Povratak   PC Ekspert Forum > Internet i mrežne tehnologije > ISP > Iskon
Staro 09.09.2007., 14:22   #361
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
ima šanse da se mi postojeći korisnici možemo prebaciti na npr duo surf? jer ja sam na 3mbit, ali mi ne treba toliko. 1 mi je ipak premalo
jollyb je offline   Reply With Quote
Staro 09.09.2007., 18:06   #362
Xan
networking wannabe guru
Xan's Avatar
Datum registracije: Sep 2002
Postovi: 1,001
ne vidim zasto ne bi mogao
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb.
Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon.
"Now I have become death, the destroyer of worlds who has come to annihilate everyone."
Xan je offline   Reply With Quote
Staro 14.09.2007., 12:01   #363
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,557
Zadnje izmijenjeno od: the_ghost. 28.05.2008. u 17:52.
Staro 14.09.2007., 14:01   #364
Facelessone
Facelessone's Avatar
Postovi: 4,205
ovo je moj....... trebalo bi bit 3mbit , možda i jesu nekej radili prek noći :P
EDIT:
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 14.09.2007., 14:12   #365
Postovi: 34,067
Obzirom da je t-scum najavio povećanje brzine od 1.10., vjerojatno će i oni povećati svoje. Bilo bi dobro i vjerojatno se nitko ne bi bunio .
Jutros sam nešto skidao i brzina skidanja je bila ista kao i prije (cca. 400kbs). Možda su u toku dana povećali. Bacim oko kad dođem doma jer me ovo zaintrigiralo.
Staro 14.09.2007., 19:08   #366
Trek
Trek's Avatar
Postovi: 1,313
Ja sam se za ovo i prijavio 10 mbit flat, prvih mjesec dana nisu mogli isporucit vise od 5120 kbps, pred 7 dana sam presao konacno na placanu brzinu, prvi mjesec su se ispricali i poslali pismo isprike i umanjili racun. Bravo iskon
router prijavljuje ovo
Bandwidth (Up/Down) [kbps/kbps]: 1.023 / 9.996
Output Power (Up/Down) [dBm]: 12,0 / 19,5
Line Attenuation (Up/Down) [dB]: 17,5 / 26,5
SN Margin (Up/Down) [dB]: 12,0 / 17,5
Biti lud ima prednosti koje razumiju samo ludjaci
FKT meber jednog dana high priest...
Trek je offline   Reply With Quote
Staro 17.09.2007., 11:50   #367
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
meni se gasi već 2-3 dana cijela veza. dođem ujtro do kompa, treba mi nešto pa je upaljen, torrent crven, zonealarm ima iks ikonu i kaže da treba system restart.... net spor... koji vrag? nakon restarta sve ok
Staro 17.09.2007., 12:19   #368
Momir
Momir's Avatar
Postovi: 1,011
Autor jollyb Pregled postova
Probaj da neskidas torrente. Nas ima jedno 8 u mrezi i svi idemo preko iste veze na net i ako netko skida torrente veza zna i u jednom danu puknit po vise puta. Zanimljivo je da nezezaju svi torrenti, nego samo neke. U zadnje vrijeme broj tih zeznutih torrenata je veci i veci.
Momir je offline   Reply With Quote
Staro 17.09.2007., 18:29   #369
bakaideda
bakaideda's Avatar
Postovi: 86
Torrenti otvaraju puno konekcija pa se router blesira... a možda se i pregrijava... međutim kod mene apsolutno nikakvih problema...
