#4171 |
Honda Prelude 2.0i driver
Lokacija: Zagreb Dubrava
Postovi: 1,128
koliko bih ja mogao imati na vdslu? imam solidnu paricu <table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td class="hd">Line Rate</td> <td> 15841 Kbps</td><td> 1375 Kbps</td> </tr> <tr> <td class="hd">Attainable Line Rate</td> <td> 18374 Kbps</td><td> 1372 Kbps</td> </tr> <tr> <td class="hd">Noise Margin</td> <td> 91 dB</td><td> 103 dB</td> </tr> <tr> <td class="hd">Line Attenuation</td> <td> 190 dB</td><td> 190 dB</td> </tr> <tr> <td class="hd">Output Power</td> <td> 185 dBm</td><td> 135 dBm</td></tr></tbody></table> |
#4172 | |
Lokacija: Velika Gorica
Postovi: 624
Po novom bi trebao dobiti T788v2 tako da će stanje biti nešto stabilnije nego ranije jer v2 bolje hendla packet loss u oba smjera, no povečati će se interleaving delay zbog paketa i modulacija koje trenutno puštaju ,a samim time i odaziv prema serverima u gejmanju. Ukoliko ti latencija u igrama apsolutno ništa ne znači, slobodno zatraži VDSL pa saugaj internet do mile volje ![]() |
#4173 | |
Postovi: 4,203
Code:
Microsoft Windows [Version 6.3.9600] (c) 2013 Microsoft Corporation. All rights reserved. C:\Users\Ivan>ping www.amis.hr Pinging www.amis.hr [194.146.109.208] with 32 bytes of data: Reply from 194.146.109.208: bytes=32 time=24ms TTL=60 Reply from 194.146.109.208: bytes=32 time=23ms TTL=60 Reply from 194.146.109.208: bytes=32 time=23ms TTL=60 Reply from 194.146.109.208: bytes=32 time=23ms TTL=60 Ping statistics for 194.146.109.208: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 23ms, Maximum = 24ms, Average = 23ms C:\Users\Ivan>ping www.pcekspert.com Pinging tethys.pcekspert.com [91.235.171.59] with 32 bytes of data: Reply from 91.235.171.59: bytes=32 time=22ms TTL=60 Reply from 91.235.171.59: bytes=32 time=23ms TTL=60 Reply from 91.235.171.59: bytes=32 time=22ms TTL=60 Reply from 91.235.171.59: bytes=32 time=22ms TTL=60 Ping statistics for 91.235.171.59: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 22ms, Maximum = 23ms, Average = 22ms C:\Users\Ivan>ping www.google.com Pinging www.google.com [208.117.229.155] with 32 bytes of data: Reply from 208.117.229.155: bytes=32 time=23ms TTL=60 Reply from 208.117.229.155: bytes=32 time=22ms TTL=60 Reply from 208.117.229.155: bytes=32 time=22ms TTL=60 Reply from 208.117.229.155: bytes=32 time=22ms TTL=60 Ping statistics for 208.117.229.155: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 22ms, Maximum = 23ms, Average = 22ms
#4174 |
Postovi: 1,128
ak bude 30/10 ja sam prezadovoljan , a treba mi za igranje , reči ču im da mi poštelaju modulaciju za što manji ping. update: sad sam pričao sa njihovom tehničkom službom , sa ovom paricom nemogu imat vdsl , tj kaže da bi mi dl ostao možda isti ali bi mi ul bio još i manji. uvijek meni kita ![]()
Zadnje izmijenjeno od: tomifish2002. 02.10.2014. u 13:16. |
#4175 |
Datum registracije: Dec 2013
Lokacija: ST
Postovi: 950
Ul ti nikako ne bi bio manji. DL bi ti bio nesto veci. |
#4176 |
Postovi: 1,128
eto tako mi je reko čovjek , kaže po njihovom da sam po kablovima udaljen 1,7 km od centrale ali mislim da to nije točno. dl mi ni netreba veči , ne skidam baš puno ali upload bi htio imat veči radi streamanja na twitch
#4177 | ||
Postovi: 67
#4178 |
Postovi: 1,128
na adslu svi koji imaju iptv automatski imaju 20 ms veči ping , brijem da se to nemože nikako podesiti
#4179 |
Postovi: 67
Facelessone, je li to VDSL 2u1 ili 3u1? Tenja ima 10 ms veci ping. |
#4180 |
Postovi: 4,203
2u1 paket je. Ne zabrinjavam se nesto oko pinga bas, vise ni buraz ni ja ne igramo bas. Glavno da je stabilno
#4181 |
Postovi: 73
Dobio optiku u Trnskom.. sve difno krasno, brzine u signatureu i tako to... Nego, primjetih da u Genexis Hybrid routeru postoji 1 USB 2.0 port, pa htjedoh pitat more li se u njega upiknuti vanjski HDD i koristiti recimo kao nekakav NAS? ;-) |
#4182 |
Postovi: 729
Insajderi, jel bude više taj VDSL za sve? Postao sam nestrpljiv i dolazim u kušnju da idem dalje, kod drugog operatera ![]() Ne znam jel ste primjetili, ali i iskon je uveo VDSL. Amis skoro uvijek zadnji izađe sa novostima, nadam se da će biti dobra ponuda kad izađu paketi inače... ![]() |
#4183 |
kripl. ing.
