Staro 01.03.2008., 11:05   #91
jurbAs
jurbAs's Avatar
Postovi: 2,582
@fug33 naviknut ces se na kontrole sigurno fajtovi su na pocetku teski kasnije su ti laksi... ovo sa prekidanjem heheh to ti je ucitavanje mape heheh druga stvar kasnije te toliko ne prekida ko na pocetku sa time....
Staro 01.03.2008., 11:14   #92
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,505
Jel problem nabaciti slike i recite na kojim je to postavkama!
Staro 01.03.2008., 11:15   #93
Facelessone
Facelessone's Avatar
Postovi: 4,203
upravo instaliral, uskoro ce slikice
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 01.03.2008., 11:23   #94
NortonCommander
Orthodox file manager
NortonCommander's Avatar
Postovi: 422
Jel proba tko na XP? Ima kakva vidljiva razlika između dx9 i dx10 verzije?
NortonCommander je offline   Reply With Quote
Staro 01.03.2008., 11:38   #95
jurbAs
jurbAs's Avatar
Postovi: 2,582
@north commandir imam vistu 32bit i nisam pokusavao na dx9.... ali siguran sam da ima nekih razlika.....
Staro 01.03.2008., 11:52   #96
Facelessone
Postovi: 4,203
Komp (pod stolom)
Postavke:
•Dx9
•1280*1024/60hz
•VerticalSync OFF
•Graphic Quality 3/3
•Shadows 2/3
•Post FX ON
•Multisampling 1
•Level Of Details 3/3
oko 25-35fps-a. Igrivo bez ikakvih problema.
Slike
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 01.03.2008., 12:12   #97
NortonCommander
Postovi: 422
Evo nabavija san je, slike (1680x1050, sve na max, Vsync ON, Dx9):
Staro 01.03.2008., 13:01   #98
jurbAs
jurbAs's Avatar
Postovi: 2,582
north commander probaj na visti sa DX10 cini mi se po slikama da kod mene to bolje izgleda.... sad ne znam ali tako mi se cini..... i iskljuci vsync to ti ubije performanse
Staro 01.03.2008., 13:21   #99
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor jurbAs Pregled postova
Pa daj ti par DX10 slika i navedi postavke.
danc00 je offline   Reply With Quote
Staro 01.03.2008., 14:01   #100
NortonCommander
Postovi: 422
Ma ne da mi se Vistu opet stavljat, pogotovo ne radi igre.
Staro 01.03.2008., 15:14   #101
TheEmpress
TheEmpress's Avatar
Lokacija: Sveta Nedelja
Postovi: 24
Upravo naručio za curu, sutra ujutro bi ga poštar trebao donjeti na vrata
Jedna čekam da zaigram danas.
“I think we can put our differences behind us. For science. You monster.”
TheEmpress je offline   Reply With Quote
Staro 01.03.2008., 15:46   #102
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,309
.....ja igram na visti i kad sam na otvorenom framerate dosta padne grafika opet nije toliko dobra da opravdava ovakve padove (ili je do viste?) ...uglavnom igra je spoj hitman, princa i splintera u srednjem vijeku..ono ok, ali nista posebno
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 01.03.2008., 17:18   #103
Fug33
Lokacija: OS
Postovi: 412
kako v-sync moze ubiti performanse (osim ako ne igras neku igru u 210 frejmova pa ukljucis v-sync pa imas 60 frejmova)
btw kako se u igri prave screenshotsi?
imam ati tray tool koji uopce ne prikazuje ni framerate niti mogu vadit screenshotovo iz igre
kao da nisam nista ni pokrenuo (u ostalim igrama radi bez beda)..
Fug33 je offline   Reply With Quote
Staro 01.03.2008., 17:22   #104
Facelessone
Postovi: 4,203
ovi su sa frapsom hvatani.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 01.03.2008., 18:47   #105
NortonCommander
Postovi: 422
Autor Fug33 Pregled postova
Najjednostavnija opcija (bez programa i sl.) je PrtSc, pa u Paint, pa Paste.
