#421 |
Lokacija: Zd
Postovi: 4,762
Intel konfa Mbo: Asrock P67 Pro - 778kn Cpu: Intel Core i5-2500K - 1498kn Ram: Kingmax 1x4GB 1600MHz - 310kn Vga: MSI GTX 560 TwinFrozr II OC + 3 igre - 1685kn Psu: XFX Core Edition 80+ 550W - 447kn Hdd: SAMSUNG SpinPoint F3 1Tb - 410kn Dvd: LG GH24NS, DVD±RW - 150kn Case: CoolerMaster Elite 335, black - 289kn ---------------------------------------------- ~5560 kn AMD konfa Mbo: Asrock 890FX Deluxe5 - 1315kn Cpu: AMD Phenom II X4 955 Black Editon - 785kn Ram: Kingmax 1x4GB 1600MHz - 310kn Vga: Sapphire HD 6950, 2GB - 1870kn Psu: XFX Core Edition 80+ 550W - 447kn Hdd: SAMSUNG SpinPoint F3 1Tb - 410kn Dvd: LG GH24NS, DVD±RW - 150kn Case: CoolerMaster Elite 335, black - 289kn ---------------------------------------------- ~5570 kn Intel konfa ima nesto jaci procesor ali i nesto slabiju grafu. Amd konfa ima skuplju plocu koja podrzava nadolazece AM3+ procesore (kao ulog u buducnost) pa ce tako buduci upgrade biti olaksan... |
#422 |
Too much busy
Postovi: 1,540
Što se pametnoga da složiti za 4000kn? Sa 20-22" monitorom, bez pržilice. Namjena: malo ne prezahtjevnog igranja, surfanja i sl.
It's nice to be important, but it's more important to be nice! |
#423 |
Postovi: 34,084
Vidi šta je zwer složio par postova više. Proc može neki Athlon X3, psu stavi XFX Core 450W i dodaj 6670 grafu.
#424 | |
Datum registracije: Jul 2011
Postovi: 4
UPDATE: Evo nekoliko dana se vec informiram, citam i primam savjete, pa sam dosao do ove dvije konfiguracije : AMD 1 x Asrock 880G Pro3 AMD SB850, ATX, FSB 2600, Dual Channel 4xDDR3 - 1866 1 x Procesor AMD Phenom II X4 955 Black Editon, socket AM3, BOX,C3 1 x DDR3 4GB (2x2GB) Corsair, 1600MHz, CL9,Value 1 x Sapphire HD 5750, 1GB GDDR5 128bit, Dual DVI + HDMI, PCI Express 1 x HDD SAMSUNG SpinPoint F3 1Tb 7200rpm 32MB cache Serial ATA II 1 x CoolerMaster Elite 370, black, (W)190 x (H)424 x (L)481 mm,4.7kg 1 x Napajanje XFX Core Edition 80+ 450W PSU - EasyRail technology Eventualno bi uzeo umjesto Saphire HD 5750 grafe ovu ili ipak ne s obzirom da prva ima 1GB memorije: Grafička kartica Sapphire PCI-E ATI Radeon HD6670 GDDR5 512MB/128bit, 800MHz/1GHz, PCI-E 2.1 x16,HDM Intel Asrock Z68 Pro3 - Intel Z68, ATX, 4xDDR3 2133MHz Procesor Intel Core i5-2500K 3.3GHz,1MB/6MB,95W,Socket 1155 DDR3 4GB (2x2GB) Corsair, 1600MHz, CL9,Value HDD SAMSUNG SpinPoint F3 1Tb 7200rpm 32MB cache Serial ATA II Napajanje XFX Core Edition 80+ 450W PSU - EasyRail technology CoolerMaster Elite 370, black, (W)190 x (H)424 x (L)481 mm,4.7kg Kod intelove konfe nema love za grafu, pa cu za prvu ruku koristiti integriranu, dok nesto od starog kompa ne prodam i ustedim za postenu grafu. Alternativno kuciste za obje konfe je Kućište Thermaltake V4 Black Edition (ukoliko ne bude na lageru) Molim Vas da mi pomognete sad evo definitivno izmedu ove dvije konfe izabrati onu koja bi najbolje odgovarala mojim zahtjevima koji su opisani u pocetku posta. Hvala lijepa unaprijed. EDIT: po naputku veve mijenjam u drugoj konfi kuciste, uzeo sam ovo gigabyte zbog cijene, al stavit cu colermaster kako to ne bi uopce utjecalo na izbor. Zadnje izmijenjeno od: Borin. 04.07.2011. u 19:20. Razlog: Mijenjam kuciste na drugoj konfi |
#426 |
Datum registracije: Jun 2011
Postovi: 12
zwer, puno hvala. ![]() Mom laičkom oku se čini dobro za ono što meni treba. Još samo 2 pitanja:
jassna I
A perfection of means, and confusion of aims, seems to be our main problem.
