Staro 10.09.2025., 11:17   #4531
Postovi: 8,527
fala decki.
ma nije problem manul copy. problem je sto evo traje oko 20-30 min po masini na taj microSD. 20-30mb/s ha ha. al dobro je sto ne radim snapshote pa sve skupa ne prelazi 28gb po masini.neznam dal microSD odlazi i od samog stajanja u masini (zagrijavanje?) ili ga drobi u pravilu samo "write", jer on je skoro pa nekoristen pa ak ga toplina ne shebava bude trajao "zauvjek" pa je dobar za backup tak da je unutar laptopa sve (lenovo x280).
veci problem je sto izgleda da mi throttlestop postavke (UV, UC) "nisu bas rock solid" i zato lap krkne kad mu pokrenem vise Virtualki, sto jako rjetko radim.
back to that ...
Ja sam kod sebe podesil WinRoboCopy koji svih 20 VM-ova od kakvih 1TB sveukupnog kapaciteta prebaci u jednom mahu na backup diskove, pa možeš i kod sebe nekaj slično složiti.
Naravno, vrijeme kopiranja/backupiranja traje ovisno o količini, brzini, hardveru općenito, ali kak god se okrene nije loše za jednom tjedno u pozadini odvrtjeti.
Staro 11.09.2025., 08:07   #4532
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
Mesa's Gallium3D video acceleration code has long supported both the VA-API and VDPAU interfaces for video acceleration. VA-API has enjoyed more widespread support among Linux applications and typically more robust while the Video Decode and Presentation API for Unix (VDPAU) was the interface originally started by NVIDIA for their official Linux driver. As of today, Mesa has now removed support for VDPAU acceleration.
AMD engineer David Rosca landed the video acceleration changes to Gallium3D today for removing VDPAU from the Mesa source tree. His reasonings for removing VDPAU are explained in the commit:
"VDPAU only supports X11 and GL interop. There is no Wayland or Vulkan interop support. The API has limitations that makes it impossible to correctly decode certain streams. Application support is also very limited, and VAAPI is always a better choice over VDPAU."
The merge lightens the Mesa codebase by nearly nine thousand lines of code in removing the VDPAU support.
> Phoronix
Fwupd 2.0.15 has been released today as the fifteenth maintenance update to the fwupd 2.0 series of this open-source Linux firmware update utility, adding support for more devices, new features, and bug fixes.
Coming about two weeks after fwupd 2.0.14, the fwupd 2.0.15 release adds support for updating the firmware on more hardware, including the NVIDIA ConnectX-6, NVIDIA ConnectX-7, and NVIDIA ConnectX-8 NICs, Jabra Evolve2 child devices, as well as the Foxconn SDX61 modem.
Apart from the extra hardware support, fwupd 2.0.15 introduces support for allowing child devices to use the parent name as a prefix, adds newer commands and options for Fish completion, and adds support for allowing the installation of firmware archives named as .CAB rather than .cab.
> 9to5
This week Jonathan and Dan chat with Frank Vasquez and Chris Simmonds about Embedded Linux, and the 4th edition of the Mastering Embedded Linux Programming book. How has this space changed in the last 20 years, and what’s the latest in Embedded Linux?
> Hackaday
Staro 13.09.2025., 16:30   #4533
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,139
Upgrade s D12 na D13 prošao sasvim očekivano dobro jedino je u apacheu php zezao jer je gledao php8.2 a trebalo je php8.4.
Staro 13.09.2025., 20:17   #4534
strikoo
strikoo's Avatar
Postovi: 1,020
To je klasika. Mi kroz puppet odma puštamo promjenu phpa
strikoo je offline   Reply With Quote
Staro 14.09.2025., 15:00   #4535
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,139
Autor strikoo Pregled postova
samo je trebalo odraditi
sudo a2dismod php8.2
sudo a2enmod php8.4
I restartati apache
Staro 24.09.2025., 19:57   #4536
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
A very exciting set of kernel patches have just been proposed for the Linux kernel, adding multikernel support to Linux.
This patch series introduces multikernel architecture support, enabling multiple independent kernel instances to coexist and communicate on a single physical machine. Each kernel instance can run on dedicated CPU cores while sharing the underlying hardware resources.
↫ Cong Wang on the LKML
Queued up into DRM-Next is a last batch of Intel Xe kernel graphics driver improvements ahead of the Linux 6.18 merge window that is expected to begin next week. With this last minute Intel Xe driver activity is also a new power management knob for those wanting to run their Intel graphics slightly more efficient.
The new addition in drm-xe-next worth mentioning is the SLPC "slpc_power_profile" sysfs interface. This allows manipulating the Single Loop Power Controller (SLPC) between its base (default) state and a "power_saving" mode.
