Postovi: 166
Catalyst 9.11 (Beta)
Ako netko hoće probati Catalyst 9.11 Beta: http://download2-developer.amd.com/a...vista-win7.zip 9.11 beta = 08/10/09 version 8.67 |
otišo po cigare i nesto
Lokacija: Zagreb (Maksimir)
Postovi: 373
Pa kaj nije 9.10 na redu, kaj budu preskoćili 9.10 ili? |
Postovi: 553
Ne budu, ali 9.10 beta su loši otprilike koliko i 9.9, tako da su se odmah bacili na 9.11 očito ![]() Betu neću ni probavat, final ću vidit, al čini mi se da ću ostat na 9.8 kak je krenulo, najbolji za sada. Sa 9.9 vidim samo neznatan pomak nabolje u Shiftu, ali je zato u svim drugim igrama koma, pogotovo red faction koji je praktički neigriv, sa 9.10 betom također. |
Postovi: 373
A jel ga ko probo i ima li šta zanimljivo za priopćit o njima? |
Postovi: 2,582
kako sam malo istrazivao po netu dosao sam do ovoga ATI finally launches OpenCL driver In Beta SDK After months of promises, ATI just launched the “first complete OpenCL™ development platform” but again in beta version. This driver is the part of ATI Stream SDK V2.0 that is, as we said, in its Beta stage. This release is fully compatible with OpenCL 1.10 specification and supports AMD GPUs as well as X86 multi core CPUs that are supporting SSE3 or higher. Now the developer of AMD supported open source Bullet Physics can start developing it on ATI drivers instead on Nvidia drivers. Let’s hope that ATI can catch up with Nvidia which is highly unlikely, as Nvidia started investing a lot of time and engineering, not to mention money, in GPU computing some three years ago. All Radeon 4x00 and 5x00 series are supported as well as some FirePRO and FireStream card, including some 4x00 series mobile Radeons. The downside is that you need to use some beta drivers as this SDK won't work on your currently installed Catalyst. www.clunk.org.uk na jednom forumu su napisali da ce ovo ici sa ovim driverima ako sam ih dobro skuzio... |
Postovi: 68
isprobao driver...osjetno poboljšanje fps-a! Isprobati! |
Bazinga
Lokacija: Križevci
Postovi: 3,928
Postovi: 68
cod5 MP..uglavnom to igram |
Lokacija: Ne znam
Postovi: 65
odlični driveri!!!! nfs shift i dalje ima problema ali ostale igre su se dosta popravile sve mi nekako fulidnije ide.. |
Postovi: 68
sa kojom to grafom!? Leadtek 8800gt? |
Lokacija: Ne znam
Postovi: 65
zaboravio sam promijenit 4870 1gb |
Postovi: 553
Ne znam je li to do "sedmice" ili do ovih drivera, al sve igre mi rade brže i uglađenije. Doduše, prije bih rekao da je do winsa. Ali u svakom slučaju, driveri su više nego solidni, sve stabilno i glatko, prvi pošteni driveri poslje 9.8 (u mom slučaju barem). ![]() |
#16 |
Lokacija: Ne znam
Postovi: 65
ja imam poboljsanja u odnosu na 9.9 u cod4 sam imao najmanje 30 fpsa sad je najmanje 45 a cod 5 mi ide do 30 fps-a neznam zasto tako nisko da li je to svima tako ili samo meni ali opet je bolje nego na 9.9 pes 2010 radi savrseno kao i h.a.w.x. o nfs shiftu necu puno pricat jer je ostalo kao i prije u prijevodu jadno |
#18 | |
Postovi: 553
![]() Izgleda da stvarno treba pogodit kombinaciju gfx postavki, drivera, os-a i tome slično. Meni se recimo igra ruši ako ugasim vsync a ostavim AA upaljen, i obrnuto. ![]() Igram na 1440x900, 2AA, Vsync ON, 16xAF, shadows na medium, ostalo na high. FPS ne ide ispod 28, to je najmanje što sam uspio primjetit, a u pravilu je oko 40-45, što mi se čini više nego dobro obzirom na konfu i postavke. Shebano baš, jer vidim da i ekipa sa 48xx/58xx grafama ima gadnih problema, koje su više nego sposobne zavrit to kak spada. Bit će to garant riješeno nekakvim patchom/budućim driverom. ![]() Zadnje izmijenjeno od: Atrax. 12.11.2009. u 00:50. |
#19 |
Lokacija: Ne znam
Postovi: 65
pa normalno da cemo trubit nitko nije dao pare za original igricu bezveze..nisam ju kupio da igram za godinu dana nego da ju igram sad..3 mjeseca im nije dovoljno da to poprave onda neka se ostave tog posla i jedni i drugi i neka zaposle druge ljude koji ce znat kako treba drivere napravit odnosno igricu naravno da je nvidia imala svoje prste u ovom ali umjesto da ratuju međusobno neka puste nas koji igramo i od cijih novaca oni zive da igramo kako treba a za rat neka nađu neku drugu zanimaciju... |
#21 |
Lokacija: vpz
Postovi: 72
Cini se i meni da su ovo odlicni driveri, dobio sam na GTAIV oko 3-5 fps-a u nekim djelovima grada cak i vise, a za druge igrice neznam nisam jos probavo, uglavnom preporucam da probate i sami se uvjerite ![]() |
#22 |
Postovi: 29
Znaci bolji u odnosu na 9.8 na 7 x64? |
