Staro 29.06.2019., 17:00   #451
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,485
https://www.anandtech.com/show/14596...y-power-outage
Hah "here we go again"
Da nebi sad kao kod RAM/a donedavno cijene u nebo.
Zadnje izmijenjeno od: Tajl3r. 29.06.2019. u 18:04.
Staro 05.07.2019., 23:27   #452
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,558
https://www.techpowerup.com/256909/t...ction-affected
https://www.techpowerup.com/257092/j...-memory-supply
Odlučili su syebat niske cijene po svaku mjeru, mamicu im kapitalističku. Iduće je ww3 i alieni...
Staro 04.02.2020., 10:25   #453
Što su sada istočnjački govnari izmislili da se opet cijene SSDova i RAMa otišle gore 20-30%?
Šta, netko je kihno u waffer ili je opet negdje "nestalo struje" na 7 sekundi pa je propalo 5 kila waffera?
Staro 04.02.2020., 10:36   #454
Postovi: 23,539
Em ne valja kad je prejeftino em treba iskoristiti situaciju oko corona kua ...
Usput, Druže ti si zadužen da održavaš duh poruka starog Visage - a
Staro 04.02.2020., 10:41   #455
Bojim se da nisam toliki veteran da se sjećam kolege Visagea i njegovih postova
Staro 04.02.2020., 11:16   #456
Postovi: 23,539
Ima search pa potražiš .... nema veze, samo ti piši u duhu gornje poruke i biti će ok
Staro 05.02.2020., 08:22   #457
Postovi: 16,904
Brkota
In 2019, NAND and DRAM prices dropped to an all-time low. This led to cheaper SSDs and memory than we've ever seen before. These times appear to be coming to an end though. A DigiTimes report today cited unnamed sources at chipmakers claiming that prices for NAND flash memory, a non-volatile type of storage used in storage components like SSDs, will rise by up to 40% by Q4 2020.
Various factors can contribute to this boost, such as increased demand or issues with supply, such as Samsung's latest incident where its Hwaseong plant landed out of order for 3 days due to a one-minute power outage.
Without named sources, it's hard to bet it all on DigiTimes' report. But if it's true, it would point to a tough year for PC builders. Just last week, market research DRAMeXchange also predicted that Q1 2020 DRAM prices would rise by 5% in Q1 2020.
Ponuda i potražnja, jednostavno je.
Prevelika potražnja, ponuda to ne može pratiti, što proizvodnjom, što ljudstvom da ne bi patila kvaliteta, da se tržište vrati u neku prvotnu stabilnost treba dići cijene, dizanjem cijena pasti će potražnja i sve se vraća u normalu.
Staro 05.02.2020., 08:27   #458
nino
nino's Avatar
Postovi: 12,613
Ne bas. 😁
Sent from my CLT-L29 using Tapatalk
Staro 05.02.2020., 08:30   #459
Postovi: 16,904
Koji dio?
Staro 05.02.2020., 11:57   #460
nino
nino's Avatar
Postovi: 12,613
Sve.
Prevelika potraznja? Neb se reklo, potraznja uvijek redovita, lageri krcati ssd-ovima, ponuda to lako prati. Stane proizvodnja i eto cijena gore, cim se malo lageri pocnu praznit.
Potraznja nema tu utjecaja.
Staro 06.02.2020., 14:43   #461
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,268
ne bi bas rekao, potraznja je porasla kako su cijene padale ali kako je trziste bilo preplavljeno SSD (flash driveovima) i memorijama cijena je ostajala niska. da su cijene padale i da skladista nisu bila prekrcana, cijena bi odmah isla gore a ne bi se zadrzavala na ovom nivou od 2018.
a praznjenje lagera je direktno povezano sa oba uvjeta, potraznjom i ponudom.
