Staro 26.10.2010., 21:54   #4171
ajvarman
Datum registracije: Mar 2009
Postovi: 26
pozdrav!
gledam malo sony 40nx700.. snizen je sa 9500 na 7000.. nisam naso na neke vece reviewe na netu, na cnetu nema, pa jel mi zna neko od vas rec nest vise o tom tvu, kaj ne pise u karakteristikama? jel vrijedi tih novaca? evo link ko nezna o cem se radi.. hvala!
http://www.sancta-domenica.hr/detalj...00hz_sony.aspx
ajvarman je offline   Reply With Quote
Staro 29.10.2010., 00:29   #4172
oko1976
Lokacija: Našice
Postovi: 13
DivX na 42PJ350 RADI!!!!
Uspio sam, naravno ništa bez Francuza :
http://www.lg-hack.info/cgi-bin/sn_f...pg=1&sc=20&x=0
DivX na 42PJ350 radi!!! Kao i na svim modelima sa Saturn6 procesorom!
oko1976 je offline   Reply With Quote
Staro 29.10.2010., 00:35   #4173
tihomir
tihomir's Avatar
Datum registracije: Jan 2002
Lokacija: ?
Postovi: 2,274
@ oko1976
To nije nikakva novost...
tihomir je offline   Reply With Quote
Staro 29.10.2010., 08:31   #4174
oko1976
Lokacija: Našice
Postovi: 13
Autor tihomir Pregled postova
@ oko1976
Pa ja nisam primjetio da je to nešto staro, pogotovo za PK PJ seriju plazmi s firwarom 3.14 i novijim, nije dovoljno imati univerzalni daljinski i promjeniti jednu postavku! Da vijest je stara 10-ak dana
OFFSET CALCULATION FOR LGMOD patch.sh FOR RELEASE firmware 3.19
INTRO: This is the procedure that I have followed to find my offset to the word that needs to be changed in RELEASE for USB playback. I followed this based in the brilliant work of Arno and Jenya. I have no access to a good decompiler nor to a cramfs kernel module that supports XIPS, so I just have checkout the code string pointed by the Arno 3.14 firmware fix.
What this all means is that this method is quick and dirty but it worked for me.
Arno, if you think that this method is somehow risky I will delete the post. Please comment.
1. Buckup your firmware from lgmod web interface of just your lgapp partition from the serial console. I will explain the serial console procedure since we will need serial connection later on.
1.1.- Get a serial cable and connect to your TV set.
1.2.- Start your TV set and wait until normal TV channel is playing.
1.3.- Start your computer and connect at 9600 , no parity, no flow control an 8 bits data and 1 stop bit (9600,8,N,1) with your favorit communication program (minicom is my case).
1.4.- Enter debug mode typing "debug" + enter key. Then again "d" + enter key and finally "sh" + enter key to get to the command console.
1.5.- Insert a FAT formated drive pen in your TV set and wait until TV sees it.
1.6.- Backup your lgapp partition: "cat /dev/mtd8 > /mnt/usb1/Drive1/8_lgapp"
1.7.- Umount the usb drive: "umount /dev/sda1"
1.8.- Now you can remove the usb drive.
2. Check out your offset to the lgapp partition: You should still be connected via serial cable and logged in the shell. If not follow steps 1.1 to 1.4
2.1.- Check out the offset until your lgapp partition: Type in "cat /proc/xipfs" this will output a number in hexadecimal base in my case "0x7100000", take note of the number that YOU ARE GETTING.
3. Calculating the offset to the divx capability test function result byte: (You will need a linux box)
3.1.- Copy the lgapp partition file to your working directory in your linux box.
3.2.- Uncompress the lgapp partition:
3.2.1.- For this you need the lzopack tool, you can find it at http://lgmod.free.fr/tools/lgapp
3.2.2.- Unpack with: "#./lzopack -d 08_lgapp 08_lgapp_cramfs"
3.3.- Edit with an hex editor the resulting 08_lgapp_cramfs for example with hexedit:
#hexedit 08_lgapp_cramfs
3.3.1.- You will see a view similar to this:
00000000 45 3D CD 28 00 10 EA 00 03 00 00 00 00 00 00 00 43 6F 6D 70 72 65 73 73 E=.(............Compress
00000018 65 64 20 52 4F 4D 46 53 93 FA D4 D3 00 00 00 00 A6 02 00 00 04 00 00 00 ed ROMFS................
