Staro 19.09.2008., 19:02   #3661
Connected_031
Connected_031's Avatar
Datum registracije: Aug 2008
Postovi: 37
hhahahahaha koji je to lik na slici on je program kajgana hahahaahahah
Connected_031 je offline   Reply With Quote
Staro 19.09.2008., 19:23   #3662
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Evo servera na kojem mogu igrat svi a i meni su najdrazi:
Svi HC Bez PB:
www.privatepowersite.de *PpS*-Crew TDM-Server #1
IP: 89.163.145.80:28961
www.privatepowersite.de *PpS*-Crew FFA-Server #1
IP: 89.163.145.80:28960
www.privatepowersite.de Old School Hardcore *PpS*-Crew
IP: 89.163.145.80:28963
Na ova 3 najvise igram. + Gamezone
Evo jedan americki zombie server
1.41 + PB citera nema nikad:
IP: 74.86.232.75:28962
I nisu obicne mape kao u obicnom mp nego neke nove, prosjek vel. mape je 35 Mb.
Server je strava.
Campeonato je offline   Reply With Quote
Staro 19.09.2008., 22:49   #3663
sipe
sipe's Avatar
Postovi: 993
Kajgana da vas asocira na ono kaj sam mislio a ne na
sipe je online   Reply With Quote
Staro 20.09.2008., 09:42   #3664
Connected_031
Postovi: 37
ja cu poluditi nadjem server prek x-fire-a i ono sve u redu igram 5 minuta i same warninge mi izbacuje i onda me nakon 7-8 minuta kick sa servera neki PB sta ja znam
Staro 20.09.2008., 11:21   #3665
sipe
sipe's Avatar
Postovi: 993
Autor Connected_031 Pregled postova
Updejtaj pb
Staro 20.09.2008., 14:01   #3666
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Najbolje se onda okani CODa i prestani nas maltretirati glupim postovima
blaa
Staro 20.09.2008., 16:44   #3667
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Kupi si konačno orginal i prestani pisat o "nekakvom PB-u" - ak ne znaš Kaj je PB onda igraš krive igre...
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 21.09.2008., 09:26   #3668
Connected_031
Postovi: 37
Autor MisterM Pregled postova
PB=PunkBuster
Staro 21.09.2008., 21:23   #3669
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
PB=PunkBuster
Nota bene: samo ako imaš orginal, sa ostalim češ stalno imati probleme!
Skini PBSetup ovdje:
http://www.evenbalance.com/index.php?page=pbsetup.php
Stavi tu aplikaciju u C (ili koji več drive):\Program Files\Activision\Call of Duty 4 - Modern Warfare\pb i pokreni ga.
Očitat će ti igru stisni na nju i stisni Check for Updates - instalirat će ti zadnju verziju PB-a.
Onda skini pbsvc (instalira ili testira Pnkbstr A i B services) aplikaciju ovdje:
http://www.evenbalance.com/index.php?page=pbsvcfaq.php
(klikni na riječ here u prvom dijelu teksta - What is all this about new PunkBuster services?)
Tada pokreni pbsvc i stisni instal ili kaj ti več nudi - ako je instalirano onda češ dobiti mogučnost - TEST SERVICES - stisni to - sve mora proči u zelenom ili ne valja (najčešče firewall blokira komunikaciju tih servisa pa se mora dati dozvola) - ako ne valja pokreni instal i to je to - sada imaš zadnji PB i full je aktivan sa Pnkbstr A i B services......
Ako PB nije updaten često vas zna bacatiti van iz igre sa PB porukama a često i sa nekim drugim čudnim porukama.
Ja bar jedanput tjedno pokrenem PBSetup aplikaciju - lakše mi je tako nego provjeravati na Evenbalanceovoj stranici da li ima nova verzija PB-a.
1oo1
Staro 21.09.2008., 21:39   #3670
Apacer ft Bozja
Baja!
