#3721 | |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,164
Možda AsRock B450/450M Pro4? Barem ima hladnjake na VRM-u i malo više USB portova iza (iako je VRM možda malo lošiji, ali msm da to i nije neki faktor u toj cjenovnoj kategoriji. Sve je to manje vise isti drek ![]() I mislim da je jedina u tom cjenovnom razredu koja ima 2 M2 slota (iako mislim da jednog dijeli sa SATA portovima i podržava samo SATA diskove...)
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#3722 |
Prvoklasni Krkan
Postovi: 5,311
Tko želi, može probati modani 7403 ili najnoviji beta 002 bios (riješava davno poznati problem za zaustavljanjem ventilatora i to kako korisnici kažu, za sada 100% uspješno; vau trebalo ima samo par godina da to riješe ![]() Izmjenjen je jedino SMU, tj ubačena je verzija iz 7201, to je kod zadužen za boostanje, a 7201 je navodno puno bolje boostao, pa eto. Morate flashat preko flashbacka: https://drive.google.com/file/d/1U4F...cKzrvag0s/view Pričam o c6h. EDIT: Zanimiljivo, odnosi se na c6h, a primjetio sam ovo i tu na forumu (većina ima puno bolje boost-ove na drugim pločama); sa Asusovih foruma: Sorry, had a hectic few days. So tried something interesting. A customer at work brought in a Strix X470-F claiming it was faulty. But we had no Ryzen chips in to test. So I nipped home and took mine in. When I tested it in the customers build lo and behold it worked. So while it was installed I thought I would see what HWinfo was reporting. Long story short it was boosting all cores to 4.2Ghz which never happens on my C6H. That board was running the 1.0.0.3AB bios and out boosted the C6H 1.0.0.2 SMU. Sadly I couldn't test much due to it being work related. But that small test was far superior to my board. So I'm back to square one again lol. Just got to see what future bios updates bring. Or buy a new mobo ^^ Zadnje izmijenjeno od: Disco. 31.08.2019. u 16:02. |
#3723 |
Datum registracije: Oct 2017
Postovi: 119
Šta je s asus crosshair pločama? Dostupnost im je nikakva što u našim trgovinama što u Njemačkim. |
#3724 |
VI Hero se prodavale ko vruće kifle pred koji tjedan i sve otišle. 2 i pol godine stara ploča je to. VII Hero su debelo debelo preskupe za ono što nude i obzirom da ima za manju lovu bolje X570 ploče. Sent from my SM-G965F using Tapatalk |
#3726 |
Postovi: 119
Mislim na VIII, u nabavi ih samo AMD ima, mindfactory i jos neke njemacke trgovine uopce nemaju asus modele. |
#3728 |
Lokacija: qǝɹƃɐz
Postovi: 436
Ja bi je na tvom mjestu sigurno probao. Barem na stolu... Što znaš, možda bi procesor ljepše prodisao s njome. ![]() Nemaš što izgubiti osim malo vremena. |
#3729 | |
..starija garda
Postovi: 3,280
![]() A komp mi radi brutalno stabilno, brijem da ga necu sad neko vrijeme dirati.. Ma gb koju imam je ipak bolja ploča tako da cu vidjeti, mozda promjenim kuciste od htpca pa ju tu ubacim. Uvjek ju mogu prodati lol ![]()
#3730 |
Lokacija: qǝɹƃɐz
Postovi: 436
Novija i opremljenija, da. A sad da li je bolja probaj pa vidi... Ne košta te ništa... Ja znam da je ne bih prodao, a da je barem ne probam ![]() |
#3731 |
Prvoklasni Krkan
Postovi: 5,311
Mah, probaj da li radi, flashaj zadnji BIOS i prodaj ju. Po svemu po netu c6h je među pločama koje najslabije boostaju. Meni se sviđa ostatak opreme plus hladan VRM, a i realno u boostu jer par % razlike, ali opet... |
