Staro 09.03.2008., 22:51   #31
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Autor elvis again Pregled postova
207 nema ovog crveno zaokruzenog plusica (threshold settings) i zato nisam mogel namjestat automatsku regulaciju venta
http://www.guru3d.com/admin/imageview.php?image=10671
dal postoji na 207 neki drugi nacin za to naparviti?
Ja sam se zbog toga vratio na 2.06, koliko znam ta je opcija jednostavno izbacena.
Staro 10.03.2008., 08:46   #32
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Fala na odgovoru, ja se bum isto vratilna stariju verziju. V206 mi zbog toga vise odgovara.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 10.03.2008., 18:18   #33
alengrosevic
alengrosevic's Avatar
Postovi: 3,775
Riva Tuner 2.08
izašla je nova verzija popularnog programa
http://downloads.guru3d.com/RivaTune...nload-163.html
bacite pogled na datum izdavanja, 11.3 back to the future...
Version 2.08:
Minor bugfixes:
RivaTuner no longer crashes when RivaTuner module activation launcher item is scheduled to run at Windows startup.
Fixed association between low-level refresh overrider rules and target display adapter, broken due to low-level profiles association related changes in the previous version.
Minor UI and localization fixes.
What's new:
Updated databases for Detonator and ForceWare drivers. Added database for ForceWare 169.44.
Added Catalyst 8.3 drivers detection.
Updated Catalyst 8.3 certified SoftR9x00 patch script (for Windows 2000/XP drivers only).
Updated PCI DeviceID database for ATI graphics processors. Added PCI DeviceID for RADEON HD 3850 AGP.
Improved G94 graphics processors support. Thanks to Jurgen in 't Zandt @ Point of View for providing NVIDIA GeForce 9600GT sample for testing. The list of G94 related improvements includes:
Added low-level fan control support for integrated PWM controllers of G94 graphics processors.
Improved driver-level fan control support for integrated PWM controllers of G94 graphics processors. Now RivaTuner can be used for switching between driver-level automatic and driver-level direct fan control modes on GeForce 9600GT series.
Improved RV6xx graphics processors family support. With this version RivaTuner continues tradition of providing workarounds for bugs existing in fan controller calibration routines of many reference AMD HD 38x0 BIOS images. The list of new workarounds and enhancements includes:
Extended list of tweakable automatic fan speed control rule parameters for RV6xx fan controllers. Now besides editing previously available thermal lookup and temperature transfer formula parameters RivaTuner also allows editing parameters of RV6xx fan controller's acoustic management system. Acoustic management related parameters include PWM hysteresis and PWM ramp settings, which are also improperly calibrated in certain AMD HD 38x0 BIOS images.
Now RivaTuner forcibly resets fan controller's PWM hysteresis settings when adjusting fan speed in fixed mode. This enhancement provides fine fan speed adjustment in fixed fan speed mode instead of stepwise fan speed adjustment mode on the systems affected by erroneously programmed PWM hysteresis.
Changed representation format for temperature transfer function's T slope parameter. Now the parameter is displayed and edited in percents instead of PWM ticks to simplify transfer formula readability.
Minor UI changes and improvements.
EDIT: koliko sam zasad vidio onaj guide za fan profile vise ne radi ili je promijenjen nacim aktiviranja pojedinih fan profila. ako netko skuzi nek javi kako je uspio...
Zadnje izmijenjeno od: alengrosevic. 10.03.2008. u 18:34. Razlog: dodatak...
alengrosevic je online   Reply With Quote
Staro 10.03.2008., 18:24   #34
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
svako tjedan dana nova verzija...
Staro 10.03.2008., 19:07   #35
elvis again
In the ghetto
Postovi: 1,943
Evo pocela me nesto zezati riva verzija 206 pa sam zato potrazil vec ovu davno otvorenu temu.
