Staro 12.07.2009., 11:31   #271
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
a zato sto daje nerealne rezultate. Physx je tu ubacen kao procesorski test a u slucaju akceleracije istog preko grafe ne dobijes rezultat procesora. I to je to.
Ako zelis imati score za usporedjivanje logicno je iskljuciti ga, ako samo zelis broj nad kojim ces sliniti naravno da ces ga ukljuciti
Staro 13.08.2009., 01:23   #272
Razer
Razer's Avatar
Postovi: 11,642
Jel ima itko single-PCB verziju kartice?
Staro 13.08.2009., 02:16   #273
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Da, i mene zanima kolko je tiha. I temp.
Staro 20.08.2009., 11:51   #274
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
BFG GeForce GTX 295 H2OC LE review test
byGuru3d
'Temperatures are well under control. See the challenge is cooling capacity. The two GPUs produce a lot of heat which in the long run needs to exit through the 120mm radiator. To get rid of that heat the ventilator has to spin hard, real hard. The reality is that for normal cooling you'd typically set the CoollIT unit to mode two, but really that mode is just too loud for my taste. You'll end up at fan mode one which is reasonably noiseless, yet definitely audible all the time. At that mode with the graphics card maxed out and stressed your temperatures will then hover close to 60 degrees C. With the overclock of this product, these really are truly respectable numbers.'
'But yeah... the bottom line is that this is true pr0n for geeks and hardcore gamers, bring it on, we can't get enough of gear like this.'
Staro 20.08.2009., 14:27   #275
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Šajni!
Majo je offline   Reply With Quote
Staro 20.08.2009., 14:37   #276
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Prije dosta vremena sam kupio tt tide water, naravno da je u banani (u biti ovisan je o bloku onom jadnom koji dobijes, a koji je nesposoban ohladiti bilo koju danasnju jacu karticu) i da sam ga rastavio 'da vidim sto se tu događa', i mogu reci da mi se pumpa i velicina cijevi cine identicni...
No sam koncept i ideja su super, kao npr corsairov h50 za cpu, mislim da bi se dobro prodavali sami moduli kada bi se mogli spojiti na bilo koji vga vodeni blok
Staro 28.08.2009., 09:17   #277
m&n
Datum registracije: Mar 2008
Postovi: 894
Mene zanima da li bi ovo funkcionirali ako bude ja odmah danas idem u nabavku istih samo mi netko treba potvrdno odgovorit
lp
http://forums.firingsquad.com/firing...read.id=131615
m&n je offline   Reply With Quote
Staro 28.08.2009., 13:30   #278
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
ne bi ja to radio...
Igor_Zg je offline   Reply With Quote
Staro 28.08.2009., 15:22   #279
StreetJosip
StreetJosip's Avatar
Datum registracije: Aug 2009
Lokacija: Vinkovci
Postovi: 31
nebi ni ja al šta če čovjek kad hoce to raditi i stavrno mu dobro ide zasad
Sig 50 kb max :-)
StreetJosip je offline   Reply With Quote
Staro 28.08.2009., 16:49   #280
m&n
Postovi: 894
Autor StreetJosip Pregled postova
ne kužim tvoj post
Staro 28.08.2009., 21:48   #281
greg SE
greg SE's Avatar
Lokacija: Vinkovci
Postovi: 5,231
covjek malo nabija postove glupim komentarima. Ni prvi ni zadnji....
Staro 05.09.2009., 12:52   #282
sasa01
Lokacija: delnice
Postovi: 10
gainward gf gtx295 problem
pozdrav svima,evo ovako,imam problema sa doticnom karticom kad ulazim u igre,npr far cry2 ili crysis,ili 3dmark2006,prodje dva testa i cijeli mi se komp ugasi,tako isto i u igrama,igram manje od minute i ugasi se,,,konfiguracija je sljedeca.maticna gigabyte ga-ep43-ds3,core2duo e7500,4gb OCZ platinum ram,320gb hdd seagate,thermaltake cooler,napajanje raptoxx 600w, windowsi su 7 64bit ultimate,molim malo pomoci,neznam sta da radim,hvala
sasa01 je offline   Reply With Quote
Staro 05.09.2009., 12:59   #283
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Taj Raptoxxxxxx je živo smeće od napajanja pa se ne bih čudio da je do njega, pokušaj s drugim napajanjem kresnut komp. Btw. jesi spojio oba PCIe kabela za napajanje grafe (6-pinski i 8-pinski)?
C L O W N I N G A R O U N D
Staro 05.09.2009., 13:06   #284
Wolverine
Wolverine's Avatar
Postovi: 12,431
Autor sasa01 Pregled postova
kupi pošteno brand-name napajanje
Raptoxx je živo smeće od napajanja (iako nisi naveo koja serija i točan naziv modela)
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 05.09.2009., 13:17   #285
sasa01
Lokacija: delnice
Postovi: 10
ja se ispricavam,model je RT600PSP
Staro 05.09.2009., 13:24   #286
ange
ange's Avatar
Datum registracije: Sep 2004
Postovi: 116
Ja sam imao isti problem kao ti, imao sam GTX 260, nakon zamjene napajanja bila mi ja ista situacija, tako da sam reklamirao grafu i zamisli riješili su mi reklamaciju i da li mi odmah drugu karticu, tako da je moguće da je i grafa, evo nadam se da sam ti pomogao.
