#63 | |
Postovi: 7,568
GPU-Z v0.1.8 Citiraj:
Oni hrabriji nek probaju, pa jave dojmove. |
#68 |
Postovi: 11,642
Koristi 0.1.7 i to je to ![]() Ionako, vidiš i sam da nova verzija ionako ne donosi nikakve nove stvari (informacije/poboljšanja) za tvoju karticu. |
#69 |
Prečupavi mod
Postovi: 9,128
Ima li nekog da mu radi 0.1.8?
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#71 |
Postovi: 11,642
Baš me zanima s čime su toliko zabrljali kad tolikima ne radi kako valja... Inače meni radi kako treba ![]() |
#72 |
muimerP
Lokacija: VG
Postovi: 3,334
#75 | |
Postovi: 7,568
GPU-Z v0.1.9 Citiraj:
#76 |
Lokacija: Dubrovnik
Postovi: 2,583
GPU-Z v0.2.1
Par sati prije ove verzije izasla je 0.2.0 verzija no u novijoj je ispravljen bug za ocitavanje na Visti (32bit/64bit) v 0.2.0 Changelog: Code:
Added support for S3 graphics cards Added screenshot upload feature (press F5 or click the camera icon) Added NVIDIA GT200 detection Updated RV770 detection Vista64 is now listed as "Vista64" in the driver version readout On Vista64, CrossFire status will be marked as "Unknown" until fix is found Added dump to XML. Use command line parameter -dump gpuz.xml More robust NVIDIA clock detection Fixed G73 fillrate calculation Added die size for RV350 Fixed R680 clock readings Fixed R600 ROM reading code Fixed sensors not refreshing properly sometimes When unknown architecture detected, NVIDIA logo won't be shown anymore Fixed random UNICODE characters on some architectures in upload progress Changelog: Code:
Fixed Vista32 / Vista64 detection. It was reversed in 0.2.0. Zadnje izmijenjeno od: Razer. 31.05.2008. u 14:12. |
#77 |
Postovi: 11,642
Gpu-z 0.2.2
GPU-Z 0.2.2 Code:
Added support for variants of i945G, Q35, G31/G33, G84, G92, G96, GT200, G86M, G84M, C79 Improved RV770 and GT200 detection code Updated NVIDIA temperature reading code Fixed updater getting stuck during refresh CrossFire on Vista64 now reported with note "unsure", instead of just "unknown" Added mini graph to sensors Screenshots are uploaded as PNG now Added crash report error handler Updated G70 number of ROPs Added PCI Vendor Point of View Improved S3 Chrome 400, S20, S18 and S8 detection |
#78 |
Lokacija: Hercegovina
Postovi: 363
GPU-Z v0.2.3 Code:
Fixed NVIDIA GeForce GTX 260/280 (GT200) support. Everything is working and tested now Removed bogus 190°C PCB temp sensor on various NVIDIA cards Added fan speed monitoring for NVIDIA Fixed crash when switching devices during sensor refresh Fixed ROP/Shader count on NVIDIA G72 Fixed graphs spilling over their client area Fixed a number of other rare crashes NVIDIA device ID 0x00F3 now correctly recognized as NV43 Improved crash reporting module
Sig 50 kb max :-) |
#79 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
GPU-Z 0.2.6
GPU-Z 0.2.6 GPU-Z 0.2.7 is out and it supports catalyst 8.7 beta & latest forceware drivers. Here is the list of changes : - Added full support for HD 4870 X2 - Added support for reading clocks on newer ATI drivers (R700) - Fix for realtime clock sensor showing double memory speed on RV770 GDDR5 - Added detection for GeForce 9800 GT, GeForce 9300 GE - Added support to start GPU-Z minimized (use -minimized) - Added tray icon when GPU-Z is minimized - Fixed crash when uploading large BIOS files - Fixed rare crash that could happen on some NVIDIA cards - Added detection for Intel Q43. G45 and some variants of G35, G965, GM965
#80 |
Super Moderators
Postovi: 17,485
GPU-Z 0.2.8
Latest Changes: Added logging of sensor data to file Added option to disable polling for individual sensors Added support for AMD RV730 Added clock reading support for Catalyst 8.9 on RV770 and RV730 Added support for NVIDIA 9400 GT, 9500 GT, 9600 GS, 9800M GS, 9600M GS, 9300M GS, 9200M GE Added support for AMD R580 Stream Processor, RV730 and one M88 variant Fixed PCI subvendor ID 1787 to be ATI AIB Fixed readings and added monitoring support for ATI M88 Fixed fan speed readings on ADT7473 sensor Added support for ADT7473 sensor chip on ATI Added release dates for several NVIDIA mobile GPUs http://fileforum.betanews.com/downlo...Z/1191593246/1
#81 | |
Super Moderators
Postovi: 17,485
GPU-Z 0.2.9 Released
http://www.techpowerup.com/downloads...-Z_v0.2.9.html
#82 | |
Six Blade Knife
Postovi: 292
#84 |
Datum registracije: Jul 2003
Postovi: 167
GPU-Z 0.31 * Fixed crash on systems without NVAPI (Win 2K, old NV drivers) * Optimized RV770 BIOS reading code for speed (faster application startup) * Improved voltage reading code for recent ATI cards * Added support for fan speed monitoring on ForceWare 180.xx and up * Added voltage monitoring for NVIDIA (GT200) * Changed reading method for RV770 sensors, fixes race conditions with other software and on-board fan control * NVIDIA 9800 GTX+ listed as 55nm now * Added support for Intel Q43/Q45 * Added support for NVIDIA Quadro FX 4700 X2, GTX 295, GTX 285 * Added preliminary support for NVIDIA GT212, GT214, GT215, GT216, GT218 GPU-Z 0.31 |
#86 | |
Six Blade Knife
Postovi: 292
#88 |
Resident Arse
Postovi: 49
GPU-Z pitanja
Zamjenio sam svoju antičku FX 5900XT sa nešto novijom Atijevkom. Pošto nisam previše upoznat sa gpu terminologijom, zamolio bi nekog da mi pojasni što je to ROP, Die Size etc... zapravo koje su brojkice najbitnije a koje najmanje bitne jer je primjerice Ati bus width duplo manji od nvidije? Nadam se da to ne znači da su im ukupne performanse podjednake. Komp je inače Athlon 2.2Ghz sa 2GB rama i 32bit XP Pro, SP2.![]() |
#90 |
Resident Arse
Postovi: 49
Znači nema veze sa ukupnom brzinom ili nije tolko važno kao DDR2? ![]() |