#3732 |
Postovi: 14,584
Kažem najbitnije je da mbo ima mesa, dobar kostur (featurei, hardverske komponente - pogotovo vrm). BIOS tj. softverski dio se lako promjeni na bolje. Pogotovo kad se radi o tako važnoj mbo - asusov flagship koji imaju mase (pogotovo "bitnih" ljudi poput recenzenata, pr0 overclockera i sl.) |
#3733 | |
Može neke konkretne brojke, linkovi, a ne subjektivna tumačenja napisa po nekim forumima. Hvala. Ne branim ploču nego me zanima dokaz da najslabije boosta i koliki je pad performansi. Sent from S7 Presidency Phone |
#3734 | |
Prvoklasni Krkan
Postovi: 5,311
https://rog.asus.com/forum/showthrea...-Bioses/page82 Tu ima 4000+ stranica, li ne znam koliko zadnjih je za zen2: https://www.overclock.net/forum/11-a...read-4289.html Ili to ne smatraš relevantnim podatkom? Jer sigurno nitko od rivjuera neće sada gledat kako boosta 2 godine stara ploča. A i sam Shamino je napisao da AMD spušta boost clockove, pa se sada ta njegova izjava raširila ko kuga po internetu... EDIT: Na forumima se vidi i koliko drugih, puno gorih problema ljudi imaju, kojih sam se ja na svu sreću riješio. Boost je najmanji problem, ako i uopće. Zadnje izmijenjeno od: Disco. 01.09.2019. u 14:06. |
#3735 |
Druže, tu temu na OCNu pratim od dana kad je otvorena, kad ju je otvorio legendarni elmor. Samo bih rekao da su u tu temu dovuklo toliko neznalica i noobova da su ubili tu temu, a da pravi znal8ci i testeri jedva dođu do daha da i kažu nešto. Što se tiče biosa, ja imam taj sporni BIOS sa 1003ABB kodom i R5 3600 pa boosta na 4.3GHz ST i 4GHz MT pod jačim opterećenjem. Ali dobro, ako Šamino kaže da je tako, onda je valjda tako. Sent from S7 Presidency Phone |
#3736 | |
Datum registracije: Apr 2017
Postovi: 343
ASUS ROG CROSSHAIR VI HERO
Koliko mi je poznato, dostupna je u DE, u ovoj trgovini i to po dobroj cijeni... to je preračunato nešto ispod 900Kn, mislim da je jako povoljno za tu klasu MB Evo ti link: https://m.notebooksbilliger.de/asus+...ard+sockel+am4 |
#3737 | |
Prvoklasni Krkan
Postovi: 5,311
Da li je ovo u redu? Ne, nije nikako, AMD očekuje od nas da budemo beta testeri, znam i sam sam si kriv jer sam odma kupio proc i ploču. Ali stvarno se nisam nadao da ima gadnih problema sa nestabilnosti. Sada mi sve radi kako treba i iskreno sam oduševljen jer mi je komp raketa prema starom, u svemu osim u igrama (zbog grafičke) je točno 3 ili više puta jači/brži. Što se ploče tiče, isto kažem, šteta boosta, ovo me čudi jer je riječ o flagship ploči, al ajd dobro. Što se tiče njenih 14 usba, 8 sata, VRMa koji je pod najgorim silovanjem i opterećenjem max na 40 stupnjeva, mislim da ne moram ni trošit riječi jer tu briljira. Sve u svemu ja sam sada jako zadvoljan kompom i preporučujem ljudima zen2, ali da ima problema ima, da ljudi i dalje imaju probleme. A Shamino bi mogao opasno dobit po repu zbog svoje izjave (svi portali su je prenjeli i stvorila se velika medijska pompa jer je to rekao baš on) i bila bi velika šteta da ga Asus najuri zbog tako nečeg jer mislim da je čovjek sposoban i surađuje sa comunityem što je odlično za nas obične smrtnike. I za kraj, pa ti si me pitao za izvore, i ja sam ti ih dao, tamo to pratim, za druge zasada ne znam, niti mi se prati 25 foruma. ![]() Stavio sam u drugu temu C/P gdje je čovjek koji ima c6h probao svoj proc na strix-f i na njoj se proc boostao više. Da, ima njubova, ali ima i ljudi koji valjda znaju što rade, ne vjerujem da su baš svi nesposobni... Jako puno ljudi ima i tih problema sa ventovima općenito na asusovim pločama kolko sam shvatio, ja nemam, ti nemaš, to ne znači da problem ne postoji. ![]() |
