#331 |
muimerP
Lokacija: VG
Postovi: 3,334
ispod možda?
#332 |
Lokacija: KC (HR)
Postovi: 916
Ja sam skino noćas igru preko rapida, danas instaliro, pokrenuo, vidio i nisam mogao izdržat kolko je jadna, tako da sam kroz 2min okinio alt F4 i uninstall. ![]() Tolko od mene. |
#333 |
Postovi: 524
Ma dajte pomagajte sve novce sam spisko i tražim gdje napraviti novog igraća ali nemrem naći, tj. Nije problem u novcima nego je problem u tome što sam kupio onog mercedes 190e ali s njim nemrem ni na jednu stazu. A nemam novaca da kupim drugi auto!!!! |
#334 | |
Postovi: 1,398
Nego, ja nemogu prodat aute koji mi netrebaju,kak vi to izvedete? |
#337 | |
Postovi: 524
A kaj se tiće novog imena ja to nemrem naći uđem u opcije>gameplay>i tam tog nema, a osim gameplay-a imam video & audio i još imam live. Ali new nemam. |
#338 |
LateralusX
Postovi: 1,788
retardirani Autolog koristi EA ID name by default i ne moze se korisiti nijedno drugo ime ![]() evo prepiska sa EA supportom: Code:
Shane: Hi, my name is Shane. How may I help you? DeadMan+: hi DeadMan+: i have a problem with shift 2 game Shane: hi Shane: ok Shane: please elaborate your issue. DeadMan+: i would like to change my Autolog name DeadMan+: autolog uses EA account ID by default DeadMan+: and i would lilke to use a diferent name Shane: mean you wish to change the EAID ? DeadMan+: if that is the only way, yes I would Shane: unfortunately we won't be able to change the EA ID because that is technically not possible to change the EAID. DeadMan+: can it contain chracters like: + Shane: Unfortunately no,because EAID should not contain the special characters DeadMan+: and is there a way to use a different name in Autolog feature of Shift 2 other than EA ID? Shane: Unfortunately no ,because only EAID can be used for that and there is no other work around for that, We are Sorry for that DeadMan+: where can I complain about that? DeadMan+: because that doesn't seem like a good thing Shane: If you wish you can post your comment on forums, but it is already mentioned that you can only create it once. DeadMan+: why wasn't I warned about that before i registered my game with this account? DeadMan+: I have no problem with my EA ID Shane: when ever you create EAID you'll get note that you can create it once and for the PC version games it will used as your login name. DeadMan+: I have a problem with Shift 2 not having an option to use a different name other than EA ID Shane: yes, you won't be able to use any other name instead of EAID. DeadMan+: but that is not really a fact with other games, for instance Battlefield Bad Company 2 does not force the same policy Shane: That is the role playing game you've to make soldier in that DeadMan+: there you can have multple names Shane: yes, As I've mentioned that is role playing game and you can create other soldiers too Shane: But in this game you need a single profile that is EAID> DeadMan+: well, it's a FPS game Shane: Yes, but you are playing a role of a soldier right ? DeadMan+: ok, i'll try complying somewhere else DeadMan+: thank you for your time Shane: Is there anything further I may assist you with ? DeadMan+: no, that was all Shane: Thank you for your contacting in EA Chat Support. Have a nice Day. Bye!! Shane has disconnected. ![]() Zadnje izmijenjeno od: DeadMan+. 01.04.2011. u 20:19. |
#339 | |
Lokacija: Sisak
Postovi: 589
Bad Company je role playing a ne samo fps stoga ti je dao dobar odg. I neces uspjeti u svojoj namjeri jer nece mjenjati pravila zbog 1 accounta, pomiri se sa time i zaboravi na taj plus i nebudi cjepidlaka.
Prvo i zadnje upozorenje. |
#340 | |
LateralusX
Postovi: 1,788
![]() a BFBC2 je RPG isto koliko i ovo ![]() naravno da necu uspjeti, ali barem mogu reci svoje misljenje bas me zanima kako to radi ako se igra kupi na Steamu, jer se tamo moze mijenjati ime kad god se sjetis |
#341 | |
Pr0d1gy
Postovi: 288
Ti si jedino mogao napraviti novi EA ID i sa njime registrirati CD Key od Shifta, pa bi ti on bio na posebnom ID-u |
#342 |
Gamer 2 the Bone
Lokacija: Zagreb, oko centra...
