Staro 09.09.2004., 16:05   #1
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,717
amd xp power
This patch will allow nForce2 chipset based motherboards to use C1/C2/C3 advanced cooling mode instead of the basic S1 and reduce idle temperatures by 5-10c degrees! supports only Windows XP/2000!
http://www.newgenerationorder.org/index.html
Prije sam u idlu imao 41C a sada 32C?
Voltages: (Core 0: 1.632V, Core 1: 1.568V, +3.3: 2.624V, +5.00: 5.08V, +12.00: 12.038V, -12.00: -7.091V, -5.00: -1.296V)
CPU Info: (1 CPU - AMD K7 processor (Barton), 2.41 GHz, L1: 64KB L2: 512KB (0% Load))
Temperature: (Case: 28°C, CPU: 32°C, Fan 1: 2083RPM, Fan 3: 2191RPM)
Neko ima ideju na kojem ovo principu radi?
Bono je online   Reply With Quote