#3738 |
Ne znam zašto si ti ovo shvatio kao napad na sebe. Samo sam htio znati izvor informacija. Ali očito je da problem postoji kod NEKIH a ne generalno SVIH korisnika ove ploče. Sent from S7 Presidency Phone |
#3739 | |
Prvoklasni Krkan
Postovi: 5,311
Ugl. dobra ploča koja slabije boosta, tj velike su šanse da slabije boosta. Postoje i drugi problemi, a to je loto. |
#3740 |
Ajmo brzo... samo 3 komada na lageru ![]() Manje od 1100 kn ![]() https://www.uzishop.hr/posebna-ponud...-x370-atx.html Sent from my SM-G965F using Tapatalk |
#3741 |
Postovi: 14,584
#3742 |
Lokacija: Lawl
Postovi: 1,378
Za početak, ako je kriva tema, neka Brko prebaci shodno tome... Naime, na mojoj Crosshair VI Hero su prestala raditi 2 memorijska (DIMM) utora, treći i četvrti (gledajući od socketa prema "van"). Ako se moduli/keksi postave u bilo koji od ta dva utora, sustav se ne podiže, a na matičnoj ploči gori LED-ica koja indicira da je problem u memoriji (narančasto svjetlo i kod greške 0d). Ako su moduli u prvom i drugom utoru, Windows se normalno podiže ali memorija radi u single channelu (efektivno duplo manja propusnost) Isprva sam pretpostavio da je problem u procesoru (Ryzen 1600), jer je u njemu memorijski kontroler, tako da sam naručio Ryzen 3600, stavio ga umjesto starog i problem ostaje, tako da je novi Ryzen otišao na refund u Amazon isti dan. Oba memorijska modula su testirana s programom Memtest86 i prolaze bez greške. Aida stress test i OCCT prolaze 2h bez greške. Vizualno također ne mogu primijetiti oštećenja na ploči,socketu, DIMM utorima kao ni tragova kratkih spojeva. Ako netko ima prijedlog uz već isprobana premještanja modula u utorima, flashanje zadnjeg Biosa, clearanje cmosa, vađenje baterije i sve moguće psovke u trenucima očaja, bio bi jako zahvalan ![]() |
#3743 |
..starija garda
Postovi: 3,280
Uh, Problem je u utorima nema tu sta drugo biti. Proc i sam kazes ne moze biti. Pregledaj malo CPU socket i CPU pinove da li vidis sta neobicno cisto za svaki slucaj. Ram radi, a dijagnostika mbo kaze da je neispravna.. znaci utori E sad, da je jedan utor rekao bih da je kontakt, da probaš malo počistiti.. ali dva? Hm.. Tu su i memorijske trase.. one se cak golim okom na dobrom osvjetljenju naziru između cpu socketa i dimm utora za ram.. nadam se da ih nisi nekako oštetio. Baci oko.. PS ..bas sam na brzinu bacio oko na te dimm utore na c6h, kad mi vec samo stoji u kutiji.. ..i razocaralo me kako socijalno izgledaju.. vide se svi kontakti s vanjske strane. mislim, to su dimm utori, ni ne trebaju biti tako dobro zasticeni kao npr na GB koju imam u kompu, ali svejedno.. uzmi neki kist malo to pocisti, ispusi (ne sa komprimiranim zrakom u spreju jer on vlaži! ) probaj malo pregledat, tesko je reci da li je neki kontakt , ali mozda uz povecalo i dobru lampu bi se mozda moglo i vidjeti nesto vise.. uglavnom ne znam, mozda netko drugi kaze nesto pametnije ..sry pitanje.. kako si skuzio da ti ne rade ti utori? to se odjednom u sred rada komp ugasio, ili je komp stajao tjedan dana i kada si ga probao upaliti nije htio ili?