#427 | |
Lokacija: Pregrada
Postovi: 3
#428 |
Postovi: 587
što mislite o ovome, jel treba nešto mijenjati? znači da bude 4000kn, iz linksa. služila bi za gaming, surfanje, fimove i slično Monitor 22'' LCD SAMSUNG B2230N LS22PUYKFHEN, 5ms, 300 cd/m2, 70000:1, D-Sub, crni 1049,00kn DVD±RW LG GH22NS, 22x, crna, SATA, Dual layer, bulk 155,00kn Kućište COOLERMASTER Elite 360, RC-360, mATX/ATX, crno, bez PS 249,00kn Grafička kartica PCI-E XFX AMD Radeon HD 6670, 1GB DDR5, dualDVI, HDMI 749,00kn Tvrdi disk 1000.0 GB, WESTERN DIGITAL Caviar Blue, SATA3, 32MB c., 7200 okr/min, za desktop 459,00kn Procesor AMD Athlon II X3 445 BOX, s. AM3, 3.1GHz, 1.5MB cache, Triple Core 539,00kn Memorija PC-10600, 4 GB, G.SKILL, F3-10600CL9S-4GBNT, DDR3 1333 259,00kn Matična ploča ASROCK 770 Extreme3, AMD 770/SB710, DDR3, zvuk, S-ATA, RAID, G-LAN, PCI-E, eSATA, USB 3.0, ATX, s. AM3 549,00kn ukupno : 4.008,00 KN |
#430 |
Datum registracije: Apr 2011
Postovi: 1,430
@Pepermint 2 stvari: 1.Bez napajanja će to teško radit osim ako ga već nemaš. 2.Ima li neki poseban razlog za Links? (skuplji je od ostalih). |
#431 |
Postovi: 587
@dena stavio sam gore 6670, kakva je ona naspram tih 5750 i 5770? @listerstorm uf bio sam uvjeren da sam stavio napajanje. treba i to ubaciti a što se linksa tiče onaj za koga je ne želi naručivati online tak da mi u os-u nepreostaje ništa pametnije, bar kolko ja znam |
#434 | |
Postovi: 1,430
AMD Athlon II X3 450, 3.2GHz Corsair Value 4GB 1333MHz DDR3 Non-ECC CL9 DIMM MSI GTX460 OC, 1GB DDR5,256bit,DX11,FAN HDD Desktop SAMSUNG SpinPoint F3 (3.5" x 1/3H, 500GB, 16MB, Serial ATA II-300) PSU XFX Core Edition 80 450W PSU - EasyRail technology SONY Optiarc AD-7263S 24xLabelFlash SATA GIGABYTE kućište GZX8, crno, bez napajanja 3.293,89 - www.magazinRS.hr Ako možeš do ovog iznosa jer bilo bi šteta uzimati slabiju grafičku. Alternativno bi mogao i Ati grafičku koja je za nijansu jačih performansi (za 50 kn više): http://www.magazinrs.hr/product.asp?...X-HD-685X-ZNFC |
#435 | ||
Lokacija: čačinci
Postovi: 8
Pozdrav - konfiguracija do 4000 kn za gaming bez monitora! ADM ove komponente: Napajanje CORSAIR 500W CX Series, ATX, ATX12V v2.3 - 400,00Kn Miš PRESTIGIO PJ-MSO3, veliki, žični, optički 1600dpi, USB - 100 kn Procesor AMD Phenom II X4 955 Black Editon, socket AM3, BOX,C3 - 785 kn Thermaltake M9 VI1000BWS Midi tower, ATX,µATX - 440 kn HDD WD 500GB, 5000AAKX, SATA 3, Buffer 16MB, 7.200 rpm , 8,9 ms - 290 kn Asrock 770 EXTREME3 - AMD 770, AMD SB710, ATX, FSB 2600, Dual Ch 498.98 DDR3 4GB (2x2GB) Kingmax, 1333MHz, FLFE -250kn Sapphire HD 6850, 1GB GDDR5 256bit, Dual Link DVI + HDMI + DP - 1181 kn ukupno - 3944,97 ocjena kučišta (glasnoća rada, prostornost) Thermaltake V6 BlackX Edition, Midi tower, ATX,µATX, 5,25" - 495 kn (koliko je ovo bolje nasuprot navedenog) ocjena miša od 1-10 (purchasing just because it has 6 buttons!) |
#436 |
Postovi: 34,084
Promijeni napajanje (radije XFX Core 450W) i kućište (nađi neki CM u toj cjenovnoj klasi, npr. nešto iz Elite serije). Hoće li ti 500Gb biti dovoljno prostora? Da uzmeš neki veći hard?
