Staro 17.04.2005., 16:02   #1
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Ati Tray Tools 1.0.2.600
http://www.radeon2.ru/atitray/
Novo:
* Improved 3D detection.
* Now ATT will not try to monitor application which was started from Windows folder.
* Fixed error in "DCC Configuration" window when "Override Display Limits" options becomes grayed if monitor doesn't support DDC.
* Fixed bug with display rotation assigned to hot keys.
+ Added support for Smart Shaders effects. A few custom shaders included in installation package. Look in "Smart Shaders" folder.
* Upgraded "Game Profiles" module. Now you can set individual 3D setting for game.
+ Added "Edit" button near 3D profiles selection to easy change settings in 3D profile without closing "Game Profiles" window.
+ Added "Play" button in "Auto 2d/3d" module for fast playing selected .wav file.
+ Added option to select type of font to draw FPS value
* Standard - fastest font
* Digits - fast font
+ Added support for Direct3D 8/Direct3D 9 games in OSD Module (FPS and FlashOSD).
+ Added new Flash OSD fields.
"Free Texture Memory (D3D)". - This field will show free Texture Memory. Texture memory is calculated as sum of on board video memory plus AGP Memory.
"Show 3D API Type" - This field will show used 3D API in game. (OGL/D3D8/D3D9)
"System Memory Used by process" - Show how much system memory currently used by application.
All fields in FlashOSD updated one time per second but be careful it can sometimes slow down a bit your game if you select "Show all times" mode. Because in this mode, your video board will make additional job to render all characters in FlashOSD strings every frame.
* Changed behavior of FPS meter. Now it can be hidden.
+ Added new hot key "Hide/Show FPS meter".
* Fixed some bugs in ATT Shared Memory interface module.
+ Added option to disable Aggressive 3D detection code for compatible issues.
* Updated "Monitoring Graphs". Added support for minus temperatures. * Added 2 new monitoring sources:
1. Free Video (onboard) Memory
2. Free Texture Memory (onboard memory + AGP Memory)
* Now monitor will display values at left side of line when you point your mouse over history line.
+ Added support for new X850 models
* Upgraded color correction module to support two displays. Now you can save separate color profiles for each display. Now hot keys will apply color correction only for selected display. You can change active display for color correction from Color menu or by pressing hotkey. After loading color profile, you active display for color correction also will be changed.
+ Added hot key to switch active display for color correction.
* All items from Tweak Menu moved into one Dialog Box "Standard Tweaks". TemporalAA, CatalystAI removed from menu and can be access from either Direct3D settings or OpenGL settings dialog boxes.
1.0.1.538 (March 16, 2005)
+ Updated plug-ins API. Included support for reading temperature values.
+ Improved 3D detection for Direct3D applications.
+ Updated auto 2d/3d Overclocking for OGL subsystem. Be informed the ATT incompatible with FRAPS 2.0 (for OpenGL only) and it will not be able to detect OGL games, autoverclock for OGL games, show OSD (fps) and flash information!
+ Added new module "OnScreen Display" with ability to show FPS and OSD Flash with information about current GPU/Memory speeds, temperatures and FAN Speed. OSD Flash has 3 modes to show information:
1. Auto flash every x minutes for xx seconds
2. Show all times.
3. Manual. (by hot key)
Be informed! If you select mode number 2, you must activate "Hardware Monitoring" to allow OSD Flash module show correct values for speed and temperatures!
At this moment module supports only OpenGL games and applications.
+ Added two global hot keys to change OSD Screen Corner and manually flash OSD information.
+ Added Overlay adjustment for secondary device (TV or Monitor)
+ Added Video Mode option in TV Properties. You can enable this option if your resolution is not bigger than 640x480. But if you enable TV as Clone of primary display (at any resolution), set Theater mode to "Theater" and start playing Video Files then you can activate Video Mode regardless of your video resolution. Or you can create profile with "Video Mode" activated, load it at any time and when you start to play video files, the "Video Mode" will be activated automatically.
+ Auto 2D/3D Overclocking options have been moved from "Overclocking" module to new "Automatic 2D/3D Overclocking" module.
+ Upgraded "Monitoring Graphs" module. Now each monitor can contain any monitoring sources. You can specify different colors for each monitor source. Updated "Export to TXT" and "Export to CSV" options to include all active sources in selected monitor.
+ Updated information database. Included device ID for FireGL series
+ Added support for FireGL X3-256, FireGL V5x00.
+ Updated "Use DDC" option. Now ATT will not reapply video settings if you change "Use DDC" option only.
Zadnje izmijenjeno od: stef. 17.04.2005. u 16:17.
Staro 20.04.2005., 15:41   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Puno bolji od zadnje verzije koja se je znala zblokati na NF3/4 i A64 platformama
Staro 20.04.2005., 16:01   #3
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Istina. Meni "Auto 2D/3D overclocking" više ne javlja greške kod WCRFT III, PowerDVD-a, RAdlighta ...
Staro 27.04.2005., 01:36   #4
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,419
Izašla nova verzija, 1.0.2.625
Versions history
1.0.2.625 (April 25, 2005)
+ Added support for PAL-M TV Format
* Now ATT can detect started application and apply apropriate settings even if this application is in exception list.
+ Added missed Smart Shader effects
* Fixed bug with restoring previouse OpenGL settings in "Game Profiles"
+ Added new monitoring source "FPS Counter".
- Removed "Free Texture Memory (D3D only)" field from FLashOSD
+ Added "Free Video Memory" and "Free Texture Memory" to FlashOSD module. Will work with any 3D API.
+ Added support for Custom Smart Shader effects in Control Center mode.
* Improved support for Catalyst Control Center.
+ Added "Force Triple Buffer (D3D)" in Game profiles. This option is application depended and can not be enabled as system wide option. To be able to use Direct3D Force Tweaks you must keep enabled "Aggressive 3D Detection" option.
* Impoved Auto 2d/3d and OSD Modules.
+ Added option to select custom Smart Shader files from list of files in "Smart Shaders" folder.
* Fixed wrong detection of some Radeon 9100 boards
* Minor changes in 3D Rendering window to speed up rendering procedure up to 10%.
http://www.radeon2.ru/atitray/attsetup.exe