Kao sto vidite u slikicam rivi se brkaju brzine vrtnje venta:
I to mi se prvi put pocelo događat neki dan bez ikakve veze, niti sam mjenjal drivere niti ista drugo. Mozda je neka opce poznata glupost koju sam previdio ali vas svejedno molim da mi pomognete rijesiti zagonetku.
Ja sam sve to lijepo po uputama sa guru3d stranice poslozio da mi se brzina venta postepeno dize za razlicite temperature. Samo sada kad odem na Launcher i kad stisnem vent na 29% on mi se vrti puno vise nego kaj bi trebal i isti je problem i u obrutoj situaciji.
EDIT:
Problem rijesen! Malo sam oglupavel pa nemojte se dat smetati. U ovome je bila stvar:
Naravno ja sam mislil da znam to naparviti i bez previse gledanja u salabahter sa guru 3d stranice. Ugl. ovako kako je prikazano na slici normalno, a meni je bilo poslozeno u suprotnom smjeru tj. od vecih okretaja prema nizim - samo sam preslozil i gotovo. Ovo je cito da da ne ponavljate moje greske.
Zadnje izmijenjeno od: elvis again. 11.03.2008. u 09:32.
Staro 10.03.2008., 19:15   #36
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
pa jucer sam skino v207 lol
Tekla je offline   Reply With Quote
Staro 10.03.2008., 20:08   #37
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
kao što tekla kaže, jučer sam skino v2.07 ali još bolje samo neka izlaze nove verzije jer vidim sve više i više bugova popravljaju i sad prepoznaje catalyste 8.3
Z-man je offline   Reply With Quote
Staro 10.03.2008., 20:14   #38
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
I nakon ovih sam se vratio na 2.06. Prvo sam probao 2.07 pa onda ove. Nijedna verzija ne omogucuje regulaciju venta na 3850.
Staro 10.03.2008., 21:22   #39
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
Autor SRV Pregled postova
206 je najbolji ali samo sto meni nepodrzava drivere pa onda maoram na ttaj novi. dok sam imo 6600GT 206 je bio zakon.
Staro 10.03.2008., 22:31   #40
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
jos uvijek nema test... i to je jedino sto mi fali.
Spoiler alert!
Staro 10.03.2008., 22:31   #41
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
e da i to sto kazes.
Staro 10.03.2008., 22:36   #42
Razer
Razer's Avatar
Postovi: 11,642
Što će ti taj ''Test''?
Ja sam to isključivao i kad je bilo...
Staro 10.03.2008., 23:45   #43
windfucker
Slažem se sa Razerom,poprilično neprecizan&iritirajući dio RT-a(a kao takav posljedično gotovo beskoristan).Ionako je radio po principu toplo-hladno,i koja korist onda od toga?
Više nedostaje ovo što SRV spominje...
Staro 11.03.2008., 08:19   #44
mskvorc1
mskvorc1's Avatar
Postovi: 288
Meni se 2.08 verzija glupira. Išao sam je instalirati na svježe stavljene Windowse, pa mi kaže da RivaTuner is already running in background i ne želi ga instalirati... verzija 2.06 sa onim cfg fajlom koji mi detektria grafičku je radila savršeno. I overclock i regulacija venta, sve...
mskvorc1 je offline   Reply With Quote
Staro 11.03.2008., 08:31   #45
elvis again
In the ghetto
Postovi: 1,943
Pa jesi prvo maknul staru verziju 2.06?
Staro 11.03.2008., 08:37   #46
mskvorc1
mskvorc1's Avatar
Postovi: 288
Napisao sam, na friško instalirane Windowse. Stavljao sam novi disk, pa sam instalirao Windowse, pa išao probati novi RivaTuner, ali ništa, neće se instalirati.
Staro 11.03.2008., 08:39   #47
elvis again
In the ghetto
Postovi: 1,943
A nis vrati se na 206 kao sto ce i vecina uciniti, bar ja jesam :-)
Staro 11.03.2008., 08:41   #48
mskvorc1
mskvorc1's Avatar
Postovi: 288
Da tako se i meni činiJoš da nisam slučajno izbrisao onaj cfg fajl preko kojeg RivaTuner podržava novi 8800 GTS bili bi savršeno...