Apacer ft Bozja's Avatar
Lokacija: Sisak
Postovi: 761
I daj zapamtite vise taj post sto MisterM ponavlja svaki puta kad se nekom nesto sjebe u vezi PB.a!!
Apacer ft Bozja je offline   Reply With Quote
Staro 22.09.2008., 09:14   #3671
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
pbsetup.exe je MUST HAVE ako igras bilo koju igru preko neta (koje koriste pb naravno). i nema price o ovome ili onome.
shortcut na desktop, i prije igranja svaki dan, upalis pbsetup i provjeris za desetak sekundi ima li koji novi updejt od pba. malo posla za mirno igranje.
i naravno...za one s originalima
°Citius Altius Fortius°
Gradjanin je offline   Reply With Quote
Staro 22.09.2008., 11:26   #3672
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,136
Treba mi jedan CoD4 mod. Igrao sam ga na jednom serveru, pa me zanima ima li tako nešto i za igranje sa frendovima na LAN serveru.
Riječ je o modu kad se boduju i killovi (+5) i kad si ubijen (-5). Dakle kad je pobjednik onaj sa najboljom razlikom kilova i "smrti". Zna li netko kako se takav mod zove da ga potražim?
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 22.09.2008., 18:05   #3673
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Pozdrav ljudi, nakon dugo izbivanja sa COD4 scene danas mi se ponovo zaigralo pa...
Ako neko moze da mi posalje svoj config.cfg (sa podesenim onim sranjima max_packets, fov,...).
Zadnje izmijenjeno od: Milentije. 22.09.2008. u 18:34.
Staro 22.09.2008., 18:18   #3674
Kimi
Kimi's Avatar
Postovi: 652
Autor Milentije Pregled postova
Ako neko moze da mi posalje svoj config.ini (sa podesenim onim sranjima max_packets, fov,...).
ovisi;reci koliko imaš fps pa ću ti napisat kak trebaju ići naredbe,fov ti je kut gledanja,a i povećaj si /gamma 1.5 ili kak ti odgovara
@pb se netreba baš svaki dan update,već vidiš ga počne kickat ljude,smanjis igru i napraviš update
Kimi je offline   Reply With Quote
Staro 22.09.2008., 18:34   #3675
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Evo skupio sam zivaca i podesio sebi.
Staro 23.09.2008., 13:56   #3676
Gradjanin
Gradjanin's Avatar
Lokacija: Livingrad
Postovi: 539
Autor Kimi Pregled postova
metafora...no, kako PBsetup updejta SVE instalirane igre, nije ga tesko pokrenuti.Pa i svakodnevno (kaj se naravno nemora raditi ) ako treba.
btw...a kaj onda ako si bas ti taj kojeg kicka? pa naprosto zaboravis, ili u vecini slucajeva niti nemas pojma za pbsetup? stoga...sto cesci updejt, mirnije igranje
Staro 23.09.2008., 16:04   #3677
Death_Bringer
Lokacija: tunguzija
Postovi: 117
Autor Campeonato Pregled postova
Svi HC Bez PB:
server connection timed out mi danas izbacuje, ne mogu se spojiti, jucer je radilo bez problema?
Death_Bringer je offline   Reply With Quote
Staro 23.09.2008., 17:26   #3678
Apacer ft Bozja
Baja!
Lokacija: Sisak
Postovi: 761
/reconnect
I meni se to cesto pojavljuje u zadnje vrijeme
Staro 23.09.2008., 23:35   #3679
Neampojma
Neampojma's Avatar
Postovi: 49
Ja imam problem da kad ocu uc u mp kaze iw3mp.exe error i tak me zeza i cod 2 i 4.Jer zna neko kak to stvarno rjesit jer probo sam sve sto sam cito na netu cak i one gluposti a trazilica mi ne pomaze
Neampojma je offline   Reply With Quote
Staro 23.09.2008., 23:38   #3680
hammer_of_thor
Postovi: 5,430
A da napišeš točno koji error?
blaa
Staro 23.09.2008., 23:42   #3681
Neampojma
Neampojma's Avatar
Postovi: 49
iw3mp.exe has stopped working i nece ni cod 2 ni 4 kao sto sam vec napiso
Staro 23.09.2008., 23:48   #3682
hammer_of_thor
Postovi: 5,430
Jel tako oduvijek ili si već igrao pa tek se kasnije taj error počeo pojavljivati?