bakaideda je offline   Reply With Quote
Staro 17.09.2007., 20:08   #370
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Momir Pregled postova
postajte skrinšote ovoga:
mislim da je direktni url: http://192.168.100.1/cgi/b/dsl/dt/?be=0&l0=1&l1=0
Mailman je offline   Reply With Quote
Staro 17.09.2007., 23:55   #371
msvrtan
Datum registracije: Oct 2001
Postovi: 2,735
Autor the_ghost Pregled postova
jel to iskon nesto radio nocas? Imam odjednom 8m a imao sam 4. (nemam flat pa zato tako velika brzina) ping je puno bolji
zanimljivo pitanje.. mozda da nazoves nekoga u iskonu pa pitas? buahahaahahaha
(jednom bus mi moral ovo objasniti )
msvrtan je offline   Reply With Quote
Staro 27.09.2007., 23:43   #372
Zakpu
Lokacija: Zgb
Postovi: 19
Dobio sam iskon duo prije nekih tjedan dana i od prvog dana mi se konstantno javljaju problemi s vezom, naime veza unutar HR mi je ok sve radi super, ali prema van mi ponekad ping zna bit ogroman, uzasno sporo ucitava stranice, skida i igre se nedaju uopce igrat, to je kako kad ima dana kada je sve ok, nije mi se dalo citat ovih 13 stranica pa ne znam ako je neko ima slicnih problema molim za pomoc, ili da zovem SZK? inace veza je 1 MBit a do sad sam imo XXLAdsl vec godinu i pol i nikad problema
Zakpu je offline   Reply With Quote
Staro 28.09.2007., 16:52   #373
Jumper
Postovi: 26
Hoce li i Iskon nakon HT-a dignuti brzine? Ima li tko kakvu ideju kako bi se situacija mogla odvijati?
Jumper je offline   Reply With Quote
Staro 28.09.2007., 17:12   #374
Facelessone
Postovi: 4,205
pošalji im mail i pitaj
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 30.09.2007., 12:31   #375
bata
Postovi: 71
dali ko zna kad ce iskon dignut brzine?
da dignu jos i to kao t-com bilo bi CUDDOOO
Nebi mi trebalo vise nista
bata je offline   Reply With Quote
Staro 30.09.2007., 15:28   #376
bakaideda
bakaideda's Avatar
Postovi: 86
Na net.hr me zaskočila neka reklama... Prozorčić s lopticom koja ide lijevo - desno i pisalo je... uhvati me... kad sam ju "uhvatio" pisalo je "Što je smiješno? Saznajte 1.10.". Poslije toga je cijeli prozorčić bio pun narančastih loptica a u pozadini se čuo neki ludi smijeh...
Iskon i narančaste loptice... Meni izgleda nekak usko povezano... Vidjet ćemo sutra...
Staro 30.09.2007., 16:07   #377
walbandon
Lokacija: Valbandon-blizu Pule
Postovi: 974
iako sam uvjeren da sam ovo vec negdje stavio, no, eto opet... ja bi rekao da to ima veze sa tkomom i maxtvom
walbandon je offline   Reply With Quote
Staro 30.09.2007., 18:02   #378
Xan
Xan's Avatar
Postovi: 1,001
a kakve veze ima t-com i maxtv sa iskon.duom?
Staro 30.09.2007., 21:28   #379
Dawar
OMG, thats the funky shit
Dawar's Avatar
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Autor walbandon Pregled postova
I ne samo s njima nego i sa Bnetom koji prenosi HBO
Dawar je offline   Reply With Quote
Staro 01.10.2007., 00:23   #380
vinja
vinja's Avatar
Postovi: 789
sigurno Bnet, jer je i njegova boja narancasta, a urpavo su u prosecu mjenjanja branda... ocito su oni na reklami
vinja je offline   Reply With Quote
Staro 01.10.2007., 01:45   #381
walbandon
Postovi: 974
a,ma..ja sam uvjeren da sam vidio negdej clanak da na maxtv dolaze te nove humor serije nbo...po cijele dane humor bez reklama..ali, nazalost ne mogu sada naci..o mode off
Staro 08.10.2007., 18:22   #382
Fatal
kenova?
Lokacija: Čilipi
Postovi: 573
Planiram si uzet Iskon duo 3mbit/sec flat pa me zanima sljedece
  • moj trosak je(uz ugovornu obvezu) 201kn (u to je ukljucena tel pretplata?) + fiksni pozivi?
  • Vidim da daju u najam wireless modem pa me zanima da li je veza stabilna, posto nikako ne zelim "pucanja" veze
  • dali mi je bolje (citaj:brze) da podjem do njih na tresnjevku ili da to obavim putem interneta?