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 04.09.2019. u 19:54. |
#3744 |
Lokacija: Lawl
Postovi: 1,378
Ne vidim ikakva oštećenja, trase se naziru ispod sloja laka ali nisu u prekidu. RAM sam u dvije godine izvadio jednom, da stavim frendov i vidim radi li. Jedino šarafanje po matičnoj se radilo prilikom instalacije, u naredne dvije godine nisam ni pastu promijenio. Ne vidim ni oštećenja na pcb-u, svi elementi golim okom izgledaju netaknuto. Stajao je cca 2 tjedna zbog selidbe i kupovine novog stola. Vratio cooler, stisnuo power button i nije upalio. Matična je imala napajanje ali se ništa nije pokretalo. Keksi su bili u utorima 2 i 4 zbog dual channela. Tek se pomicanjem modula u prva dva utorka sustav dignuo, ali sve daljnje kombinacije s memorijom (utori 1/3 ili 2/4) su rezultirali narančastom ledicom i q-kodom F9 i 0d. Zadnje izmijenjeno od: sti. 04.09.2019. u 20:13. |
#3747 | |
..starija garda
Postovi: 3,280
pretpostavljam da si probao samo s jednom pločicom.. a ne isključivo kombinacije s obje? Citiraj:
Po ovome zakljucujem da je veća šansa da je "mehanicki" kvar, a ne "električni".. Ajmo reći, vjerovatno nije ništa izgorilo. Prije bih rekao da je uslijed stajanja se nesto zaprašilo, ili uslijed "seljenja" je nešto "puklo" , neki kontakt ili nešto.. Zanimljivo mi je da su oba dva utora neispravna, taj dio mi se čini ključan, ali nisam nikad radio na projektiranju MBO ![]() želim reći, da je npr. neki kontakt unutar utora, onda bi mogli sumnjati da ne radi samo taj utor. ovako je stvar ipak na nekom spoju van samog utora, a taj spoj na neki način ima veze s oba dva.. eto, gledao sam bas star trek pa glumim vulkanca, sumnjam da sam imalo pomogao, ali eto.. kao što su i drugi rekli, reklamacija ako je ikako moguće .. bolje ne prtljati previse ako imas garanciju ![]()
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 04.09.2019. u 22:26. |
#3748 |
..starija garda
Postovi: 3,280
Imas hrgu od coolera, spominjao si seljenje, pa vidi ovaj komentar: https://www.techpowerup.com/forums/t...orking.216856/ "With some coolers, attaching them too tightly bends the motherboard and disconnects all or some DIMM pins. Is any of 3 and 4 slot located near CPU socket? I had this problem once. In best cases, you just don't have RAM detected, in worse, the system won't even boot." PS ..pazi ovo, ovaj je imao problem s metalnim sajbicama: https://rog.asus.com/forum/showthrea...allation-error ..izvadi plocu van, ocisti kuciste, i testiraj van kucista samo plocu i stock cooler ili tako nekako ..
__________________ MojSkuter ---------------------------------PEACE Zadnje izmijenjeno od: Eladio. 04.09.2019. u 22:43. |
#3749 |
Datum registracije: Nov 2014
Lokacija: ¯\_(ツ)_/¯
Postovi: 539
Nije to Rudi Čajavec da bi se moglo pratiti štampu. To su višeslojne ploče i tu se nemre vidjeti kaj se dogodilo između slojeva i gdi može biti prekid.. Veliki hladnjaci pigaju ploče dosta pa možda je zbog toga
Kupujem |
#3750 |
..starija garda
Postovi: 3,280
..istina.. ako ima garanciju, ja dalje nebi nista dirao ako nema, e jbg onda
