Staro 22.06.2009., 14:05   #331
Pantera-N
Pantera-N's Avatar
Lokacija: In front of the monitor
Postovi: 1,593
Nema reset gumb, pogledaj malo reviewe. BTW Domagoj, izgleda da 690 dobro hladi
Pantera-N je offline   Reply With Quote
Staro 22.06.2009., 14:51   #332
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
a s 8 ventova mora dobro hladit
DomagojX je offline   Reply With Quote
Staro 22.06.2009., 15:43   #333
Pantera-N
Pantera-N's Avatar
Postovi: 1,593
8 ventova?? daj pogledaj jel ti kučište lebdi
Staro 24.06.2009., 12:58   #334
DomagojX
Postovi: 1,307
evo jedan primjer savršenog cm690 ko da je držan u kokošinjcu
Staro 24.06.2009., 13:42   #335
tech
Postovi: 1,687
Katastrofa...
Meni se konfa hladi sa jednim 120mm ventom i u pola godine nisam imao kaj prasine ispuhati.Samo treba rupe gore, na stranicama pozatvarati i bok.
Staro 25.06.2009., 16:09   #336
karlito
sam svoj aka
karlito's Avatar
Postovi: 789
Domagoj hladnjak ti izgleda ko sače, daj provjeri da ti se pčele ne skrivaju negdje u kejsu
karlito je offline   Reply With Quote
Staro 25.06.2009., 16:18   #337
Hunt.ONE
ЬГΛY.Z0ИЗ
Hunt.ONE's Avatar
Lokacija: Sisak
Postovi: 258
lol domagoj, pa di ti drzis komp? u prasnjavom podrumu?
This post is copyrighted ©
Hunt.ONE je offline   Reply With Quote
Staro 25.06.2009., 16:24   #338
Jackson
Postovi: 648
Autor dh41400 Pregled postova
# Temperatures
# For CPU revisions F and G, according to AMD's "Revision
# Guide for AMD NPT Family 0Fh Processors", "The internal
# thermal sensor ... is inaccurate". This may be the reason
# for many reports of k8temp giving absurdly low CPU core
# temperatures and for there being no generally accepted
# computation to derive actual temperature from the raw data.
# The workaround is to ignore core temperatures and use the
# CPU case temperature as was done before core temperatures
# were available. On this motherboard the CPU case temperature
# is reported by the it8718 chip's temp2 (see above).
# For CPU revisions other than F and G, the proper use of
# k8temp temperatures may be to compute an average for each
# core rather than to report two temperatures for each core.
# For a sample computation see mingus' posting at
# http://forums.opensuse.org/archives/...ml#post1793098
# If you don't trust the readings, you might as well not load
# the k8temp driver (which, in practice, means blacklisting it,
# as this driver auto-loads on most systems.
Ostatak je ovdje.
Thanks, imam odvojeni mjerač temperature sa Scythe Kaze Master priljepljen na bazu coolera i daje par stupnjeva veće temperature za CPU, dok su ostale (za GPU) usporedive.
Druga jezgra ima apsurdne rezultate (20C).
Mislim da su realne temperature +5C od onoga što javlja matična.
Ubacio sam četvrti ventilator u vrh kućišta (iznad CPU-a), ali moram priznati da nema nikakve razlike...
@DomagojX no comment
Jackson je offline   Reply With Quote
Staro 25.06.2009., 16:28   #339
DomagojX
Postovi: 1,307
Autor Hunt.ONE Pregled postova
a nije to moj...našao sam negdje na netu te slike, nebi si ja dopustio da tak izgleda a i vidi se po komponentama da nije moj
Staro 25.06.2009., 17:41   #340
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja sam smontirao na sve 4 rupe na svojem ventove da ispuhuju na minimalcu i nema prašine baš jer sav zrak ulazi kroz filtrirane otvore i samo ih s vremena na vrijeme početkam i ispušem filtere, jedino kaj se praši je PSU jer je iznad poda a nema filtera na njegovom ulazu i malo ulazi na onoj rupi iza matične ali to je zanemarivo...