Probaj reinstall puknuti.
blaa
Staro 23.09.2008., 23:50   #3683
Neampojma
Neampojma's Avatar
Postovi: 49
Reinstaliro 4-5 puta prije isto imo taj problem i znam da sam ga rjesio sam se nesjecam kako.
Staro 23.09.2008., 23:53   #3684
hammer_of_thor
Postovi: 5,430
Ja se sječam sličnoga problema jednom sa "stopped working" na Visti, na 1.5 patchu još...
Problem je bio driverima zvučne, googlanjem sam našao riješenje, koje sam u međuvremenu zaboravio, uglavno jako jednostavno riješenje, neku kvačicu isključit ili tako nešto
Uglavnom, zna se klat sa Realtekovim integrušama
blaa
Staro 23.09.2008., 23:56   #3685
Neampojma
Neampojma's Avatar
Postovi: 49
Evo slucajno rjesio moro sam ustekat bilo sta u mic in i sad sve radi ono strasno.Sad mi je mal bed jer sam jucer ispado budala da to namjestim i sad otvorim bogzna koju stranicu na googlu na stranici 50i nekoj i nadem odma ugl hvala na pomoci
Staro 25.09.2008., 10:21   #3686
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Autor Death_Bringer Pregled postova
U utorak i srijedu im je pao server od danas sve radi normalno.
Ev jos jedan server ak ocete 24 vs 24 (uvijek je pun)
Netreba origigi key:
24/7 <|TGC|> HardCore CracKeD v1.7 NO HELI !! :::: 195.149.21.107:28960
Staro 25.09.2008., 12:06   #3687
xEnomania
xEnomania's Avatar
Lokacija: Purger city
Postovi: 109
Da li je itko od vas zainteresiran biti član nekog klana?
Evo, mi smo svoj osnovali prije negdje tjedan dana, zove se inače Penis'4'Vagina, trenutno nas je 4, pa tražimo još negdje 6 ljudi (jer imamo privatan server od 10 slotova). Ovaj tren nemamo napravljen sajt ni forum tako da svoje prijavnice pošaljite na mail adresu:
kiwi-aka-veglio@hotmail.com
U njoj je potrebno ispuniti slijedeće:
Dob:
Iskustvo u FPS igrama (u godinama, K/D ratio iz nekih igara):
Mjesto:
Da li sam spreman plaćati server mjesečno ~20kn:
Biti u mogućnosti prisustvovati treninzima najmanje 2 put tjedno: DA/NE
Vaše skillove ćemo provjeriti na serveru.
IP: 212.95.32.38:28975
You called down the thunder.
xEnomania je offline   Reply With Quote
Staro 25.09.2008., 12:11   #3688
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Oću ja oću ja
Imate orginale? Jel smijem haxaT? plzzzzz ^^
žmnpp
Staro 25.09.2008., 12:56   #3689
Apacer ft Bozja
Baja!
Lokacija: Sisak
Postovi: 761
Zanimljiv naziv klana...
btw. mislim da necete dugo trajati..max. mjesec dana..
Staro 25.09.2008., 15:22   #3690
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 649
Pozdrav, igram COD4 već dobrih mjesec dana i odjednom više nemogu ući u consolu, neznam zašto pa bih vas molio da mi pomognete ako znate do čega je to??
Unaprijed hvala
Mejzlik je offline   Reply With Quote
