Staro 03.04.2011., 02:06   #451
Firkraag
Firkraag's Avatar
Postovi: 32
referirao sam se na ovo, jest da su možda počeli prošle godine ali prema business planu ova im je udarna, gornji segment matičnih žele udvostručiti
http://www.wantchinatimes.com/news-s...20110129000081
Firkraag je offline   Reply With Quote
Staro 03.04.2011., 12:44   #452
Wolverine
Wolverine's Avatar
Postovi: 12,425
Krenuli su oni udarno na premium segment izlaskom prvih ploča na X58 čipu. Nije ovo nikakav novi plan za ASRock.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 03.04.2011., 12:47   #453
Chiron
Chiron's Avatar
Postovi: 371
Zar nije Asrock bio ili je pod ASUS-om?
Destiny isn't already Forged!!!
Chiron je offline   Reply With Quote
Staro 03.04.2011., 13:03   #454
Wolverine
Wolverine's Avatar
Postovi: 12,425
ASRock je nastao kao firma kćerka Asusa. No već neko vrijeme nisu pod njihovom kapom.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 03.04.2011., 14:51   #455
Ranma 1/2
Anything Goes Martial Art
Ranma 1/2's Avatar
Lokacija: Tendo Dojo
Postovi: 542
a i dio inženjera iz nekadašenjeg Abita je prešao raditi u Asrock
"Water! Why does it always have to be water?!"
Ranma 1/2 je offline   Reply With Quote
Staro 03.04.2011., 17:55   #456
Postovi: 8,218
Staro 13.04.2011., 19:39   #457
Firecracker
Firecracker's Avatar
Postovi: 621
Pitanjce, imam AC freezer pro rev2 sa i7 2600K procesorom, u pozadini vrtim BIONIC Manager, 90% opterećenje pocesora i sad mu je temperatura 60° dok su mi jezgre 75-78°C. Ovaj cooler je tih, ali isto mi se čini da je ovo dosta visoko... Što vi kažete?
Na idle je temp 35°C (uključen je speedstep).
Zadnje izmijenjeno od: Firecracker. 13.04.2011. u 20:07.
Firecracker je offline   Reply With Quote
Staro 13.04.2011., 21:03   #458
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Da puno mu je to. Koja je frevencija proca? Mislim koja god, puno je. Treba malo bolji hladnjak za 2600k a ni 2500k nije bas mala beba po pitanju temp.
Staro 13.04.2011., 21:05   #459
donniedarko133
donniedarko133's Avatar
Postovi: 80
Autor Firecracker Pregled postova
Nisi napisao da li je procesor na stock frekvenciji ili overclockan.
Uglavnom, ja imam AC Freezer 13 na i5-2500k (OC 4GHz) i namjestio sam postavke u BIOS-u tako da temperature jezgri ne prelaze kojih 60-tak stupnjeva ni na stress testu.
Skraćeno: Puno previše. Osim ako si ga natjerao preko 5GHz.
donniedarko133 je offline   Reply With Quote
Staro 13.04.2011., 21:40   #460
Firecracker
Postovi: 621
Stock je frekv , 3.5Ghz sa turbo boostom.
Staro 13.04.2011., 21:42   #461
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Skini cooler i vidi kako je sjeo. Nešto tu grdno smrdi..
Sa stock coolerom bi imao manje temperature od tih a Frizerka je bar klasu bolja od stocka.
Staro 13.04.2011., 21:43   #462
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Onda ti hladnjak ne sjedi dobro.
Ja sa Venomusom i prosjecnim ventom mogu imat proc na 4.7ghz i bit ispod 70c u svemu. 78c na stock frekvama nikako nije dobro, bez obzira na hladnjak. Stock hladnjak je bolji od toga.
Staro 13.04.2011., 21:48   #463
Firecracker
Postovi: 621
A problem kod tog coolea je šta on ima svoje sjedište i ne mogu bas kontrolirat jeli sjeo ili ne, ja ga samo zavidajem sa odvijačem do kraja i to je to
Staro 13.04.2011., 21:50   #464
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Provjeravanje je li cooler sjedi dobro se vrši pomoću termalne paste. Ovisno o tome kako se pasta raspršila, vidiš je li isti sjedi dobro ili ne. U svakom slučaju, namontiraj ponovo.
