Staro 19.12.2013., 21:15   #1
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 833
AMD Catalyst Display Driver 13.12
Izasao,ali ih ne mogu skinuti xD jer download uopce ne prikazuje koliko je preostalo,a na kraju kaze interupted i dobijem corupted file. Dobar je ovaj AMD,predvidjam im svjetlu buducnost u crnoj rupi.
FEATURE HIGHLIGHTS OF AMD CATALYST™ 13.12
  • ​Support for the following new products:
    • AMD Radeon™ R9 290, 280, and 270 Series
    • AMD Radeon™ R7 260, 250, and 240 Series
  • ​Improved AMD CrossFire™​ scaling for the following game titles:
    • Call of Duty®: Ghosts (multiplayer component)
    • Splinter Cell Blacklist
    • Saints Row 4
    • Metro Last Light
  • ​New AMD Enduro™ Technology profiles for the following game titles:
    • ​XCOM: Enemy Unknown
    • Need for Speed Rivals
    • Total War™​: Rome 2
    • Battlefield 4
    • Saints Row 4
    • FIFA 14
  • ​Support For AMD CrossFire frame pacing
    • Frame pacing ensures that frames rendered across multiple GPUs in an AMD CrossFire configuration will be displayed at an even and regular pace
    • Frame pacing is enabled through the AMD Catalyst Control Center, or on a per application basis
    • Frame pacing is supported on DirectX® 10 and DirectX 11 applications using resolutions up to (and including) 2560x1600 on a single display
RESOLVED ISSUES
  • ​​​May resolve intermittent black screens or display loss observed on some AMD Radeon™ R9 290X and AMD Radeon R9 290 graphics cards
  • Resolves intermittent crashes seen in legacy DirectX® 9 applications
  • AMD Radeon™ R9 290 Series - Power Tune update to reduce variance of fan speed / RPM
  • PCI-E bus speed is no longer set to x1 on the secondary GPU when running in an AMD CrossFire configuration
  • Resolves incorrect HDMI Audio Driver information being listed in the AMD Catalyst Control Center
  • Resolves AMD Steady Video option being grayed out in the AMD Catalyst Control Center
  • Resolves intermittent flickering seen on some AMD Radeon R9 270X graphics cards
  • Resolves graphics corruption issues found in Starcraft®​
  • Resolves image corruption seen in Autodesk Investor 2014
  • Resolves flickering water corruption found in World of Warcraft®​
  • Resolves intermittent black screen when resuming from a S3/S4 sleep-state if the display is unplugged during the sleep-state on systems supporting AMD Enduro™ Technology
  • Resolves intermittent crashes experienced with Battlefield 4 on Windows 8 based systems
  • Resolves the display turning green when using Windows Media Player to view HD .avi format video in an extended desktop configuration
  • Resolves Metro applications experiencing frame drops during playback of interlaced video content
  • Resolves video playback corruption of .wmv format files in Windows Media Player
Update.
Prvi bug registriran je da ovaj drajver ne updejta verziju drajvera u registriju.Znaci ako ste prije koristili recimo beta 13.9,nakon instalacije ovog i dalje ce vam pisati verzija 13.9 iako je 13.12
Zadnje izmijenjeno od: Romano.Cule. 19.12.2013. u 21:52.
Staro 19.12.2013., 23:16   #2
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Staro 20.12.2013., 00:10   #3
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Ja sam bez problema skinuo obe verzije sa sluzbene stranice i obe su se otpakirale bez problema.
AMD Radeon™ Desktop Video Card Drivers
Catalyst 13.12 WHQL 64-bit
Catalyst 13.12 WHQL 32-bit
Staro 20.12.2013., 01:14   #4
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,071
To je u biti prepakirana verzija 13.11 beta 9.5.
Meni na 7950 to ne radi kako treba na Win8.1 (idem nešto odigrati i svakih 5 sekundi driveri se ruše uz "recovered" poruku) pa sam uz čišćenje drivera uspješno vratio se na betu 9.4 koja radi bez greške pošto sam sa 9.5 imao isti problem.
Staro 20.12.2013., 10:07   #5
mrva_zg
mrva_zg's Avatar
Datum registracije: Feb 2010
Postovi: 938
Meni bez greške radi na istoj VGA-i i OS-u
Staro 20.12.2013., 11:55   #6
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,071
Ovisi u čemu, meni je problem Planetside 2.
Staro 20.12.2013., 14:20   #7
mrva_zg
mrva_zg's Avatar
Postovi: 938
Onda moraš kupit BF i driveri će ti bit najmanji problem
Staro 21.12.2013., 14:01   #8
Goranbm
Goranbm's Avatar
Postovi: 1,238
Autor Bluzer Pregled postova
Ja imam 9.5 na 6850 na win 8.1 i nemam nikakvih problema sa driverima. Jel to onda ovisi o grafi da li su stabilni ili ne, ili samo random ?
Goranbm je offline   Reply With Quote
Staro 25.12.2013., 15:14   #9
ExtremePower
ExtremePower's Avatar
Datum registracije: Aug 2008
Lokacija: Moj dom Krapina
Postovi: 246
Instalirao nove drivere.
Potvrđujem da nemam nikakvih problema na svojoj HD 5870.
ExtremePower je offline   Reply With Quote
Staro 26.12.2013., 09:37   #10
Prki
Prki's Avatar
Postovi: 1,315
Na 6870, na COD-u izgubio nekih 20fps-a i dobio 2celziusa, pa morao vratiti 13.10.
Staro 26.12.2013., 16:41   #11
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,025
Ja se idem malo igrati i probat ću portati drivere za svoju HD4850, for the lulz
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 27.12.2013., 19:00   #12
RaZ0R911
RaZ0R911's Avatar
Datum registracije: Jun 2011
Lokacija: Šemovci
Postovi: 84
Katastrofa verzija drivera.
Na stocku radi dobro uz gubitak fps-a u odnosu na prošlu betu.
a ako dignem gpu core ili mem za 1mhz ruše se driveri.
Pošteni trgovac:
1 2 3
RaZ0R911 je offline   Reply With Quote
Staro 06.01.2014., 13:55   #13
Brain32
Brain32's Avatar
Postovi: 498
Na 6670(DDR5 verzija) niti jedan driver nakon 13.1. ne valja golog k****...
Brain32 je offline   Reply With Quote
Staro 09.01.2014., 17:22   #14
2 die 4
2 die 4's Avatar
Postovi: 2,238
Ja sam se sa 5870 vratio skroz na 11.7 jer mi ostali samo smanjuju FPS-ove!
RedGreenBlue