00000030 43 6F 6D 70 72 65 73 73 65 64 00 00 00 00 00 00 ED 41 49 04 48 00 00 64 Compressed.......AI.H..d
00000048 C0 04 00 00 ED 83 49 04 A0 31 D3 64 42 09 00 00 52 45 4C 45 41 53 45 00 ......I..1.dB...RELEASE.
00000060 A4 81 49 04 50 E3 25 64 03 00 35 0D 52 45 4C 45 41 53 45 2E 73 79 6D 00 ..I.P.%d..5.RELEASE.sym.
00000078 A4 81 49 04 38 68 04 64 04 EA 83 0E 75 2D 62 6F 6F 74 2D 73 70 69 2E 62 ..I.8h.d....u-boot-spi.b
3.3.2.- Now we have to search for the string "050040141C80828F2000BF8F9C5242900800E003". I use such a long string because I want to get sure that this is not another statistical match in the RELEASE code.
To search this string we should press Ctrl+s and we will see hexedit prompting us for the string like this:
Hexa string to search:
3.3.3.- Type in the string (or better copy&paste :-)). And press enter. In my case hexedit finds that the string is beginning at 0x36D4, you will see something like this at the last line at the console:
--- 08_lgapp_cramfs --0x36D4/0xEA1000
3.3.4.- Add number from step 2.1 "0x7100000" (in my firmware) and 3.3.3 "0x36D4" (also my firmware). The result in my case is "0x71036D4". Remember to do it with an hex calculator since you maybe are not us lucky as I am with the lgapp partition offset.
4.- Add a line to patch.sh in lgmod1.54: In my case "devmem 0x71036D4 32 0x00000000" in yours the result of your calculation.
Staro 29.10.2010., 13:05   #4175
tihomir
tihomir's Avatar
Lokacija: ?
Postovi: 2,274
PJ350 se uvijek mogao otključati ulaskom u servisni meni isto kao LCD LH modeli.
Staro 29.10.2010., 13:49   #4176
oko1976
Lokacija: Našice
Postovi: 13
Nemaš pojma! Pogledaj moje stare postove sve moguće sam probao kroz servisni menu no nije išlo! Pročitaj sve domaće i strane forume u zadnjih 10 mjeseci i vidjet ćeš da je samo jedan rus imao firmware 3.09 i da je išlo jednostavno kroz servisni menu.
Pogledaj zadnji post na ovom linku, svaka čast Arno !!!
http://www.lg-hack.info/cgi-bin/sn_f...=60&pg=1&sc=20
Zadnje izmijenjeno od: oko1976. 01.11.2010. u 19:20.
Staro 29.10.2010., 16:54   #4177
denied
denied's Avatar
Postovi: 1,193
Autor ajvarman Pregled postova
pozdrav!
Super LCD....neš takvog i ja namjeravam kupit
denied je offline   Reply With Quote
Staro 29.10.2010., 18:18   #4178
subtitle
Datum registracije: Oct 2010
Postovi: 2
Pozdrav, kupio sam Samsung LCD-LE32C530 i imam problem s gledanjem filmova preko USB-a (.avi, .mkv). Problem je u titlovima koji su premali. Na daljinskom ima opcija povecavanja i smanjivanja titlova, ali to ne pomaze jer su titlovi svejedno premali.
subtitle je offline   Reply With Quote
Staro 29.10.2010., 18:23   #4179
tihomir
tihomir's Avatar
Lokacija: ?
Postovi: 2,274
Autor oko1976 Pregled postova
Zadnji post na ovom linku, svaka čast Arno !!!
Zašto tako grubo?
Staro 30.10.2010., 11:43   #4180
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
sony ima akcije
V.I.P je offline   Reply With Quote
Staro 30.10.2010., 16:11   #4181
daim
Lokacija: karlovac
Postovi: 13
pozdrav!
ja sam isto vidio da su snizili ovaj model.. i takodjer me zanima ako netko ima kakav komentar.. da li je to ok kupovina?
u biti, ja sam vec odlučio kupiti panasonicovu plazmu 42s20e ali dok sam cekao da je jos malo snize, vidjeh ovo. cini mi se tv ok na prvu, ali nisam neki expert i ne mogu bas procijenit da li se isplati to kupit. odnosno, da li se isplati dat 2000 kn vise za taj tv nego 5000kn za s20???? a opet u tom cjenonvnom rangu (7000+kn) dolazi i p42g20e... totalno sam sad zbunjen. kaj bi vi na mom mjestu? (ne mislim igrat nikakve igrice, samo filmovi, internet i tak to)
daim je offline   Reply With Quote
Staro 30.10.2010., 18:19   #4182
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,920
Autor daim Pregled postova
Na znam za ovaj Sony gore ali ako se mozes rastegnuti toliko, G20 od Panasonica je cudo za te novce. Ja imam 46" G20E i prezadovoljan sam. Ne bih mijenjao za nijedan LCD.