Staro 01.03.2008., 21:58   #106
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
evo danas ins. i trebam iti u jeruzalem i svaki put kad mi loada kao tu mapu me baci van, ponorel sam, čekal sam igru tak dugo i sad je neberem prejti... i općenito me baca van svakih pola sata... je ko došel u jeruzalem????
xGAME je offline   Reply With Quote
Staro 01.03.2008., 23:21   #107
Exe
Exe's Avatar
Postovi: 349
Autor xGAME Pregled postova
Koliko vidim na stranim forumima nemoguče je doći u Jeruzalem jer nevalja DataPC_Jerusalem.forge. Ovo je navodno bila neka pre-gold faza igre tak da ima grešaka.
Exe je offline   Reply With Quote
Staro 01.03.2008., 23:40   #108
NortonCommander
Postovi: 422
Yep, tako je svima, ne moze se ic u Jeruzalem.
Staro 01.03.2008., 23:44   #109
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor Exe Pregled postova
No super, i kaj sad??
Staro 02.03.2008., 01:07   #110
jurbAs
jurbAs's Avatar
Postovi: 2,582
mislim da cemo pricekat jos 30dana da izade prava stvar... ovo mi sve lici na neku betu....... kako god bilo da bilo....... morat cemo cekat osim ako neko ne pusti neki patch....
EDIT evo decki imam info na jednom forumu o cemu se tu radi
Youre up for a big disapointment, the release is fucked, its not a retail version and keeps crashing and at one point in the game, you cant go further.
And for those who dont beleive me, check the ini file and youll see AlphaTest=1, that means Alpha Test enable for debug mode console screen
i jos nekaj
Jerusalem map is corrupt...thats why its NUKE, this is not a retail version.
Not only the header of DataPC_Jerusalem.forge is missing the whole file seems to be completely random data. In the other .forge files you can see readabel text and some parts are only zeros, in DataPC_Jerusalem.forge there is nothing like that. So it won’t work with any crackfix etc. We need a new DataPC_Jerusalem.forge.
And probably other levels are corrupt aswell so you guys can all enjoy your 8gb DEMO
eto to je rekla osoba koja se bavi programiranjem igrica moderator je jedne stranice......
Staro 02.03.2008., 01:31   #111
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
A damn...
Ajde javite dalje ako nekaj saznate...
Matth€w je offline   Reply With Quote
Staro 02.03.2008., 03:17   #112
xPsycho
xPsycho's Avatar
Postovi: 957
dobra igra i sve to jako lijepo izgleda ali neznam nesto me odbija od nje a inace sam fan takvih igara ....mozda s vremenom mi se svidi
xPsycho je offline   Reply With Quote
Staro 02.03.2008., 07:55   #113
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,734
znači treba pričekati s kupnjom za pc
Hamm je online   Reply With Quote
Staro 02.03.2008., 10:45   #114
Fug33
Lokacija: OS
Postovi: 412
Autor NortonCommander Pregled postova
ne pali
samo dobijem screenshot windowsa a ne same igre
Staro 02.03.2008., 11:00   #115
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,042
Probaj stisnut PrtScr dok igraš. Nakon tog lupiš Alt+Tab da se prebaciš u Winse ili jednostavno ugasiš igru. Upališ Paint i lupiš Ctrl+V. Ako sad nemaš sliku igre, onda fakat ne znam kaj ti je s kompom
Staro 02.03.2008., 12:34   #116
Newmie
Postovi: 1,389
Istina... baca van kad treba učitati mapu
Staro 02.03.2008., 12:52   #117
TheEmpress
TheEmpress's Avatar
Postovi: 24
A faaaak...
Staro 02.03.2008., 13:02   #118
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Staro 02.03.2008., 13:49   #119
atha
atha's Avatar
Postovi: 9,067
I ja sam dofurao do Jeruzalema, dalje ne ide. Ali me i prije par puta samo hitilo van iz igre.
___________
Just atha
x
Staro 02.03.2008., 13:50   #120
jurbAs
jurbAs's Avatar
Postovi: 2,582
jos gore to je alpha ne beta ako je bilo tko od vas imao posla sa alphama znaju koliko su zafrknute heheheh stalno 1001 greska i to... ufff
decki nadam se da sam neke spasio od nekih radnji....