We've seen Intel work on SLPC power management enhancements in the past and this latest addition for Linux 6.18 lets users adjust the state by reading/writing to the "slpc_power_profile" under the DRM sysfs entries.
> Phoronix
Zadnje izmijenjeno od: tomek@vz. 24.09.2025. u 20:23.
Staro 27.09.2025., 10:47   #4537
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Wendell i GN Steve o problematici gaminga na linuxu:
Adding Linux GPU Benchmarks: Best Distributions for Gaming Tests, ft. Wendell of Level1 Techs
**Bazzite je baziran na Fedori.
Zadnje izmijenjeno od: stef. 27.09.2025. u 11:15.
Staro 27.09.2025., 11:23   #4538
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
Autor stef Pregled postova
Vidjeh jutros. Kao i obično odličan video i objašnjenje
Staro 27.09.2025., 19:57   #4539
strikoo
strikoo's Avatar
Postovi: 1,020
sve mi doslo da digne CachyOS, ali #nedamise
nadam se da stevo nece odustati od linuksa kao ostali
Staro 27.09.2025., 20:20   #4540
Postovi: 8,527
IMHO Heavy Metal Steve bude to postepeno dovel na isti nivo kakav npr. Ancient Gameplays (1 - 2) već naveliko pokriva na svoj način.
As we're publishing this, we're about 2 weeks into setup, pre-testing, variable isolation, and calibration for a Bazzite Linux GPU benchmark suite.
We don't have a firm ETA yet, but we are working on it every day right now! Very excited to run the numbers!
Staro 27.09.2025., 20:41   #4541
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Nisam sad detaljno proučavao Bazzite, ali po onome što je rečeno rekao bih da je bazirano na Fedora CoreOS ili Atomic. Ili nešto treće, slično.
Staro 27.09.2025., 22:08   #4542
Postovi: 8,527
Da, Atomic je u pitanju, odnosno Bazzite je baziran na Silverblue izdanju.
Staro 28.09.2025., 07:12   #4543
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,367
Ja sam bazzite probao samo onako, na brzinu na laptopu i vrtio se očajno, plus je krcat predinstaliranih govnarija, ali dobro, kako je rekao Wendell to je idiot proof linux (npr baš za mene). Ali probao sam i cachy koji mi je SF za bazzite, ima hrpu opcija, lijepo vrti, ja sam updateam kada hoću (mislim da bazzite forsa update kad se starta, ali se ne sjećam više), samo tu treba očito i zavrnuti mentalne rukave i naučit nešto.
Kužim da je GN išao na bazzite da bude uvijek isto iskustvo, tj da ne moraju ništa dodatno podešavati što je zapravo bolje za benchanje.
Slobodno me dodajte na PSN
Staro 28.09.2025., 12:44   #4544
rodriguez
rodriguez's Avatar
Postovi: 2,066
Koju weather app koristite? na varijanti archa sam endeavour OS
Thinkpad T430 running
Staro 28.09.2025., 13:51   #4545
Postovi: 8,527
Autor Disco Pregled postova
Bazzite po defaultu dolazi samo s onim predinstaliranim aplikacijama koje su vezane za gaming, tj. Steam, Lutris i sl., ništ pretjerano mimo toga. System Update se uvijek može pokrenuti ručno, pa onda sam odradi sve kaj treba, nema nekih dodatnih naredbi, odnosno nisam skužil da se automatski nadograđuje kak mu paše bez ikakvih pitanja. IMHO ovaj Ancient Gameplays lik je već u nebrojeno navrata dokazal da neovisno o kojoj distribuciji je riječ (Bazzite, CachyOS, Nobara, itd.), gaming na Linuxu itekak funkcionira, samo da još GN i ostali veći kanali pomognu u populariziranju i bog-bogova.
Staro 28.09.2025., 17:09   #4546
d0X
Kostolomac
d0X's Avatar
Postovi: 1,542
Još da malo sazriju driveri, pogotovo za Nvidiu, i stvarno ne vidim zašto bih se zadržao na Winsima. Jedino nisam fan klasičnog distro raslojavanja. 100 distri za sličnu namjenu i nikad ne znaš koja će preživjeti, umjesto da se male ruke slože i naprave jednu poštenu. Ali to je valjda ljepota i prokletstvo FOSS-a.
PSN Steam
Staro 28.09.2025., 17:19   #4547
Neo-ST
Neo-ST's Avatar
Postovi: 8,564
Autor d0X Pregled postova
Multiplayer.
