Staro 02.09.2007., 21:57   #1
mihael19900
mihael19900's Avatar
Lokacija: Đakovo
Postovi: 24
Šta kažete na ove konfe?
Konfa 1. monitor : Monitor Samsung SM 206BW, 20" LCD, 2 ms, DVI, Premium stand
procesor: CPU AMD Athlon64 X2 6000+ BOX, dual core, SckAM2
matična: MB Gigabyte M59SLI-S4, sAM2, nForce 590-SLI, SATA, FW, GLAN
memorija: 2x DDR2 1GB PC6400 (800MHz), Kingmax
HDD: HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200
pržilica: DVD+RW/-RW/RAM LG GSA-H62N Dual Layer, SATA, 18x, bulk, black
FDD: FDD 1.44 MB BLACK
grafička: Gigabyte GF 8800GTS, 320MB DDR3, TV-out, Dual DVI
kućište: Thermaltake VD2000BNS, mid tower Matrix, bez PS, crno, met-alu maska, USB, Fire wire, 1×120mm fan
napajanje: OCZ power supply GameXStream 600W, SLI-ready, crno, EPS, ATX 2.2, 4×12V (72A), 12cm blue led FAN
OS : OEM. Windows Vista Home Premium Croatian
konfa 2. monitor: Monitor LG LCD L194WT, 1440 x 900 widescreen, 2000:1, 5ms, DVI
procesor: Intel Core 2 Duo E6750 BOX, 2×2.66GHz, 1333MHz, 775-pin, 4MB
matična: MB Gigabyte 965P-DS3, s775, i965P, DDR II, SATA II, GLAN
HDD: HDD Seagate ST3250620AS/ST3250410AS, 250 GB 16MB, S-ATA300, NCQ3, 7200
pržilica : DVD+RW/-RW/RAM LG GSA-H50L Dual Layer, LightScribe, 18x, bulk
grafička: Gigabyte Radeon HD 2600 XT 256MB DDR4, PCIE, TVout, dual DVI
napajanje: Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors
hvala!
MOJ KOMP: CPU AMD Athlon64 X2 6000, Matična : MB Gigabyte M59SLI-S4, sAM2, Mema: 1GB PC6400 (800MHz), Kingmax x2, HDD Seagate ST3320620AS, 320 GB 16MB, 8800 GTS 320 MB, napajanje: OCZ 600W. AMD i Nvidia su najbolji!!!!!!!!!!!
mihael19900 je offline   Reply With Quote
Staro 02.09.2007., 22:09   #2
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Što mislim...hmmm...Prva je tvoja konfa, druga vjerovatno frendova...pa se ti pitaš koja je bolja? Moja je najbolja, normalno!
Sutra će škola pa nećeš imati vremena otvarati glupe teme
Staro 02.09.2007., 22:15   #3
hash
Postovi: 1,431
radit ce oba
ako kupujes novo reci kolko love je u igri i da li si ogranicen na odredjene ducane?
sto se tice monitora mislim da je 19'' wide premalo ali to je subjektivno pa pogledaj
diskove bi radje uzeo samsung t166 ako postoji takva mogucnost
u intel konfi bi uzeo plocu baziranu na p35 chipsetu
mislim da ti netreba ovaj OCZ od 600W, mislim da bi bio ok neki chieftec sa 500W ali sve ovisi o kolicini love i razlici u cijeni
windowsi?? to ti je za firmu komp ili za igre?
8800gts je puno bolja kartica od 2600XT, opet, sve ovisi o kolicini love i kolko se igras na kompu
koja je rezolucija na onom 20'' monitoru, mozda ce ti trebati graficka sa 512ili vise MB ako je reza 1680xnesto (to pricekaj jos nekog ko bolje zna)
edit:
sad vidim o cem se radi
prva je bolja za igre, druga ima bolji procesor
***ote na sta sam ja sad potrosio svoje vrijeme
Staro 02.09.2007., 22:25   #4
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,358
ja mislim da se mihael samo oće pohvalit koju je mašinu kupio
Staro 02.09.2007., 22:46   #5
mihael19900
Lokacija: Đakovo
Postovi: 24
Autor nick praskaton Pregled postova
ma nije to nego me iskreno zanima Vaše mišljenje o tim konfama a ne prijedlozi za komponente kao što su neki počeli "bolje da si uzeo...." - KONFE SU KUPLJENE , SAMO ME ZANIMA VAŠE MIŠLJENJE!!!