Matta je offline   Reply With Quote
Staro 31.10.2010., 16:12   #4183
daim
Lokacija: karlovac
Postovi: 13
aj dobro. hvala na misljenju. onda cu pricekat jos malo da vidim oce snizit taj g20 bar još malo jer je to totalno van mojih financijskih mogucnosti.. s obzirom da sam i za s20 htio netgnut malo vise para nego sto sam u pocetku htio dat za tv, a eto me sad vec na 7 i pol....
Staro 31.10.2010., 20:38   #4184
Nickfast
Lazy person
Nickfast's Avatar
Lokacija: U blizini zg
Postovi: 91
Kupio bih novi tv za dnevnu sobu.
Savršena veličina bi bila 37"
Najvisa cijena do koje bih isao je 5000 kuna.
Gledao sam malo po netu i vidio ovaj TV Philips 37 PFL 5405H.
Zanima me Vase misljenje o njemu te da li ima bolji tv za te novce..
Hvala Vam na pomoci
Nickfast je offline   Reply With Quote
Staro 31.10.2010., 23:52   #4185
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
Autor Nickfast Pregled postova
Hvala Vam na pomoci
ima, panasonic plasma s20 recimo... odi na hd televizija portal i čitaj recenzije.....
snorky_vk je offline   Reply With Quote
Staro 01.11.2010., 15:04   #4186
prasak
You'll never walk alone
prasak's Avatar
Postovi: 324
Plazmi S20 nema u veličini 94cm (37'').
i5 2500k i Ryzen 5 1600
prasak je offline   Reply With Quote
Staro 01.11.2010., 15:41   #4187
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,178
Hvala Vam na pomoci
Zaboravi to. Evo ti S20 po dobroj cijeni. Tu sam ga ja uzeo i super je.
A što se tiče savršenosti za prostoriju, neznam kolka ti je veličina sobe? Moja je skoro pa 20 kvadrata i trebao sam uzet 50".
Zadnje izmijenjeno od: DiRT. 01.11.2010. u 15:46.
DiRT je offline   Reply With Quote
Staro 02.11.2010., 17:10   #4188
veva
Lokacija: vž
Postovi: 77
pozdrav... trebam savjet, pročitao sam zadnjih dvadesetak stranica ove teme ali sam sad još u većim dvojbama
trebao bi hitno preporuku za TV do 3500 kn max, po mogućnosti i niže.... TV ide u stan koji će se iznajmljivati pa ne mogu reći za što će ga budući najmoprimci koristiti, tako da tražim neki best buy za tu lovu... Tv bi se gledao sa nekih 2,5 m udaljenosti, da ima DVB-T i DVB-C mpeg4, mislim da bi 32" bilo taman, eventualno 37", svejedno dal plazma ili LCD....
uz preporuku modela dobrodošli su i linkovi gdje se može kupiti u Zagrebu... puno hvala unaprijed
edit:
nakon malo surfanja po nabava.net, po cijeni su mi prihvatljivi ovi modeli:
LG 32LD350 / 32LD420 / 32LD450 / 32LD465
Sony KDL-32BX300 / KDL-32BX400 / KDL-32EX302 / KDL-32EX402
Samsung LE32C350 / LE32C450
Panasonic L32C linija
pa ako netko preporuča neki od navedenih...
Zadnje izmijenjeno od: veva. 02.11.2010. u 18:59.
veva je offline   Reply With Quote
Staro 02.11.2010., 20:50   #4189
oko1976
Lokacija: Našice
Postovi: 13
Autor veva Pregled postova
edit:
Ako če se gledati samo TV program, kupi plazmu nemara biti ni Full HD. a to je znaći 42", a lakše ćeš iznajmiti stan .
Staro 03.11.2010., 22:01   #4190
gesaugen
Postovi: 347
TV sa mpeg4 do 3000kn
Tražim TV do 3000kn za starce. Dakle ništa sa nekim uber naprednim funkcijama, netreba gro utora i te spike već vulgaris TV sa mpeg4 tunerom i da je min 82cm. na TV-u bi se 99,9% vremena vrtio TV signal tak da je recimo najbitnije da TV ima dobru obradu slike i upscaling...