Staro 28.09.2025., 17:33   #4548
d0X
Kostolomac
d0X's Avatar
Postovi: 1,542
@Neo-ST meni svejedno jer od multija igram samo CS povremeno koji šljaka na Linuxu. Ali u pravu si za ekipu koja roka puno raznih multiplayera.
PSN Steam
Staro 28.09.2025., 18:11   #4549
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
Zato ja vise ni ne obracam paznju na manje distre osim ako zbilja nisu po necem posebne (Alpine primjerice koji mi je postao go-to baza za sve docker based). Za sve ostalo preferiram vec dobro ustolicene distre - Fedora i Debian ( i tu i tamo OpenSuse Tumbleweed). Ovo je ostalo sve prerastrkano resursima i uvijek na necem padne. Immutable ditre vise nisu novost ali osim povremenih eskapada drzao sam se standardnih distri iz ciste navike iskreno ( i averzije prema btrfs-u jer me vec nekoliko puta opekao).
Staro 29.09.2025., 06:57   #4550
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
Tim Berners-Lee writes in a new article in the Guardian that "Somewhere between my original vision for web 1.0 and the rise of social media as part of web 2.0, we took the wrong path Today, I look at my invention and I am forced to ask: is the web still free today? No, not all of it. We see a handful of large platforms harvesting users' private data to share with commercial brokers or even repressive governments. We see ubiquitous algorithms that are addictive by design and damaging to our teenagers' mental health. Trading personal data for use certainly does not fit with my vision for a free web. On many platforms, we are no longer the customers, but instead have become the product. Our data, even if anonymised, is sold on to actors we never intended it to reach, who can then target us with content and advertising...
We have the technical capability to give that power back to the individual. Solid is an open-source interoperable standard that I and my team developed at MIT more than a decade ago. Apps running on Solid don't implicitly own your data — they have to request it from you and you choose whether to agree, or not. Rather than being in countless separate places on the internet in the hands of whomever it had been resold to, your data is in one place, controlled by you. Sharing your information in a smart way can also liberate it. Why is your smartwatch writing your biological data to one silo in one format? Why is your credit card writing your financial data to a second silo in a different format? Why are your YouTube comments, Reddit posts, Facebook updates and tweets all stored in different places? Why is the default expectation that you aren't supposed to be able to look at any of this stuff? You generate all this data — your actions, your choices, your body, your preferences, your decisions. You should own it. You should be empowered by it...
We're now at a new crossroads, one where we must decide if AI will be used for the betterment or to the detriment of society. How can we learn from the mistakes of the past? First of all, we must ensure policymakers do not end up playing the same decade-long game of catchup they have done over social media. The time to decide the governance model for AI was yesterday, so we must act with urgency. In 2017, I wrote a thought experiment about an AI that works for you. I called it Charlie. Charlie works for you like your doctor or your lawyer, bound by law, regulation and codes of conduct. Why can't the same frameworks be adopted for AI? We have learned from social media that power rests with the monopolies who control and harvest personal data. We can't let the same thing happen with AI.
Berners-Lee also says "we need a Cern-like not-for-profit body driving forward international AI research," arguing that if we muster the political willpower, "we have the chance to restore the web as a tool for collaboration, creativity and compassion across cultural borders.
"We can re-empower individuals, and take the web back. It's not too late."
Berners-Lee has also written a new book titled This is For Everyone.
Staro 29.09.2025., 15:53   #4551
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,873
lijepo sročeno, naivno malčice, ali ajd.
Staro 01.10.2025., 17:55   #4552
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
The Fedora Council has unveiled a comprehensive draft policy on AI-assisted contributions. This marks the culmination of a year-long community consultation process that began with a survey in summer 2024.
> itsfoss
OpenSUSE Leap 16.0 is out today as this community Linux distributiom built from the same sources as SUSE Linux Enterprise 16.
OpenSUSE Leap 16 / SUSE Linux Enterprise 16 are based on the Linux 6.12 LTS kernel, IA32 32-bit support is now disabled by default, x86_64-v2 CPUs and newer are required with removing baseline support, the modern Agama installer is now employed by openSUSE Leap 16, SELinux support as a Linux security module, and a wealth of other changes over the openSUSE Leap 15 series.
The openSUSE Leap 16 comes with 24 months of updates / community support and there will continue being openSUSE Leap 16 annual minor releases through 2031.
> Phoronix
Staro 02.10.2025., 18:58   #4553
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
The cybersecurity landscape witnessed the emergence of a sophisticated rootkit variation, FlipSwitch, targeting modern Linux kernels. First surfacing in late September 2025, FlipSwitch exploits recent changes in syscall dispatching to implant stealthy hooks directly into kernel code.
Early indicators suggest attackers leverage this novel approach to evade traditional detection, compromising critical infrastructure and cloud environments.