Postovi: 289
Kod mene testni VDSL, cca 1.2km od centrale... dobio 45/10Mbit, ping je manji nego na ADSL-u, vjerojatno zbog boljeg modema, ovaj Technicolor je super čini mi se. Prvo sam se natezao s njima jer sam imao ADSL atenuaciju između 11-14, nakon uključenja VDSL-a skočilo na 33/42, što je nemoguće... Tad su mi pustili 25/10, kakti maksimalno. Ali su super uslužni iako je testna usluga, malo smo se igrali s postavkama i sada super stabilno radi na gore spomenutim brzinama. Imam 2x IPTV prijemnik, 3u1 paket, ADSL nema šta tražit tu ![]()
#4184 |
Postovi: 30
Mene su obavijestili još 24.09. da će me prebaciti na VDSL (treba im oko 2-3 tjedna), nadam se da ću do 15.10. biti prebačen na VDSL. Jedino mi nisu mogli precizirati koju brzinu ću dobiti, ali navodno barem duplo više. Trenutno mi je brzina 14/1.30 (3u1 paket + 2x IPTV prijemnik). Nažalost ne mogu vidjet parametre "Line attenuation" jer mi je trenutni ENKOM prebačen u bridge mode i nemam više pristup na njega, pa ne znam ni otprilike koliko sam udaljen od centrale (Kruge, Trnje). Da li se može na kakav drugi način saznati udaljenost od centrale, kako bi mogao barem otprilike saznati koja me brzina očekuje? Mislim ako bi brzina bila kao i do sada, onda mogu komotno ostat na ADSL-u. |
#4185 | |
Uptime 99.99%
Postovi: 2,547
#4187 |
Uptime 99.99%
Postovi: 2,547
#4188 |
Postovi: 30
Zadnje izmijenjeno od: Rupy. 04.10.2014. u 16:55. |
#4189 |
Postovi: 2,241
Ekipa, koliko cca treba tehničaru da dođe pustiti signal nakon kaj su vam proveli instalaciju? Meni sada napravili instalaciju pa da znam koliko dugo još moram čekati!
![]() RedGreenBlue |
#4190 | |
kripl. ing.
Postovi: 289
![]() Što bi reklo SN margina 9.1/8.9, atenuacija 11/11
#4191 |
Postovi: 30
#4192 |
kripl. ing.
Postovi: 289
#4193 |
Uptime 99.99%
Postovi: 2,547
#4194 |
kripl. ing.
Postovi: 289
#4198 |
Uptime 99.99%
Postovi: 2,547
Pusteno ti je 16.5Mbita i kad se oba ugase imas 14, bandwdith varira od 2-3mbps po receiveru, ovisi koliko je intezivan video.
#4199 |
Postovi: 30
#4200 |
Uptime 99.99%
Postovi: 2,547
Kod T-coma kad korisnik hoce 2 receivera, a imas paket od 10mbita, oni ga prebace na VDSL i on i dalje ima 10Mbita, a ostatak bandwidtha je za IPTV i VoIP. Ovi novi njihovi ZTE modemi su ADSL2+ i VDSL.
“Those who surrender freedom for security will not have, nor do they deserve, either one.” Zadnje izmijenjeno od: Bono. 04.10.2014. u 18:03. |