Postovi: 1,640
Evo ja upravo instalirao. Međutim kad pokrenem trku, ne mogu uopće upravljati s autom...niti gamepadom niti tipkovnicom. Kao da nisu spojeni....hmmm, pitam se zašto. ![]()
- Nothing in this world is certain. That's the only certain thing I know. - |
#343 | |
LateralusX
Postovi: 1,788
#344 |
Postovi: 65
Skinija san igru i proba je. Za početak mi se sviđa sve (osim malo težeg kontroliranja auta na tastaturi), ali iman jedan problem. Jednostavno neman vrimena igrat svaki dan i postupno prilazit igru... Dok bi otključa neke aute prošli bi tjedni pa i mjeseci ![]() ![]() ![]() ![]() ![]() |
#348 |
DragonBall Z Fan
Postovi: 1,244
imam problem oko automatika na volanu...jednostavno nece prebacivati brzine..cijelo vrijeme je u N, kada na volanu prebacim brzinu, on odmah vrati u N...a kada je na manual onda normalno hvata preko volana brzine...ali previse mi je za razmisljati onda ![]() |
#349 |
IT Consultant
Lokacija: Geneva, Petit-Lancy / Zagreb , Dubrava
Postovi: 323
"All we have to decide is what to do with the time that is given us" J.R.R. Tolkien |
#350 | |
Lokacija: Križ
Postovi: 87
#351 |
Postovi: 939
Evo nakon par sati igranja igrice i moj osvrt na igru Sam princip vožnje mi je jako slican jedinici samo sta se sad necuje skripanje guma ostalo je i dalje ono glupo zanošenje zadnjeg kraja prilikom svakog skretanja sta mi nema smisla nikakvog, sad dal je do mog joyticka ili al svaki put kad pustim gas brzina mi drasticno brzo pada skoro pa kao i da kocim Grafika u igri je mogla bit bolja, ima svakako zanimljivih detalja na kojim su si dali truda, al posto su toliko najavljivali kako ce ova igra bit konkurencija forzi i gran turismu trebali su si dat jos jako jako puno truda da bi njih dostigli, kada shvate da nije bitno izdat igru svake godine nego napravit kvalitetan naslov budemo mogli i nesto ocekivat od nfs-a Zvuk u igri mi je recemo 6/10 mogli su puno bolje i realisticnije zvukove svakog pojedinog auta napravit posto ih nema toliko punu Izbor auta je ok, makar su i tu jos mogli poradit,radije bih u igri ove jurilice kaj se daju sredit nego nekakve ferrarije i lamborginije Sve u svemu ok igra za ubit vrijeme, ali i ne igra koja ce me drzat prikovanu za sebe godinu dana kao sto je npr Forza3 koju odigram svaki dan bar 20 min Veliki plus igri je od mene jedino veliki izbor staza koje su stvarno ljepo napravljene, jedina stvar koja po meni fali u forzi 3 Konacna ocjena 7/10 |
#352 |
Casual Racist
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Evo za vlasnike smradeona tweak za bolje performanse. Meni je na hd4870 poduplalo fps, a igra ne izgleda nista losije. Inace grafika je zbilja koma, sve nesto mutnjikavo, nazubljeno, dosta losije neg u Shift1. Budem sad probao ovaj fix za bolju grafiku sta je Nathan postao, al nekak nisam bas optimist. Igra sama po sebi je definitivno pomak na bolje od prvog dijela, pogotovo sto se fizike i zvuka tice. Grafika i ffb efekti u nekim trenucima ruse ocjenu, kao i nemogucnost biranja vise auta i staza za free race odmah na pocetku. Za sad sam zadovoljan 7,5/10 BTW jel tko prokontao onaj drift ![]() ![]() |
#353 | |
Bazinga
Lokacija: Križevci
Postovi: 3,932
Btw, jel tebi fakat ovo pomaže s novijim driverima?
#354 | |
Datum registracije: Aug 2008
Postovi: 2,000
#355 |
Casual Racist
Postovi: 422
Ne znam sad jel do novih drivera ili cisto do forsiranja AA preko njih umjesto namjestanja u igri, ali prije sam imao nekih 40 fps (AA normal) sad je 60-80 s postavkama koje je lik napisao na tom linku (ja sam doduse upalio sjene). Ako imas starije drivere mozes probati s njima napraviti isto. Probao sam i ovaj config tweak za grafiku, ali nisam bas primjetio razliku. Auto i kokpit ok izgledaju, ali okolo suma na recimo Alpentalu je bljak, no dobro sta sad ![]() vozim ja na volan, al opet taj drift ne ide i neide. Proabt cu malo kontrole podesit, pa ak se da sta dobro, ak ne, nije mi ni bitno toliko. |
#356 |
Postovi: 2,000
Ja sam obradio xml file za Shift 1, odjednom auto skrece kako treba i nema onog laga na kontrolama. Cak sam uspio na tastaturi odvozit Nurburgring bez ijednog izletanja za 7:20sec. Sve to applayam u Shift 2, jer je isti file i lokacija. I nurburgring na 7:16 sa Pagani Hyu....nesto. I to sam se jos jednom okrenio na stazi u blagoj krivini pobjeglo dupe, glupa greska kad sam zabio gas malo prerano. ![]() Drift nisam probao, jer mi se gadi sta su ucinili od njega, a onog debila sta mi sere non stop i daje..poticaje, gledam kako mu izbrisat glas iz igre totalno. |
#357 |
Postovi: 5,989
Na gamepadu i sa elite postavkama sa obicnom Zondom vozim ispod 7 min bez puno forsiranja. U prvom Shiftu sa imao ispod 6:50 i to na tastaturu, ovdje nema sansi ni sa svim twakovima. btw. Zonda F je brza na Ringu od HYu..Najbolji auto za tu stazu mi je Radical i Maserati GT1(fantastican zvuk motora) koji ima brutalne kocnice ali ga treba malo porihtat jer prvise baca straznji kraj u brzim zavojima. Presao sam 50% igre i neda mi se vise vozit SP. Sad ostaje samo popravljanje vremena na ringu. Zadnji beta driveri su digli perf. za 20% i dobar bost sam jos dobio podizanjem takta proca. Prije je radila sa 70tak sada sa 80 i 90 fps. ZONdA F: 6.52.364 ![]() http://www.youtube.com/watch?v=yIHezbSvcac GT1 Zadnje izmijenjeno od: MAGARAC. 02.04.2011. u 16:49. |
#358 |
Premijum
Postovi: 1,360
S volanom je to druga igrica, samo nije bas fer sto nisu prolagodili malo bolje za tipkovnicu, nemaju bas svi nuzno volan. Tuning mi se svida, u onim retro natjecanjima uzeo kocku M3, poslije kad sam trebao skinut AE86 od 500ks, napravo swap V10 iz M6 + turbo = 830KS ![]() ![]() |
#359 |
Postovi: 1,441
#360 |
LateralusX
Postovi: 1,788