> cybersecuritynews
Staro 04.10.2025., 08:18   #4554
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
A set of patches merged via the networking pull request for the Linux 6.18 will help servers better cope with distributed denial of service "DDoS" attacks. Thanks to a Google engineer there are some significant optimizations found in the Linux 6.18 kernel code for more efficiently handling of UDP receive performance under stress, such as in DDoS scenarios.
> Phoronix
Staro 06.10.2025., 18:47   #4555
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
Linus Torvalds has raised concerns about Rust's automated formatting tool and pull request text formatting practices in a recent Linux Kernel Mailing List discussion.The conversation started on October 2nd when he responded to the Direct Rendering Manager (DRM) subsystem's pull request for Linux 6.18, submitted by maintainer Dave Airlie on October 1st. The pull request included Rust code additions for DRM drivers.
Linus first addressed what he saw as corrupted formatting in the pull request's changelog. The hierarchical indentation showing the organization of different subsections had been flattened.
> itsfoss
In early September, a request for comments (RFC) proposed making Rust mandatory in Git, potentially by the time of a future Git 3.0 release. The idea is not to immediately rewrite large sections of the tool but to prepare infrastructure and workflows so developers can confidently build with Rust in place.Patrick Steinhardt, who authored the RFC, put it like this:
As said, the entire goal is for us to have an easy playground that we can experiment on and develop the infrastructure incrementally without yet having to commit to anything.
I'm mostly splitting out the topic of introducing Rust from the larger series that introduce it into xdiff so that we can focus more on the actual process of introducing Rust into Git and less on the potential features that we want to build on top of it.
> itsfoss
Staro 07.10.2025., 06:11   #4556
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,367
Staro 07.10.2025., 06:24   #4557
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
Earlier this year, we worked with a local computer refurbishing and e-waste recycling organization to part-out computers that were discarded by everyone from end users to corporations. These laptops and desktops can be saved, or in the very least, the valuables (like aluminum and copper) can be removed and smelted down into reusable materials. Parts like CPUs can be repurposed into computers with broken CPUs or used in education, good batteries can be taken from laptops with dead motherboards and installed into laptops with dead batteries, and so forth. Kramden organizes these "Geek-a-Thon" events and Steve attended one nearly 20 years ago, but this time, he got to see how they actually arrange them. This event was super fun! Not everything in here is because of Windows 10 support ending; Kramden does this all the time, for any computer or reason. That's also why you see some Macs in here. Some more background if you're curious: Kramden gets a mix of e-waste and donated / retired machines from local individuals and from companies. Sometimes, these have perfectly good hardware, sometimes they have one or two broken things. They then work with volunteers (like in this episode) to reclaim anything valuable that could be used for education or cobbled-together into a new machine. A good example is the 12700K: This was in there because some company or person got rid of the computer, but obviously that's still a great part. The next step is to identify whatever was broken in the system, save the good parts, and repurpose them (or sell them to fund the classroom program). Anything unusable, such as just broken hardware or obsolete hardware, is broken down into recyclables and trash, sorted, and sent to the right groups to smelt down or dispose of. They are awesome.
> GamerNexus
Disco me preteko :P
Staro 07.10.2025., 13:05   #4558
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,718
Da li je netko uspio sloziti certifikat od fine na Ubuntu sa stickom Gemalto?
SafeNet Authentication Client je prosao i vidi certifikate, ali SignErgyFina vidi kao instaliran i bez obzira sto sam importao certifikat ne radi na fina stranicama.
Naravno, Fina daje programsku podrsku bez upustava, posalo sam im mail, ali vec dva dana ne odgovaraju.
Staro 09.10.2025., 07:04   #4559
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,302
Čini se da postoji novi način pokretanja Windows Softwera na Linuxu: Winboat. Iako zasad u Beta fazi, barem kolko vidim feedback korisnika je pozitivan i koncept izgleda obećavajuće.
Ispod haube: https://github.com/dockur/windows
Update: malo sam se poigral sa ovim čudom. Nije bedasta alternativa pokretanju virtualke. Za manje upućene korisnike možda i jednostavnija solucija (korisnik mora znati instalirati winboat, docker,docker-compose i freerdp na svoju distru i dodat svog korisnika u grupu docker). Za nekog tko samo želi par aplikacija tipa MS Office pokretat na Linuxu riješenje nije tak bedasto.
Par screenshotova:
Zadnje izmijenjeno od: tomek@vz. 09.10.2025. u 07:50.
Staro 09.10.2025., 11:26   #4560
Ivo_Strojnica
PRO
Postovi: 4,873
isprobat ću bome, hvala ti na ovome.