Have a nice day...
Staro 15.08.2009., 14:43   #341
Pantera-N
Pantera-N's Avatar
Postovi: 1,593
Autor DomagojX Pregled postova
Pročitao sam u nekoliko reviewa da ovi plavi klipovi nisu kompatibilni sa gual slot grafičkim karticama.
Baš me zanima kak je to riješeno na slikama koje si stavio
Staro 15.08.2009., 15:09   #342
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
Autor Pantera-N Pregled postova
to su il predprodukcijski primjerci bili il su ti ljudi stvarno nesposobni, nema nikakvih problema s karticama ikakvog tipa, bez brige. kao sto vidis i na onim slikama iznad od domagoja, dual slot kartice sjedaju normalno.
ja sam slagao jednog s gainward 9600gt gs s onim cudnim coolerom i sve isto ok
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 15.08.2009., 15:14   #343
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,140
Ja baš ne vjerujem tim kopčama da mogu držat dualslot grafičku, pa sam je zašarafil i još kopču prebacil preko tog sveg i mogu reć da nikakvih problema nema.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Zadnje izmijenjeno od: 1v@n. 15.08.2009. u 15:52.
Staro 15.08.2009., 15:24   #344
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
ma sta nebi drzali, stoji ona i sama od sebe, tak je moja duze vrijeme bila posto sam ljencina za sarafljenje svako tolko a znao sam da ce mi trebat (nemam cak ni cm 690 da bi imao kopcice )
iako zasarafit je uvjek dobro, hehe
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 20.10.2009., 20:17   #345
Šole
Šole's Avatar
Datum registracije: Aug 2009
Lokacija: Zürich
Postovi: 710
Evo jedno rješenje za sve kojima zuji bočni ventilator
http://img190.imageshack.us/img190/1248/slika0649.jpg
http://img27.imageshack.us/img27/2166/slika0650.jpg
http://img11.imageshack.us/img11/3263/slika0653.jpg
Stavljen je onaj filter kaj je dolje.
Vent na 1100 RPM se još malo čuje al na 1000 više ne i još nejde prašina nutra
Još samo moram zamjenit šerafe jer se sad vide van al mi se nije dalo druge tražit, a znam da su negdje.
Šole je offline   Reply With Quote
Staro 21.10.2009., 16:42   #346
yedwy
yedwy's Avatar
Postovi: 6,956
Hmh propustio sam onu staru diskusiju o coolerima višlje al da velim - ja sam imao 6800 Ultra sa dualslot backplateom (nisam dobio cooler s njom, gore je bio zalman VF900) i kopča se bez problema i kopče su držale i nju u sadašnju grafu na kojoj je VF1000, dapače čak je stabilnije i bolje kad je dualslot jer onda leži uvjek ravno a ovako se malo nakosi...
Have a nice day...
Staro 26.11.2009., 00:18   #347
DomagojX
Postovi: 1,307
evo da malo dignem temu...pofarbao sam svog u crno...ne sprejom nego baš kompresorom boja je crna mat...sad slijedi najzabavniji dio a to je da se opet sve sastavi
Staro 26.11.2009., 11:07   #348
yedwy
yedwy's Avatar
Postovi: 6,956
Ja sam razmišljao da uzmem ubodnu i otpilim si iza ploče ovu rešetku i napravim pristup za mjnjanje coolera jer i tak ne držim tamo vent niti ikad namjeravam...
Have a nice day...