Staro 02.09.2007., 23:00   #6
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Prva je bolja za igranje zbog osjetno jace grafe, no druga ima nesto jaci proc. Prva ima i bolji i veci ekran.
Po ostalome su konfe tu negdje, ok prva ima veci disk no i druga ima sasvim dovljno velik.
Staro 03.09.2007., 00:25   #7
klinsider
klinsider's Avatar
Lokacija: nowhere
Postovi: 16
Bok drustvo
Ko da sam doima na f***m.hr, toliko mi je prijatelja tu
klinsider je offline   Reply With Quote
Staro 03.09.2007., 01:38   #8
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
prva je bolja a druga je jos bolja, zato sto mozes vrtit super PI <20s kad je naklokas, stavi Zalman kuler od 450kn i brzim ventilatorom, opcenito preslaba su napajanja, ja bi barem 700 Vati u svaku piknuo, za svaki slucaj, 2600xt vuce bar 300 Vati znas, memorija je trebala bit na 1066Mhz jer je ta prespora i usporavat ce ti komp, umisto crnog stavi bijeli Floppy, to je jako vazno jer ces ga cesto koristit, a crna nije bas ugodna boja kada gledas floppy dok stavljas danas izuzetno popularne crne diskete, Vista Ajtimejt je bolja od home premijum pa i to treba prominit, i naravno, u obe konfe je jedna velika greska, a to je da maticna ploca treba bit Fokskon Zvijer
bobe je offline   Reply With Quote
Staro 03.09.2007., 01:49   #9
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
LOOOOL
gg bobe
Staro 03.09.2007., 08:49   #10
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
bobe je pod utjecajem nepoznatih preparata...
dobra dobra...
Staro 03.09.2007., 15:06   #11
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Autor klinsider Pregled postova
Dobrodosao care!
Bobe...
Staro 03.09.2007., 16:30   #12
mihael19900
Lokacija: Đakovo
Postovi: 24
[quote=hash;803944]radit ce oba
edit:
Kako druga može imati bolji procesor kad je u prvu konfu ugrađen najjači procesor koji postoji od AMD-a na tržištu??
Staro 03.09.2007., 16:35   #13
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Autor mihael19900 Pregled postova
6000+ x2 nije najjači AMD procesor. A e6750 s malim clockom je brži od tog aemdejca
Staro 03.09.2007., 16:35   #14
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
prvo naući quotat, jer se u tvom zadnjem postu ne zna ko pije a ko placa, evo vako:
pa to ti je nes vako, otprilike, ko je brzi? najjaci Renol klio ili najslabiji Ferrari? ne doslovno, al otprilike...naravno mislim na OC-an C2D
Staro 03.09.2007., 16:42   #15
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,743
Šta se tu ima reći, ak radi onda je dobro složeno.
pinkskin je online   Reply With Quote
Staro 03.09.2007., 18:39   #16
mihael19900
Lokacija: Đakovo
Postovi: 24
Autor bobe Pregled postova
Ja sam mislio na nominalnim postavkama a ne na OC-anim postavkama!!!!!! (pola ljudi svejedno ne OC-a svoje procesore -Intelove , jer ne znaju!!)
Staro 03.09.2007., 20:47   #17
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
hmmm, tih pola ljudi mene ne zanima, jer vecina na ovom forumu nabaci OC proca, a i oni koji neznaju kad dodju tu saznaju, i nakon tjedan-dva tucu reze u top 10 SPI@PCE
btw mislim da si mogel zakljucit na kojoj je razini moja ozbiljnost u ovoj temi, jer i sama tema je totalni "OT"
Staro 04.09.2007., 16:18   #18
mihael19900
Lokacija: Đakovo
Postovi: 24
Čuj, ja sam mislio da mi date mišljenje o onim konfama , jel valjaju ili ne te šta bu vi tu nadogradili...(ako treba)
Staro 04.09.2007., 16:26   #19
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
U prvu konfiguraciju dodaj još jednu 8800 gts tako da malo opteretiš to napajanje
Staro 04.09.2007., 17:56   #20
Bravo
Bravo's Avatar
Postovi: 1,450
obje konfe su super..
x2 6000+ je sitno sporiji od E6750(na defaultu). zamjenio bih grafe, 8800gts stavio u intel konfu i onda bi to bilo over kill i gaming do jaja