#437 |
Lokacija: čačinci
Postovi: 8
Napajanje sam od 500W mislio uzet samo zato jer sve jače grafičke preporučuju 500W, ali ako to neigra neku veču ulogu onda bih mogao uzet i to od 450w. kučište Coolarmaster Elite 334 nVidia Edition, NV-334-KWN1-GP, MIDI - 420kn. dali je to tiše iako mislim da je ono bolje zbog 2 ventilatora + led lights(not bad not bad at all aiight) vi presudite!!!(and a verdict is...) 500 gb je sasvim dovoljno. dadli je matična zadovoljavajuća ili treba jača. koliko je bolja HD6850 toxic od navedene(100-kn razlike otprilike) is that the way to go or? much appreciated (games to play - CRYSIS 2, SPACE MARINE, BF3!) |
#438 |
Postovi: 34,084
Kod ovih napajanja, caka je u tome da XFX daje više W od Corsaira iako u imenu stoji drugačije. Kvaliteta Corsa je dosta pala u zadnje vrijeme, a ovaj XFX je u stvari rebrandani Seasonic. Ono što piše na kutijama grafa, možeš slobodno staviti mačku o rep jer nema veze sa realnošću. Bilo koje CM kućište je kvalitetnije od TT-a. Uzmi ono koje ti se sviđa i ulazi ti u budžet. Obzirom na jak proc, bolje bi bilo uzeti ploču sa boljom faznom regulacijom. Baci oko na temu o AMD pločama. Toxic je oc-ana grafa. Po meni, bolje bi bilo uložiti lovu u grafu s boljim/tišim hlađenjem (npr. MSI 6850 Hawk)nego sa boljim taktovima. Više detalja potraži na temi o toj grafi.
#439 |
Lokacija: čačinci
Postovi: 8
Bacih oko i promjenih u Asrock 870 EXTREME3 - AMD 870, AMD SB850, ATX, FSB 2600, Dual Ch - 630 kn - prolly the same Sh$t. NO clocking!!! samo tražim da matična radi normalno 2-3 godine. ako ima neka bolja slične cijene please recommend. ostajem pri grafičkoj zbog pojačanja matične. Napajanje XFX Core Edition 80+ 450W PSU - EasyRail technology - 365,00Kn Miš PRESTIGIO PJ-MSO3, veliki, žični, optički 1600dpi, USB - 100 kn Procesor AMD Phenom II X4 955 Black Editon, socket AM3, BOX,C3 - 785 kn Coolarmaster Elite 334 nVidia Edition, NV-334-KWN1-GP, MIDI - 420 kn HDD WD 500GB, 5000AAKX, SATA 3, Buffer 16MB, 7.200 rpm , 8,9 ms - 290 kn Asrock 870 EXTREME3 - AMD 870, AMD SB850, ATX, FSB 2600, Dual Ch - 630kn DDR3 4GB (2x2GB) Kingmax, 1333MHz, FLFE -250kn Sapphire HD 6850, 1GB GDDR5 256bit, Dual Link DVI + HDMI + DP - 1181 kn ukupno 4021 kn jedino što bih mogao pojačavat nakon kupnje su rami nothing else u tome slučaju s tom konfiguracijom dali je bolje instalirat windows7 32 ili 64 bit pretty much now the answer ali ako ostavim na 4 gb ddr3 dali mi je svejedno pošto imam samo 32 bit? me talking gibberish cause it's hot like a motherfu$$er! |
#440 |
Postovi: 34,084
Svakako 64bit, jer 32bit raspoznaje samo 3,25Gb rama. Inače, 4Gb će ti biti i više nego dovoljna za sve radnje.
