Staro 13.11.2025., 16:09   #691
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,290
Dvaput je dvaput, a fata je fata 😃
Staro 15.11.2025., 20:02   #692
alengrosevic
alengrosevic's Avatar
Postovi: 3,785
OpenVPN upute:
Evo ako će netko slučajno trebati, step by step kako podesiti open VPN da radi na Miktrotiku. I čak radi vrlo pristojno na običnom HEX-u:
1. Bridge
2. + (add new)
3. ime - "vpn_bridge"
4. IP - adresses
5. + (add new)
6. 10.10.251.1/24 i vezati na "vpn_bridge"
7. IP - Pool
8. + - "vpn_pool"
9. dodati adresses npr 10.10.251.101-10.10.251.199
10. System - certificates
11. + name - "opnvpn-CA" (key-cert-sign, crl-sign, validity 3650 days common name "openvpn-CA")
12. + name - "opnvpn-server" (digital signature, key encipherment, tls server) common name "openvpn-server" validity 3650 days
13. + name "opnvpn-client" (digital signature, key encipherment, tls client) common name "ovpn-client" validity 3650 days
14. desni klik na opnvpn-CA "sign" - sign
15. desni klik na "opnvpn-server" sign (sign with opnvpn-CA) - sign
16. properties od opnvpn-servera i zaklikati "trusted certificate"
17. desni klik na "opnvpn-client" sign (sign with opnvpn-CA) - sign
18. Export client certifikata u PEM oblliku (obavezno staviti lozinku)
19. Export CA certifikata
20. podesiti Open VPN server na željeni port (1194), default proile se odabere openvpn-profile i certifikat openvpn-server.
21. IP - Firewall - + - Chain "input" - protocol (6,tcp), dest port 1194 (ili željeni podešeni gore), action "accept"
22. PPP profiles - Name "ovpn-profile", local address 10.10.251.1, remote address je "vpn_pool"
23. PPP OVPN Servers, +, Name "ovpn-server1", port 1194 (ili željeni", tcp, Certificate "ovpn-server", ostaviti zaklikano Require ClientCertificate, zaklikati samo sha256 i "aes 256 cbc", "Redirect Gateway" na "def-conf"
24. PPP - Secrets, Ime, Password, Service ovpn, Profile "ovpn-profile"
25. PPP - OVPN Servers i odabrati server. Kad se otvori prozor na desnoj strani kliknuti na "export .ovpn". Pod IP adresu upisati vanjsku IP adresu ili DynDNS servis, CA certifikat, Client certifikat i Client key (dobiveno na exportu certifikata, Files na routeru)
26. Files - odabrati ovpn file i downloadati ga na PC.
27. Downloadati OpenVPN connect i učitati downloadani file
29. za DynDNS se koristi Mikrotik DNS rješenje, piše na početnoj strani pod Quick settings npr "nestoxyz.sn.mynetname.net"
Napomena, za open VPN GUI dodati liniju u ovpn conf file:
cipher AES-256-CBC
compat-mode 2.4.0
Za openVpn connect ne treba ništa dodavati
Staro 15.11.2025., 21:23   #693
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,913
Upute kako aktivirati BackToHome VPN
1. Skinuti BackToHome aplikaciju na mob
2. Ukljuciti je i pritisnuti Create New
3. Unjeti podatke za ulogirati se u router preko BTH i pritisnuti ok
Prvi put da je nesto na mikrotiku jednostavno
I meni cudo dobro radi, top topova.
Staro 19.11.2025., 12:38   #694
Nick7
Lokacija: Velika Gorica
Postovi: 1,533
Dost' jednostavno je i za Wireguard... na hEX-u ide cca 200Mbit/s brzina (limit HW-a).
Staro 23.11.2025., 13:22   #695
alengrosevic
Postovi: 3,785
Autor zbuzanic Pregled postova
ok, jučer sam nabrzakao pokušao sve prebaciti na svoj MT, naletio sam negdje da bi mogao biti problem oko autonegotiationa, danas ću se detaljno pozabaviti pa javim rezultate, čitao sam da je možda i prašina uletila, to je moguće, tavan je prašnjav...jel mogu kako bez alata počistiti konektor? nemam baš iskustva s optikom
ps. složio konačno sve bez huaweia i speedporta, samo mikrotik i zyxel spf. Složim tutorial pa stavim na web za smrtnike poput mene.
Evo i uputa, jučer sam to posložio za 20-tak minuta, djelovalo je puno "strašnije" čitajući po forumu i ostalim stranicama što je potrebno napraviti:
https://www.zvonimir-buzanic.from.hr...el-pmg3000-sfp
Kolega zahvaljujem na detaljnim uputama. Slijedio sam ih i uspio sam podesiti sve i radi odlično.
Zadovoljan sam što sam maknuo ONT, još da RB5009 ima model sa AX wirelessom, to bi bilo taman
Edit: riješeno. Trebalo je staviti lan brzinu na SFP-u na 1 gb
Zadnje izmijenjeno od: alengrosevic. 03.12.2025. u 22:29.
