Kako promjeniti font u Android widgetu - Android studio
bok, naime početnik sam, i već sam sve živo probao ali jednostavno font se ne želi promjeniti... napravio sam jednostavan widget koji prikazuje točno vrijeme i sad želim koristiti custom font ali u Android studio skroz desno gdje je virtualni uređaj tamo ne želi prikazati novi font dok u layout pod design piše da font family: @font/pixel ovo je code: widget.xml: Code:
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android" xmlns:app="http://schemas.android.com/apk/res-auto" android:layout_width="match_parent" android:layout_height="match_parent" android:gravity="center"> <ImageView android:id="@+id/imageView" android:layout_width="wrap_content" android:layout_height="wrap_content" android:layout_centerHorizontal="true" android:src="@drawable/my_image" /> <TextView android:id="@+id/textView" android:layout_width="wrap_content" android:layout_height="wrap_content" android:layout_alignParentBottom="true" android:layout_centerHorizontal="true" android:fontFamily="@font/pixel" android:gravity="center" android:textColor="#FF0000" android:textSize="48sp" /> </RelativeLayout> Code:
<?xml version="1.0" encoding="utf-8"?> <font-family xmlns:android="http://schemas.android.com/apk/res/android"> <font android:fontStyle="normal" android:fontWeight="400" android:font="@font/pixel" /> </font-family> hvala |
probao sam par metoda i sa java ali nula bodova: Code:
package com.example.sexyclockwidget; import android.appwidget.AppWidgetManager; import android.appwidget.AppWidgetProvider; import android.content.ComponentName; import android.content.Context; import android.graphics.Bitmap; import android.graphics.Canvas; import android.graphics.Paint; import android.graphics.Typeface; import android.os.Handler; import android.widget.RemoteViews; import androidx.core.content.ContextCompat; import java.text.SimpleDateFormat; import java.util.Date; public class SexyClockWidget extends AppWidgetProvider { private Context context; private static final String TIME_FORMAT = "HH:mm:ss"; private static final String SHARED_PREFS_FILE = "com.example.sexyclockwidget"; private static final String PREF_TIME = "time"; private Handler handler = new Handler(); private Runnable runnable = new Runnable() { public void run() { updateClock(context); // pass the context parameter here handler.postDelayed(this, 1000); } }; @Override public void onUpdate(Context context, AppWidgetManager appWidgetManager, int[] appWidgetIds) { this.context = context; // initialize the context variable for (int appWidgetId : appWidgetIds) { RemoteViews views = new RemoteViews(context.getPackageName(), R.layout.sexy_clock_widget); // Postavi sliku na ImageView views.setImageViewResource(R.id.imageView, R.drawable.my_image); // Pokreni runnable koji će osvježavati vrijeme handler.postDelayed(runnable, 1000); appWidgetManager.updateAppWidget(appWidgetId, views); } } @Override public void onDisabled(Context context) { super.onDisabled(context); // Zaustavi runnable kada je zadnji widget uklonjen handler.removeCallbacks(runnable); } private void updateClock(Context context) { AppWidgetManager appWidgetManager = AppWidgetManager.getInstance(context); int[] appWidgetIds = appWidgetManager.getAppWidgetIds(new ComponentName(context, SexyClockWidget.class)); for (int appWidgetId : appWidgetIds) { RemoteViews views = new RemoteViews(context.getPackageName(), R.layout.sexy_clock_widget); // Postavi trenutno vrijeme na TextView SimpleDateFormat sdf = new SimpleDateFormat(TIME_FORMAT); String currentTime = sdf.format(new Date()); // Set custom font for TextView Typeface font = Typeface.createFromAsset(context.getAssets(), "font/pixel.ttf"); Paint paint = new Paint(); paint.setTypeface(font); paint.setStyle(Paint.Style.FILL); paint.setColor(ContextCompat.getColor(context, R.color.purple_200)); paint.setTextSize(context.getResources().getDimension(R.dimen.text_size)); // Draw text on bitmap and set it to ImageView Bitmap myBitmap = Bitmap.createBitmap((int) paint.measureText(currentTime), (int) paint.getTextSize(), Bitmap.Config.ARGB_8888); Canvas myCanvas = new Canvas(myBitmap); myCanvas.drawText(currentTime, 0, (int) paint.getTextSize(), paint); views.setImageViewBitmap(R.id.textView, myBitmap); appWidgetManager.updateAppWidget(appWidgetId, views); } } } |