Fatal je offline   Reply With Quote
Staro 08.10.2007., 18:30   #383
///Marac
Emergency Scratcher
///Marac's Avatar
Postovi: 142
Autor Fatal Error Pregled postova
mislim da si ti nešto krivo skužio. Iskon Duo Surf paket ti je:
2mbps, flat, i mjesečno je 170kn, neznam di si vidio da je 200+kn!
IskonDuo Surf
Uglavnom, ja još čekam da mi dođu instalirat flat, zvao sam ih par puta, i takvu ljubaznost nisam doživio nigdje. A oni koji ga več imaju, hvale ga na sva zvona!!
Have you ever noticed that chicks against abortion are the ones you would never fuck anyway?
///Marac je offline   Reply With Quote
Staro 08.10.2007., 18:41   #384
Fatal
kenova?
Lokacija: Čilipi
Postovi: 573
Ne citas post....Ja ne zelim surf paket, zelim 3mbit/+telefon=duo paket pa me zanimala cijena toga...Gdje sam nasao? Evo ovdje
Btw: Kad si ga narucio i kad ce ti doc...?
Staro 08.10.2007., 18:51   #385
///Marac
Emergency Scratcher
///Marac's Avatar
Postovi: 142
moja isprika, nisam skužio skroz
naručio sam prije cca 10 dana, natrag sam im faxirao dokumentaciju 4.10.2007, meni če malo duže trajat taj proces radi toga što sam uzimao fixnu liniju, pa mora ić sve u t-com...uglavnom malo je duža procedura.
Rekli su mi da će me nazvati ovaj tjedan, pa če mi reći kad će mi doć doma, čim mi jave kada će doći, ja ti javim ovdije da znaš...
Staro 08.10.2007., 18:57   #386
vinja
vinja's Avatar
Postovi: 789
brze je otici osobno (nema slanja tamo-amo). Veza ne puca, al nemoj da ti se pregrije modem ... zna se zblesirati.
Staro 08.10.2007., 18:57   #387
Fatal
kenova?
Lokacija: Čilipi
Postovi: 573
Nema frke
Znaci tako, trebalo im je faxirati dokumentaciju...Da li se to naručivao online ili? Pitam iz razloga jer bi htio narucit online, a gazdaricu izbjec sto je moguce vise iz cijele stvari(osim potrebnih podataka naravno)...
@vinja:auf, znaci ja to narucim online oni postom posalju zahtjev, vlasnik linije potpise i posalje, to oni zaprime i tek onda mogu pocet sa odbrojavanjem...
ako bih posao tamo(sa vlasnikom linije) mogu ga narucit,potpisat sve na jednom mjestu...Znaci ipak osobno
Staro 08.10.2007., 19:03   #388
///Marac
Emergency Scratcher
///Marac's Avatar
Postovi: 142
Nema frke
nemoj online... nazovi 08001000 i naruči, nakon par dana doma ti dolazi ugovor, pitat će te dali oćeš sa poštom, mailom,ili faxom da ti pošalju, kada ti dođe, ako imaš novu osobnu moraš iskopirati prednji i zadnji dio iskaznive, potpisat ugovor, i poslat zajedno sa dvije strane iskaznive faxom,mailom ili poštom, svejedno je!!
da možeš poćet sa odbrojavanjem tek kada te oni nazovu da su primili potpisanu dokumentaciju odnosno ugovor. Ja ih zovem ljepo svaki dan da ih malo ubrzam
Staro 08.10.2007., 19:06   #389
vinja
vinja's Avatar
Postovi: 789
yup, ako odes osobno krece od tog dana brojanje (8 radnih dana za T-Com da prebaci paricu)... i stvarno, meni su dosli 8-i radni dan oko 2 popodne, i za jedno 10 min sve bilo gotovo
Staro 08.10.2007., 19:34   #390
Fatal
kenova?
Lokacija: Čilipi
Postovi: 573
Pretpostavljam da si bio korisnik max adsla od t-scumu...Ja sam trenutno na modemu :-( tako da vjerujem da ce iskonov montazer sve sredit onog lijepog dana kad pokuca na moja vrata :-)