#442 |
Datum registracije: Feb 2011
Postovi: 262
@ wade bzvz bacaš pare na to kučište(nvidia edition a ti kupuješ ati grafu) bolje uzmi isto kučište al obično i za tu razliku novaca kupi malo bolji cooler za cpu(original je ionako bučan, pogotovo u ovo doba godine) |
#443 |
Lokacija: čačinci
Postovi: 8
ah damn how loud (decibels) otprilike - like a lions roar or T-rex'es! SCYTHE Katana 3 SCKTN-3000I White Box, 775/1155/1156/1366 - 168kn SCYTHE Katana 3 SCKTN-3000A White Box, 754/939/AM2/AM2+/AM3 - 168kn koje je bolje i dali oba dva odgovaraju s procesorom ili treba gledat ovo AM3 da odgovara sa matičnom. Adm shop ako kažem da sklope pri kupnji dali će onda zamjenit oni cooler stari sa tim katanom ako naručim. koje isto kučište po 300 neko ha? it should not go above 4k a lot Aiight. holla at cha playa! |
#444 |
Postovi: 34,084
To je isti hladnjak, ali ima drugačije 'nosače' za socket. Tebi treba A verzija za AMD sockete. Ako ga naručiš, sigurno će ti ga staviti umjesto defaultnog. Naravno, treba im to i reći. I neka ti daju box cooler kojeg dobiješ s procom. btw, daj malo manje tog engleskog. Na ovom forumu je službeni jezik hrvatski.
#447 |
Lokacija: Mostar
Postovi: 45
Pozdrav, dali bi mi netko mogao složiti konfiguraciju s ove stranice http://www.genelec.ba/ Treba mi konf. sa svom periferijom (zvučnici,miš,tipk.) osim monitora do 1000 KM (što spada u ovaj cjenovni rang od 3-5k kuna). Konf. je namijenjena tipičnim zadaćam poput interneta, office programa ali i HD filmova. Pretpostavljam da mi ne trebaju neke ultra bijesne komponente pošto nemam namjere igrati igre. Ako bi se mogla sastaviti konfa za gore navedene zadaće uz još manje love bio bi još sretniji. Hvala |
#448 |
Lokacija: čačinci
Postovi: 8
pošto kupujem pc jednom u desetlječu bum dodah tih 189 kn ![]() Napajanje XFX Core Edition 80+ 450W PSU - EasyRail technology - 365,00Kn Miš PRESTIGIO PJ-MSO3, veliki, žični, optički 1600dpi, USB - 100 kn Procesor AMD Phenom II X4 955 Black Editon, socket AM3, BOX,C3 - 785 kn Coolarmaster Elite 334 nVidia Edition, NV-334-KWN1-GP, MIDI - 420 kn HDD WD 500GB, 5000AAKX, SATA 3, Buffer 16MB, 7.200 rpm , 8,9 ms - 290 Asrock 870 EXTREME3 - AMD 870, AMD SB850, ATX, FSB 2600, Dual Ch - 630kn DDR3 4GB (2x2GB) Kingmax, 1333MHz, FLFE -250kn Sapphire HD 6850, 1GB GDDR5 256bit, Dual Link DVI + HDMI + DP - 1181 kn SCYTHE Katana 3 SCKTN-3000A White Box, 754/939/AM2/AM2+/AM3 - 168kn Ukupno: 4189,00 kn hvala na pomoći!!! ![]() |
#449 |
Postovi: 524
Dali je ovo ok konfa za te pare? Ne piše ali znam da je unutra nvidia 460gtx. http://www.feniks-kompjutori.hr/inde...133&kateg=2932 |
#450 |
Datum registracije: Aug 2009
Postovi: 1,492
ne, konfa je očaj za te pare... pogledaj post iznad svog bolje. |