Staro 13.03.2008., 18:54   #49
Independent
Independent's Avatar
Postovi: 202
Evo ja sam preko njega iso clockat grafu (7600gt) sa core 560 i memory 700 na 600/800. No kad restartam komp i pokrenem onaj load monitor on meni kaze da je grafa OC sa 800 memory a umjesto clock 600 na 576...sta da radim da je dignem na 600? je stavljen mozda neki limit ili? plz ko zna nek odg
Independent je offline   Reply With Quote
Staro 13.03.2008., 18:59   #50
Razer
Razer's Avatar
Postovi: 11,642
Druga tema na kojoj upadaš sa pričom o svojoj 7600GT
Pročitaj si stare teme o dotičnoj kartici, barem njih ima gro...
Staro 13.03.2008., 22:00   #51
Independent
Postovi: 202
Ne upadam nego mi nije jasno zas riva tuner nece jace clockat jer sam cuo da ima limit pa me zanima...a to spada pod ovu temu.
Staro 13.03.2008., 22:03   #52
Razer
Razer's Avatar
Postovi: 11,642
Upadaš
Zašto neće clockati više? Nije ti palo napamet da kartica jednostavno ne ide više
(bilo to zbog premalo ''soka'' bilo zbog lošeg hlađenja)?
Staro 13.03.2008., 22:29   #53
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,853
Autor Razer Pregled postova
za nabrzaka gledanje do kolko okvirno ide gpu... na 7800gs+ mi je to radilo skoro savrseno.
Spoiler alert!
Staro 13.03.2008., 22:30   #54
Razer
Razer's Avatar
Postovi: 11,642
Okvirno više manje znam i sam koliko ide.
A tu je i Artifact Test u AT-u...
Staro 16.04.2008., 09:31   #55
mskvorc1
mskvorc1's Avatar
Postovi: 288
Vezano uz RivaTuner 2.08 i neke njegove nedostatke, vezano uz podešavanje vrtnje ventilatora. što se tiče verzije 2.06 sa 174.74 Beta drajverima, znao mi se tu i tamo zblesirati. Ili ne podigne vrtnju venta ili ju podigne i ostavi na 100%. Pa sam išao probati sa 2.08. Ovdje sam našao lijepi guide:
Code:
http://www.vaguesoft.com/index.php?pageid=rt207#advcontrol
I odlučio se na automatic fan control. Moram reći da sam se preporodio. Vent ne ide u radu preko 50-55% i drži mi grafu na 60-61 C. Tu imate i Excel Sheet i objašnjenje kako odrediti Duty cycle min, Duty cycle max, T min, T range, T operating, T low limit, T high limit i moram reći da je puno bolje i jednostavnije nego stvaranje svih onih fan profiles. Kada sve podesite čisto za svaki slučaj provjerite sa ATITool, da budete sigurni...
Za vlasnike novih 8800 GTS-ica
Meni je Duty cycle min 36, Duty cycle max 100, T min 46 (zbog nekakvog offseta od 8, znači to je 52-8=46), T range 10, T operating 110, kao i T high limit, T low limit 0. Zašto tako, pročitajte članak. Nakon mijenjanja postavi pod Power User za enablanje automatic fan control, ne mojte zaboraviti restartati RivaTuner, jer nećete moći mijenjati postavke automatic fan controla.
Staro 01.05.2008., 00:38   #56
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Riva Tuner 2.09
Izasla je nova verzija svima poznatog - Riva Tuner-a.
Najvise srece stize za one koji imaju CF/SLI a nikako nisu mogli kontrolirat oba venta tj od jedne i od druge kartice istovremeno. I svi koji su kukali da nemaju TEST opciju, u ovoj verziji je vracena. No to je samo najmanji detalj naspram onome sto sve donosi drugo.