Staro 26.04.2011., 23:26   #465
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,573
Autor MAGARAC Pregled postova
Pase sigurno. 4.5 bas i nije nesto blagi OC i zavisno o proceoru moze zahtjevat do 1.35v ak ne i vise. U tom slucaju freezer nije dovoljan sigurno ali za neke voltaze ispod 1.3v bi vjerojatno bio. Znaci ovisi o procesoru.
Kvotam sa topica o Asrocku P67 pro jer je ovdje više on topic.
Koji bi onda hladnjak bio najsretnije rješenje za overclockanog 2500k (sa voltažom ne višom od 1,35V) a da je cijena <=300kn a tišina venta (pogotovo
dok proc idlea) prioritet?
Staro 26.04.2011., 23:45   #466
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,566
Staro 26.04.2011., 23:56   #467
donniedarko133
Postovi: 80
Autor Exy Pregled postova
Imam nešto noviju verziju (AC Freezer 13) koja mislim da je dosta slična tvojoj. A prije toga sam imao AC Freezer 64 na AMD-u. U oba slučaja hladnjaci su gotovo bešumni čak i na većem broju okretaja.
Proc mi je podešen na 4GHz, a mislim da bi išlo i dosta više s tim hladnjakom. Ništ te ne košta da probaš, ako već imaš taj model iz starije konfiguracije. Ako nisi zadovoljan uvijek možeš krenuti na kupnju novog.
Staro 27.04.2011., 01:41   #468
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Taj Zalman je dobar ali se nabi kladio da ce ti se svidat tisna njegovog venta. Nije medu tisima sigurno. Kak hladnjak dela sa drugim venotm ne znam ali pretpostavljam da bi radio sasvim ok sa nekim boljim ventom na 1200rpm.
Za 4.5 stvarno nemas potrebe osim ak ima neku grafetinu i igras CPU zahtjevne igre. 4.0 ili manje je i vise nego dovoljno za sve zivo i bit ce ti velik upgrade u odnosu na sadasnju kofu. Hladnjak uvijek mozes kupit kad bude prilike. Nemam poima kak rade ostali jeftiniji hladnjaci. Pretpostavljam da su u redu. Mene moj Venomus veseli jer a njega mogu stavit SFlexa na 800rpm i imat tih 4.5 poprilicno ispod 70c(necujno) i mislim da je tu najveca razlika u odnosu na jefinije hladnjake.
Staro 27.04.2011., 09:43   #469
Verbum
Postovi: 682
Koristim tog Zalmana duže vrijeme i vent stvarno nije glasan naravno kada se stavi otpornik koji i omogućava njegov tihi rad tj. da se okreće do 1400 RPM-a.
Većinu vremena držima proc na 3.6Ghz pri 1.20V i vent se vrti preko 1000 RPM-a jedino kada pokrenem PRIME95 ili nešto slično, s time da temperature u PRIME-u ne prelaze 60C.
BTW sa strane mi stoje dva SCYTHE GentleTyphoon-a na 1150 RPM-a i još mi nije palo na pamet da zamjenim vent na cooler-u.
Sve u svemu Performa je bez premca best buy cooler s obzirom na omjer cijena/performanse.
Zadnje izmijenjeno od: Verbum. 27.04.2011. u 09:52.
Verbum je offline   Reply With Quote
Staro 27.04.2011., 10:34   #470
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Da ali ipak se tu prica o voltazama iznad 1.3v i taktu od 4.5ghz sto je dosta vece od 1.2v i 3.6ghz. Bez obzira sto se 2500k nesto malo manje grije. To su temp izmdu 65 i 70c sa najboljim hladnjacima u LinX i sl. loadu. Treba probat. Sigurno da bi bio dovoljan ali jedino pitanje je sa koliko venta i koliko buke.
Treba jos uzet u obzir da je LinX ili prime95 load nekih 5,6,7c topliji od nekog rendanja ili encodiranja sa 100% venta a u igrama je i 20c razlike. Tako da je vejrojatno da tu temp nece nikad dostic u normalnom radu.
Staro 28.04.2011., 14:57   #471
housel
aka Sizif
housel's Avatar
Lokacija: požega
Postovi: 581
Ima li tko stock hladnjak i da nije OCao, kolike su vam temp?
Složio sam curi i5 2400 i Asus P8H67 mbo, koristim integriranu grafiku,
idle temp cpu 45°C i mbo 50°C. Vjerojatno se sve više zagrijava jer koristi i gpu no nije li to malo previše? Probao sam skinuti hladnjak i staviti AC ceramic ili tako nešto, temp su pale za svega 2,3 °C. Sve ostalo je po defaultu.
