08.10.2007., 14:37 | #32 |
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
http://www.techpowerup.com/downloads...-Z_v0.0.6.html Evo i 0.0.6 Meni sve radi: http://img510.imageshack.us/img510/8742/gpuzol9.gif
11.10.2007., 17:16 | #33 |
od LemilicE
Postovi: 4,712
Evo i 0.0.7 beta http://www.majorgeeks.com/GPU-Z_d5796.html
14.10.2007., 11:06 | #35 |
Ultrabitchinfast
Postovi: 880
16.10.2007., 20:44 | #36 |
od LemilicE
Postovi: 4,712
18.10.2007., 16:26 | #37 |
Rambus 3xtr1m
Postovi: 2,694
21.10.2007., 22:30 | #38 |
Postovi: 11,642
Izašla i 0.0.9 verzija. |
05.11.2007., 16:04 | #39 |
od LemilicE
Postovi: 4,712
06.11.2007., 12:13 | #41 |
Postovi: 11,642
Nije ni čudo s obzirom koliko je kartica stara...program je ionako još uvijek u beti... S druge strane ne kužim svrhu tvog posta. Pošalji mail autorima i slično, jer ti mi ovdje sigurno ne možemo pomoći... |
15.11.2007., 00:05 | #42 |
Postovi: 7,568
05.12.2007., 01:11 | #43 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,484
Gpu-z 0.1.2
Latest Changes: Added/improved device detection for certain models of: Rage Pro, Rage XL, RageII, RV280, RV515, RV516, R580, R600, Rage Mobility. i810G, i815G, i845G, i865G, i915G, i830GM, i910GL, i915GV, i855GM, i915GM, i945G. G84, G86, G92, G98, C51 Pressing F5 will now take a .GIF format screenshot RV6xx clock reading will now always display high-performance clocks Update check won't show up anymore when "Never" is selected Update check can be aborted at any time during execution Added mouse over tooltips for text boxes that could have too long text Added experimental memory type and bus width detection for Intel integrated Added PCI vendor PNY Intel driver version is now properly detected on all operating systems Added N/A to ATI GPU revision and other similar fields Memory bus width detection improved for RV530, RV535, RV560, RV570, R520, R580, M56, M58, M66, M68 Added option to receive E-Mail with validation ID after submission Fixed Catalyst version detection on XP64 Added detection for AGP cards running in PCI mode Age setting now properly reflects author's age (Happy Birthday!) http://fileforum.betanews.com/downlo...Z/1191593246/1
20.12.2007., 02:15 | #44 |
Super Moderators
Postovi: 17,484
GPU-Z 0.1.5 Latest Changes: Online BIOS submission dupecheck now actually works More changes to G70/G71 ROP/shader detection code (never ending story) G71 AGP is now 90nm instead of 110nm If default clocks on NVIDIA can not be determined via BIOS, try fallback via driver Better driver communication to NVIDIA driver Corrected shader detection for softmodded R300, R480 cards Known issue: NVIDIA SLI status can not be detected under Vista http://fileforum.betanews.com/detail/GPUZ/1191593246/1
20.12.2007., 08:33 | #45 |
Pod naletima kopita zla
Lokacija: SMB / ZGB
Postovi: 7,728
ja pokrenem GPU-z. proces uredno vidim u task manageru ali program kao takav se ne pokreće pokrene se nakon kojih 1h ne znam zašto nastaje takav delay isto mi se događalo sa x800gto, 6200, 7900 |
20.12.2007., 10:59 | #46 |
Premium moderator
Postovi: 4,600
Sve te grafe si imao na jednom OS-u? Tj. nisi reinstalirao nakon tih grafa?
__________________ |
11.02.2008., 02:10 | #50 |
Postovi: 7,568
11.02.2008., 02:16 | #51 |
Postovi: 11,642
Interesantno, štošta ima za pokazati na tvojoj kartici. Evo što sam htio reći, GPU-Z pod GPU Temperature pokazuje ono, za što Everest veli da je GPU Memory: EDIT: hm, tek sam sad primijetio da GPU-Z ima mogućnost spremanja BIOS-a kartice Zadnje izmijenjeno od: Razer. 11.02.2008. u 02:43. |
11.02.2008., 02:25 | #52 |
Postovi: 7,568
Ko bi znal kak su oni sredili ta očitavanja. Valjda budu u sljedećim verzijama "ispolirali" to kak spada. Treba pričekati da se i ostali jave, tj. da jave kaj i kak njima očitava. |
11.02.2008., 03:12 | #53 |
Super Moderators
Postovi: 17,484
Zamjenio je GPU i ENV temperaturu na mojoj AIW...
11.02.2008., 09:25 | #58 |
Lokacija: Križevci
Postovi: 73
meni baš i neda puno informacija. |
12.02.2008., 00:04 | #60 |
In the ghetto
Postovi: 1,943