Staro 04.12.2009., 12:40   #349
zgmmax
zgmmax's Avatar
Postovi: 1,677
Prije jedno tjedan dana nabavio kuciste i jucer nakon 5h posla sve slozio i upalim ga i sam kaj nisam pao sa stolice kolko je bucno
2x120 na vrhu (njegovi ventovi), 1x120 naprijed (plavi vent), 1x120 Scythe Slip stream na AC S1 rev2 i jos 1x120 Scythe na Ninji 2 rev B
svi su @5V oko 500-600 rpm
Jos cu se danas zajebavat sa kombinacijama ventova i mislim da cu maknut od 2x venta na vrhu onaj koji nije direkt iznad CPU.
Kak da ublazim buku? Da zacepim sve rupe?
Dajte neke ideje
Staro 04.12.2009., 12:50   #350
Buger
Postovi: 4,398
stavi samo vent na usis i na ispuh, oni gore ti ni ne trebaju (budući da su vodoravno položeni garant čuješ i ležajeve), a sve rupe začepi sa spužvom
Staro 05.12.2009., 23:26   #351
zgmmax
zgmmax's Avatar
Postovi: 1,677
Evo me nazad
malo sam prcko po konfiguraciji ventova i uspio sam ga utisat. evo slikica kak to sada zgleda
Ovo je bilo prvi pokusaj
A onda sam danas popravio
Ovak zgleda unutra
Staro 06.12.2009., 12:26   #352
yedwy
yedwy's Avatar
Postovi: 6,956
Autor zgmmax Pregled postova
Dajte neke ideje
NEznam kakve ti kriterije buke imaš ali IMHO ovi CM ventovi koje dobiš sa caseom ti nemogu bit bučni na 500 RPM da rak raka hebe i gotovo, mislim dleko od toga da je to NEČUJNO ali smetati ti njihov zvuk može samo ako nasloniš uho na case ili gurneš glavu unutra...
Have a nice day...
Staro 06.12.2009., 12:42   #353
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Lijepo si ti to posložio.
d4rk_ch1ld je offline   Reply With Quote
Staro 06.12.2009., 13:51   #354
zgmmax
zgmmax's Avatar
Postovi: 1,677
Autor yedwy Pregled postova
Znam da nisu bucni
Cak sam ih stavio da rade na 12V jer se opce ne cuju, buku mi je radio vent na grafi Scythe slip stream @12V, al sada je na 5V pa je ok
Autor d4rk_ch1ld Pregled postova
Prvi put sam slago jedno 3h, a onda sam jucer ponovo sve odspojio i spojio na novo za jedno sat i pol
Staro 06.12.2009., 14:49   #355
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
zanima me dali se hdd-ovi bar imalo ohlade u kucistu, dal idu ispod 40C*...meni case dolazi u utorak, a komp mi gori stalno pa da nebi HDD-ovi riku bacili
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 06.12.2009., 16:03   #356
Šole
Šole's Avatar
Lokacija: Zürich
Postovi: 710
Autor fre@k Pregled postova
Meni se kreće od 28 - 32C*, mjereno sa everestom.
Staro 06.12.2009., 16:21   #357
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
de mi reci, na koliko drzis taj prednji vent, ili se stalno na full okrece
CPU: I5 2500k
GPU: MSI TF 660 OC
PSU: Seasonic 620W
CASE: CM Elite 370
Staro 06.12.2009., 16:23   #358
yedwy
yedwy's Avatar
Postovi: 6,956
Neće im ništa biti ja nemam niti venta ispred njih i ništa im nije imam 4 komada naslagana u bracketima jedan iznad drugog i često mi zna komp raditi 24/7 kad nekaj skidam pa nikom ništa...
Have a nice day...
Staro 06.12.2009., 16:29   #359
zgmmax
zgmmax's Avatar
Postovi: 1,677
evo sada sam igro NFS:Shift 2h i HDD su mi 37C (speedy gonzales) i 34C (WD 1TB green) i seedam, zadovoljan sam sa temp hardova.
Imam 2x120 naprijed i oba su @12V oko 1000rpm
Staro 06.12.2009., 17:02   #360
Šole
Šole's Avatar
Lokacija: Zürich
Postovi: 710
Moj je na oko 800 rpm
