internet demagoge (podsjecate me na MySQL zealote svojedobno, s nekom nevezanom pricom) - barem sto sa tice Azurea i Google (Clouda), doslovce niti jedna VM instanca ne koristi nista osim Intela. Tocnije, Platinume za jace price, odnosno V-x Xeone (kako koji tier i geolokacija) za manje CPU intenzivne.
Microsoft to cak ima dokumentirano. Na nekih 300njak GCloud instanci nisam takodjer vidio nista osim Intela.
Programer
Staro 07.11.2018., 21:58   #4853
Postovi: 8,353
Baci pogled na Azure ponudu, čak su i bili prvi od ovih većih koji su prigrlili EPYC od samog početka. Mislim, tak svejedno za nas prosječne, ali očito da nekakva podrška i ponuda postoji.
Staro 07.11.2018., 22:09   #4854
messiah
aka Mithrandir
messiah's Avatar
Postovi: 449
Autor Bubba Pregled postova
Nije lagano penetrirat tržište gdje je Intel imao skoro 100% market sharea.
Ali kad izbaciš proizvod s većim performansama, s manje zagrijavanja za manje para mislim da je računica jednostavna.
Pitanje je kakve postojeće ugovore imaju s Intelom, sigurno neće preko noći razbit server tržište.
Mislim da Intel ne može uopće izbacit konkureniciju Romeu ni iduće godine, ni u broju jezgri ni u TDP-u, a bome ni cijenom.
Staro 07.11.2018., 23:31   #4855
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,764
To su storage optimized (s) obitelji instanci. Daklem, blago receno opskurno i s vrlo vrlo uskom primjenom. Uz to, u West Europe regiji ih uopce ne vidim dostupne u Dashboardu, samo ovo:
https://docs.microsoft.com/en-us/azu.../sizes-storage
Autor messiah Pregled postova
Ono o cemu se uporno tupi a svi koji to tupe elementarno ne shvatjaju kako stvari funkcioniranju - ne kupuju se procesori u Linksu ili Uzi Šopi, niti je segment retaila toliko dramatican. Mislis da Amazon/Microsoft/Google kupuju ista po RSP iznosima? Uz to, ne cini sustav samo CPU, i to je ono na cemu AMD mora, a pitanje je hoce li ikada moci, poraditi.
Tako da, ukratko, poanta price "penetracije AMD na [umetni velikog igraca po zelji]" je na revijalnoj bazi. Od 212 meni dostupnih VM instanci na Azureu, 6 (šest) ih je AMD bazirano, i to u poprilicno opskurnoj kategoriji. Dakle, ni 3%. I tu je problem.
Na Google Cloud VM-ovima uopce nisam ni naletio na AMD.
Programer
Staro 07.11.2018., 23:49   #4856
Postovi: 8,353
Daleko od toga da ti netko proturječi u ovome, pogotovo ja - samo komentiram(o) da do jučer nisu imali ovo malo kaj trenutno nude.
Kaj se serverskog dijela tiče, još uvijek su debelo ispod 5% udjela, nekih 1.3% ili tome slična smiješna brojka u usporedbi s Intelom, a prošle godine su bili na 0.5% - ko da ih i nema.
Možda se sad s novim 7nm EPYC + MI60 Radeonima stvari i preokrenu u neku veću korist za AMD, jer tak jasno da Intel ne popušta svoj stisak, pa makar i morali kupiti AMD.
Staro 08.11.2018., 00:13   #4857
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,764
Sve se mi kuzimo. Samo ti velim, od godine i pol dana na trzistu, slabo to gmilji. To govori nesto o proizvodu, ali i puno toga o tome kako kuronja kao Intel s hrpom para moze razjebati nesto cak i ako nije toliko lose koliko netehnoloski parametri pokazuju. Sto samim time onda neminovno tehnoloski kvari postojeci proizvod, jer ti nedostaje novaca za "ici dalje". Ruzno zacarani krug, nazalost...
Programer
Staro 08.11.2018., 07:52   #4858
Postovi: 8,353
Bome ne bi bilo ništ čudno da Intel dan-danas koristi istu taktiku (1 - 2) koju su koristili prije desetak i više godina. Tim više, jer su u startu pokušali posrati prvu EPYC generaciju, samo da bi prije koji dan (opet u pokušaju sjebavanja EYPC Rome modela) najavili slične MCM planove. Tak da AMD u svakom slučaju ima itekakvog posla kad je u pitanju proboj na serverski dio, čak i sad kad imaju nekaj konkretno za ponuditi.
Zadnje izmijenjeno od: The Exiled. 08.11.2018. u 08:05.
Staro 08.11.2018., 08:30   #4859
Manuel Calavera
Postovi: 14,584
MCM pristup je budućnost, to je očito. Tako da su se posrali sami sebi po stolu
Inače serveri se puno rjeđe mjenjaju pa i taj proboj epyca na navedno tržište ne može biti brz. Za primjer znam da hoteli u Dubaiju, čiji vlasnici imaju milijarde ne žele promjeniti po 15 god. stare odrtine od servera. OK hoteli nisu neki power useri, ali primjera radi.
Staro 08.11.2018., 18:45   #4860
Postovi: 8,353
Škoti Pippen o novom Zen 2 7nm EPYC Rome procesorčetu.