Download
Minor bugfixes:
  • The server no longer erroneously swaps RGB components and no longer causes On-Screen Display to be rendered in unexpected color under Direct3D10 when non-default OSD color is being used.
What's new:
  • Added ForceWare 175.xx drivers family support.
  • Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 174.40, 174.51, 174.53, 174.60, 174.70, 174.74, 174.82, 174.85, 174.88, 174.93 and 175.12.
  • Added Catalyst 8.4 drivers detection. Please take a note that ATI continues "old good" tradition of using the same build version of different driver versions, so both Catalyst 8.3 and 8.4 will be detected as Catalyst 8.3 or newer.
  • Updated Catalyst 8.4 certified SoftR9x00 patch script (for Windows 2000/XP drivers only).
  • Updated PCI DeviceID database for AMD graphics processors. Added PCI DeviceIDs for RADEON X1650 AGP and RADEON 3850 X2.
  • Update driver files database for 64-bit NVIDIA ForceWare drivers.
  • Unlocked previously available experimental AMD RV620 graphics processors family support.
  • Added experimental NVIDIA G96 graphics processors family support.
  • Added experimental NVIDIA G100 (aka GT200) graphics processors family support.
  • Added experimental driver-level multi-GPU fan control support for Quad-SLI systems. Thanks to Jacob Freeman @ EVGA for testing driver-level fan control with2x NVIDIA 9800GX2 system.
  • Now RivaTuner is able to detect driver version and display driver files info for drivers using multiple driver files and active non-primary driver file.
  • Added experimental clock frequency stress-testing for NVAPI overclocking interfaces. Please take a note that NVAPI's own stress testing is not ideal yet and it is not available for some GPU families (e.g. G80) or may work improperly for others. Due to this reason NVAPI clock frequency stress-testing feature is disabled by default, however power users may enable it using NVAPIClockTest registry entry.
  • Added set of technologies aimed to improve RivaTuner startup and usage safety in conjunction with other hardware monitoring and diagnostics related tools:
    • Added low-level PCI controller access synchronization protocol. The protocol serves for preventing possible PCI controller access collisions when multiple tools are being started and scanning PCI buses simultaneously (e.g. detecting supported hardware during OS startup). Please take a note that to take full effect the protocol must be supported by other tools used simultaneously with RivaTuner, so please ensure that you're using this version of RivaTuner with the latest versions of other monitoring or diagnostics related software products (e.g. Everest).
    • Previously used low-level I2C synchronization protocol is now also applied to driver-level thermal monitoring function calls to prevent possible conflicts between low-level I2C transactions and internal driver-level I2C transactions.Please take a note that to take full effect the protocol must be supported by other tools used simultaneously with RivaTuner, so please ensure that you're using this version of RivaTuner with the latest versions of other monitoring or diagnostics related software products (e.g. Everest).
    • Added hardware scanning synchronization protocol, aimed to optimize startup process and reduce startup time when multiple tools are intensively scanning hardware.
    • Now startup daemon routine displays warning message in case of driver load failure (e.g. when the driver is blocked by antivirus tool).
    • Startup daemon self-deinstallation technology is disabled by default now. The daemon no longer uninstalls itself from Windows startup when it fails to apply any startup settings (e.g. due to driver load blocked by antivirus tool). If needed, the technology can be re-enabled by setting DontUninstallStartupDaemon registry entry to 0.
  • Updated bundled RivaTunerStatisticsServer v2.6.0 utility:
    • Now OSD rendering routines are compatible with WPF based applications.
    • Now the server's manifest file specifies full administrative privileges requirement. If you're using Windows Vista with UAC enabled, it is recommended to create scheduled task launching the server simultaneously with RivaTuner to minimize amount of displayed UAC evaluation dialogs.
    • Changed sever's own OSD rendering behavior, now the server doesn't display 3D API usage information in the OSD when framerate display is not requested by a client application.
    • Updated pseudo-3D applications list.