Zadnje izmijenjeno od: housel. 28.04.2011. u 15:00. Razlog: link
housel je offline   Reply With Quote
Staro 28.04.2011., 15:56   #472
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
Autor housel Pregled postova
mislim da je u granicama,još ako je kućište slabo ventilirano razumljivo
koje su load
prt scr je offline   Reply With Quote
Staro 28.04.2011., 16:04   #473
housel
aka Sizif
housel's Avatar
Lokacija: požega
Postovi: 581
Nije ni došlo do loada, nije mi to komp kod kuće, vidjet ću navečer no pretpostavljam da će biti previsoke. Kržljav je neki taj hladnjak što dođe sa njime.
Staro 28.04.2011., 16:42   #474
mhadina
mhadina's Avatar
Postovi: 436
i ja i ja
Autor prt scr Pregled postova
koje su load
odmah sam isto pomislio - štedi se na kućištu, ali šta fali za uredski rad tim temperaturama? Iako sumnjivo je, koliko si coolera montirao do sad?
Možda is pretjerao s pastom ili si loše one pinove od hladnjaka učvrstio?
poz
  • Vidiš li čovjeka koji se sam sebi mudrim čini? Znaj, i od bezumnika ima više nade nego od njega!
  • San dolazi od mnogo briga, a lud govor od mnogo riječi.
  • Neka su ti mnogi poznanici, ali pouzdanik samo jedan od tisuću.
  • Ne ponizuj se pred budalom i ne budi pristran pred mogućnicima.
  • Ne budi silovit na jeziku a lijen i mlitav na djelu.
mhadina je offline   Reply With Quote
Staro 28.04.2011., 17:03   #475
housel
aka Sizif
housel's Avatar
Lokacija: požega
Postovi: 581
Sve sam složio kako treba. Kućište je neko jeftino Frontierovo sa jednim 120mm ventom no temp su takve bile i kada su obe stranice bile skinute.
Koristi li još tko integriranu grafiku? Vjerojatno i to uzrokuje višu temp s obzirom na to da i taj gpu, kakav god bio, treba napon za rad. Koliko sam god pročitao, svi koji su zadovoljni temperaturama, ne koriste integriranu grafiku. Vrlo vjerojatno da je i sam mbo zbog toga topliji. Morat ću kupiti nekakav cooler. VIdio sam nekakav AC Freezer13 za nekih 250kn a i ako se ne varam, ovdje ga je netko spomenuo da ima.
Staro 29.04.2011., 15:45   #476
MujagaWudakhi
MujagaWudakhi's Avatar
Postovi: 57
Core i5 2500 radna temperatura
bok ljudi,
zanima me da li je normalno da MAX temperatura CPU nakon gameanja u HW monitoru dosegne čak 68 stupnjeva??
to je obicna vezija 2500, nije K, u idleu je temp oko 35C takodjer i kod surfanja i ostalih nezahjtevnih radnji, a vecinom je 50-+ stupnjeva dok radim nešto zahtjevnije, no zna doci cak i do 68 prilikom gameanja...
MujagaWudakhi je offline   Reply With Quote
Staro 29.04.2011., 15:52   #477
alengrosevic
alengrosevic's Avatar
Postovi: 3,779
http://ark.intel.com/Product.aspx?id=52209
koliko po specifikacijama vidim,temp je jos uvijek u granicama...
alengrosevic je online   Reply With Quote
Staro 29.04.2011., 15:57   #478
MujagaWudakhi
Postovi: 57
dakle ukoliko budem gameao i dalje i sa stock coolerom ako mi bude oko 70, ne trebam se brinuti ili...??
tnx
Staro 29.04.2011., 16:10   #479
alengrosevic
Postovi: 3,779
ma ne brini se. Proc u sebi ima ugradjenu zastitu, i ako zaista temperatura predje granicu gdje je kriticno, racunalo ce se samo ugasiti. Ako se to dogodi, onda pogledaj da li je dovoljan protok zraka kroz kuciste, da li je dobro pasta razmazana po procu tj da li je cooler dobro sjeo na proc itd...
Ali zasad ne brini, sve je ok
Staro 29.04.2011., 16:15   #480
MujagaWudakhi
Postovi: 57
oke, nadam se da nece uopce do toga doci.... hvala puno na brzom replyu...
pozzz