ange je offline   Reply With Quote
Staro 05.09.2009., 13:25   #287
Wolverine
Wolverine's Avatar
Postovi: 12,431
Taj model nema niti približno 600W
Ima snage otprilike ko jedno pošteno 400W napajanje
Za tvoju konfu bi savršeno pasao jedan Corsair HX520 iako bi i HX450 bio dovoljan (tjerao je na testu AMD Phenom II X4 + GTX295)
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 05.09.2009., 13:34   #288
sasa01
Lokacija: delnice
Postovi: 10
ok,,idem po drugo napajanje,,za jedno 1000kn,,ako ima ko kakav prijedlog
Staro 05.09.2009., 13:36   #289
Wolverine
Wolverine's Avatar
Postovi: 12,431
prije toga radije provjeri kod nekoga dal karticxa radi kako treba (alikod nekoga tko ima napajanje koje tu grafu može hraniti)
možeš probati i sa nekim drugim driverima
i provjeri da se slučajno kartica ne pregrijava pa zato gasi računalo
A za napajanje sam već naveo što možeš uzeti
Ovo bi ti bilo i više no dovoljno
http://www.nabava.net/trazilica.php?...HX+520&x=0&y=0
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 05.09.2009., 13:46   #290
sasa01
Lokacija: delnice
Postovi: 10
sa driverima sam probo,a karticu nemogu probat kod nikog,jer niko nema iznad 400w,kog znam,skinuo sam riva tuner i ventilator navio do kraja,i opet ista stvar,,jos se prije ugasi.
Staro 05.09.2009., 13:48   #291
Wolverine
Wolverine's Avatar
Postovi: 12,431
mijenjaj napajanje onda
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 05.09.2009., 14:09   #292
sasa01
Lokacija: delnice
Postovi: 10
ok idem se zaletit onda u rijeku,pa kad kupim i stavim pa cu javit,,pozdrav
Staro 05.09.2009., 20:02   #293
sasa01
Lokacija: delnice
Postovi: 10
evo mene,,uzeo sam corsair TX650w pa da vidimo sad,javim
Staro 05.09.2009., 21:16   #294
sasa01
Lokacija: delnice
Postovi: 10
eto sad radi,hvala decki na odgovorima,ipak je bila stvar u napajanju
Staro 05.09.2009., 21:32   #295
Wolverine
Wolverine's Avatar
Postovi: 12,431
uzeo si mrak napajanje, dosta bi ti bilo i nešto slabije no TX650 je zvijer od napajanja
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 09.09.2009., 18:28   #296
sasa01
Lokacija: delnice
Postovi: 10
neka se nađe,kod sljedece nadogradnje ,ja se nadam,
Staro 10.09.2009., 08:52   #297
Postovi: 34,062
Taj TX650 bi ti bez problema držao još jednu konfu.
Staro 15.09.2009., 19:16   #298
m&n
Postovi: 894
imam jedan problem na xpu i mislim da je do graficke kartice gtx295..
no da vam objasnim..
3dmark06- windows vista ili sedmica - manji cpu score(sta je normalno)
3dmark06 - xp - veci cpu score manji graficki score.
call of duty 4 mp windows vista ili sedmica - stavim na 250 lock i fps miruje ne mrda niti u jednoj situaciji tako je poriktan config..
call of duty 4 mp windows xp isti config fps se ubrzano mjenja i nije stabilan 200-250... ako stavim na 125 lock isti k nije miran..
ono sta sam ja probo napravit u cpu od nvidie iskljucit multi gpu i vidi vraga na xpu udem u igru cod 4 mp isto radi ko i sa ukljucenim multi gpu.
dok naranvo 3dmark06 radi pun k losije bez mutligpu-a
stvarno bi mi dobro doslo rjesnje nekakvo jer zelim imat xp..
ono sta imam mozda drugacije od ostalih je raid 0..
vista i sedmica ih sami nadu.. na xpu moras preko diskete ili intergrirat u windows pa instalirat drivere.. za sata/raid.
pls help. nemocan sam vise
Staro 15.09.2009., 19:36   #299
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,755
Isti fps sa i bez SLI-a? Jesi u opcijama igre upalia ono dual-cards ili tako nesto...
Ne kuzim te, u cemu je tocno problem? Zasto bas zelis xp, navika ili? Stavi win7 ili Vistu sp2 i pici
To sto ti je fps nestabilan pod xp-om je ajmo reci normalno, jer su noviiji driveri bolje optimizirani za nove windoze, te su manje ograniceni mogucnostima istih... Uostalom, sto ima veze ako ti fps skace.. Da ide, neznam, od 100-250 - opet dobro.. Bitno da se ne pada tolko da osjetis trzanje ili lagg...
Staro 15.09.2009., 20:00   #300
m&n
Postovi: 894
Autor Sn4k3 Pregled postova
ma sve sam napravio jbga.. da isti fps sa slijem i bez slija..
xp hocu iz vise razloga . ne svida mi se niti vista niti sedmica ali ocigledno sam osuden na njih
cod2 ne radi na sedmici a vista je shit od windowsa
Zadnje izmijenjeno od: m&n. 15.09.2009. u 20:14.