  • Updated bundled D3DOverrider v1.6.0 utility:
    • Now the D3DOverrider's manifest file specifies full administrative privileges requirement. If you're using Windows Vista with UAC enabled, it is recommended to create scheduled task launching the utility simultaneously with RivaTuner to minimize amount of displayed UAC evaluation dialogs.
  • Improved launcher module:
    • Added 'Show item in tray menu' option to regular launch item editor. By disabling this option you may prevent some regular launch items from being displayed in RivaTuner's tray menu. This option is helpful if you're intensively use scheduled tasks and define many helper launch items, required only for scheduled tasks.
    • Now you may select 'All files' as file when browsing for application associated with a launch item and this way start and non-executable file type (e.g. WAV or MIDI) registered in the OS. Please take a note that 'Restore settings after terminating application' option will not affect non-executable file types.
    • Now RivaTuner stores application specific event markers in the event history panel of hardware monitoring window, allowing you to analyze all item launch events and reasons (e.g. item launch due to pressed hotkey, due to scheduled task etc). This feature simplifies debugging complex dynamic hardware control algorithms programmed via scheduler module etc.
  • Improved scheduler module:
    • Now you may specify custom scheduled tasks names in the task editor window to improve scheduled tasks list readability.
    • Added 'Wait for application termination' option for 'Launch application' tasks, allowing you to program sequentional tasks execution if needed.
    • Now you may select 'All files' as file type when browsing for application associated with 'Launch application' task and this way start and non-executable file type (e.g. WAV or MIDI) registered in the OS. Please take a note that 'Wait for application termination' option will not affect non-executable file types.
    • Now RivaTuner stores application specific event markers in the event history panel of hardware monitoring window, allowing you to analyze all shceduled tasks events and reasons (e.g. scheduled task launch due to core temperature change from 50°C to 51°C). This feature simplifies debugging complex dynamic hardware control algorithms programmed via scheduler module etc.
  • Improved hardware monitoring module:
    • Now you may use 'Override group name' option in each data source's properties to define custom on-screen display group for it and override default OSD grouping rule if needed,
    • Now RivaTuner is able to detect PLL shutdown and swicth to bus clock on G8x and newer GPU families to provide dynamic memory clock frequency monitoring on upcoming G96 graphics processors family.
    • Now RivaTuner uses BIOS PLL information tables on G9x and newer GPU families to detect reference clock frequencies for core and memory PLLs if unknown GPU is detected. If needed, reference clocks can be redefined via [CrystalClock] section of RivaTuner.cfg file.
    • Improved SMART.dll hardware monitoring plugin. Now the plugin supports SMART temperature reading for up to 8 hard drives instead of 4 hard drives in the previous version.
  • Improved low-level diagnostic report module:
    • Now RivaTuner displays PLL table contents containing per-PLL reference clock frequencies for G8x and newer display adapter families in 'NVIDIA VGA BIOS information' diagnostic report category.
  • Unlocked undocumented SSAA and combined MSAA / SSAA antialiasing modes for G8x and newer display adapters.
  • Now you may change external I2C fan controller detection retry counter using ExternalFanControllerDetectRetry registry entry or completely disable external I2C fan controller detection by setting this registry to 0.
  • Minor UI changes and improvements.
Download
Zadnje izmijenjeno od: Bullet1. 01.05.2008. u 12:57.
Staro 27.07.2008., 20:04   #57
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,009
kako podesit ručno brzinu vrtnje venta na određenom loadu grafe?
Staro 27.07.2008., 20:14   #58
Razer
Razer's Avatar
Postovi: 11,642
To nije moguće udesiti. Moguće je samo ovisno o temperaturi. A to zapravo dođe na isto s loadom
Staro 27.07.2008., 21:46   #59
tpm4
tpm4's Avatar
Postovi: 326
tpm4 je offline   Reply With Quote
Staro 28.07.2008., 20:47   #60
kasko
kasko's Avatar
Postovi: 2,009
išao sam po tutorialu i na ovoj slici nema opcije dodavanja profilea za podešavanje brzine venta pri određenoj temperaturi ?!?