Ovo sam izdvodjio u tom cjenovnom rangu:
Toshiba 32AV733 2579kn
Samsung LE32C350D1 2799kn
Grunding 32-6940T 2739kn
Panasonic TX-L32C2E 2749kn
LG 32LD320 2650kn
Sony 32BX300AEP 2766kn
Sharp LC32DH510EV 2999kn
Toshiba 32LV733G 2999kn
koje bi bile vaše preporuke i zašto?
Zadnje izmijenjeno od: gesaugen. 05.11.2010. u 14:02.
gesaugen je offline   Reply With Quote
Staro 04.11.2010., 15:06   #4191
Nickfast
Lazy person
Nickfast's Avatar
Postovi: 91
Covjek mi moze jeftino nabaviti lcd Medion life s16000, pa me zanima sto mislite o njemu jer ja iskreno nikad cuo za firmu. Mislim da je firma iz Njemacke a cak i to nisam siguran.
Evo malo o tv
http://www.idealo.de/preisvergleich/...08-medion.html
Staro 08.11.2010., 17:24   #4192
Underdog
Datum registracije: Nov 2010
Lokacija: v srcu Prigorja
Postovi: 11
edit:
ako bi uzimali 37", onda bi panasonic plazma bio najbolji izbor. model tx p37x20e ili tx p37c2(ako se može negdje naći).
Underdog je offline   Reply With Quote
Staro 08.11.2010., 20:48   #4193
speoon
Lokacija: vukovar
Postovi: 57
definitivno najbolji izbor u tom rangu cijena i dijagonale...
speoon je offline   Reply With Quote
Staro 09.11.2010., 22:45   #4194
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Pozdrav ljudi!
Rodbina mi je u procesu kupovine novog TV-a. Pošto nisam u ovim vodama došao sam po savjet. Jasno mi je da su plazme iznad LCD-a, ali ovde imam nabacano par modela (i LCD i plazma) pa hoću da vidim šta mislite o njima.
Situacija:
Budžet: 3700 kn
Šta će se gledati: trenutno kablovska (analogna), kasnije digitalni program, filmovi u svim mogućim formatima
Udaljenost od TV-a: 3-4m
Ono što mi je dostupno su sledeći modeli:
LG 42PJ350 3622 kn
LG LF32LH3000 3330 kn
PHILIPS 32PFL3605H/12 3034 kn
PHILIPS 32PFL3403 2627 kn
PHILIPS 32PFL5404 3700 kn
PANASONIC TX-L32C10F 2590 kn
PANASONIC TX-L32U2E 3548 kn
PANASONIC TX-P37C2E 3700 kn
PANASONIC 32C20F 2960 kn
BEKO ACTIVE PRO 32-911B 2960 kn
BEKO ACTIVE PRO 32-911B DVB-T 2786 kn
BEKO ACTIVE PRO 32-910B 2652 kn
BEKO W32LX-LY1B 2590 kn
SONY KDL-32EX3021EP 2941 kn
TELEFUNKEN TB32D857 2582 kn
TELEFUNKEN TB37HD857L 3563 kn
Eto, to je to što mi je trenutno dostupno. Trebam neku preporuku šta uzeti od navedenog za gore pomenute potrebe.
Staro 09.11.2010., 23:53   #4195
Underdog
Postovi: 11
mislim da im bude 32" LCD televizor premali s obzirom na udaljenost od TV-a...
bar je meni tak.
Staro 10.11.2010., 07:57   #4196
freddie
freddie's Avatar
Postovi: 351
Autor Underdog Pregled postova
bar je meni tak.
ispod 42 ni za živu glavu
freddie je offline   Reply With Quote
Staro 10.11.2010., 11:27   #4197
Los Sam
Los Sam's Avatar
Lokacija: Duga Resa
Postovi: 513
@Milentije - preporuka Plazma Panasonic TX-P42X20E - 3714kn
http://protis.hr/products/details/pl...0274?service=1
Los Sam je offline   Reply With Quote
Staro 10.11.2010., 15:03   #4198
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Sve je to OK, ali ja mogu uzeti samo nesto od ovih modela sto sam stavio na spisak. Mada mislim da bih nekako mogao žicati nekog uvoznika da vidim može li napaviti nešto, jedino nisam siguran da li taj dila Philips ili Panasonic.
Hvala na preporukama, ali da li bi ste još mogli izabrati neki sa ovog spiska.
Staro 10.11.2010., 16:37   #4199
freddie
freddie's Avatar
Postovi: 351
Autor Milentije Pregled postova
ako je sa spiska onda možda 37c2e
Staro 10.11.2010., 20:22   #4200
Underdog
Postovi: 11
Nije ni plazma LG 42PJ350 loš izbor, pogotovo ne za cca 3500kn.
